F-217
HMTSW–126–23–L–S–237
MTSW–117–09–G–D–383–RA
(2.54 mm) .100"
MODIFIED .025" SQ POST HEADERS
Board Mates:
SSW, SSQ, ESW,
ESQ, BCS, BSW
CES, SLW, HLE, SSM
TYPE
STRIP
Cable Mates:
IDSD, IDSS, SMSD, SMSS
Modified .025"
strips permit
custom post
heights.
(0.13)
.005
Samtec offers
the greatest
stacking
flexibility in
the industry.
The “M” stands
for Modified.
You tell us the
post height you need
and we’ll deliver it.
= (5.08 mm)
.200" Pitch
(2.54)
.100
= Hi-Temp
Modified Strip
LEAD STYLE
–2
= (2.54 mm)
.100" Pitch
HMTSW
(5.08)
.200
(0.13)
.005
SPECIFY “LEAD STYLE”
FROM CHART
(2.54) .100 x No. of Positions
(2.54)
.100
50
02
MTSW
SPECIFICATIONS
For complete specifications
see www.samtec.com?MTSW
or www.samtec.com?HMTSW
Insulator Material:
MTSW: Black Glass
Filled Polyester
HMTSW: Natural Liquid
Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
RoHS Compliant:
Yes
Lead–Free Solderable:
MTSW: No, Wave Only
HMTSW: Yes
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
FILE NO. E111594
–1
MTSW
= Modified Strip
(0.13)
.005
NO. PINS
PER ROW
PIN PITCH
Straight
Pin
Versions
(2.54)
.100
01
03
(2.54) (5.02)
.100 .198
–D
(2.54)
.100
(5.08) (7.56)
.200 .298
–T
148
150
(5.08) (7.56)
.200 .298
(7.62)
.300
01
MTSW
–Q
Right (3.02) (1.78)
.119
.070
Angle
Versions
(8.12)
.320
TAIL
(0.00).000
MIN
= (2.54 mm)
.100"
Center
Version
148
(3.09)
(1.78) .120
.070
–S
01
100
02
50
(2.54)
.100
(6.10)
.240
(1.78)
.070
01
99
03
150
(2.54)
.100
(5.08)
.200
(8.10)
.319
–D
02
thru
25
LEAD STYLE
OAL
–06
(7.62) .300
–07
(10.92) .430
–08
(13.46) .530
–09
(18.54) .730
–10
(21.08) .830
= (5.08 mm)
.200"
Center
Version
–T
(1.78)
.070
(1.78)
.070
01
148
03
150
(5.08)
.200
(8.12)
.320
(8.10)
.319
–Q
(1.78)
.070
(1.78)
.070
01
MTSW
OVERALL
LENGTH
(OAL)
(2.54)
.100
01
thru
50
HMTSW
HMTSW
–S & –D (5.56)
.219
(1.78)
= 36
.070
positions
maximum
POST
(0.00)
.000
MIN
99
150
01
03
FILE NO: 090871_0_000
Note:
These Series are
non-standard, non-returnable.
–S
100
(5.08)
.200
(7.62)
.300
(2.48)
.098
01
HMTSW
148
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
–11
(23.62) .930
–12
(26.16) 1.030
–13
(31.24) 1.230
–21
(36.32) 1.430
–22
(16.00) .630
–23
(11.30) .445
–24
(12.19) .480
–27
(33.78) 1.330
–28
(28.70) 1.130
MTSW–115–09–L–S–229-RE
MTSW–126–08–T–S–229–RA
MTSW–108–28–G–D–920
HMTSW–110–23–L–S–237
MTSW, HMTSW SERIES
ROW
OPTION
PLATING OPTION
–F
POST
HEIGHT
OTHER
OPTION
POLARIZED
OPTION
–S
= Gold flash on post, Matte Tin on tail
–“XXX”
= Single
–L
= Polarized
(Specify ‘XXX’ as
position number)
–D
= 10 µ" (0.25 µm) Gold on post,
Matte Tin on tail
= Double
(4.19)
.165"
Contact
Area
–T
–G
–RA
= Triple
Gold flash on balance
Tail
= Locking Lead
(N/A with –RE,
N/A in single row 1 or 2
positions. Available on
tails from (2.29 mm) .090"
to (10.16 mm) .400" only)
= Double Row
.200" (5.08 mm)
row space
= Matte Tin
–RE = Right-angle
–LL
–Q
–T
or
ALSO AVAILABLE
(MOQ Required)
Two leads per strip
crimped in opposite
directions on or near
centerline. See TSW
for availability.
–RA Option with –LL Option
• Other platings
Contact Samtec.
–LA = (Maximum “C” = (13.46 mm) .530)
–“XXXX”= “C” Dimension (Specify post height in INCHES – .005" (0.13 mm) increments)
FOR A = (2,29) .090
LEAD
STYLE
OAL
–06
–07
–08
–09
–10
–11
–12
–13
–21
–22
–23
–24
–27
(7.62)
.300
(10.92)
.430
(13.46)
.530
(18.54)
.730
(21.08)
.830
(23.62)
.930
(26.16)
1.030
(31.24)
1.230
(36.32)
1.430
(16.00)
.630
(11.30)
.445
(12.19)
.480
(33.78)
1.330
(28.70)
1.130
–28
C
C
C
(2.79)
.110
(6.10)
.240
(8.64)
.340
(13.72)
.540
(16.26)
.640
(18.80)
.740
(21.34)
.840
(26.42)
1.040
(31.50)
1.240
(11.18)
.440
(6.48)
.255
(7.37)
.290
(28.96)
1.140
(23.88)
.940
N/A
N/A
(3.30)
.130
(5.84)
.230
(10.92)
.430
(13.46)
.530
(16.00)
.630
(18.54)
.730
(23.62)
.930
(28.70)
1.130
(8.38)
.330
(3.68)
.145
(4.57)
.180
(26.16)
1.030
(21.08)
.830
N/A
–S
MAXIMUM MAXIMUM MAXIMUM
STRAIGHT
w/RA
w/RE
(3.30)
.130
(8.38)
.330
(10.92)
.430
(13.46)
.530
(16.00)
.630
(21.08)
.830
(26.16)
1.030
(5.84)
.230
Straight Pin Versions A = OAL–C– (2.54)
.100
–D
C
OAL
C
OAL
(2.54)
.100
(2.54)
.100
A
A
C
OAL
C
(2.54)
.100
(2.54)
.100
A
A
(5.33) Styles –21, –23, –24, –27 N/A with –D
Right-Angle Versions (– RA Options) A = OAL–C– .210 Styles –13, –21, –23, –24, –27, –28 N/A with –T or – Q
(1.78)
.070
(1.78)
.070
C
A
(1.52)
.060
(2.54)
.100
A
(1.52)
.060
(1.78)
.070
C
(2.54)
.100
(1.78)
.070
C
A
(1.52)
.060
(2.54)
.100
(2.54)
.100
C
(1.52)
.060
(2.54)
.100
(2.54)
.100
N/A
(1.78)
.070
(23.62)
.930
(18.54)
.730
* Styles –21, –23, –24, –27
not available with –D Right-Angle
not available with –T or – Q Right-Angle
OAL
–Q
–T
C
A
(4.06)
.160
(2.54)
.100
(– RE Options) Single Row Only
(7.87)
A = OAL–C– .310
WWW.SAMTEC.COM
(5.08)
.200
A
(2.54)
.100
MTSW-111-08-G-D-310 价格&库存
很抱歉,暂时无法提供与“MTSW-111-08-G-D-310”相匹配的价格&库存,您可以联系我们找货
