20821010020
20821010020
    HARTING(浩亭)
    Conn RJ-45 PL 8 POS IDT ST Cable Mount 8 Terminal 1 Port Cat 6a
20821010020 数据手册
Product data sheet 20 82 101 0020 preLink RJ45 plug, IP20 Cat.6A L-0° preLink RJ45 plug, IP20 Cat.6A L-0° Part number 20 82 101 0020 Specification preLink RJ45 plug, IP20 Cat.6A L-0° HARTING eCatalogue https://b2b.harting.com/20821010020 Image is for illustration purposes only. Please refer to product description. Identification Category Connectors Series preLink® Series of hoods/housings RJ45 Element Connector Specification RJ45 Straight Version Termination method preLink® IDC insulation displacement termination Gender Male Shielding Shielded Number of contacts 8 Coding RJ45 Technical characteristics Transmission characteristics Cat. 6A Class EA up to 500 MHz Data rate 10 Mbit/s 100 Mbit/s 1 Gbit/s 2.5 Gbit/s 5 Gbit/s 10 Gbit/s Limiting temperature -40 ... +85 °C Relative humidity 95 % Non-condensing (operation) Mating cycles ≥750 Page 1 / 2 | Creation date 2021-10-09 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com Product data sheet 20 82 101 0020 preLink RJ45 plug, IP20 Cat.6A L-0° Technical characteristics Degree of protection acc. to IEC 60529 IP20 Cable diameter 5 ... 9 mm Material properties Material (insert) Zinc die-cast, nickel-plated Specifications and approvals Approvals DNV GL PROFINET Yes Commercial data Packaging size 1 Net weight 26.46 g Country of origin Latvia European customs tariff number 85366990 eCl@ss 27440101 Rectangular connectors (set) Page 2 / 2 | Creation date 2021-10-09 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com
20821010020 价格&库存
很抱歉,暂时无法提供与“20821010020”相匹配的价格&库存,您可以联系我们找货
  • 1+229.272371+29.66250
  • 5+203.244495+26.29510
  • 20+178.2647220+23.06330
