450405020524
450405020524
    WURTHELEKTRONIKIBE
450405020524 数据手册
Dimensions: [mm] Recommended Land Pattern: [mm] 1,5 2,0 ±0,1 2,0 ±0,1 2,0 ±0,3 3x 1,0 ±0,1 3 2,0 0,25 max. 3 3x 0,5 ±0,05 2,0 2x O 0,8 1 +0, 0 -0, Scale - 6:1 0,6 ±0,1 2,0 0,25 8,7 0,6 ±0,15 6,25 ±0,1 Schematic: 1,1 2,0 2 3,1 1 5,0 ±0,1 2 +0,0 -0,2 1 0,65 ±0,05 0,15 ±0,05 6,25 ±0,1 COM 1,5 ±0,2 P.C.B. MOUNTING FACE 1 3 3,0 2,0 ±0,15 2 non-shorting Type of Schematic: SPDT 2xC0,2 Scale - 6:1 CHECKED REVISION DATE (YYYY-MM-DD) GENERAL TOLERANCE MTH 001.002 2021-06-29 DIN ISO 2768-1m PROJECTION METHOD DESCRIPTION Würth Elektronik eiSos GmbH & Co. KG EMC & Inductive Solutions Max-Eyth-Str. 1 74638 Waldenburg Germany Tel. +49 (0) 79 42 945 - 0 www.we-online.com eiSos@we-online.com WS-SLSU SMT Mini Slide Switch, Same side connection ORDER CODE 450405020524 SIZE/TYPE BUSINESS UNIT STATUS PAGE 8.7 x 3.0 mm side push eiCan Valid 1/7 This electronic component has been designed and developed for usage in general electronic equipment only. This product is not authorized for use in equipment where a higher safety standard and reliability standard is especially required or where a failure of the product is reasonably expected to cause severe personal injury or death, unless the parties have executed an agreement specifically governing such use. Moreover Würth Elektronik eiSos GmbH & Co KG products are neither designed nor intended for use in areas such as military, aerospace, aviation, nuclear control, submarine, transportation (automotive control, train control, ship control), transportation signal, disaster prevention, medical, public information network etc.. Würth Elektronik eiSos GmbH & Co KG must be informed about the intent of such usage before the design-in stage. In addition, sufficient reliability evaluation checks for safety must be performed on every electronic component which is used in electrical circuits that require high safety and reliability functions or performance. Material Properties: General Information: Cover Material Stainless Steel Actuator Material Operating Temperature PA46 Actuator Flammability Rating Storage Conditions (in original packaging) UL94 HB Actuator Color Black Frame Material LCP Frame Flammability Rating -40 up to +85 °C < 40 °C ; < 75 % RH Moisture Sensitivity Level (MSL) 1 Certification: UL94 V-0 Black RoHS Approval Compliant [2011/65/EU&2015/863] Contact Material Copper Alloy REACh Approval Conform or declared [(EC)1907/2006] Contact Plating Silver Frame Color Terminal Material Copper Alloy Terminal Plating Silver Halogen Free Conform [IEC 61249-2-21] Electrical Properties: Properties Value Unit Rated Current Switching IR Test conditions 300 mA Tol. Rated Voltage Switching VR 5 V (DC) Contact Resistance Initial R 70 mΩ max. Contact Resistance After Life Test R 500 mΩ max. min. Insulation Resistance RISO 500 V (DC) 100 MΩ Withstanding Voltage 1 min 250 V (AC) Value Unit Tol. 225 g max. 10000 Steps Mechanical Properties: Properties Test conditions Operation Force Electrical Life 300mA / 5 V (DC) Switching Function On-On Connection Type Same Side Connection CHECKED REVISION DATE (YYYY-MM-DD) GENERAL TOLERANCE MTH 001.002 2021-06-29 DIN ISO 2768-1m PROJECTION METHOD DESCRIPTION Würth Elektronik eiSos GmbH & Co. KG EMC & Inductive Solutions Max-Eyth-Str. 1 74638 Waldenburg Germany Tel. +49 (0) 79 42 945 - 0 www.we-online.com eiSos@we-online.com WS-SLSU SMT Mini Slide Switch, Same side connection ORDER CODE 450405020524 SIZE/TYPE BUSINESS UNIT STATUS PAGE 8.7 x 3.0 mm side push eiCan Valid 2/7 This electronic component has been designed and developed for usage in general electronic equipment only. This product is not authorized for use in equipment where a higher safety standard and reliability standard is especially required or where a failure of the product is reasonably expected to cause severe personal injury or death, unless the parties have executed an agreement specifically governing such use. Moreover Würth Elektronik eiSos GmbH & Co KG products are neither designed nor intended for use in areas such as military, aerospace, aviation, nuclear