Data sheet | Item number: 870-501
Double-deck terminal block; Through/through terminal block; L/L; for DIN-rail
35 x 15 and 35 x 7.5; 2.5 mm²; CAGE CLAMP®; 2,50 mm²; gray
www.wago.com/870-501
Color:
Item description
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
29.12.2019 Page 1/15
Safety information 1:
Max. insulation diameter: 4.4mm
Data
Electrical data
Ratings per IEC/EN 60664-1
Rated voltage (III / 3)
500 V
Rated impulse voltage (III / 3)
6 kV
Rated current
24 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Connection data
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Connectable conductor materials
Copper
Solid conductor
0.08 … 2.5 mm² / 28 … 12 AWG
Fine-stranded conductor
0.08 … 4 mm² / 28 … 12 AWG
Strip length
6 … 7 mm / 0.24 … 0.28 inch
Total number of connection points
4
Total number of potentials
2
Number of levels
2
Type of wiring
Front-entry wiring
Geometrical Data
Width
5 mm / 0.197 inch
Height from upper-edge of DIN-35 rail
40 mm / 1.575 inch
Depth
70 mm / 2.756 inch
Mechanical data
Design
horizontal
Type of mounting
DIN-35 rail
Potential marking
L/L
Marking level
Side marking
Material
Data
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 2/15
Material Data
Color
gray
Insulating material
Polyamide 66 (PA 66)
Fire load
0.168 MJ
Weight
9.9 g
Commercial data
Product Group
16 (Rail Mounted Terminal Block with CCC)
Packaging type
BOX
Country of origin
DE
GTIN
4044918630863
Customs Tariff No.
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CCA
DEKRA Certification B.V.
EN 60947
2189801.01
CCA
EN 60947
NTR NL
7468
Approval
ABS
American Bureau of Shipping
14HG1293677PDA
BV
Bureau Veritas S.A.
EN 60947
07436/E0 BV
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001V2
Ship Approvals
Logo
Certificate
name
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 3/15
LR
Lloyds Register
EN 60947
91/20112
(E9)
UL-Approvals
Logo
Approval
cURus
UL International Germany GmbH
UL 1059
Certificate
name
20160928E45172
Compatible products
End plate
Item no.: 870-518
End and intermediate plate; 2 mm thick; gray
www.wago.com/870-518
Item no.: 870-519
End and intermediate plate; 2 mm thick; orange
www.wago.com/870-519
Carrier rail
Item no.: 210-112
www.wago.com/210-112
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm
Item no.: 210-113
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715
www.wago.com/210-113
Item no.: 210-114
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715
www.wago.com/210-114
Item no.: 210-115
www.wago.com/210-115
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm
Item no.: 210-118
Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715
Item no.: 210-196
Subject to changes.
Hansastr. 27
32423 Minden
www.wago.com/210-118
www.wago.com/210-196
29.12.2019 Page 4/15
Item no.: 210-196
Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
Item no.: 210-197
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715
www.wago.com/210-197
Item no.: 210-504
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715
www.wago.com/210-504
Item no.: 210-505
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715
www.wago.com/210-505
Item no.: 210-506
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715
www.wago.com/210-506
Item no.: 210-508
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715
www.wago.com/210-508
Item no.: 216-121
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated
www.wago.com/216-121
Item no.: 216-122
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated
www.wago.com/216-122
Item no.: 216-123
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-123
Item no.: 216-124
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated
www.wago.com/216-124
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-131
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-221
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-221
Item no.: 216-222
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-222
Item no.: 216-223
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-223
Item no.: 216-224
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-224
Item no.: 216-321
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-321
Item no.: 216-322
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-322
ferrule
Jumper
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 5/15
Jumper
Item no.: 709-110
Wire commoning chain; insulated; 4 connections; 3 x 110 mm; black
www.wago.com/709-110
Item no.: 709-111
Wire commoning chain; insulated; 3 connections; 2 x 120 mm; black
www.wago.com/709-111
Item no.: 709-112
Wire commoning chain; insulated; 3 connections; 2 x 170 mm; black
www.wago.com/709-112
Item no.: 870-402
Push-in type jumper bar; insulated; 2-way; Nominal current 18 A; light gray
www.wago.com/870-402
Item no.: 870-403
Push-in type jumper bar; insulated; 3-way; Nominal current 18 A; light gray
www.wago.com/870-403
Item no.: 870-404
Push-in type jumper bar; insulated; 4-way; Nominal current 18 A; light gray
www.wago.com/870-404
Item no.: 870-405
Push-in type jumper bar; insulated; 5-way; Nominal current 18 A; light gray
www.wago.com/870-405
Item no.: 870-405/011-000
Ready-made push-in type jumper bar; insulated; 3-way (1-3-5); Nominal current 18 A; light gray
/011-000
Item no.: 870-406
Push-in type jumper bar; insulated; 6-way; Nominal current 18 A; light gray
www.wago.com/870-406
Item no.: 870-407
Push-in type jumper bar; insulated; 7-way; Nominal current 18 A; light gray
www.wago.com/870-407
Item no.: 870-407/011-000
Ready-made push-in type jumper bar; insulated; 1-3-5-7; Nominal current 18 A; light gray
/011-000
Item no.: 870-408
Push-in type jumper bar; insulated; 8-way; Nominal current 18 A; light gray
