21 34 808 3380 010
21 34 808 3380 010
    HARTING(浩亭)
    HARTING - 21 34 808 3380 010 - Sensor Cable, M8 Plug, 90° M8 Receptacle, 3 Positions, 1 m, 3.28 ft
21 34 808 3380 010 数据手册
HARTING Selection Guide for the M8/M12 cabling range In just few steps to complete cabling solutions – with the Selection Guide With this Selection Guide you get an easy tool, which supports The profil-specific cabling solutions follow automation protocols you in designing your Smart Network Infrastructure quick, and installation guidelines most common in the industry and in reliable and suitable for your requirements. In the topic Smart application areas near to the industry. Network Infrastructure, HARTING is bundling their activities The 8-wired cabling solutions broaden the field of application and products for passive and active network infrastructure for from Fast Ethernet (100 Mbit/s) to Gigabit Ethernet and Industry-Applications. beyond e.g. 10 GB. At the same time the mentioned cables and Data network cabling divides into profil-specific solutions, connectors meet the standards for structured cabling according 4-wire and suitable up to 100 Mbit/s (Fast Ethernet) and 8-wire ISO/IEC 11 801 and according ISO/IEC 24 702 especially for solutions suitable for Gigabit Ethernet and further applications. installations in industrial buildings and similar applications. M8 cable assemblies and components M12 A-coded cable assemblies and components M12 B-coded cable assemblies and components M12 D-coded cable assemblies and components 7/8 inch cable assemblies and components Incomplete part numbers In some cases you will find incomplete part numbers in this Selection Guide. Please fill in at all positions where you find “xxx” as follows: e.g. part number is 21 34 800 0380 xxx cable lengths xxx = 001 xxx = 002 xxx = 003 … … xxx = 098 xxx = 099 xxx = 100  0.1 m  0.2 m  0.3 m … …  9.8 m  9.9 m 10.0 m cable lengths available lengths in 0.1 m steps xxx = 110 xxx = 120 xxx = 130 … … xxx = 380 xxx = 390 xxx = 400 11.0 m 12.0 m 13.0 m … … 38.0 m 39.0 m 40.0 m available lengths in 1.0 m steps HARTING Selection Guide for the M8/M12 cabling range M8 double ended cordsets M8 connectors M8 panel feed-throughs M8 cable assemblies and components M8 single ended cordsets Mating face, coding A-coding Mating face acc. to IEC 61 076-2-101 A-coding Mating face acc. to IEC 61 076-2-101 A-coding Mating face acc. to IEC 61 076-2-101 A-coding Mating face acc. to IEC 61 076-2-101 Description Part number M8 cable assembly, 3 poles, male, straight, PVC 21 34 800 0380 xxx M8 cable assembly, 3 poles, female, straight, PUR 21 34 810 0388 xxx M8 cable assembly, 3 poles, female, angled, PVC 21 34 830 0380 xxx M8 cable assembly, 3 poles, female, angled, PUR 21 34 830 0388 xxx M8 cable assembly, 4 poles, male, straight, PVC 21 34 800 0481 xxx M8 cable assembly, 4 poles, female, straight, PUR 21 34 810 0481 xxx M8 cable assembly, 4 poles, female, angled, PVC 21 34 830 0481 xxx M8 cable assembly, 4 poles, female, angled, PUR 21 34 830 0489 xxx M8 cable assembly, 3 poles, male/female, straight, PVC 21 34 808 1380 xxx M8 cable assembly, 3 poles, male/female, straight, PUR 21 34 808 1388 xxx M8 cable assembly, 3 poles, male/female, straight/angled, PVC 21 34 808 3380 xxx M8 cable assembly, 3 poles, male/female, straight/angled, PUR 21 34 808 3388 xxx M8 cable assembly, 4 poles, male/female, straight, PVC 21 34 808 1481 xxx M8 cable assembly, 4 poles, male/female, straight, PUR 21 34 808 1489 xxx HARAX ® M8-XS, 