DF40TC(4.0)-40DS-0.4V(58)
    HRS(广濑)
    SMD,P=0.4mm
    板对板连接器 立贴 间距:0.4mm 排数:2
DF40TC(4.0)-40DS-0.4V(58) 数据手册
DF40T/DF40GT Series Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.4mm Pitch, 3.38mm Depth, 125ºC Heat Resistance, Board-to-Board/FPC-to-Board Connector for Automotive Product Page https://www.hirose.com/en/product/series/DF40T Dec. 2023 DF40T/DF40GT Series/0.4mm Pitch, 3.38mm Depth, 125ºC Heat Resistance, Board-to-Board/FPC-to-Board Connector for Automotive Features 1. Space- Saving Design and Wide Variations Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. The space- saving design with 0. 4mm pitch and 3. 38mm depth, a wide variety of number of pos. and height variation. ( 1. 5, 2. 0, 2. 5, 3. 0, 3. 5, 4. 0mm) . ( Note) MP : Mass Production UP : Under Planning UD : Under Development Stacking Height (mm) 1.5 2.0 2.5 3.0 3.5 4.0 10pos. MP ー ー ー ー ー 20pos. UP UD MP MP MP MP 30pos. MP UP MP MP MP MP 34pos. MP ー ー ー ー ー 40pos. MP UP UP MP MP MP 50pos. MP ー MP ー ー MP 60pos. UP ー ー ー ー ー 120pos. MP ー ー ー ー ー 2. 125℃ Heat Resistant Contact Design Design and Materials for Heat Resistance, Stable Contact Resistance Heat resistance test 125℃ after 1, 000h Contact resistance AVG : Initial 19. 05 → after 1, 000h 18. 62mΩ Temperature cycle test - 55 to + 125℃ after 1, 000 cycles Contact resistance AVG : Initial 19. 76 → after 1, 000 cycles 20. 05mΩ 3. World Longest Class Effective Mating Length Stable connection with the world' s largest effective mating length realization 0.45mm 2 DF40T/DF40GT Series/0.4mm Pitch, 3.38mm Depth, 125ºC Heat Resistance, Board-to-Board/FPC-to-Board Connector for Automotive 4. Guide Ribs for Wide Self Alignment Range Self Alignment Range: ±0. 33mm in X and Y Directions Achieves smooth Mating Operation YD Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ire cti on XD n tio c ire Broaden the range of self alignment during mating, efficiently using dead space. ±0.33mm Guide Ribs 5. Supports PCI- ex Gen4( 16Gbps) All DF40T series is applicable to the PCI- ex Gen4 transmission. 3 DF40T/DF40GT Series/0.4mm Pitch, 3.38mm Depth, 125ºC Heat Resistance, Board-to-Board/FPC-to-Board Connector for Automotive 6. Metal Shielding for Superior EMI【 DF40GT】 EMI prevention by shield plate on receptacle side. Magnetic Field Reduced by 18. 5dB μA/ m with Shield Plate Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Shielding Suppresses Radiation and Incident Magnetic Fields <Near Magnetic Field Simulation Results> DF40T 4.5GHz MAX 100.2dBμA/m 100.2dBµA/m DF40GT 4.5GHz MAX 81.7dBμA/m 81.7dBµA/m 7. Reliable Ground Design 【 DF40GT】 The contact area between the shield plate and the retention tab placed at the four corners strengthens grounding. Receptacle Shielding Contact Spring Plug Retention Tab Contact Point Ground connection on dead space 4 DF40T/DF40GT Series/0.4mm Pitch, 3.38mm Depth, 125ºC Heat Resistance, Board-to-Board/FPC-to-Board Connector for Automotive Applications It can be used as a FPC- to- Board connector inside in- vehicle applications such as cameras, millimeter- wave radar, and LiDAR. Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Product Specifications Rated Current 0.3A Operating Temperature (Note 1)(Note 2) -55 to +125℃ Rated Voltage 30V AC/DC Storage Temperature (Note 3) -10 to +60℃ Item Specifications Conditions Contact Resistance 90m Ω Max. Measured at 20mV AC, 1kHz, 1mA Insulation Resistance 50M Ω Min. Measured at 100V DC Withstand Voltage No Flashover or Breakdown 100V AC for 1 min. Mating Durability Contact Resistance : 90m Ω Max. No damage, cracks or part dislocation. 10 times Vibration Resistance There should be no electrical interruption of 1 μ s Min. No damage, cracks or part dislocation. Frequency 10 to 500Hz, Acceleration 49m/s2 Swept speed 1oct/min 8 hours each of 3-axis direction Heat Resistance Contact Resistance : 90m Ω Max. No damage, cracks or part dislocation. Left for 1000 hours at Temperature 125 ± 2℃ Moisture Resistance Contact Resistance : 90m Ω Max. Insulation Resistance : 25M Ω Min. No damage, cracks or part dislocation. Temperature -10 → +65℃ , RH In 90 - 96% Left for 10 cycles (240 hours) Temperature Cycles Contact Resistance : 90m Ω Max. No damage, cracks or part dislocation. Temperature -55℃ : 30min. → +125℃ : 30min., 1000 cycles (Tank transfer time : 2 to 3min.) Solder Heat Resistance No deformation in appearance or significant damage to contacts. Reflow : According to the Recommended Temperature Profile Hand Soldering : 350℃ within 3 sec. Note 1 : Includes the temperature rise due to current flow. Note 2 : Use without condensation. Note 3 : Storage refers to long-term storage of unused items before they are mounted on the PCB.   Operating temperature and humidity range apply when the product is not powered after PCB mounting and when temporarily stored during transportation. Materials / Finish ■125℃ Heat Resistant Standard Type (DF40T) Product Plug Receptacle Component Material Color / Finish Housing LCP Black Signal Contact Copper Alloy Gold Plating Remarks UL94V-0 - ■125℃ Heat Resistant Shielded Type (DF40GT) Product Plug Receptacle Component Material Color / Finish Remarks Housing LCP Black Signal Contact Copper Alloy Gold Plating - Retention Tab Copper Alloy Gold Plating - Housing LCP Black Signal Contact Copper Alloy Gold Plating - Shield Copper Alloy Gold Plating - 5 UL94V-0 UL94V-0 DF40T/DF40GT Series/0.4mm Pitch, 3.38mm Depth, 125ºC Heat Resistance, Board-to-Board/FPC-to-Board Connector for Automotive Product Number Structure Please utilize the below part number chart when selecting. ■ DF40T (125℃ Heat Resistant Standard Type) ● Plug DF40 # - # DP - 0.4 V (##) Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❷ ❸  ❹ ❺ ❻ ❼ ❶ Series Name DF40 ❺ Contact