231-332/001-000
231-332/001-000
    WAGO(万可电子)
    插件,P=5.08mm
    接线端子 间距:5.08mm 1x2P 直插
231-332/001-000 数据手册
Data sheet | Item number: 231-332/001-000 THT male header; 1.0 x 1.0 mm solder pin; straight; Pin spacing 5.08 mm; 2pole; orange www.wago.com/231-332_001-000 i Picture differs from the item. Color: L = (pole no. – 1) x pin spacing + 8.2 mm Item description Horizontal or vertical PCB mounting via straight or angled solder pins Pin cross-section: 1 x 1 mm With coding fingers Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 27.02.2021    Page 1/8 Data sheet | Item number: 231-332/001-000 www.wago.com/231-332_001-000 Safety information 1: The MCS – MULTI CONNECTION SYSTEM includes connectors without breaking capacity in accordance with DIN EN 61984. When used as intended, these connectors must not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Data Electrical data Ratings per IEC/EN 60664-1 Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 320 V Rated surge voltage (III/3) 4 kV Rated voltage (III/2) 320 V Rated surge voltage (III/2) 4 kV Nominal voltage (II/2) 630 V Rated surge voltage (II/2) 4 kV Rated current 12 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Ratings per UL 1059 Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 10 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Ratings per UL 1977 Rated voltage UL 1977 600 V Rated current UL 1977 10 A Ratings per CSA Approvals per CSA Rated voltage CSA (Use Group B) 300 V Rated current CSA (Use Group B) 10 A Rated voltage CSA (Use Group D) 300 V Rated current CSA (Use Group D) 10 A Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 27.02.2021    Page 2/8 Data sheet | Item number: 231-332/001-000 www.wago.com/231-332_001-000 Connection data Pole No. 2 Total number of potentials 2 Number of connection types 1 Number of levels 1 Physical data Pin spacing 5.08 mm / 0.2 inch Width 13.28 mm / 0.523 inch Height 17 mm / 0.669 inch Height from the surface 12 mm / 0.472 inch Depth 8.4 mm / 0.331 inch Solder pin length 5 mm Solder pin dimensions 1 x 1 mm Drilled hole diameter with tolerance 1.4 (+0.1) mm Plug-in connection Contact type (pluggable connector) Male connector/plug Connector (connection type) for PCB Mismating protection No Mating direction to the PCB 90 ° PCB contact PCB Contact THT Solder pin arrangement over the entire male connector (in-line) Number of solder pins per potential 1 Material data Color orange Material group I Insulation material Polyamide (PA66) Flammability class per UL94 V0 Contact material Electrolytic copper (ECu) Contact plating tin-plated Fire load 0.017 MJ Weight 0.8 g Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 27.02.2021    Page 3/8 Data sheet | Item number: 231-332/001-000 www.wago.com/231-332_001-000 Weight 0.8 g Environmental requirements Limit temperature range -60 … +100 °C Commercial data Product Group 3 (Multi Conn. System) Packaging type BOX Country of origin PL GTIN 4044918865173 Customs tariff number 85366990990 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CB DEKRA Certification B.V. IEC 61984 NL-39756 CSA DEKRA Certification B.V. C22.2 1466354 KEMA/KEUR DEKRA Certification B.V. EN 61984 2190761.01 Ship Approvals Logo Approval Additional Approval Text ABS American Bureau of Shipping - Certificate name 19HG1869876PDA UL-Approvals Logo Approval Additional Approval Text Certificate name UL UL International Germany GmbH UL 1977 E45171 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 27.02.2021    Page 4/8 Data sheet | Item number: 231-332/001-000 www.wago.com/231-332_001-000 UR Underwriters Laboratories Inc. UL 1059 E45172 Counterpart Item no.231-302/026-000 1-conductor female plug; 2.5 mm²; Pin spacing 5.08 mm; 2-pole; 2,50 mm²; orange www.wago.com/231-302 /026-000 Item no.231-2302/026-000 