3 poles, male, straight, for 0.1 - 0.14 mm² 21 02 159 1305 HARAX ® M8-S, 3 poles, male, straight, for 0.14 - 0.34 mm² 21 02 151 1305 HARAX ® M8-S, 3 poles, female, straight, for 0.14 - 0.34 mm² 21 02 151 2305 HARAX ® M8-S, 4 poles, male, straight, for 0.14 - 0.34 mm² 21 02 151 1405 HARAX ® M8-S, 4 poles, female, straight, for 0.14 - 0.34 mm² 21 02 151 2405 M8 panel receptacle, 3 poles, female, length = 0.5 m 21 02 357 6305 M8 panel receptacle, 4 poles, female, length = 0.5 m 21 02 357 6405 M12 A-coded single ended cordsets A-coding Mating face acc. to IEC 61 076-2-101 A-coding Mating face acc. to IEC 61 076-2-101 A-coding Mating face acc. to IEC 61 076-2-101 M12 A-coded double ended cordsets M12 A-coded cable assemblies and components Mating face, coding A-coding Mating face acc. to IEC 61 076-2-101 A-coding Mating face acc. to IEC 61 076-2-101 A-coding Mating face acc. to IEC 61 076-2-101 Description Part number M12 cable assembly, A-coded, 3 poles, male, straight, PVC grey, 3 x 0.34 mm² 21 34 840 0383 xxx M12 cable assembly, A-coded, 3 poles, female, straight, PVC grey, 3 x 0.34 mm² 21 34 850 0383 xxx M12 cable assembly, A-coded, 3 poles, male, straight, PUR black 21 34 850 0390 xxx M12 cable assembly, A-coded, 3 poles, female, straight, PVC grey 21 34 870 0383 xxx M12 cable assembly, A-coded, 3 poles, female, straight, PUR black 21 34 870 0390 xxx M12 cable assembly, A-coded, 4-poles, male, straight, PVC grey 21 34 840 0484 xxx M12 cable assembly, A-coded, 4 poles, female, straight, PVC grey 21 34 850 0484 xxx M12 cable assembly, A-coded, 4 poles, female, straight, PUR black 21 34 850 0491 xxx M12 cable assembly, A-coded, 4 poles, female, angled, PVC grey 21 34 860 0484 xxx M12 cable assembly, A-coded, 4 poles, female, angled, PUR black 21 34 860 0491 xxx M12 cable assembly, A-coded, 5 poles, male, straight, PVC grey 21 34 840 0585 xxx M12 cable assembly, A-coded, 5 poles, female, straight, PVC grey 21 34 850 0585 xxx M12 cable assembly, A-coded, 5 poles, female, angled, PVC grey 21 34 870 0585 xxx M12 cable assembly, A-coded, 8 poles, male, straight, PVC grey 21 34 840 0882 xxx M12 cable assembly, A-coded, 8 poles, female, straight, PVC grey 21 34 850 0882 xxx M12 cable assembly, A-coded, 12 poles, male, straight, PVC grey 21 34 840 0079 xxx M12 cable assembly, A-coded, 12 poles, male, angled, PVC grey 21 34 860 0079 xxx M12 cable assembly, A-coded, 12 poles, female, straight, PVC grey 21 34 850 0079 xxx M12 cable assembly, A-coded, 12 poles, female, straight, PUR black 21 34 850 0078 xxx M12 cable assembly, A-coded, 12 poles, female, angled, PVC grey 21 34 870 0079 xxx M12 cable assembly, A-coded, 12 poles, female, angled, PUR black 21 34 870 0078 xxx M12 cable assembly, A-coded, 5 poles, male, straight, press and go 21 33 100 0502 xxx M12 cable assembly, A-coded, 3 poles, female, straight, PVC grey 21 34 848 5383 xxx M12 cable assembly, A-coded, 3 poles, female, straight, PUR black 21 34 848 5390 xxx M12 cable assembly, A-coded, 4 poles, female, straight, PVC grey 21 34 848 5484 xxx M12 cable assembly, A-coded, 4 poles, female, angled, PVC grey 21 34 848 7484 xxx M12 cable assembly, A-coded, 4 poles, female, straight, PUR black 21 34 848 5491 xxx M12 cable assembly, A-coded, 4 poles, female, angled, PUR black 21 34 848 7491 xxx M12 cable assembly, A-coded, 5 poles, female, straight, PVC grey 21 34 848 5585 xxx M12 cable assembly, A-coded, 8 poles, female, straight, PVC grey 21 34 848 5882 xxx M12 cable assembly, A-coded, 12 poles, male / female, straight, PVC grey 21 34 848 5079 xxx M12 cable assembly, A-coded, 12 poles, male / female, straight, PUR black 21 34 848 5078 xxx M12 cable assembly, A-coded, 12 poles, male / female, angled, PUR black 21 34 868 7078 xxx M12 cable assembly, A-coded, 5 poles, male, straight, press and go 21 33 101 0502 xxx M12 A-coded connectors A-coding Mating face acc. to IEC 61 076-2-101 M12 panel feedthroughs single ended, A-coded M12 B-coded double ended cordsets M12 B-coded connectors M12 panel feedthroughs single ended, B-coded M12 B-coded cable assemblies and components Description Part number HARAX ® M12-S, A-coded, 4 poles, male, straight, for 0.14 - 0.34 mm² 21 03 111 1405 HARAX ® M12-S, A-coded, 4 poles, male, straight, for 0.25 - 0.50 mm² 21 03 112 1405 HARAX ® M12-S, A-coded, 4 poles, female, straight, for 0.14 - 0.34 mm² 21 03 111 2405 HARAX ® M12-S, A-coded, 4 poles, female, straight, for 0.25 - 0.50 mm² 21 03 112 2405 HARAX ® M12-S, A-coded, 3 poles, male, straight, for 0.34 - 0.75 mm² (assignment 3, 4, 5) 21 03 212 1400 M12-S, A-coded, 3 poles, male, straight, for 0.34 - 0.75 mm² (assignment 1, 3, 4) 21 03 212 1306 HARAX ® A-coding Mating face acc. to IEC 61 076-2-101 M12 B-coded single ended cordsets M12 A-coded cable assemblies and components Mating face, coding B-coding Mating face acc. to IEC 61 076-2-101 B-coding Mating face acc. to IEC 61 076-2-101 B-coding Mating face acc. to IEC 61 076-2-101 HARAX ® M12-S, A-coded, 4 poles, male, straight, for 0.34 - 0.75 mm² 21 03 212 1305 HARAX ® M12-S, A-coded, 4 poles, male, straight, to 2.6 mm core diameter 21 03 212 1407 HARAX ® M12-S, A-coded, 5 poles, male, straight, for 0.34 - 0.50 mm² 21 03 272 1505 HARAX ® M12-S, A-coded, 3 poles, female, straight, for 0.34 - 0.75 mm² (assignment 3, 4, 5) 21 03 212 2400 HARAX ® M12-S, A-coded, 3 poles, female, straight, for 0.34 - 0.75 mm² (assignment 1, 3, 4) 21 03 212 2306 M12-S, A-coded, 4 poles, female, straight, for 0.34 - 0.75 mm² 21 03 212 2305 HARAX ® HARAX ® M12-S, A-coded, 4 poles, female, straight, to 2.6 mm core diameter 21 03 212 2407 HARAX ® M12-S, A-coded, 5 poles, female, straight, for 0.34 - 0.50 mm² 21 03 272 2505 M12 slim design, A-coded, 5 poles, male, straight, with crimp termination 21 03 821 1505 M12 panel receptacle, A-coded, 3 poles, female, length = 0.5 m 21 03 317 6305 M12 panel receptacle, A-coded, 4 poles, female, length = 0.5 m 21 03 317 6405 M12 panel receptacle, A-coded, 5 poles, female, length = 0.5 m 21 03 317 6505 M12 panel receptacle, A-coded, 8 poles, female, length = 0.5 m 21 03 317 6805 M12 panel receptacle, A-coded, 12 poles, female, length = 0.5 m 21 03 353 2C00 M12 cable assembly, B-coded, 4 poles, male, straight, PVC 21 34 880 0486 xxx M12 cable assembly, B-coded, 4 poles, male, angled, PVC 21 34 900 0486 xxx M12 cable assembly, B-coded, 4 poles, female, straight, PVC 21 34 890 0486 xxx M12 cable assembly, B-coded, 4 poles, female, straight, PUR 21 34 890 0487 xxx M12 cable assembly, B-coded, 4 poles, female, angled, PVC 21 34 910 0486 xxx M12 cable assembly, B-coded, 4 poles, female, angled, PUR 21 34 910 0487 xxx M12 cable assembly, B-coded, 4 poles, male/female, straight, PVC 21 34 888 9486 xxx M12 cable assembly, B-coded, 4 poles, male/female, straight, PUR 21 34 888 9487 xxx M12 cable assembly, B-coded, 4 poles, male/female, angled, PUR 21 34 909 1487 xxx HARAX ® M12-L, B-coded, 2 poles, male, straight, for 0.25 - 0.34 mm² 21 03 241 1301 HARAX ® M12-L, B-coded, 2 poles, female, straight, for 0.25 - 