www.wago.com/870-408
Item no.: 870-409
Push-in type jumper bar; insulated; 9-way; Nominal current 18 A; light gray
www.wago.com/870-409
Item no.: 870-409/011-000
Ready-made push-in type jumper bar; insulated; 1-3-5-7-9; Nominal current 18 A; light gray
/011-000
Item no.: 870-410
Push-in type jumper bar; insulated; 10-way; Nominal current 18 A; light gray
www.wago.com/870-410
Item no.: 870-433
Push-in type jumper bar; insulated; from 1 to 3; Nominal current 18 A; light gray
www.wago.com/870-433
Item no.: 870-434
Push-in type jumper bar; insulated; from 1 to 4; Nominal current 18 A; light gray
www.wago.com/870-434
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 6/15
Item no.: 870-435
Push-in type jumper bar; insulated; from 1 to 5; Nominal current 18 A; light gray
www.wago.com/870-435
Item no.: 870-436
Push-in type jumper bar; insulated; from 1 to 6; Nominal current 18 A; light gray
www.wago.com/870-436
Item no.: 870-437
Push-in type jumper bar; insulated; from 1 to 7; Nominal current 18 A; light gray
www.wago.com/870-437
Item no.: 870-438
Push-in type jumper bar; insulated; from 1 to 8; Nominal current 18 A; light gray
www.wago.com/870-438
Item no.: 870-439
Push-in type jumper bar; insulated; from 1 to 9; Nominal current 18 A; light gray
www.wago.com/870-439
Item no.: 870-440
Push-in type jumper bar; insulated; from 1 to 10; Nominal current 18 A; light gray
www.wago.com/870-440
Item no.: 209-106
Mounting carrier; for isolated mounting on DIN 35 rails; gray
www.wago.com/209-106
Item no.: 249-116
Screwless end stop; 6 mm wide; for DIN-rail 35 x 15 and 35 x 7.5; gray
www.wago.com/249-116
Item no.: 249-117
Screwless end stop; 10 mm wide; for DIN-rail 35 x 15 and 35 x 7.5; gray
www.wago.com/249-117
assembling
Marking accessories
Item no.: 2009-115
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-115
Item no.: 2009-115/000-002
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; yellow
/000-002
Item no.: 2009-115/000-006
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 2009-115/000-007
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 2009-115/000-012
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 2009-115/000-017
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; light green
/000-017
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 7/15
Item no.: 2009-115/000-023
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 2009-115/000-024
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Item no.: 2009-145
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-145
Item no.: 2009-145/000-002
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; yellow
/000-002
Item no.: 2009-145/000-005
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; red
/000-005
Item no.: 2009-145/000-006
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 2009-145/000-007
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 2009-145/000-012
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 2009-145/000-023
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 2009-145/000-024
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Item no.: 248-501
Miniature WSB Quick marking system; plain; Marker width 5 mm; 10 strips with 10 markers per card
www.wago.com/248-501
Item no.: 248-501/000-002
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Item no.: 248-501/000-005
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 248-501/000-006
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 8/15
Item no.: 248-501/000-007
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 248-501/000-012
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 248-501/000-017
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 248-501/000-023
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 248-501/000-024
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 709-177
Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; translucent
www.wago.com/709-177
Item no.: 709-178
Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; white
www.wago.com/709-178
Item no.: 709-196
Marking strips; for laser printer; translucent
www.wago.com/709-196
Item no.: 709-198
Marking strips; white
www.wago.com/709-198
Item no.: 793-501
WMB marking card; as card; not stretchable; plain; snap-on type; white
www.wago.com/793-501
Item no.: 793-501/000-002
WMB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Item no.: 793-501/000-005
WMB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 793-501/000-006
WMB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Item no.: 793-501/000-007
WMB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 793-501/000-012
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 9/15
WMB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 793-501/000-017
WMB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 793-501/000-023
WMB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 793-501/000-024
WMB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501
type; white
Item no.: 793-5501/000-002
/000-002
type; yellow
Item no.: 793-5501/000-005
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; red
/000-005
Item no.: 793-5501/000-006
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 793-5501/000-007
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 793-5501/000-012
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 793-5501/000-017
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; light green
/000-017
Item no.: 793-5501/000-023
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 793-5501/000-024
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
tools
Item no.: 210-657
Subject to changes.
