73101000007
73101000007
    HARTING(浩亭)
    Conn Module M/F RA
73101000007 数据手册
Han® Kits Technical Characteristics Part Number Han 16B Rear-Mount Kit Hood Housing Material IP / NEMA Temp Rating Cable Gland Cable Diameter Insert Screw Terminals Wire Strip Length Mating Cycles Flammability Side Entry Double Lever Bulkhead Die Cast Aluminum IP66 / 4, 4x, 12 -40 to +125C M32 Metal 13-20mm / 18-25mm Han 16E, 16+GND 18-14AWG 7.5mm >500 V-0 73 10 100 0007 Electrical Characteristics Rated Current Rated Voltage Rated Impulse Voltage 16amps 600V 6kV Drawings and Assembly Information Dimensions in mm Tooling and Torque Values Type Terminal Screws (M3) Fixing Screw (M3) Tool Torque (Nm) PH1 or Slotted 0.50 0.6 x 3.5 PH2 or Slotted 0.50 0.6 x 3.5 Mounting Screws (M4 recommended) - 0.8…1.0 Cable Gland (M32) SW 40 15 Kit Contents For further information, please reach out to techsupportUS@HARTING.com Male Insert 09 33 016 2601 Female insert 09 33 016 2701 Housing 09 30 016 0391 Hood 19 30 016 0527 Cable Gland 19 00 000 5095
73101000007 价格&库存
很抱歉,暂时无法提供与“73101000007”相匹配的价格&库存,您可以联系我们找货