Pitch 0.4mm ❷ Shape Symbol TC : No Retention Tab ❻ Contact Type V : Straight SMT ❸ No. of Pos. 10, 20, 30, 34, 40, 50, 60, 120 ❼ Packaging Type ❹ Connector Type DP : Double Row Pin Plug (51) : Embossed Packaging (88) : Embossed Packaging ● Receptacle DF40 # (##) - # DS - 0.4 V (##) ❶ ❷ ❸  ❹ ❺ ❻ ❼ ❽ ❶ Series Name DF40 ❹ No. of Pos. 10, 20, 30, 34, 40, 50, 60, 120 ❷ Shape Symbol. TB : Retention Tab TC : No Retention Tab ❺ Connector Type DS : Double Row Receptacle ❸ Stacking Height None : 1.5mm 2.0 : 2.0mm 2.5 : 2.5mm 3.0 : 3.0mm 3.5 : 3.5mm 4.0 : 4.0mm ❻ Contact Pitch 0.4mm ❼ Contact Type V : Straight SMT ❽ Packaging Type (51) : Embossed Packaging (88) : Embossed Packaging ■ DF40GT (125℃ Heat Resistant Shield Type) ● Plug DF40 GT - # DP - 0.4 V (51) ❶ ❷ ❸  ❹ ❺ ❻ ❼ ❶ Series Name DF40 ❺ Contact Pitch 0.4mm ❷ Shape Symbol GT : With Shield ❻ Contact Type V : Straight SMT ❸ No. of Pos. 10 ❼ Packaging Type (51) : Embossed Packaging ❹ Connector Type DP : Double Row Pin Plug ● Receptacle DF40 GT (##) - # DS - 0.4 V (51) ❶ ❷ ❸  ❹ ❺ ❻ ❼ ❽ ❶ Series Name DF40 ❺ Connector Type DS : Double Row Receptacle ❷ Shape Symbol GT : With Shield ❻ Contact Pitch 0.4mm ❸ Stacking Height 1.5 : 1.5mm ❼ Contact Type V : Straight SMT ❹ No. of Pos. 10 ❽ Packaging Type (51) : Embossed Packaging 6 DF40T/DF40GT Series/0.4mm Pitch, 3.38mm Depth, 125ºC Heat Resistance, Board-to-Board/FPC-to-Board Connector for Automotive Combinations ■125℃ Heat Resistant Standard Type (DF40T) Receptacle/Plug Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unit : mm DF40TC-##DP-0.4V(51) Stacking Height DF40TC-##DS-0.4V(51) 1.5 DF40TC(2.0)-##DS-0.4V(51) 2.0 DF40TC(2.5)-##DS-0.4V(51) 2.5 DF40TC(3.0)-##DS-0.4V(51) 3.0 DF40TC(3.5)-##DS-0.4V(51) 3.5 DF40TC(4.0)-##DS-0.4V(51) 4.0 ■125℃ Heat Resistant Shielded Type (DF40GT) Unit : mm DF40GT-10DP-0.4V(51) Stacking Height Receptacle/Plug DF40GT(1.5)-10DS-0.4V(51) 1.5 7 DF40T/DF40GT Series/0.4mm Pitch, 3.38mm Depth, 125ºC Heat Resistance, Board-to-Board/FPC-to-Board Connector for Automotive DF40T (125℃ Heat Resistant Standard Type) Plug Vacuum Pick & Place Area : C±0.2 ● Recommended PCB Layout B±0.02 0.475±0.02 0.35±0.02 0 2.05 -0.05 P=0.4±0.02 3.37 +0.05 0 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.15±0.02 1.14±0.15 1.85±0.2 2.97±0.2 A±0.2 B±0.08 P=0.4±0.05 0.23±0.02 Recommended Metal Mask Thickness : 0.12mm, Open Area Ratio : 80% Unit : mm Part No. HRS No. No. of Pos. A B C DF40TC-10DP-0.4V(51) CL0684-4269-0-51 10 3.52 1.60 1.00 DF40TC-20DP-0.4V(51) CL0684-4262-0-51 20 5.52 3.60 1.00 DF40TC-30DP-0.4V(51) CL0684-4263-0-51 30 7.52 5.60 1.50 DF40TC-34DP-0.4V(51) CL0684-4255-0-51 34 8.32 6.40 2.30 DF40TC-40DP-0.4V(51) CL0684-4264-0-51 40 9.52 7.60 3.20 DF40TC-50DP-0.4V(51) CL0684-4268-0-51 50 11.52 9.60 3.20 DF40TC-60DP-0.4V(51) Under Planning 60 13.52 11.60 3.20 CL0684-4295-0-88 120 25.52 23.60 3.20 DF40TC-120DP-0.4V(88) Note 1 : Please order embossed tape packaged items by the reel. Note 2 : This connector has no polarity. 8 Purchase Unit 5,000pcs per reel DF40T/DF40GT Series/0.4mm Pitch, 3.38mm Depth, 125ºC Heat Resistance, Board-to-Board/FPC-to-Board Connector for Automotive DF40T (125℃ Heat Resistant Standard Type) Receptacle (Stacking Height 1.5mm) Vacuum Pick & Place Area : C±0.2 ● Recommended 2.38 1.5MAX 0 -0.05 PCB Pattern B±0.02 P=0. 4±0.02 3.78 +0.05 0 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.12±0.02 1.45±0.15 3.38±0.2 2.88±0.2 A±0.2 B±0.08 P=0.4±0.05 0. 2±0.02 Insulation Area Recommended Metal Mask Thickness : 0.12mm, Aperture Ratio : 80% Unit : mm Part No. HRS No. No. of Pos. A B C DF40TB-10DS-0.4V(51) CL0684-4273-0-51 10 4.6 1.6 1.0 DF40TC-20DS-0.4V(51) Under Planning 20 6.6 3.6 1.0 DF40TC-30DS-0.4V(51) CL0684-4261-0-51 30 8.6 5.6 1.5 DF40TC-34DS-0.4V(51) CL0684-4240-0-51 34 9.4 6.4 2.3 DF40TC-40DS-0.4V(51) CL0684-4272-0-51 40 10.6 7.6 3.2 DF40TC-50DS-0.4V(51) CL0684-4249-0-51 50 12.6 9.6 3.2 DF40TC-60DS-0.4V(51) Under Planning 60 14.6 11.6 3.2 CL0684-4296-0-88 120 26.6 23.6 3.2 DF40TC-120DS-0.4V(88) Note 1 : Please order embossed tape packaged items by the reel. Note 2 : This connector has no polarity. 9 Purchase Unit 5,000pcs per reel DF40T/DF40GT Series/0.4mm Pitch, 3.38mm Depth, 125ºC Heat Resistance, Board-to-Board/FPC-to-Board Connector for Automotive DF40T (125℃ Heat Resistant Standard Type) Receptacle (Stacking Height 2.0mm) A±0.2 B±0.08 2.94±0.2 3.38±0.2 P=0.4±0.05 1.95±0.15 Vacuum Pick & Place Area : C±0.2 ● Recommended PCB Pattern B±0.02 3.78 +0.05 0 P=0.4±0.02 0 2.38 -0.05 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.12±0.02 0.2±0.02 Recommended Metal Mask Thickness : 0.12mm, Aperture Ratio : 80% Unit : mm HRS No. No. of Pos. A B C DF40TC(2.0)-20DS-0.4V(51) CL0684-4241-0-51 20 6.6 3.6 1.0 DF40TC(2.0)-30DS-0.4V(51) Under Planning 30 8.6 5.6 1.5 DF40TC(2.0)-40DS-0.4V(51) Under Planning 40 10.6 7.6 3.2 Part No. Note 1 : Please order embossed tape packaged items by the reel. Note 2 : This connector has no polarity. 10 Purchase Unit 4,000pcs per reel DF40T/DF40GT Series/0.4mm Pitch, 3.38mm Depth, 125ºC Heat Resistance, Board-to-Board/FPC-to-Board Connector for Automotive DF40T (125℃ Heat Resistant Standard Type) Receptacle (Stacking Height 2.5mm to 4.0mm) ● Stacking Height 2.5mm A±0.2 B±0.08 Vacuum Pick & Place Area : C±0.2 ● Recommended PCB Pattern B±0.02 0 2.38 -0.05 P=0.4±0.02 3.78 +0.05 0 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.12±0.02 2.4±0.15 2.94±0.2 3.38±0.2 P=0.4±0.05 0.2±0.02 Recommended Metal Mask Thickness : 0.12mm, Open Area Ratio : 80% Unit : mm HRS No. No. of Pos. A B C DF40TC(2.5)-20DS-0.4V(51) CL0684-4280-0-51 20 6.6 3.6 1.0 DF40TC(2.5)-30DS-0.4V(51) CL0684-4266-0-51 30 8.6 5.6 1.5 DF40TC(2.5)-40DS-0.4V(51) Under Planning 40 10.6 7.6 3.2 DF40TC(2.5)-50DS-0.4V(51) CL0684-4279-0-51 50 12.6 9.6 3.2 Part No. Note 1 : Please order embossed tape packaged items by the reel. Note 2 : This connector has no polarity. 