Ha-VIS eCon 3000 Full Gigabit Ethernet Basic PoE / PoE+
5 to 7 Ethernet ports RJ45, FOC, and PoE / PoE+
English
Unmanaged Plug and Play Ethernet switches for DIN rail assembly in
control cabinets
Commercial temp.: 0 °C ... +55 °C / Industrial
temp.: -40 °C ... +70 °C
Energy
Efficient
Ethernet
■ Energy supply of up to 4 terminal devices via PoE+ (137 watts) in
accordance with IEEE 802.3at
■ Full Gigabit Ethernet non-blocking switch architecture according to IEEE 802.3
■ Support of jumbo frames (10 kB)
■ Variants with industrial temperature range of -40 °C ... +70 °C
■ Surge protection and reverse polarity protection
■ Minimum energy consumption due to energy-efficient Ethernet
■ Optimised DIN rail bracket
Target markets
Machinery & Robotics
Wind Energy,
Solar Energy
Industrial network
infrastructures
Automation
Transportation
Shipbuilding
General description
The Ha-VIS eCon 3000 Full Gigabit family of unmanaged Ethernet switches is
equipped with up to 7 gigabit Ethernet ports and allows for cost-efficient and
quick expansion and/or reconstruction of network infrastructures with high
bandwidth requirements. In this, all variants support extra-long Ethernet frames
(jumbo frames). The switches work as power sourcing equipment (PSE) and are
capable of simultaneously providing the full PoE output of 34.2 watts on up to
four ports. The slender design of the switches enables an extremely high packing
density on the DIN rail. The selection includes various combinations of variants
with RJ45 and fibre optic cables. Automatic detection of the transmission rate
(auto-negotiation) and of the wiring of the twisted pair data cable (auto-polarity
and auto-MDI(X)) allow for simple plug and play. All variants are available with the
temperature ranges "Industrial" and "Commercial".
Technical characteristics
Switch Features
Ethernet ports 10BASE-Te / 100BASE-TX EEE / 1000BASE-TX EEE
Enclosure width
25 mm
Type of connection
RJ45
Number of ports
5, 6, 7
Auto-negotiation
Yes
Yes
Switching technology
Store and Forward
Auto-polarity
Supported standards
IEEE 802.3
Frame size
Auto-MDI(X)
10 kBytes
MAC table size
Transfer conditions
8k entries
Transfer speed
10 / 100 / 1000 Mbit/s
Transfer length
100 m (Twisted Pair, Cat 5)
Packet buffer size
1 Mbit
Non-blocking
Yes
Quality of Service
Yes
Energy-efficient Ethernet
Yes
PROFINET-compatible
Yes
EthernetIP-compatible
Yes
Ethernet ports 100BASE-SX / 100BASE-FX
Type of fibre
24 VDC
48 VDC
Surge protection
Yes
Reverse polarity proof
Yes
Starting current
3.20 A
Overcurrent protection at input
Max. power consumption @ 24 VDC
Conductor cross-section
Type of connection
Pinout
54 VDC
9 VDC ... 60 VDC
6.40 A
Output power
Input sensitivity
7.20 A
Yes (12 A)
3.84 W ... 4.56 W
0.08 mm² ... 2.5 mm² (28 AWG ... 12 AWG)
3-pole, pluggable screw type terminal block
Supply circuit (according to 60950)
SELV (circuit breaker 10 A)
HARTING Technology Group
P.O.Box 1473, D-32325 Espelkamp
Wilhelm-Harting-Straße 1, D-32325 Espelkamp, Germany
ICPN-Service@harting.com | Service hotline: +49 5772 47-9479
Fax: +49 5772 47-495 | www.HARTING.com/de/ethernet-switches
FOC
850 nm
Transfer speed
Transfer length
Single-mode (SM)
SC Duplex
Transfer conditions
Wavelength
Permissible voltage range
Multi-mode (MM)
Type of connection
Power supply
Nominal voltage
Yes
Twisted pair
1310 nm
1000 Mbit/s
0.55 km
10 km
-9,5 dBm ... -3 dBm
-9,5 dBm ... -4 dBm
≤ -17 dBm
≤ -21 dBm
SFP ports
Transfer standard
Depending on used SFP
Type of connection
Depending on used SFP, RJ45 or LC
Transfer conditions
Depending on used SFP, TP or FOC
Transfer
speed
Transfer length
Depending on used SFP, 100 or 1000 Mbit/s
Note: We reserve the right to make technical changes to the products and to the content of this
document at any time without prior notification. The HARTING Technologiegruppe does not accept any responsibility for possible errors or incompletions in this document. We reserve all the
rights to this document and the topics and illustrations contained within it. Copying, disclosure to
third parties or use of its content - even partially - is forbidden without the prior written consent
of the HARTING Technologiegruppe.
