(1.27 mm) .050" PITCH • DISCRETE WIRE ASSEMBLY/COMPONENTS
SERIES
POSITIONS
PER ROW
SFSS
–03, –04, –05,
–07, –10, –15,
–20, –25, –40, –50
= Single Row
PVC Cable
SFSST
–28
–28C
= Color
Coded Cable
(SFSS only)
Board Mates:
TFM, TFC
(–SR & –DR requires
–WT option)
SPECIFICATIONS
Insulator Material:
Black LCP
Contact Material:
BeCu
Plating:
Au over 50 µ" (1.27 µm) Ni
Current Rating:
2.9 A per pin (2 pins powered)
Operating Temp Range:
-10 °C to +80 °C (PVC)
-40 °C to +125 °C (*Teflon®)
Voltage Rating:
275 VAC (PVC)
235 VAC (*Teflon®)
Wire:
28 or 30 AWG
PIN
COLOR
1
2
3
4
5
6
7
8
9
10
ETC
BROWN
RED
ORANGE
YELLOW
GREEN
VIOLET
GRAY
WHITE
BLACK
BLUE
REPEAT
ASSEMBLED
LENGTH
–S
= Assembled
Length in Inches
(76.20 mm)
03.00" min. for
–S end option
(82.60 mm)
03.25" min. for
–D end option
–30
= Single Ended
–D
= Double Ended
–SR
= Single Ended
Retention Latch
(TFM-WT option
required for mating)
No. of Positions
x (1.27) .050
+ (0.53) .021
–DR
End 1 Notch
(Always Up)
(5.08)
.200
Assembled
Length
± (3.18)
.125
–03, –04, –05,
–07, –10, –15,
–20, –25, –40, –50
–NUS
= Notch up,
straight
(Pin 1 to Pin N)
–NDS
= Notch down,
straight
(Pin 1 to Pin 1)
*DuPont™ Teflon® is a
registered trademark of the
E.I. du Pont de Nemours
and Company or its affiliates.
End 2
notch
location
determined
by part
number
POSITIONS
PER ROW
Requires
–D or –DR
(End 1 Notch Up)
= Double Ended
Retention Latch
(TFM-WT option
–D–NUS
Notes:
Teflon® cable is intended
for crimp only. Contact
Samtec for solderable cable
applications.
SFSS OR SFSST
For wiring option information
refer to drawings on web.
View complete specifications at: samtec.com?SFSS & samtec.com?SFSST
END 2
OPTION
(11.18)
.440
–SR
ISDF
END
OPTION
–“XX.XX”
= 10 µ"
(0.25 µm)
Gold on
contact,
Gold Flash
on balance
= 30 AWG
–28C CABLE
COLOR CODING
SFSS(T)
PLATING
OPTION
–G
= 28 AWG
(Standard sizes)
= Single Row
Blue *Teflon® Cable
WIRE
GAUGE
ROW
OPTION
–S
–M
= Single
Row
= Metal
Retention
Latch
(Standard sizes)
SERIES
OPTION
CC03R
= Contact, Full Reel
(35,000 Parts per Reel)
WIRE
GAUGE
- 01 -
–2830
–GF
= 28 to 30
AWG
CC03M
= Gold flash
contact
–G
= Contact, Mini Reel
(1,000 - 5,000 Parts
per Reel)
No. of Positions
x (1.27) .050
+ (0.53) .021
PLATING
= 10 µ" (0.25 µm)
Gold on contact
(5.08)
.200
(15.37)
.605
(11.18)
.440
(3.81)
.150
(6.32)
.249
–S
–M
TOOLING
Hand Tool: CAT-HT-203-2830-12
Mini Applicator: CAT-MC-203-2830-XX-01
Clamp for mounting hand tool: CAT-HT-MNT-01
Extraction Tool: CAT-EX-169-01
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
View complete specifications at: samtec.com?ISDF, samtec.com?CC03R & samtec.com?CC03M
samtec.com/127mm-TigerEye
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-221
很抱歉,暂时无法提供与“ISDF-35-S”相匹配的价格&库存,您可以联系我们找货
