PCIE-LP-16-01-F-DV-A-WT
    SAMTEC(申泰)
PCIE-LP-16-01-F-DV-A-WT 数据手册
PCI EXPRESS® EDGE CARD SOCKETS (1.00 mm) .0394" PITCH FEATURES & BENEFITS • 1.00 mm pitch • Supports 1, 4, 8 and 16 PCI Express® links • PCIE® 3.0 Solution (PCIE) 11 mm 8 mm • PCIE® 4.0 Solution with low profile design for space savings (PCIE-LP) • PCIE® 4.0 with slim body design (PCIE-G4) • PCIE® 5.0 Solution with differential pair signaling (PCIE-G5) • Vertical, right-angle and edge mount PCIE • Mates with .062" (1.60 mm) thick cards PCIE -LP PCIE® 3.0 & 4.0 Edge Card connectors • Alignment pin and weld tab options PCIE® 4.0 slim body socket with Edge Rate® contacts (PCIE-G4) KEY SPECIFICATIONS SERIES TOTAL PINS (LANES) INSULATOR MATERIAL CONTACT MATERIAL OPERATING TEMP RANGE CURRENT RATING VOLTAGE RATING PCIE® COMPATIBILITY PCIE 36 (x1), 64 (x4), 98 (x8), 164 (x16) -TH = Black Nylon -EMS2 & -TH = LCP Phosphor Bronze -55 °C to +125 °C 2.4 A (2 pins) 215 VAC 3.0 PCIE-LP 36 (x1), 64 (x4), 98 (x8), 164 (x16) LCP Phosphor Bronze -55 °C to +125 °C 2.1 A (2 pins) 215 VAC 4.0 PCIE-G4 36 (x1), 64 (x4), 98 (x8), 164 (x16) LCP Copper Alloy -55 °C to +125 °C 2.2 A (2 pins) 300 VAC 4.0 PCIE-G5 36 (x1), 64 (x4), 98 (x8), 164 (x16) LCP Copper Alloy -55 °C to +125 °C 3.2 A (2 pins) 235 VAC 5.0 F-224 samtec.com/EdgeCard Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. 3.0 & 4.0 SOLUTIONS (1.00 mm) .0394" PITCH • PCI EXPRESS® CARD SOCKETS - PCIE - NUMBER OF POSITIONS - 02 –036, –064, –098, –164 PLATING OPTION - - D TAIL OPTION –F –EMS2 =Gold flash on contact, Tin on tail = Edge Mount –TH =Through-hole –RA =Right-angle A PCIE Card Mates: (1.60 mm) .062" card Cable Mates: PCIEC (8.61) .339 (7.30) .287 (11.05) .435 (15.40) .606 POSITIONS A –036 (x1) (25.00) .984 –064 (x4) (39.00) 1.535 –098 (x8) (56.00) 2.205 –164 (x16) (89.00) 3.504 -TH -EMS2 A (9.45) .372 -RA View complete specifications at: samtec.com?PCIE PCIE - LP - NUMBER OF LANES –01, –04, –08, –16 - 01 - PLATING OPTION - DV - A - –F –WT = Gold Flash on contact, Matte Tin on tail = Weld Tab –K = Polyimide film Pick & Place Pad –S = 30 µ" (0.75 µm) Gold on contact, Matte Tin on tail PCIE-LP Card Mates: (1.60 mm) .062" card Cable Mates: PCIEC OPTION NUMBER OF LANES A –01 (26.60) 1.047 –04 (40.60) 1.598 –08 (57.60) 2.268 –16 (90.60) 3.567 (7.50) .295 - PACKAGING (For -16 lanes only leave blank for Tray Packaging) –TR = Tape & Reel (“X”R required with –01, –04, –08 lanes) –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (“X”R required with –01, –04, –08 lanes) A PCI-SIG®, PCI Express® and the PCIe® design marks are registered trademarks and/or service marks of PCI-SIG. Note: Some lengths, styles and options are non-standard, non-returnable. (7.80) .307 (7.98) .314 View complete specifications at: samtec.com?PCIE-LP samtec.com/EdgeCard Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
PCIE-LP-16-01-F-DV-A-WT 价格&库存
很抱歉,暂时无法提供与“PCIE-LP-16-01-F-DV-A-WT”相匹配的价格&库存,您可以联系我们找货
