BCS-130-L-D-DE
BCS-130-L-D-DE
    SAMTEC(申泰)
    插件,P=2.54mm
    排母 间距:2.54mm 2x30P 直插
BCS-130-L-D-DE 数据手册
TIGER CLAW™ PASS-THROUGH SOCKET (2.54 mm) .100" PITCH • BCS SERIES BCS Mates: TSW, MTSW, HTSW, HMTSW, TSS, ZSS, DW, EW, ZW, HW, TSM, MTLW, PHT BCS -1 NO. PINS PER ROW 01 thru 50 SPECIFICATIONS - PLATING OPTION - –F ENTRY OPTION –S = Gold flash on contact, Matte Tin on tail - –TE = Single –D OTHER OPTION –“XXX” = Top Entry = Polarized Position (–BE not available) –DE = Double –L Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Voltage Rating: 495 VAC (-TE/-DE/-PE mated with TSM) 450 VAC (-HE mated with TSW) Operating Temp Range: -55 °C to +125 °C Insertion Depth: (4.34 mm) .171" to (7.24 mm) .285" from top, (5.64 mm) .222" plus board thickness minimum from bottom. –HE is (4.34 mm) .171" to (6.35 mm) .250" - ROW OPTION = Top Entry (For Bottom Entry specify –DE–BE) Cannot be used with plated through-holes = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –PE = Pass-through Entry (For Bottom Entry specify –PE–BE) –HE = Horizontal Entry     PROCESSING Lead–Free Solderable: Yes MATES BCS/TSW  [1RRI3RVLWLRQV CURRENT RATING (PER PIN) BCS/TSM 4.6 A 5.0 A 2 POSITIONS POWERED ALSO AVAILABLE     MOQ Required —TE Other Platings     —DE     —PE              Note: Some lengths, styles and options are non-standard, non-returnable. —HE samtec.com?BCS Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
BCS-130-L-D-DE 价格&库存
很抱歉,暂时无法提供与“BCS-130-L-D-DE”相匹配的价格&库存,您可以联系我们找货
BCS-130-L-D-DE
  • 7+77.609937+10.03885