11 Purchase Unit 3,000pcs per reel DF40T/DF40GT Series/0.4mm Pitch, 3.38mm Depth, 125ºC Heat Resistance, Board-to-Board/FPC-to-Board Connector for Automotive ● Stacking Height 3.0mm A±0.2 B±0.08 2.94±0.2 3.38±0.2 P=0.4±0.05 0.12±0.02 ● Recommended PCB Pattern B±0.02 0 3.78 +0.05 0 P=0.4±0.02 2.38 -0.05 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2.9±0.15 Vacuum Pick & Place Area : C±0.2 0.2±0.02 Recommended Metal Mask Thickness : 0.12mm, Open Area Ratio : 80% Unit : mm HRS No. No. of Pos. A B C DF40TC(3.0)-20DS-0.4V(51) CL0684-4275-0-51 20 6.6 3.6 1.0 DF40TC(3.0)-30DS-0.4V(51) CL0684-4242-0-51 30 8.6 5.6 1.5 DF40TC(3.0)-40DS-0.4V(51) CL0684-4276-0-51 40 10.6 7.6 3.2 Part No. Note 1 : Please order embossed tape packaged items by the reel. Note 2 : This connector has no polarity. 12 Purchase Unit 3,000pcs per reel DF40T/DF40GT Series/0.4mm Pitch, 3.38mm Depth, 125ºC Heat Resistance, Board-to-Board/FPC-to-Board Connector for Automotive ● Stacking Height 3.5mm A±0.2 3.38±0.2 2.94±0.2 B±0.08 P=0.4±0.05 Vacuum Pick & Place Area : C±0.2 ● Recommended PCB Pattern B±0.02 2.38 0 -0.05 P=0.4±0.02 3.78 +0.05 0 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3.4±0.15 0.12±0.02 0.2±0.02 Recommended Metal Mask Thickness : 0.12mm, Open Area Ratio : 80% Unit : mm HRS No. No. of Pos. A B C DF40TC(3.5)-20DS-0.4V(51) CL0684-4253-0-51 20 6.6 3.6 1.0 DF40TC(3.5)-30DS-0.4V(51) CL0684-4237-0-51 30 8.6 5.6 1.5 DF40TC(3.5)-40DS-0.4V(51) CL0684-4254-0-51 40 10.6 7.6 3.2 Part No. Note 1 : Please order embossed tape packaged items by the reel. Note 2 : This connector has no polarity. 13 Purchase Unit 2,000pcs per reel DF40T/DF40GT Series/0.4mm Pitch, 3.38mm Depth, 125ºC Heat Resistance, Board-to-Board/FPC-to-Board Connector for Automotive ● Stacking Height 4.0mm A±0.2 2.94±0.2 3.38±0.2 B±0.08 P=0.4±0.05 Vacuum Pick & Place Area : C±0.2 3.9±0.15 ● Recommended PCB Pattern B±0.02 2.38 0 -0.05 P=0.4±0.02 3.78 +0.05 0 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.12±0.02 0.2±0.02 Recommended Metal Mask Thickness : 0.12mm, Open Area Ratio : 80% Unit : mm HRS No. No. of Pos. A B C DF40TC(4.0)-20DS-0.4V(51) CL0684-4258-0-51 20 6.6 3.6 1.0 DF40TC(4.0)-30DS-0.4V(51) CL0684-4256-0-51 30 8.6 5.6 1.5 DF40TC(4.0)-40DS-0.4V(51) CL0684-4259-0-51 40 10.6 7.6 3.2 DF40TC(4.0)-50DS-0.4V(51) CL0684-4297-0-51 50 12.6 9.6 3.2 Part No. Note 1 : Please order embossed tape packaged items by the reel. Note 2 : This connector has no polarity. 14 Purchase Unit 2,000pcs per reel DF40T/DF40GT Series/0.4mm Pitch, 3.38mm Depth, 125ºC Heat Resistance, Board-to-Board/FPC-to-Board Connector for Automotive DF40GT (125℃ Heat Resistant With Shield Type) Plug 3.16±0.3 2.67±0.1 1.6±0.08 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.85±0.02 P=0.4±0.05 0.15±0.02 Vacuum Pick & Place Area : 1±0.2 0.08±0.02 1.14±0.15 0.25±0.08 2.02±0.2 ● Recommended PCB Pattern 4.74 +0.05 0 0 3.32 -0.05 2.67±0.02 0 2.12 -0.05 1.6±0.02 0 1.02 0 -0.05 3.32 +0.05 0 1.88 -0.05 0 0.23±0.02 2.42 +0.05 0 0.35±0.02 2.05 -0.05 3.37 +0.05 0 P=0.4±0.02 : Signal : Ground : Insulation Area Recommended Metal Mask Thickness : 0.12mm, Aperture Ratio : 80% Unit : mm HRS No. No. of Pos. Purchase Unit CL0684-4260-0-51 10 5,000pcs per reel Part No. DF40GT-10DP-0.4V(51) Note 1 : Please order embossed tape packaged items by the reel. Note 2 : This connector has no polarity. 15 DF40T/DF40GT Series/0.4mm Pitch, 3.38mm Depth, 125ºC Heat Resistance, Board-to-Board/FPC-to-Board Connector for Automotive DF40T (125℃ Heat Resistant With Shield Type) Receptacle 4.64±0.3 2.48±0.1 1.6±0.08 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3.38±0.3 P=0.4±0.05 0.2±0.02 0.12±0.02 Vacuum Pick & Place Area : 1±0.2 1.45±0.15 3.12±0.2 ● Recommended PCB Pattern 2.48±0.02 1.6±0.02 +0.05 0 0 0.2±0.02 4.08 2.64 -0.05 1.5MAX 0 2.38 -0.05 3.78 +0.05 0 P=0.4±0.02 0.28±0.02 : Signal : Ground : Insulation Area Recommended Metal Mask Thickness : 0.12mm, Open Area Ratio : 80% Unit : mm HRS No. No. of Pos. Purchase Unit CL0684-4248-0-51 10 5,000pcs per reel Part No. DF40GT(1.5)-10DS-0.4V(51) Note 1 : Please order embossed tape packaged items by the reel. Note 2 : This connector has no polarity. 16 DF40T/DF40GT Series/0.4mm Pitch, 3.38mm Depth, 125ºC Heat Resistance, Board-to-Board/FPC-to-Board Connector for Automotive Packaging Specifications Diagram (JIS C 0806, IEC 60286 -3 Compliant) ■ DF40T (125℃ Heat Resistant Standard Type) Plug Reel Dimensions F-F 0.8 1± φ2 E φ80±1 12 0° A±0.3 D±0.5 F t=0.3±0.1 C±1 Unreeling Direction E-E 1.34±0.15 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. B±0.1 φ1.5 Feed Hole Back 0° 12 E 8±0.1 2±0.5 φ380±2 F 2±0.1 φ1 3± 0.2 +0.1 0 .5 φ1 4±0.1 1.75±0.1 Embossed Tape Dimensions Unit : mm Part No. HRS No. A B C D DF40TC-10DP-0.4V(51) CL0684-4269-0-51 12 5.5 17.5 13.5 DF40TC-20DP-0.4V(51) CL0684-4262-0-51 16 7.5 21.5 17.5 DF40TC-30DP-0.4V(51) CL0684-4263-0-51 16 7.5 21.5 17.5 DF40TC-34DP-0.4V(51) CL0684-4255-0-51 24 11.5 29.5 25.5 DF40TC-40DP-0.4V(51) CL0684-4264-0-51 24 11.5 29.5 25.5 DF40TC-50DP-0.4V(51) CL0684-4268-0-51 24 11.5 29.5 25.5 DF40TC-60DP-0.4V(51) Under Planning 24 11.5 29.5 25.5 CL0684-4295-0-88 44 40.4 49.5 45.5 DF40TC-120DP-0.4V(88) Note : The hole of the carrier tape for 10 to 60pos. will be only one side. 17 Purchase Unit 5,000pcs per reel DF40T/DF40GT Series/0.4mm Pitch, 3.38mm Depth, 125ºC Heat Resistance, Board-to-Board/FPC-to-Board Connector for Automotive Receptacle ● Stacking Height 1. 5 to 3. 