27211218000
27211218000
    HARTING(浩亭)
    弯插,P=2mm
    线对板针座 2x5P 弯插 间距:2mm
27211218000 数据手册
connector system The connector system of HARTING complies with the requirements of IEC 61 076-4-107 and is a compact and robust pcb-to-cable interface with excellent data transmission properties for high-speed networking and telecommunications. General information To reach a screening attenuation of more than 50 dB up to 1 GHz, HARTING offers brackets covering each connector in conjunction with a gasket, which is compressed between the bracket and the front panel (see Fig. 3). All dimensions of the connector are in accordance with IEC 917 and IEEE P 1301 requirements, which allows for easy implementation into both metric and inch-based systems. In addition, supports hot plugging as required by modern bus systems such as CompactPCI, S-bus and VME. har-link Bracket allows data transmission up to 2 Gbit/s per pair and is therefore perfectly suited for modern transmission protocols such as Low Voltage Differential Signals (see Fig. 1). The design of the connector allows differential pairs to be placed horizontally (parallel to the pcb), thus reducing the skew at high frequencies and considering high signal integrity. Gasket Fig. 3: 4 cavities bracket and gasket Once plugged, the mated pair shows excellent mating safety. Due to the locking levers on both sides of the male connector, the connection withstands a pulling force of up to 80 N (see Fig. 2). The high temperature resistant material of the female connector body supports the safe reflow soldering process. For easy identification of female modules, six different colours are available (see Fig. 4). Fig. 1: Eye diagram of a 1280 MBit signal (512 Bits) The metal shells of the connector are a guarantee for its superior performance in the EMIpolluted environment (see Fig. 2). Fig. 4: Female modules 07 04 Fig. 2: 360° screened-can construction with locking levers In addition to single connectors, HARTING provides cable assemblies with unshielded twisted pairs or with shielded twisted pairs for high speed applications such as IEEE 1355. A crimping tool range for connectors is available. terminating the male Number of contacts 10 Approvals IEC 61 076-4-107 UL recognized: E102079 Contact pitch Connector pitch 2 mm 6 mm Working current 1.5 A at 70 OC Test voltage Ur.m.s. 750 V Contact resistance Insulation resistance ≤ 30 mΩ ≥ 10 10 Ω Temperature range -55 OC … + 125 OC female: max. + 260 OC for 60 s during reflow soldering Mating cycles 250, performance level 2 Terminations Insulation displacement (male), AWG 28/7 - 30/7, AWG 30 solid Solder pins for ø 0.6 mm min. (female) Insertion force Withdrawal force 10 N max. / module 2 N min. / module (without locking levers) Latching system Locking levers har-link Technical characteristics Materials Mouldings Contacts Shells Male connector: Polyester, UL 94-V0 Female connector: High temperature plastic material, UL 94-V0 Copper alloy Male connector: Stainless steel Female connector: Silver nickel Contact surface Contact zone Selectively gold-plated 07 05 Male connectors, straight Female connectors, angled No. of contacts Colour Part No. Male connector for insulation displacement 10 Black 27 11 161 8001 Female connector with solder pins 10 Beige (standard) 27 21 121 8000 10 10 10 10 10 Red Yellow Green Blue Black 27 21 121 8002 27 21 121 8004 27 21 121 8005 27 21 121 8006 27 21 121 8010 har-link Identification Male connector First mate - last break pin (2c) Female connector Shielding pins date code Nipple location Shielding pins 07 06 0.4 x (0.25) for pin z 0.4 x (0.3) for pins a, b, c, d, e Dimensions [mm]
27211218000 价格&库存
很抱歉,暂时无法提供与“27211218000”相匹配的价格&库存,您可以联系我们找货
  • 1+143.62764
  • 15+139.30590
  • 50+135.01540
  • 100+132.15160
  • 250+129.26696
库存:389
27211218000
  • 15+139.30590
  • 50+135.01540
  • 100+132.15160
  • 250+129.26696
库存:389
27211218000
  • 1+231.022891+29.82050
  • 10+195.0506510+25.17719
  • 25+136.6861825+17.64349
  • 50+128.8990250+16.63832
  • 100+121.56998100+15.69229
  • 300+111.49225300+14.39145
  • 500+106.45378500+13.74108
库存:1000
27211218000
  • 1+235.944751+30.45581
  • 10+199.2058810+25.71355
  • 25+139.5981725+18.01937
  • 50+131.6450950+16.99278
  • 100+124.15975100+16.02657
  • 300+113.86801300+14.69811
  • 500+108.72133500+14.03378
库存:1000
