Product data sheet
02 53 909 1102
har-modular C9 module male straight V1
This product is available upon request. Please contact your local HARTING subsidiary.
Part number
02 53 909 1102
Specification
HARTING eCatalogue
https://b2b.harting.com/02539091102
Image is for illustration purposes only. Please refer to product description.
Identification
Category
Connectors
Series
har-modular®
Identification
C9 module
Element
Male connector
Description of the contact
Straight
Leading contact Position a1
Version
Termination method
Reflow soldering termination (THR)
Wave soldering termination
Connection type
Mezzanine
Signal contacts
9
Contact configuration
Rows a, b and c, positions 1, 2 and 3
Termination length
4.8 mm
Performance level
1
acc. to IEC 60603-2
Technical characteristics
Contact spacing (mating side)
2.54 mm
Rated current
2 A
Clearance distance
1.2 mm
Creepage distance
1.2 mm
Insulation resistance
>1012 Ω
Contact resistance
≤20 mΩ
Page 1 / 4 | Creation date 2020-09-01 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to
the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality,
conformity with applicable laws and directives, as well as for the electrical safety in the particular application.
HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany
Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com
Product data sheet
02 53 909 1102
Limiting temperature
-55 ... +125 °C (during reflow soldering max. +240 °C for 15 s)
Mating cycles
≥500
Isolation group
I (600 ≤ CTI)
Hot plugging
No
Moisture Sensitivity Level (MSL)
1 acc. to ECA/IPC/JEDEC J-STD-020D
Material properties
Material (insert)
Polyamide (PA)
Colour (insert)
Black
Material (contacts)
Copper alloy
Surface (contacts)
Noble metal Mating side
Sn over Ni Termination side
Material flammability class acc. to UL 94
V-0
Length
10.16 mm
Specifications and approvals
Railway classification
F1/I2 acc. to NFF 16-101/102
Commercial data
Packaging size
1
Country of origin
Romania
European customs tariff number
85389099
eCl@ss
27440402 PCB connector
Page 2 / 4 | Creation date 2020-09-01 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to
Product data sheet
02 53 909 1102
Current carrying capacity
Operating current (A)
The current carrying capacity of the connectors is
limited by the thermal load capability of the contact
element material including the connections and the
insulating parts. The derating curve is therefore
valid for currents which flow constantly (nonintermittent) through each contact element of the
connector evenly, without exceeding the allowed
maximum temperature.
Measuring and testing techniques acc. to IEC
60512-5-2
Ambient temperature (°C)
Cross section of solder termination
Quantity of solder paste
Before the components are assembled, solder paste must be applied to all the solder pads (for connecting surfacemount components) and the plated through holes. To ensure that the plated through holes are completely filled,
significantly more solder paste must be applied than traditional solder pads on the pcb surface. There are numerous
calculation methods available which are complicatd to apply. The following rule of thumb has proved valuable in
practice.
Required volume of paste = 2 (Volume of plated through hole - Volume of the connector termination in the hole)
Comment: the multiplier "2" compensates for solder paste shrinkage during soldering. For this purpose, it was
assumed that 50% of the paste consists of the actual solder, the other 50% being soldering aids.
Page 3 / 4 | Creation date 2020-09-01 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to
Product data sheet
02 53 909 1102
Soldering instructions
THR (ThroughHoleReflow) connectors are designed to be used in a reflow oven together with other SMD
(SurfaceMountDevice) components. In the process, called as well "Pin in Hole Intrusive Reflow", the connectors are
inserted into plated through holes in a comparable way to conventional component mounting. All other components
can be assembled on the pcb surface.
The length of the connector contacts should be such that they protrude by no more than 1.5 millimetres after insertion
to the pcb. Each contact collects solder on its tip as it penetrates the solder paster in the hole. So if the contact is
too long, this solder would no longer be able to reflow back into the plated through hole by capillary action during the
soldering process, therefore the quality of the soldered connection would suffer as a result.
The connectors should be protected when being soldered. Otherwise, they might become contaminated as a result of
soldering operations or deformed as a result of overheating.
1) For prototypes and short runs protect the connectors with an industrial adhesive tape, e.g. Tesaband 4331
(www.tesa.de). Cover the underside of the connector moulding and the adjacent parts of the pcb as well as the open
sides of the connector. This will prevent heat and gases of the soldering apparatus from damaging the connector.
About 140 + 5 mm of the tape should suffice.
2) For large series a jig is recommended. Its protective cover with a fast action mechanical locking devie shields the
connectors from gas and heat generated by the soldering apparatus. As an additional protection a foil can be used for
covering the parts that should not be soldered.
3) For prototypes and short runs the protection described under point 1) can be replaced by a solder protection cap.
This cap can be ordered under the part no. 09 02 000 9935.
Page 4 / 4 | Creation date 2020-09-01 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the
很抱歉,暂时无法提供与“02539091102”相匹配的价格&库存,您可以联系我们找货