0mm .1 +00 5 1. φ 4±0.1 F 2±0.1 1.75±0.1 Embossed Tape Dimensions F-F Reel Dimensions φ1 3± 0.2 φ80±1 φ380±2 12 0° A±0.3 φ1.5 Feed Hole Back 0° 12 D±0.5 C±1 E 8±0.1 F E t=0.3±0.1 Unreeling Direction E-E G±0.15 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. B±0.1 0.8 1± φ2 2±0.5 18 DF40T/DF40GT Series/0.4mm Pitch, 3.38mm Depth, 125ºC Heat Resistance, Board-to-Board/FPC-to-Board Connector for Automotive ● Stacking Height 3. 5 to 4. 0mm F-F Reel Dimensions φ80±1 12 0° A±0.3 0° 12 D±0.5 C±1 E 8±0.1 t=0.4±0.1 F E Unreeling Direction E-E G`0.15 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. φ1.5 Feed Hole Back φ380±2 0.8 1± φ2 2±0.5 φ1 3± 0.2 F B±0.1 .1 +0 0 .5 φ1 4±0.1 2±0.1 1.75±0.1 Embossed Tape Dimensions 19 DF40T/DF40GT Series/0.4mm Pitch, 3.38mm Depth, 125ºC Heat Resistance, Board-to-Board/FPC-to-Board Connector for Automotive ● Stacking Height 1. 5mm Unit : mm Part No. HRS No. A B C D G DF40TB-10DS-0.4V(51) CL0684-4273-0-51 16 7.5 21.5 17.5 1.65 DF40TC-20DS-0.4V(51) Under Planning 16 7.5 21.5 17.5 1.65 DF40TC-30DS-0.4V(51) CL0684-4261-0-51 24 11.5 29.5 25.5 1.65 DF40TC-34DS-0.4V(51) CL0684-4240-0-51 24 11.5 29.5 25.5 1.65 DF40TC-40DS-0.4V(51) CL0684-4272-0-51 24 11.5 29.5 25.5 1.65 DF40TC-50DS-0.4V(51) CL0684-4249-0-51 24 11.5 29.5 25.5 1.65 DF40TC-60DS-0.4V(51) Under Planning 24 11.5 29.5 25.5 1.65 CL0684-4296-0-88 44 40.4 49.5 45.5 1.65 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF40TC-120DS-0.4V(88) Purchase Unit 5,000pcs per reel Note : The hole of the carrier tape for 10 to 60pos. will be only one side. ● Stacking Height 2. 0mm Unit : mm Part No. HRS No. A B C D G DF40TC(2.0)-20DS-0.4V(51) CL0684-4241-0-51 16 7.5 21.5 17.5 2.2 DF40TC(2.0)-30DS-0.4V(51) Under Planning 24 11.5 29.5 25.5 2.2 DF40TC(2.0)-40DS-0.4V(51) Under Planning 24 11.5 29.5 25.5 2.2 Purchase Unit 4,000pcs per reel ● Stacking Height 2. 5mm Unit : mm Part No. HRS No. A B C D G DF40TC(2.5)-20DS-0.4V(51) CL0684-4280-0-51 16 7.5 21.5 17.5 2.72 DF40TC(2.5)-30DS-0.4V(51) CL0684-4266-0-51 24 11.5 29.5 25.5 2.72 DF40TC(2.5)-40DS-0.4V(51) Under Planning 24 11.5 29.5 25.5 2.72 DF40TC(2.5)-50DS-0.4V(51) CL0684-4279-0-51 24 11.5 29.5 25.5 2.72 Purchase Unit 3,000pcs per reel ● Stacking Height 3. 0mm Unit : mm Part No. HRS No. A B C D G DF40TC(3.0)-20DS-0.4V(51) CL0684-4275-0-51 16 7.5 21.5 17.5 3.15 DF40TC(3.0)-30DS-0.4V(51) CL0684-4242-0-51 24 11.5 29.5 25.5 3.15 DF40TC(3.0)-40DS-0.4V(51) CL0684-4276-0-51 24 11.5 29.5 25.5 3.15 20 Purchase Unit 3,000pcs per reel DF40T/DF40GT Series/0.4mm Pitch, 3.38mm Depth, 125ºC Heat Resistance, Board-to-Board/FPC-to-Board Connector for Automotive ● Stacking Height 3. 5mm Unit : mm Part No. HRS No. A B C D G DF40TC(3.5)-20DS-0.4V(51) CL0684-4253-0-51 16 7.5 21.5 17.5 3.72 DF40TC(3.5)-30DS-0.4V(51) CL0684-4237-0-51 24 11.5 29.5 25.5 3.72 DF40TC(3.5)-40DS-0.4V(51) CL0684-4254-0-51 24 11.5 29.5 25.5 3.72 Purchase Unit 2,000pcs per reel ● Stacking Height 4. 0mm Unit : mm Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. HRS No. A B C D G DF40TC(4.0)-20DS-0.4V(51) CL0684-4258-0-51 16 7.5 21.5 17.5 4.22 DF40TC(4.0)-30DS-0.4V(51) CL0684-4256-0-51 24 11.5 29.5 25.5 4.22 DF40TC(4.0)-40DS-0.4V(51) CL0684-4259-0-51 24 11.5 29.5 25.5 4.22 DF40TC(4.0)-50DS-0.4V(51) CL0684-4297-0-51 24 11.5 29.5 25.5 4.22 21 Purchase Unit 2,000pcs per reel DF40T/DF40GT Series/0.4mm Pitch, 3.38mm Depth, 125ºC Heat Resistance, Board-to-Board/FPC-to-Board Connector for Automotive ■ DF40GT (125℃ Heat Resistant Standard Type) Plug φ1 3± 0.2 φ380±2 φ80±1 5.5±0.1 φ1.5 Feed Hole Back 0° 12 F 13.5±0.5 17.5±1 Unreeling Direction 1.34±0.15 8±0.1 E-E HRS No. No. of Pos. Purchase Unit CL0684-4260-0-51 10 5,000pcs per reel Part No. DF40GT-10DP-0.4V(51) Receptacle Reel Dimensions 12 0° 16±0.3 φ1.5 Feed Hole Back 0° 12 7.5±0.1 0.8 1± φ2 2±0.5 φ80±1 F-F φ380±2 .1 0 +0 5 F φ1 3± 0.2 2±0.1 4±0.1 1.75±0.1 Embossed Tape Dimensions 1. φ 17.5±0.5 E E 8±0.1 21.5±1 t=0.3±0.1 F Unreeling Direction E-E 1.65±0.15 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2±0.5 t=0.3±0.1 E E 0.8 1± φ2 .1 +0 0 5 F-F 12 0° 1. φ 2±0.1 4±0.1 Reel Dimensions 12±0.3 F 1.75±0.1 Embossed Tape Dimensions HRS No. No. of Pos. Purchase Unit CL0684-4248-0-51 10 5,000pcs per reel Part No. DF40GT(1.5)-10DS-0.4V(51) 22 DF40T/DF40GT Series/0.4mm Pitch, 3.38mm Depth, 125ºC Heat Resistance, Board-to-Board/FPC-to-Board Connector for Automotive TEMPERATURE(℃) Precautions Recommended Temperature Profile 250 250℃ 【Conditions】 220℃ 200 1. Peak Temperature : 250℃ 60sec. Max. 2. Heating : 220℃ Min. for 60 sec. Max. 180℃ 3. Preheating : 150 to 180℃, 90 to 120 sec. 150 150℃ 4. Number of Reflow Cycles : 2 cycles Max. 90-120sec. 100 * Temperature refers to the surface temperature of the board near the connector lead. We recommend reflow mounting in a nitrogen environment. Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 50 Normal Temperature 0 50 100 150 200 250 300 HEATING TIME (sec.) Recommended Manual Soldering Soldering iron temperature : 340 ± 10℃ , Soldering Time : Within 3 sec. Conditions Recommended Metal Mask Thickness and Open Area to PCB Pattern (Area Ratio) Thickness : 0.12mm, Aperture Ratio : DS 80% DP 80% Board Warpage Max. of 0.02mm at the center in reference to both ends of the connector Cleaning Cleaning is not recommended. If you clean this product, please evaluate its performance before using it. (Cleaning may impair the mating/unmating properties and lower resistance to environmental factors.) Precautions ・Be careful when mating/unmating the connector when it is not mounted on the PCB as it may cause damage/deformation to contacts. ・Avoid supporting the PCB only with the connectors. Support it by other means such as bolts, screws, posts, etc. ・Excessive prying during unmating/mating may result in damage. ・In the case of hand soldering, please do not apply any flux which could cause flux wicking. ・This product may have slight color differences due to production lot variability, but this does not affect the performance. ・Please refer to the following page for handling precautions when inserting and removing. ・Because the product can disengage if dropped (or other impact), or by FPC routing, it is advised to secure the mated connectors to the board with housings and cushioning materials. ・Do not use the connector in non-recommended conditions (i.e., rated current, rated voltage, PCB design and operating environment, etc.). Such usage could lead to material outgassing, ignition, or short-circuit, etc. Refer to the specifications and guidelines for board pattern dimensions, board cautions, and connector treatment. Please contact Hirose if connector usage in conditions other than those described in the specifications and the guidelines is being considered. 