HARTING
Han® 24 HPR
Ha-VIS
enlarged
eCon 2160-A
Ethernet Switch
IP 30
Advantages
General Description
• Flat housing format
The Ethernet Switch HARTING Ha-VIS eCon 2160-A can
be used in industrial environments and supports Ethernet
(10 Mbit/s) and Fast Ethernet (100 Mbit/s). Up to 16
Ethernet devices can be connected via the RJ45-ports.
• Robust metal housing
• Adapted for mounting onto top hat
mounting rail 35 mm according to
EN 60 715
• RoHS compliant
Identification
Part number
The Ethernet Switch supports a simple and quickly
network diagnostics with integrated LEDs at every port.
It works as unmanaged switch in the Store and Forward
switching mode and supports Auto-crossing, Auto-negotiation and Auto-polarity.
Drawing
Dimensions in mm
HARTING Ha-VIS
eCon 2160-A
Ethernet Switch with
16 ports RJ45
20 76 116 3000
All data represent the current state of development at the time of print and are therefore non-binding.
HARTING reserves the right to modify designs without prior notice.
Han® Data Sheet 0372
Technical characteristics
Features
Auto-crossing
Auto-negotiation
Auto-polarity
Store and Forward switching mode
Ethernet Interface
Number of ports
• 16x 10/100Base-TX, unmanaged
Cable types acc. to IEEE 802.3
• Shielded Twisted Pair (STP) or Unshielded Twisted Pair (UTP),
Category 5
Data rate
• 10/100Mbit/s (RJ45)
Maximum cable length
• 100 m (Twisted Pair; with cable Category 5 acc. to EN 50 173-1)
Terminating method
• RJ45 (Twisted Pair)
Diagnostics (via LED)
• Status Link - green
• Status Data transfer (Act) - green flashing
• Data transfer rate (Speed) - 100 Mbit/s: yellow / 10 Mbit/s: OFF
Topology
Line, Star or mixed
Power Supply
Power supply
24 V DC
Permissible range
12 V ... 48 V
Current consumption
100 mA (at 24 V DC)
Power supply
Terminating Power supply
3-pole pluggable contact (+24 V DC / 0 V / FE)
Design features
Material of housing
Aluminium
Dimensions (W x H x D)
119.4 x 113.5 x 27.3 mm mm (without connectors)
Degree of protection
acc. to DIN 60 529
IP 30
Environmental conditions
Operating temperature
-10 °C ... +70 °C
Storage temperature
-40 °C ... +85 °C
Relative humidity
10 % ... 95 % (non-condensing)
Approvals
cUL
(in preparation)
2013-04-25
HARTING Electric GmbH & Co. KG
Wilhelm-Harting-Straße 1 | D-32339 Espelkamp | P.O.Box 14 73 | D-32328 Espelkamp
Phone: +49 5772 47-97100 | Fax: +49 5772 47-688 | HARTING.Electric@HARTING.com | www.HARTING.com
很抱歉,暂时无法提供与“20761163000”相匹配的价格&库存,您可以联系我们找货