control, submarine, transportation (automotive control, train control, ship control), transportation signal, disaster prevention, medical, public information network etc.. Würth Elektronik eiSos GmbH & Co KG must be informed about the intent of such usage before the design-in stage. In addition, sufficient reliability evaluation checks for safety must be performed on every electronic component which is used in electrical circuits that require high safety and reliability functions or performance. Packaging Specification - Tape and Reel: [mm] Packaging Specification - Reel: [mm] P0 T E1 D0 A K0 P2 W3 W A C N B E2 B0 D F W1 close to center Top Cover Tape A0 A P1 T1 W2 T2 detail B Feeding direction End Start Carrier Tape Cover Tape B Cover Tape Chip Cavity Sprocket Hole No Component min. 160mm Component No Component min. 100mm Embossment Cover Tape min. 400mm Tape Type 2a A0 (mm) typ. 7,50 B0 (mm) typ. 9,50 W (mm) +0,3/ -0,3 16,00 T (mm) ref. 0,30 T1 (mm) ref. 0,10 T2 (mm) typ. 3,45 K0 (mm) typ. 3,20 P0 (mm) ±0,1 4,00 P1 (mm) ±0,1 8,00 P2 (mm) ±0,1 2,00 D0 (mm) +0,1/ -0,0 1,50 D1 (mm) min. 1,50 E1 (mm) ±0,1 1,75 E2 (mm) min. 14,25 F (mm) ±0,1 7,50 Material Qty. (pcs.) Polystyrene 1800 165° - 180° B (mm) min. 1,50 C (mm) min. 12,80 D (mm) min. 20,20 N (mm) min. 60,00 W1 (mm) + 2,0 16,40 W2 (mm) max. 22,40 CHECKED REVISION DATE (YYYY-MM-DD) GENERAL TOLERANCE MTH 001.002 2021-06-29 DIN ISO 2768-1m W3 (mm) min. 15,90 W3 (mm) max. 19,40 Material Polystyrene PROJECTION METHOD DESCRIPTION Pull-of force Tape width A (mm) ± 2,0 330,00 16 mm 0,1 N - 1,3 N Würth Elektronik eiSos GmbH & Co. KG EMC & Inductive Solutions Max-Eyth-Str. 1 74638 Waldenburg Germany Tel. +49 (0) 79 42 945 - 0 www.we-online.com eiSos@we-online.com WS-SLSU SMT Mini Slide Switch, Same side connection ORDER CODE 450405020524 SIZE/TYPE BUSINESS UNIT STATUS PAGE 8.7 x 3.0 mm side push eiCan Valid 3/7 This electronic component has been designed and developed for usage in general electronic equipment only. This product is not authorized for use in equipment where a higher safety standard and reliability standard is especially required or where a failure of the product is reasonably expected to cause severe personal injury or death, unless the parties have executed an agreement specifically governing such use. Moreover Würth Elektronik eiSos GmbH & Co KG products are neither designed nor intended for use in areas such as military, aerospace, aviation, nuclear control, submarine, transportation (automotive control, train control, ship control), transportation signal, disaster prevention, medical, public information network etc.. Würth Elektronik eiSos GmbH & Co KG must be informed about the intent of such usage before the design-in stage. In addition, sufficient reliability evaluation checks for safety must be performed on every electronic component which is used in electrical circuits that require high safety and reliability functions or performance. Classification Reflow Profile for SMT components: Classification Reflow Soldering Profile: Profile Feature Tp tp Max. Ramp Up Rate Max. Ramp Down Rate TL Temperature Ts max tL Preheat Area Ts min TC –5°C Value Preheat Temperature Min Ts min 150 °C Preheat Temperature Max Ts max 200 °C Preheat Time ts from Ts min to Ts max ts Ramp-up Rate (TL to TP) 60 - 120 seconds 3 °C/ second max. Liquidous Temperature TL 217 °C Time tL maintained above TL tL 60 - 150 seconds Peak package body temperature Tp Tp ≤ Tc, see Table below Time within 5°C of actual peak temperature tp 20 - 30 seconds Ramp-down Rate (TP to TL) 6 °C/ second max. Time 25°C to peak temperature 8 minutes max. refer to IPC/ JEDEC J-STD-020E tS Package Classification Reflow Temperature (Tc): Volume mm³ 350-2000 Volume mm³ >2000 PB-Free Assembly | Package Thickness 260 °C < 1.6 mm 260 °C 260 °C PB-Free Assembly | Package Thickness 260 °C 1.6 mm - 2.5 mm 250 °C 245 °C PB-Free Assembly | Package Thickness 250 °C > 2.5 mm 245 °C 245 °C Properties 25 Time 25°C to Peak Time Applied cycles Volume mm³
450405020524 价格&库存
很抱歉,暂时无法提供与“450405020524”相匹配的价格&库存,您可以联系我们找货