0.34 mm² 21 03 241 2301 M12, B-coded, 5 poles, male, straight, with crimp termination 21 03 841 1505 M12, B-coded, 5 poles, female, straight, with crimp termination 21 03 841 2505 M12 panel receptacle, B-coded, 4 poles, female, length = 0.5 m 21 03 338 6405 B-coding Mating face acc. to IEC 61 076-2-101 HARTING Selection Guide for the M8/M12 cabling range M12 D-coded double ended cordsets M12 D-coded connectors M12 panel feed-throughs single ended, D-coded M12 D-coded cable assemblies and components M12 D-coded single ended cordsets Mating face, coding D-coding Mating face acc. to IEC 61 076-2-101 D-coding Mating face acc. to IEC 61 076-2-101 Description Part number M12 cable assembly, D-coded, male, straight, PUR green 21 34 920 0477 xxx M12 cable assembly, D-coded, male, straight, PVC green 21 34 920 0405 xxx M12 cable assembly, D-coded, male, angled, PUR green 21 34 940 0477 xxx M12 cable assembly, D-coded, male, angled, PVC green 21 34 940 0405 xxx M12 cable assembly, D-coded, female, straight, PUR green 21 34 930 0477 xxx M12 cable assembly, D-coded, female, straight, PVC green 21 34 930 0405 xxx M12 cable assembly, D-coded, female, angled, PUR green 21 34 950 0477 xxx M12 cable assembly, D-coded, female, angled, PVC green 21 34 950 0405 xxx M12 cable assembly, D-coded, male, straight, PVC, press and go 21 33 090 0401 xxx M12 cable assembly, D-coded, male, straight, PUR green 21 34 929 2477 xxx M12 cable assembly, D-coded, male, straight, PVC green 21 34 929 3405 xxx M12 cable assembly, D-coded, male / female, straight, PUR green 21 34 929 3477 xxx M12 cable assembly, D-coded, male, straight, PVC green 21 34 929 2405 xxx M12 cable assembly, D-coded, male, angled, PUR green 21 34 949 4477 xxx M12 cable assembly, D-coded, male, angled, PVC green 21 34 949 4405 xxx M12 cable assembly, D-coded, male, straight, press and go 21 33 090 9401 xxx HARAX ® M12-L, D-coded, 4 poles, male, straight, for 0.14 - 0.34 mm² 21 03 281 1405 HARAX ® M12-L, D-coded, 4 poles, male, straight, for 0.34 - 0.50 mm² 21 03 282 1405 HARAX ® M12-L, D-coded, 4 poles, female, straight, for 0.14 - 0.34 mm² 21 03 281 2405 M12-L, D-coded, 4 poles, female, straight, for 0.34 - 0.50 mm² 21 03 282 2405 HARAX ® D-coding Mating face acc. to IEC 61 076-2-101 D-coding Mating face acc. to IEC 61 076-2-101 M12, D-coded, 4 poles, male, straight, with crimp termination 21 03 882 1405 M12 slim design, D-coded, 4 poles, male, straight, with crimp termination 21 03 881 1405 M12, D-coded, 4 poles, male, angled, with crimp termination 21 03 882 3405 M12, D-coded, 4 poles, female, straight, with crimp termination 21 03 882 2405 M12 preLink ® housing, D-coded 20 82 000 1210 M12 preLink ® module, D-coded, 4 poles, male 20 82 005 1214 M12 panel receptacle, D-coded, 4 poles, male, straight, for 0.14 - 0.34 mm² 21 03 381 1425 M12 panel receptacle, D-coded, 4 poles, female, straight, for 0.14 - 0.34 mm² 21 03 381 2425 M12 panel receptacle, D-coded, 4 poles, male, straight, with crimp termination 21 03 882 1425 M12 panel receptacle, D-coded, 4 poles, female, straight, with crimp termination 21 03 882 2425 M12 panel receptacle, D-coded, 4 poles, male, straight, length = 0.5 m 21 03 371 1403 M12 panel receptacle, D-coded, 4 poles, female, straight, length = 0.5 m 21 03 371 2403 M12 panel receptacle, D-coded, 4 poles, female/RJ45, angled 21 03 381 4400 M12 panel receptacle, D-coded, 4 poles, female/RJ45, straight 21 03 381 2400 M12 panel receptacle, D-coded, 4 poles, male/RJ45, straight 21 03 371 1420 