www.wago.com/231-2302 2-conductor female connector; with integrated end plate; 2.5 mm²; Pin spacing 5.08 mm; 2-pole; 2,50 /026-000 mm²; orange Item no.231-2302/037-000 2-conductor female connector; Locking lever; 2.5 mm²; Pin spacing 5.08 mm; 2-pole; 2,50 mm²; orange www.wago.com/231-2302 /037-000 Item no.2231-302/031-000 1-conductor female plug; push-button; clamping collar; 2.5 mm²; Pin spacing 5.08 mm; 2-pole; 2,50 mm²; orange www.wago.com/2231-302 /031-000 Item no.2231-302/026-000 1-conductor female plug; push-button; 2.5 mm²; Pin spacing 5.08 mm; 2-pole; 2,50 mm²; orange www.wago.com/2231-302 /026-000 Item no.2231-302/037-000 1-conductor female plug; push-button; Locking lever; 2.5 mm²; Pin spacing 5.08 mm; 2-pole; 2,50 mm²; orange www.wago.com/2231-302 /037-000 Item no.231-302/031-000 1-conductor female plug; clamping collar; 2.5 mm²; Pin spacing 5.08 mm; 2-pole; 2,50 mm²; orange www.wago.com/231-302 /031-000 Item no.231-302/102-000 www.wago.com/231-302 1-conductor female plug; with integrated end plate; 2.5 mm²; Pin spacing 5.08 mm; 2-pole; 2,50 mm²; /102-000 orange Item no.2231-302/102-000 1-conductor female plug; push-button; with integrated end plate; 2.5 mm²; Pin spacing 5.08 mm; 2pole; 2,50 mm²; orange www.wago.com/2231-302 /102-000 Item no.231-302/037-000 1-conductor female plug; Locking lever; 2.5 mm²; Pin spacing 5.08 mm; 2-pole; 2,50 mm²; orange www.wago.com/231-302 /037-000 Item no.232-302/026-000 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/232-302 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 27.02.2021    Page 5/8 Data sheet | Item number: 231-332/001-000 www.wago.com/231-332_001-000 Item no.232-302/026-000 1-conductor female plug; angled; 2.5 mm²; Pin spacing 5.08 mm; 2-pole; 2,50 mm²; orange www.wago.com/232-302 /026-000 Item no.232-402/026-000 1-conductor female plug; angled; 2.5 mm²; Pin spacing 5.08 mm; 2-pole; 2,50 mm²; orange www.wago.com/232-402 /026-000 Compatible products Marking accessories Item no.: 210-833 Marking strips; on reel; 6 mm wide; plain; Self-adhesive; white www.wago.com/210-833 Item no.: 210-834 Marking strips; on reel; 5 mm wide; plain; Self-adhesive; white www.wago.com/210-834 Item no.: 231-129 Coding key; snap-on type; light gray www.wago.com/231-129 Item no.: 231-500 Spacer; for formation of groups; light gray www.wago.com/231-500 Coding Downloads Documentation Additional Information Technical explanations 2019 Apr 3 pdf 2.0 MB Download URL Download EPLAN Data Portal 231-332/001-000 URL Download ZUKEN Portal 231-332/001-000 URL Download EPLAN Data Portal 231-332/001-000 URL Download CAD/CAE-Data CAD data 2D/3D Models 231-332/001-000 CAE data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 27.02.2021    Page 6/8 Data sheet | Item number: 231-332/001-000 www.wago.com/231-332_001-000 PCB Design Symbol and Footprint 231-332/001-000 URL Download URL Download CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian Environmental Product Compliance Compliance Search Environmental Product Compliance 231-332/001-000 THT male header; 1.0 x 1.0 mm solder pin; straight; Pin spacing 5.08 mm; 2-pole; orange Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 27.02.2021    Page 7/8 Data sheet | Item number: 231-332/001-000 www.wago.com/231-332_001-000 Installation Notes Coding Coding a male header – fitting coding key(s). Product family MCS MIDI Classic Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 27.02.2021    Page 8/8
231-332/001-000 价格&库存
很抱歉,暂时无法提供与“231-332/001-000”相匹配的价格&库存,您可以联系我们找货
    库存:1000
    231-332/001-000
    • 1+10.317421+1.33647
    • 10+8.7612810+1.13490
    • 100+7.44261100+0.96408
    • 500+6.64323500+0.86053
    • 1000+6.326081000+0.81945
    • 5000+5.647235000+0.73152
    • 10000+5.3779210000+0.69663
    库存:344
    231-332/001-000
    库存:168