Hansastr. 27
32423 Minden
www.wago.com/210-657
29.12.2019 Page 10/15
Item no.: 210-657
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short
Item no.: 210-658
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short
www.wago.com/210-658
Item no.: 210-720
www.wago.com/210-720
Insulation stop
Item no.: 280-470
Insulation stop; 0.08 - 0.2 mm² "s" (0.14 mm² "f-st"); 5 pieces/strip; white
www.wago.com/280-470
Item no.: 280-471
Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray
www.wago.com/280-471
Item no.: 280-472
Insulation stop; 0.75 - 1 mm²; 5 pieces/strip
www.wago.com/280-472
General accessories
Item no.: 870-182
Adaptor
www.wago.com/870-182
Item no.: 870-183
Adaptor
www.wago.com/870-183
Item no.: 870-184
Adaptor
www.wago.com/870-184
Item no.: 870-425
Tap-off module; with anti-rotation protection; modular; suitable for 870 Series terminal blocks with
jumper slots in the current bar; gray
www.wago.com/870-425
Item no.: 870-426
Tap-off module; modular; suitable for 870 Series terminal blocks with jumper slots in the current bar;
gray
www.wago.com/870-426
Item no.: 870-427
Spacer module; modular; bridging commoned terminal blocks; gray
www.wago.com/870-427
Protective Warning Marker
Item no.: 280-405
Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow
www.wago.com/280-405
Downloads
Documentation
Bid Text
870-501
May 31, 2017
doc
25.1 kB
Download
Feb 19, 2019
xml
Download
doc - Datei
870-501
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 11/15
870-501
Feb 19, 2019
xml
3.3 kB
Download
Apr 3, 2019
pdf
2.1 MB
Download
URL
Download
X81 - Datei
Additional Information
Technical explanations
CAD/CAE-Data
CAD data
2D/3D Models 870-501
CAE data
EPLAN Data Portal 870-501
Download
WSCAD Universe 870-501
Download
Installation Notes
Removing a terminal block from the
assembly.
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 12/15
CAGE CLAMP® connection
Inserting a conductor (0.08 … 4 mm² “f-st”).
Jumpered
Push jumper bars down firmly until fully
inserted. When using multipole bars, push
alternately on the right and then left side,
until installed.
Commoning with push-in type jumper bars:
Two parallel jumper slots are
accommodated in one terminal block.
Push-in type jumper bars 1 – 3 – 5 – 7 or
1 – – 4 – – 7
upon request
Testing
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 13/15
Testing with phase testing device, also
possible with single-pole voltage tester.
Testing is also possible using a pre-wired
tap-off module assembly in the very same
way as test plugs.
Cover
Protective warning markers (280‑405), with a
black high-voltage symbol
Use 50 % less rail space with double-deck
terminal blocks.
Marking
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 14/15
WMB markers in Mini-WSB marker slots
Translucent marking strip (709‑196) –
jumpers below may be visible.
Marking strip, translucent
Mini-WSB markers
In addition to the plastic marker strips, group
marker carriers are now available for the
WMB and WSB marking systems. They can
be mounted parallel to a push-in type jumper
bar via open jumper contact slot. It assists
with viewing marker slots on the side of the
terminal block. Group marker carriers are
available in 5 mm/0.197 inch, 10 mm/0.
394 inch and 15 mm/0.591 inch widths.
Notice:
Marker carriers are not suitable for ground
conductor terminal blocks and doublepotential terminal blocks as they have no
jumper contact slots.
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 15/15
很抱歉,暂时无法提供与“870-501”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+18.13690
- 10+15.34650
- 100+14.25040