23 DF40T/DF40GT Series/0.4mm Pitch, 3.38mm Depth, 125ºC Heat Resistance, Board-to-Board/FPC-to-Board Connector for Automotive Precautions for Handling During Use 【 Mating Method of Connector】 When Mating this Item, please do so by hand. Mating Method 1.Locate the guide port and align. This product has a guide rib on the plug to ensure proper engagement. Once aligned, the connector engages. You can feel the mated height of the connector lower. Move the connector forward and backward, left and right to find the guide port. Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Finding Mated height goes down one step. Finding 2. In the engaged state, the connectors are parallel to each other, and the connectors cannot move forward, backward, left, or right. Complete mating from this state. 3. Check that mating is completed. If one side is floating, or if it is mated at a diagonal, remove and re- mate. 【 Handling Precautions for Connector Removal】 1. When removing the connector, it is preferable to pull it out in the upward direction from the connector mounting surface. However, when removing the FPC from the circuit board it becomes more difficult to remove it vertically with higher pin counts and thin FPCs. OK OK FPC FPC Board Board 2. If difficult to remove, extract the connector diagonally in the direction of the pitch. Note that removal from the widthwise side will apply a large load to the contacts. OK FPC FPC Board Board 24 DF40T/DF40GT Series/0.4mm Pitch, 3.38mm Depth, 125ºC Heat Resistance, Board-to-Board/FPC-to-Board Connector for Automotive 3. If the FPC does not have sufficient rigidity, solder stripping or connector breakage may occur. Please use it after checking the repetitive operation with a flexible board in advance, such as during a trial manufacture run. Refrain from holding the corner of the flexible board and removing it diagonally as it will result in a large load to the contacts. Thin FPC Thin FPC Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Board While Taking into Consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please review the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, the warranty of the product may be affected. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. HIROSE 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com ※ The contents of this catalog are current as of date of 12/ 2023. Contents are subject to change without notice for the purpose of improvements. ※ The HRS logo and "HIROSE" are trademarks of HIROSE ELECTRIC CO., LTD. 25 DF40F Series Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Small Floating Board-to-Board Connector, 125ºC Heat Resistance for Automotive Product Page https://www.hirose.com/en/product/series/DF40T Dec. 2023 DF40F Series/Small Floating Board-to-Board Connector, 125ºC Heat Resistance for Automotive Features Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.       0. 4mm Pitch, 3. 68mm Width, Stacking Height 3. 5 to 6. 0mm World' s Smallest Width Class in Floating   Board- to- Board Connectors Receptacle DF40T It contributes to making board design spacesaving. Significantly reduces the area occupied on mounting part. Plug DF40F 8.6 3 9.6 Mated Small & Space- Saving ( e. g. 30pos. ) 2. Absorption of Misalignment Y Direction ±0.3mm X and Y Directions : Floating Range ±0. 3mm X Direction ±0.3mm Receptacle Z Direction : Effective Mating Length ±0. 25/ 0mm Stacking Height: 3.5 to 6.0mm The board mounting misalignment and misalignment due to board warpage can be absorbed by the connector. Plug Z Direction +0.25/0mm *Plug side has a floating design. Large Floating Range & Effective Mating Length 2 DF40F Series/Small Floating Board-to-Board Connector, 125ºC Heat Resistance for Automotive 3. Wide Variety of Stacking   Heights by Mating Combination with DF40T Distance Between PCBs Plug DF40F and Receptacle DF40T are used in combination. Stacking Height can be changed by changing receptacle side. Unit : mm - DF40F : 1 Type - DF40T : 6 Types 3.5 4.0 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Distance Between PCBs Stacking Height 3.5 to 3.75mm 4.0 to 4.25mm * 4.5 4.5 to 4.75mm 5.0 5.0 to 5.25mm 5.5 5.5 to 5.75mm 6.0 6.0 to 6.25mm *Stacking Height in Under Planning Stacking Height Variation 4. 125℃ Heat Resistance for Automotive Specifications 5. Supports High Speed Transmission All heights support these standards. PCI- ex Gen. 4 ( 16Gbps) - Pin Assign : GGGSSGSSGGG - Reference Impedance : 85Ω MIPI D- PHY Ver. 1. 1 ( 1. 5Gbps) - Pin Assign : GGSGSGSGSGG - Reference Impedance : 100Ω 3 DF40F Series/Small Floating Board-to-Board Connector, 125ºC Heat Resistance for Automotive Applications It can be used for in- vehicle applications for front cameras, Rear/ Side Cameras, Millimeter- Wave Radar LiDAR and other devices that require misalignment absorption of the substrate by small size floating. It can also be used in devices that require absorption of the substrate misalignment for consumer and industrial equipment. Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Product Specifications Rated Current 0.3A Operating Temperature (Note 1)(Note 2) -55 to +125℃ Rated Voltage 30V AC/DC Storage Temperature (Note 3) -10 to +60℃ Item Specifications Conditions Contact Resistance 90m Ω Max. Measured at 20mV AC, 1kHz, 1mA Insulation Resistance 50M Ω Min. Measured at 100V DC Withstanding Voltage No Flashover or Breakdown 100V AC for 1 min. Mating Durability Contact Resistance : 90m Ω Max. No damage, cracks or part dislocation. 10 times Vibration Resistance There should be no electrical interruption of 1 μ s Min. No damage, cracks or part dislocation. Frequency 10 to 500Hz, Acceleration 49m/s2 Swept speed 1oct/min 8 hours each of 3-axis direction Heat Resistance Contact Resistance : 90m Ω Max. No damage, cracks or part dislocation. Left for 1000 hours at Temperature 125 ± 2℃ Moisture Resistance Contact Resistance : 90m Ω Max. Insulation Resistance : 25M Ω Min. No damage, cracks or part dislocation. Temperature -10 → +65℃ , RH In 90 - 96% Left for 10 cycles (240 hours) Temperature Cycles Contact Resistance : 90m Ω Max. No damage, cracks or part dislocation. Temperature -55℃ : 30min. → +125℃ : 30min., 1000 cycles (Tank transfer time : 2 to 3min.) Solder Heat Resistance No deformation in appearance or significant damage to contacts. Reflow : According to the Recommended Temperature Profile Hand Soldering : 350℃ within 3 sec. Note 1 : Includes the temperature rise due to current flow. Note 2 : Use without condensation. Note 3 : Storage refers to long-term storage of unused items before they are mounted on the PCB.   Operating temperature and humidity range apply when the product is not powered after PCB mounting and when temporarily stored during transportation. Materials/Finish Item Plug DF40F Receptacle DF40T Component Material Color/Finish Insulator LCP Black Contact Copper Alloy Gold Plating (Nickle Underplating) Retention Tab Copper Alloy Gold Plating (Nickle Underplating) Insulator LCP Black Contact Copper Alloy Gold Plating (Nickle Underplating) 4 DF40F Series/Small Floating Board-to-Board Connector, 125ºC Heat Resistance for Automotive Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ■ Plug DF40 F (2.0) - 30 DP - 0.4 V (51) ❶ ❷ ❸  ❹ ❺ ❻ ❼ ❽ Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■ Receptacle DF40 TC (4.0) - 30 DS - 0.4 V (51) ❶ ❷ ❸  ❹ ❺ ❻ ❼ ❽ ❶ Series Name DF40 ❺ Connector Type DP : Double Row Plug DS : Double Row Receptacle ❷ Shape Symbol F : Floating TC : No Retention Tab ❻ Contact Pitch 0.4mm ❸ Stacking Height 3.5, 4.0, 4.5, 5.0, 5.5, 6.0 mm ❼ Contact Type V : Straight SMT Stacking Height is total value of (a) and (b) below. ❽ Packaging Type (51) : Embossed Tape Packaging,       DF40F 3,000pcs/reel      DF40TC 5,000pcs/reel      DF40TC(2.5) 3,000pcs/reel      DF40TC(3.0) 3,000pcs/reel      DF40TC(3.5) 2,000pcs/reel      DF40TC(4.0) 2,000pcs/reel Plug (a) : 2.0 Receptacle (b) : 1.5, 2.0, 2.5, 3.0, 3.5, 4.0 (Note 1) (Note 2) ❹ No. of Pos. 30 (53) : Embossed Tape Packaging,      500pcs/reel (For trial production) Note 1 : (1.5) of the Receptacle will be blank. (e.g. : DF40TC-30DS-0.4V(51)) Note 2 : (2.0) for Receptacle is under planning. 5 DF40F Series/Small Floating Board-to-Board Connector, 125ºC Heat Resistance for Automotive Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Combinations H=3.5mm H=4.0mm H=4.5mm H=5.0mm H=5.5mm H=6.0mm (Note) Unit : mm DF40F(2.0)-30DP-0.4V(##) Stacking Height Receptacle/Plug DF40TC-30DS-0.4V(##)  3.5 DF40TC(2.0)-30DS-0.4V(##) (Note) 4.0 (Note) DF40TC(2.5)-30DS-0.4V(##)  4.5 DF40TC(3.0)-30DS-0.4V(##)  5.0 DF40TC(3.5)-30DS-0.4V(##) 5.5 DF40TC(4.0)-30DS-0.4V(##)  6.0 Note : Stacking Height in Under Planning 6 DF40F Series/Small Floating Board-to-Board Connector, 125ºC Heat Resistance for Automotive DF40F (125℃ Heat Resistant Floating Type) Plug A ±0.2 B ±0.08 C ±0.08 3.32 ±0.2 3.68 ±0.2 0.4 ±0.05 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3.15 ±0.15 Vacuum Pick & Place Area: D ±0.2 ● Recommended PCB Layout B ±0.02 0.88 ±0.02 C ±0.02 +0.05 0 0 -0.05 3.98 2.62 P=0.4 ±0.01 0.22 ±0.02 Pattern Prohibited Area ● Recommended Metal Mask Dimensions B ±0.01 0.88 ±0.02 C ±0.02 3.98±0.01 2.89±0.01 P=0.4 ±0.01 0.22±0.01 Recommended Metal Mask Thickness : 0.12mm, Open Area Ratio : 80% Unit : mm Part No. DF40F(2.0)-30DP-0.4V(##)  HRS No. No. of Pos. A B C D CL0684-4501-0-## 30 9.63 8.53 5.6 1.5 Note : This connector has no polarity. 7 Purchase Unit Purchase Unit (##) : (51) (##) : (53) 3,000pcs per reel 500pcs per reel DF40F Series/Small Floating Board-to-Board Connector, 125ºC Heat Resistance for Automotive DF40T (125℃ Heat Resistant Standard Type) Receptacle (Stacking Height 3.5mm) Vacuum Pick & Place Area : C±0.2 ● Recommended PCB Layout B±0.02 0 -0.05 2.38 1.5MAX +0.05 0 P=0.4±0.02 3.78 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.12±0.02 1.45±0.15 3.38±0.2 2.88±0.2 A±0.2 B±0.08 P=0.4±0.05 0.2±0.02 Pattern Prohibited Area Recommended Metal Mask Thickness : 0.12mm, Open Area Ratio : 80% Unit : mm Part No. HRS No. No. of Pos. A B C DF40TC-30DS-0.4V(##) CL0684-4261-0-## 30 8.6 5.6 1.5 Note : This connector has no polarity. 8 Purchase Unit Purchase Unit (##) : (51) (##) : (53) 5,000pcs per reel 500pcs per reel DF40F Series/Small Floating Board-to-Board Connector, 125ºC Heat Resistance for Automotive DF40T (125℃ Heat Resistant Standard Type) Receptacle (Stacking Height 4.0mm) A±0.2 B±0.08 2.94±0.2 3.38±0.2 P=0.4±0.05 1.95±0.15 Vacuum Pick & Place Area : C±0.2 ● Recommended PCB Layout B±0.02 3.78 +0.05 0 P=0.4±0.02 0 2.38 -0.05 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.12±0.02 0.2±0.02 Recommended Metal Mask Thickness : 0.12mm, Open Area Ratio : 80% Unit : mm Part No. HRS No. No. of Pos. A B C DF40TC(2.0)-30DS-0.4V(##) Under Planning (Note1) 30 8.6 5.6 1.5 Note 1 : Contact positions without HRS No. are currently under planning. Please contact a Hirose representative regarding questions on pin count variation development. Note 2 : This connector has no polarity. 