PoE
Enclosures
Number of PoE ports
4
Standard
IEEE 802.3af / IEEE 802.3at
PoE type
PSE
Supported mode
Alternative A
Power supply PSE
48 VDC
54 VDC
Maximum power consumption PSE
1380 mA
2380 mA
Maximum current (PoE / PoE+)
375 mA
638 mA
15.4 W per port
61.6 W total
34.2 W per port
136.8 W total
Maximum output power PSE
Supported cabling
See 802.3at, section 33.1.4
PoE pinout
Alternative A, MDI-X (1/2 = V-, 3/6 = V+)
Status and diagnostic displays
Power ("Pwr")
illuminated green
Supply voltage is applied
Link/Activity ("L/A") off
No link
Link/Activity ("L/A") illuminated green
Link/Activity ("L/A") flashes green
Link is active
Link is active and data is transferred
Link speed ("Spd") off
10 Mbit/s
Link speed ("Spd") illuminated yellow
100 Mbit/s
Link speed ("Spd") illuminated green
1000 Mbit/s
PoE status
off
PoE status
illuminated green
Voltage in PoE range
PoE status
illuminated blue
Voltage in PoE+ range
PoE status
illuminated red
Fault
PoE is inactive / low voltage
Ambient conditions
Commercial temperature range
-40 °C ... +70 °C
Storage temperature range
-40 °C ... +85 °C
Relative humidity (operation)
0 % ... 95 % (non-condensing)
Relative humidity (storage and
transport)
Air pressure
25 mm
142 mm x 25 mm x 107.5 mm
Weight
498 g ... 513 g
Type of installation
35 mm DIN rail acc. to EN 60 715
Material enclosures
Anodised aluminium / powder-coated
steel sheet
Protection class (with pluggable
screw type terminal block)
IP30
Protection class
III
Approvals
CE FCC CFR 47 Part 15, cUL US 508 listed, DNV, GL, ABS, NK, ABB IIT
EMC and environmental conditions
EMC interference immunity (EN 61000-6-1, 61 000-6-2 55024)
Electrostatic discharge (ESD) EN 61 000-4-2
Electromagnetic field EN 61 000-4-3
Rapid transients (burst) EN 61 000-4-4
Surge voltages EN 61 000-4-5
Conducted interference voltages EN 61 000-4-6
EMC interference emission (EN 61000-6-4, EN 55 022, FCC CFR 47 Part 15)
Mechanical stability (EN 60721-3)
IEC 60068-2-6 Vibration
IEC 60068-2-6 Resonance search
IEC 60068-2-27 Shock test
Included in delivery
■ Pluggable screw type terminal block for power supply
■ Installation instructions
0° C ... +55 °C
Industrial temperature range
Enclosure width
Dimensions H x W x D (without
block and holding bracket)
2000 m (795 hPa)
Drawings
Technical characteristics / order information
Ports / order information
RJ45
SFP
SC
Enclosure
width
Power consumption @ 24 VDC
without PoE
4
1x MM (0.55 km)
25 mm
4
1x SM (10 km)
25 mm
4
2x MM (0.55 km)
4
4
Industrial temp.: -40 °C ... +70 °C
MTBF
in million h
Switch
Part no.
Switch
Part no.
0.17 A
1.13
Ha-VIS eCon 3041GB-AD-P
24 03 404 1130
Ha-VIS eCon 3041GBT-AD-P
24 03 404 1120
0.17 A
1.13
Ha-VIS eCon 3041GB-AF-P
24 03 404 1230
Ha-VIS eCon 3041GBT-AF-P
24 03 404 1220
25 mm
0.19 A
1.11
Ha-VIS eCon 3042GB-AD-P
24 03 404 2130
Ha-VIS eCon 3042GBT-AD-P
24 03 404 2120
2x SM (10 km)
25 mm
0.19 A
1.11
Ha-VIS eCon 3042GB-AF-P
24 03 404 2230
Ha-VIS eCon 3042GBT-AF-P
24 03 404 2220
3
25 mm
0.18 A
0.70
Ha-VIS eCon 3043GB-AC-P
24 03 404 3330
Ha-VIS eCon 3043GBT-AC-P
24 03 404 3320
5
25 mm
0.16 A
1.08
Ha-VIS eCon 3050GB-A-P
24 03 405 0030
Ha-VIS eCon 3050GBT-A-P
24 03 405 0020
5
1x MM (0.55 km)
25 mm
0.19 A
1.06
Ha-VIS eCon 3051GB-AD-P
24 03 405 1130
Ha-VIS eCon 3051GBT-AD-P
24 03 405 1120
5
1x SM (10 km)
25 mm
0.19 A
1.06
Ha-VIS eCon 3051GB-AF-P
24 03 405 1230
Ha-VIS eCon 3051GBT-AF-P
24 03 405 1220
5
2
25 mm
0.19 A
0.68
Ha-VIS eCon 3052GB-AC-P
24 03 405 2330
Ha-VIS eCon 3052GBT-AC-P
24 03 405 2320
6
25 mm
0.18 A
1.01
Ha-VIS eCon 3060GB-A-P
24 03 406 0030
Ha-VIS eCon 3060GBT-A-P
24 03 406 0020
6
1
25 mm
0.19 A
0.66
Ha-VIS eCon 3061GB-AC-P
24 03 406 1330
Ha-VIS eCon 3061GBT-AC-P
24 03 406 1320
7
25 mm
0.19 A
0.63
Ha-VIS eCon 3070GB-A-P
24 03 407 0030
Ha-VIS eCon 3070GBT-A-P
24 03 407 0020
Copyright© 2014
All rights reserved
Date of issue 02.2015
ICPN Datasheet 0850/01
很抱歉,暂时无法提供与“24034070030”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+7543.991261+980.53490
- 5+7005.227895+910.50880
- 国内价格 香港价格
- 1+8137.554501+1057.68365
