SFMC-123-03-S-D
SFMC-123-03-S-D
    SAMTEC(申泰)
    .050" X .050 CUTTABLE SOCKET ST
SFMC-123-03-S-D 数据手册
FLEXIBLE PIN COUNT TIGER EYE™ SOCKET 2.9 8 MAX A (1.27 mm) .050" PITCH • SFMC SERIES SFMC Board Mates: TFM Cable Mates: FMTP, FFMD* SFMC -1 NO. PINS PER ROW - m p s LEAD STYLE 02 thru 50 G b p s - PLATING OPTION –01, –03 D - –L = Through-hole *Note: Standard FFMD callout will not mate with FLE, SFMC. Must use gold plated callouts. (See drawing on web.) - –K = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –L1, –L3 = Low Insertion Force Through-hole = (4.00 mm) .157" DIA Polyimide film Pick & Place Pad (4 positions min.) –P = Plastic Pick & Place Pad (5 positions min.) –02 = Surface Mount SPECIFICATIONS PROCESSING –TR –L2 = Tape & Reel = Low Insertion Force Surface Mount Insulator Material: Black Liquid Crystal Polymer Contact Material: Tiger Eye™ = BeCu Tiger Eye™ LITE= Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: 2.9 A per pin (2 pins powered) Voltage Rating: 220 VAC/310 VDC Operating Temp Range: -55 °C to +125 °C Insertion Depth: (3.05 mm) .120" to (4.06 mm) .160" Max Cycles: 10,000 with 30 µ" (0.76 µm) Au –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) –T1 = Through-hole Tiger Eye™ LITE –T2 = Surface Mount Tiger Eye™ LITE (10.00) .394 x (5.72) .225 (1.27) .050 x No. of Positions + (0.38) .015 (3.05) .120 Lead-Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (02-26) (0.15 mm) .006" max (27-50)* *(.004" stencil solution may be available; contact ipg@samtec.com) –P OPTION (4.57) .180 (4.70) .185 A Note: Some lengths, styles and options are non-standard, non-returnable. F-224 (4.19) .165 B ALSO AVAILABLE Other plating (MOQ Required) OPTIONS LEAD STYLE A B –01, –L1, –T1 (3.05) .120 (0.51) .020 –03, –L3 (1.91) .075 (0.41) .016 View complete specifications at: samtec.com?SFMC samtec.com/127mm-TigerEye Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
SFMC-123-03-S-D 价格&库存
很抱歉,暂时无法提供与“SFMC-123-03-S-D”相匹配的价格&库存,您可以联系我们找货