9 Purchase Unit Purchase Unit (##) : (51) (##) : (53) 4,000pcs per reel 500pcs per reel DF40F Series/Small Floating Board-to-Board Connector, 125ºC Heat Resistance for Automotive DF40T (125℃ Heat Resistant Standard Type) Receptacle (Stacking Height 4.5 to 6.0mm) ● Stacking Height 4.5mm A±0.2 B±0.08 Vacuum Pick & Place Area:C±0.2 ● Recommended PCB Layout B±0.02 0 2.38 -0.05 P=0.4±0.02 3.78 +0.05 0 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.12±0.02 2.4±0.15 2.94±0.2 3.38±0.2 P=0.4±0.05 0.2±0.02 Recommended Metal Mask Thickness : 0.12mm, Open Area Ratio : 80% Unit : mm Part No. HRS No. No. of Pos. A B C DF40TC(2.5)-30DS-0.4V(##) CL0684-4266-0-## 30 8.6 5.6 1.5 Note : This connector has no polarity. 10 Purchase Unit Purchase Unit (##) : (51) (##) : (53) 3,000pcs per reel 500pcs per reel DF40F Series/Small Floating Board-to-Board Connector, 125ºC Heat Resistance for Automotive ● Stacking Height 5.0mm A±0.2 B±0.08 2.94±0.2 3.38±0.2 P=0.4±0.05 2.9±0.15 Vacuum Pick & Place Area:C±0.2 ● Recommended PCB Layout B±0.02 0 3.78 +0.05 0 P=0.4±0.02 2.38 -0.05 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.12±0.02 0.2±0.02 Recommended Metal Mask Thickness : 0.12mm, Open Area Ratio : 80% Unit : mm Part No. HRS No. No. of Pos. A B C DF40TC(3.0)-30DS-0.4V(##) CL0684-4242-0-## 30 8.6 5.6 1.5 Note : This connector has no polarity. 11 Purchase Unit Purchase Unit (##) : (51) (##) : (53) 3,000pcs per reel 500pcs per reel DF40F Series/Small Floating Board-to-Board Connector, 125ºC Heat Resistance for Automotive ● Stacking Height 5.5mm A±0.2 3.38±0.2 2.94±0.2 B±0.08 P=0.4±0.05 Vacuum Pick & Place Area:C±0.2 ● Recommended PCB Layout B±0.02 0 3.78 +0.05 0 P=0.4±0.02 2.38 -0.05 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3.4±0.15 0.12±0.02 0.2±0.02 Recommended Metal Mask Thickness : 0.12mm, Open Area Ratio : 80% Unit : mm Part No. HRS No. No. of Pos. A B C DF40TC(3.5)-30DS-0.4V(##) CL0684-4237-0-## 30 8.6 5.6 1.5 Note : This connector has no polarity. 12 Purchase Unit Purchase Unit (##) : (51) (##) : (53) 2,000pcs per reel 500pcs per reel DF40F Series/Small Floating Board-to-Board Connector, 125ºC Heat Resistance for Automotive ● Stacking Height 6.0mm A±0.2 2.94±0.2 3.38±0.2 B±0.08 P=0.4±0.05 Vacuum Pick & Place Area:C±0.2 ● Recommended PCB Layout B±0.02 2.38 0 -0.05 P=0.4±0.02 3.78 +0.05 0 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3.9±0.15 0.12±0.02 0.2±0.02 Recommended Metal Mask Thickness : 0.12mm, Open Area Ratio : 80% Unit : mm Part No. HRS No. No. of Pos. A B C DF40TC(4.0)-30DS-0.4V(##) CL0684-4256-0-## 30 8.6 5.6 1.5 Note : This connector has no polarity. 13 Purchase Unit Purchase Unit (##) : (51) (##) : (53) 2,000pcs per reel 500pcs per reel DF40F Series/Small Floating Board-to-Board Connector, 125ºC Heat Resistance for Automotive Packaging Specifications Diagram (JIS C 0806, IEC 60286-3 Compliant) ■ DF40F Plug F Reel Dimensions F-F 1 φ2 2 ±0.5 12 0° A ±0.2 E 0° 12 D±0.5 F (0.12) C±1 t=0.4 ±0.05 Unreeling Direction E-E 3.43 ±0.15 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. B ±0.1 .8 ±0 E φ1.5 Feed Hole Back φ80 ±1 4 ±0.1 φ380±2 8 ±0.1 0.2 .5 0+0.1 3± φ1 φ1 2 ±0.1 1.75 ±0.1 Embossed Carrier Tape Dimensions Unit : mm Part No. DF40F(2.0)-30DP-0.4V(##)  HRS No. A B C D Purchase Unit (##) : (51) CL0684-4501-0-## 24 11.5 29.5 25.5 3,000pcs per reel 14 Purchase Unit (##) : (53) 500pcs per reel DF40F Series/Small Floating Board-to-Board Connector, 125ºC Heat Resistance for Automotive ■ DF40T Receptacle ● Stacking Height 3.5 to 5.0mm 0° 12 A±0.3 0° 12 φ80±1 0.8 D±0.5 C±1 E 8±0.1 t=0.3±0.1 F E Unreeling Direction E-E G±0.15 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1± φ1.5 Feed Hole Back φ380±2 φ2 B±0.1 .1 0 2±0.5 0.2 +0 Reel Dimensions F-F 13 ± 1.5 F φ φ 4±0.1 2±0.1 1.75±0.1 Embossed Carrier Tape Dimensions Unit : mm HRS No. A B C D G Purchase Unit (##) : (51) Purchase Unit (##) : (53) CL0684-4261-0-## 24 11.5 29.5 25.5 1.65 5,000pcs per reel 500pcs per reel DF40TC(2.0)-30DS-0.4V(##) Under Planning (Note) 24 11.5 29.5 25.5 2.2 4,000pcs per reel 500pcs per reel DF40TC(2.5)-30DS-0.4V(##) CL0684-4266-0-## 24 11.5 29.5 25.5 2.72 DF40TC(3.0)-30DS-0.4V(##) CL0684-4242-0-## 24 11.5 29.5 25.5 3.15 3,000pcs per reel 500pcs per reel Part No. DF40TC-30DS-0.4V(##) Note : Contact positions without HRS No. are currently under planning. Please contact a Hirose representative regarding questions on pin count variation development. 15 DF40F Series/Small Floating Board-to-Board Connector, 125ºC Heat Resistance for Automotive ● Stacking Height 5.5 to 6.0mm Embossed Carrier Tape Dimensions Reel Dimensions F-F φ80±1 φ A±0.3 D±0.5 C±1 E 8±0.1 t=0.4±0.1 F E Unreeling Direction E-E G±0.15 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 12 0° 12 0° B±0.1 0.8 13 ± 1± φ1.5 Feed Hole Back φ380±2 φ2 2±0.5 0.2 F 1.75±0.1 .1 +0 0 1.5 φ 4±0.1 2±0.1 Unit : mm Part No. HRS No. A B C D G DF40TC(3.5)-30DS-0.4V(##) CL0684-4237-0-## 24 11.5 29.5 25.5 3.72 DF40TC(4.0)-30DS-0.4V(##) CL0684-4256-0-## 24 11.5 29.5 25.5 4.22 16 Purchase Unit (##) : (51) Purchase Unit (##) : (53) 2,000pcs per reel 500pcs per reel DF40F Series/Small Floating Board-to-Board Connector, 125ºC Heat Resistance for Automotive TEMPERATURE(℃) Precautions Recommended Temperature Profile 250 250℃ 【Conditions】 220℃ 200 1. Peak Temperature : 250℃ 60sec. Max. 2. Heating : 220℃ Min. for 60 sec. Max. 180℃ 3. Preheating : 150 to 180℃, 90 to 120 sec. 150 150℃ 4. Number of Reflow Cycles : 2 cycles Max. 90-120sec. 100 * Temperature refers to the surface temperature of the board near the connector lead. We recommend reflow mounting in a nitrogen environment. Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 50 Normal Temperature 0 50 100 150 200 250 300 HEATING TIME (sec.) Recommended Manual Soldering Conditions Soldering iron temperature : 340 ± 10℃ , Soldering Time : Within 3 sec. Recommended Metal Mask Thickness and Open Area to PCB Pattern (Area Ratio) Thickness : 0.12mm, Aperture Ratio : Plug 80% / Receptacle 80% Board Warpage Max. of 0.02mm at the center in reference to both ends of the connector Cleaning Cleaning is not recommended. If you clean this product, please evaluate its performance before using it. (Cleaning may impair the mating/unmating properties and lower resistance to environmental factors.) Precautions ・Be careful when mating/unmating the connector when it is not mounted on the PCB as it may cause damage/deformation to contacts. ・Avoid supporting the PCB only with the connectors. Support it by other means such as bolts, screws, posts, etc. ・Excessive prying during unmating/mating may result in damage. ・In the case of hand soldering, please do not apply any flux which could cause flux wicking. ・This product may have slight color differences due to production lot variability, but this does not affect the performance. ・Please refer to the following page for handling precautions when inserting and removing. ・Because the product can disengage if dropped (or other impact), or by FPC routing, it is advised to secure the mated connectors to the board with housings and cushioning materials. ・Do not use the connector in non-recommended conditions (i.e., rated current, rated voltage, PCB design and operating environment, etc.). Such usage could lead to material outgassing, ignition, or short-circuit, etc. Refer to the specifications and guidelines for board pattern dimensions, board cautions, and connector treatment. Please contact Hirose if connector usage in conditions other than those described in the specifications and the guidelines is being considered. 17 DF40F Series/Small Floating Board-to-Board Connector, 125ºC Heat Resistance for Automotive Precautions for Handling During Use ● About Setting The Distance Between PCBs Use within the specified dimensions between PCBs below. Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Specified Dimensions Between PCBs Stacking Height Specified Dimensions Between PCBs Plug 3.5mm 3.5 to 3.75mm DF40TC-30DS-0.4V 4.0mm* 4.0 to 4.25mm DF40TC(2.0)-30DS-0.4V* 4.5mm 4.5 to 4.75mm 5.0mm 5.0 to 5.25mm 5.5mm 5.5 to 5.75mm DF40TC(3.5)-30DS-0.4V 6.0mm 6.0 to 6.25mm DF40TC(4.0)-30DS-0.4V DF40F(2.0)-30DP-0.4V Receptacle DF40TC(2.5)-30DS-0.4V DF40TC(3.0)-30DS-0.4V *Stacking Height in Under Planning ● Securing PCBs This connector can absorb misalignment between PCBs, but not vibration. If you support PCBs only with the connectors without taking any fixing measures, the load on the connectors will be excessive and may cause broken or contact failure. Be sure to secure PCBs except for the connectors as shown below to prevent the board from moving. This connector connects the board to the board. When using mounting to FPC, fasten the board and FPC to the case separately. Fixing PCBs with a Spacer or Case OK Do not use the product without fixing PCBs together. 18 DF40F Series/Small Floating Board-to-Board Connector, 125ºC Heat Resistance for Automotive ● Mating Precautions 1. Mating The alignment dimension is ±0. 3mm in the X and Y directions. After the start of mating, follow the alignment and mate perpendicularly to the board without applying an overloading to the connector. Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ±0.3mm ±0.3mm 2. Misalignment Allowance in Mated Condition ( Floating Range) Because of floating design, this connector has a ±0. 3mm board misalignment tolerance in the X and Y directions when mated. However, it is not suitable for absorption when the range of misalignment constantly changes due to vibration, etc. The number of repetitions of floating movable operations is stipulated to be no more than 10 times. ±0.3mm ±0.3mm 3. Removing When removing the connector, pull it out in parallel. If it is removed in an inclined position, connector may deform. 19 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF40F Series/Small Floating Board-to-Board Connector, 125ºC Heat Resistance for Automotive While Taking into Consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please review the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, the warranty of the product may be affected. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. HIROSE 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com ※ The contents of this catalog are current as of date of 12/ 2023. Contents are subject to change without notice for the purpose of improvements. ※ The HRS logo and "HIROSE" are trademarks of HIROSE ELECTRIC CO., LTD. 20
DF40TC(4.0)-40DS-0.4V(58) 价格&库存
很抱歉,暂时无法提供与“DF40TC(4.0)-40DS-0.4V(58)”相匹配的价格&库存,您可以联系我们找货
    • 1+20.442191+2.64970
    • 10+17.7684010+2.30313
    • 25+17.0159125+2.20559
    • 50+16.6388150+2.15671
    • 100+15.88120100+2.05851
    • 250+14.36923250+1.86253
    • 500+13.23478500+1.71548
    库存:159
    • 1+19.909561+2.58066
    • 10+16.8789210+2.18783
    • 25+15.8249625+2.05122
    • 50+15.0673550+1.95302
    • 100+14.34671100+1.85961
    • 250+13.44813250+1.74314
    • 500+12.80612500+1.65992
    库存:159
    • 1000+14.158941000+1.83527
    • 2000+13.483552000+1.74773
    • 3000+13.103573000+1.69848
    • 5000+12.640245000+1.63842
    • 7000+12.344057000+1.60003
    库存:159