M12 gender changer, D-coded, 4 poles, female/female 21 03 381 6405 7/8’’ double ended cordsets 7/8’’ connectors 7/8’’ panel feed-throughs single ended 7/8 inch cable assemblies and components 7/8’’ single ended cordsets Mating face, coding Description Part number 7/8’’ cable assembly, 2 poles + PE, female, straight, PVC grey, 3 x 1.5 mm² 21 34 970 0393 xxx 7/8’’ cable assembly, 2 poles + PE, female, straight, PUR black, 3 x 1.5 mm² 21 34 970 0394 xxx 7/8’’ cable assembly, 4 poles, female, straight, PVC grey, 4 x 1.5 mm² 21 34 970 0495 xxx 7/8’’ cable assembly, 4 poles, female, straight, PUR black, 4 x 1.5 mm² 21 34 970 0496 xxx 7/8’’ cable assembly, 4 poles, female, angled, PVC grey, 4 x 1.5mm² 21 34 990 0495 xxx 7/8’’ cable assembly, 4 poles, female, angled, PUR black, 4 x 1.5 mm² 21 34 990 0496 xxx 7/8’’ cable assembly, 4 poles + PE, female, straight, PVC grey, 5 x 1.5 mm² 21 34 970 0597 xxx 7/8’’ cable assembly, 4 poles + PE, female, straight, PUR black, 5 x 1.5 mm² 21 34 970 0598 xxx 7/8’’ cable assembly, 4 poles + PE, female, angled, PVC grey, 5 x 1.5 mm² 21 34 990 0597 xxx 7/8’’ cable assembly, 4 poles + PE, female, angled, PUR black, 5 x 1.5 mm² 21 34 990 0598 xxx 7/8’’ cable assembly, 4 poles, male/female, straight/straight, PVC grey, 4 x 1.5 mm² 21 34 969 7495 xxx 7/8’’ cable assembly, 4 poles, male/female, straight/straight, PUR black, 4 x 1.5 mm² 21 34 969 7496 xxx 7/8’’ cable assembly, 4 poles, male/female, straight/angled, PVC grey, 4 x 1.5 mm² 21 34 989 9495 xxx 7/8’’ cable assembly, 4 poles, male/female, straight/angled, PUR black, 4 x 1.5 mm² 21 34 989 9496 xxx 7/8’’ cable assembly, 4 poles + PE, male/female, straight/straight, PVC grey, 5 x 1.5 mm² 21 34 969 7597 xxx 7/8’’ cable assembly, 4 poles + PE, male/female, straight/straight, PUR black, 5 x 1.5 mm² 21 34 969 7598 xxx 7/8’’ cable assembly, 4 poles + PE, male/female, straight/angled, PVC grey 5 x 1.5 mm² 21 34 989 9597 xxx 7/8’’ cable assembly, 4 poles + PE, male/female, straight/angled, PUR black, 5 x 1.5 mm² 21 34 989 9598 xxx 7/8’’ HARAX ® male 21 04 116 1505 7/8’’ HARAX ® female 21 04 116 2505 7/8’’ panel receptacle, 3 poles, male, length = 0.2 m 21 04 316 1305 7/8’’ panel receptacle, 5 poles, male, length = 0.5 m 21 04 316 1505 7/8’’ panel receptacle, 3 poles, female, length = 0.5 m 21 04 316 2301 7/8’’ panel receptacle, 4 poles, female, length = 0.5 m 21 04 316 2401 7/8’’ panel receptacle, 5 poles, female, length = 0.5 m 21 04 316 2501 Mating face Mating face Mating face Mating face HARTING Selection Guide for the M8/M12 cabling range www.HARTING.ae www.HARTING.at www.HARTING.com.au www.HARTING.be www.HARTING.com.br www.HARTING.ca www.HARTING.ch www.HARTING.com.cn www.HARTING.cz www.HARTING.de www.HARTING.dk www.HARTING.es www.HARTING-easterneurope.com www.HARTING.fi www.HARTING.fr HARTING.com – the gateway to your country website. www.HARTING.co.uk www.HARTING.com.hk www.HARTING.hu www.HARTING.co.in www.HARTING.it www.HARTING.co.jp www.HARTING.co.kr www.HARTINGbv.nl www.HARTING.no www.HARTING.pl www.HARTING.pt www.HARTING.ro www.HARTING.ru www.HARTING.se www.HARTING.sg www.HARTING.sk www.HARTING.com.tr www.HARTING.com.tw www.HARTING-USA.com HARTING Technology Group info@HARTING.com www.HARTING.com MO/2014-0-3/.0 98 32 019 0201 Version 1 www.HARTING.co.za
21 34 808 3380 010 价格&库存
很抱歉,暂时无法提供与“21 34 808 3380 010”相匹配的价格&库存,您可以联系我们找货
  • 1+127.019151+16.46410
  • 10+108.0142310+14.00070
  • 25+101.2143025+13.11930
  • 50+96.3323050+12.48650
  • 100+91.79902100+11.89890
