QRM8-026-07.0-L-D-A-GP
    SAMTEC(申泰)
    SMD,P=0.8mm
    板对板连接器 立贴 针脚数:52Pin 间距:0.8mm 排数:2
QRM8-026-07.0-L-D-A-GP 数据手册
QRM8–036–05.0–L–D–DP–A–K F-215 QRM8–078–05.0–L–D–A ® QRM8–026–02.0–L–D–A (0,80 mm) .0315" QRM8 SERIES SLIM BODY GROUND PLANE HEADER SPECIFICATIONS Board Mates: QRF8 For complete specifications and recommended PCB layouts see www.samtec.com?QRM8 Cable Mates: EQRD Insulator Material: Black LCP Terminal & Ground Plane Material: Phosphor Bronze Plating: Au or Sn over 50µ" (1,27 µm) Ni Current Rating: Contact: 2.2 A per pin (1 pin powered per row) Ground: 8.5 A per ground plane (1 ground plane powered) Operating Temp Range: -55°C to +125°C Voltage Rating: 215 VAC RoHS Compliant: Yes Processing: Lead–Free Solderable: Yes SMT Lead Coplanarity: (0,10 mm) .004" max (018-026) (0,15 mm) .006" max (036-078) (1,20 mm) .047" NOMINAL WIPE Integral ground/power plane ® Choice of stack heights s ocol Prot orted Supp 100 GbE Increased wipe for rugged applications notes at Download app ppnote om/a www.samtec.c mtec.com @ sa Contact SIG on protocols for questions Rated @ 3dB Insertion Loss with PCB effects* w/o PCB effects** Single-Ended Signaling –D 9.5 GHz / 19 Gbps 11 GHz / 22 Gbps Differential Pair Signaling –D 8.5 GHz / 17 Gbps 10.5 GHz / 21 Gbps Differential Pair Signaling –DP 9 GHz / 18 Gbps 17.5 GHz / 35 Gbps *Performance data includes effects of a non-optimized PCB. **Test board losses de-embedded from performance data. Performance data for other stack heights and complete test data available at www.samtec.com?QRM8 or contact sig@samtec.com QRM8/QRF8 7 mm Stack Height QRM8 Type PINS PER ROW NO. OF PAIRS LEAD STYLE PLATING OPTION A TYPE OTHER OPTION RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality –026, –052, –078 (52 total pins per bank = –D) –018, –036, –054 (18 pairs per bank = –D–DP) –02.0 –L = 2 mm Body Height (Not available with –054 & –078 positions) = 10µ" (0,25 µm) Gold on contact, Matte Tin on tail –D = SingleEnded –D–DP = Differential Pair –05.0 = 5 mm Body Height ALSO AVAILABLE (MOQ Required) –07.0 • Other platings Contact Samtec. –02.0 –05.0 –07.0 –05.0 –07.0 (7,00) .276 (10,00) .394 (12,00) .472 (9,00) .354 (12,00) .472 (14,00) .551 *Processing conditions will affect mated height. B (9,12) –05.0 (7,81) .307 .359 01 QRF8 LEAD STYLE A (6,12) –02.0 (4,81) .189 .241 No. of Banks x (24,80) .976 + (1,77) .070 MATED HEIGHT* QRM8 LEAD STYLE LEAD STYLE = 7 mm Body Height –GP = Guide Post (Requires –GP on mating connector) –K = (5,00 mm) .197" DIA Polyimide Film Pick & Place Pad –TR = Tape & Reel (–018, –026, –036, –052 only) (11,12) –07.0 (9,78) .385 .438 (4,60) .181 02 (0,80) .0315 (1,32) .052 (1,00) .039 DIA (2,20) .087 A (3,67) .145 • Edge Rate® contacts No. of Banks x (24,80) .976 - (1,10) .043 (1,89) .074 (3,18) .125 B • Increased contact wipe • 10 year MFG • Guide post option Note: Patented No. of Banks x (24,80) .976 + (3,55) .140 Note: Some lengths, styles and options are non-standard, non-returnable. –GP OPTION WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice.
QRM8-026-07.0-L-D-A-GP 价格&库存
很抱歉,暂时无法提供与“QRM8-026-07.0-L-D-A-GP”相匹配的价格&库存,您可以联系我们找货
  • 1+134.442891+17.47714
  • 80+103.3770480+13.43868
  • 160+102.45631160+13.31899
库存:2
