09 18 516 6813
09 18 516 6813
    HARTING(浩亭)
    Conn IDC Connector F 16 POS 2.54mm IDT RA Cable Mount
09 18 516 6813 数据手册
SEK IEC 60 603-13 Number of contacts 6--64 Female connector Identification Female connector with central polarization SEK without strain relief clamp without strain relief clamp with bulk packaging  ackaging unit (PU) P 5,000 pieces 3) PU 3,000 pieces 2) with strain relief clamp with strain relief clamp with bulk packaging  ackaging unit (PU) P 3,000 pieces 4) PU 2,500 pieces 5) PU 2,000 pieces 6) PU 1,500 pieces 7) PU 1,000 pieces 3) 08 24 No. of contacts Part No. open end cover 6 10 14 16 20 24 26 30 34 40 50 60 64 09 18 506 09 18 510 09 18 514 09 18 516 09 18 520 09 18 524 09 18 526 09 18 530 09 18 534 09 18 540 09 18 550 09 18 560 09 18 564 803 803 803 803 803 803 803 803 803 803 803 803 803 6 10 14 16 20 26 30 34 40 09 18 506 09 18 510 09 18 514 09 18 516 09 18 520 09 18 526 09 18 530 09 18 534 09 18 540 803 58U2) 803 58U2) 803 58U2) 803 58U2) 803 58U2) 803 58U2) 803 58U2) 803 58U3) 803 58U3) 6 10 14 16 20 24 26 30 34 40 50 60 64 09 18 506 09 18 510 09 18 514 09 18 516 09 18 520 09 18 524 09 18 526 09 18 530 09 18 534 09 18 540 09 18 550 09 18 560 09 18 564 813 813 813 813 813 813 813 813 813 813 813 813 813 6 10 14 16 20 26 30 34 40 09 18 506 09 18 510 09 18 514 09 18 516 09 18 520 09 18 526 09 18 530 09 18 534 09 18 540 813 58U3) 813 58U3) 813 58U4) 813 58U4) 813 58U5) 813 58U6) 813 58U5) 813 58U7) 813 58U7) performance level 3 please specify digit For performance level 2 please specify digit For = 0.76 µm (30 µinch) Au or PdNi eqivalent S4 7 6 5 * Drawing closed end cover 09 18 506 09 18 510 09 18 514 09 18 516 09 18 520 804 804 804 804 804 09 18 526 09 18 530 09 18 534 09 18 540 09 18 550 09 18 560 09 18 564 804 804 804 804 804 804 804 Dimensions in mm closed end cover open end cover option No. 1 contact No. 2 contact Strain relief clamp option Marking No. 1 contact 09 18 506 09 18 510 09 18 514 09 18 516 09 18 520 814* 814* 814* 814* 814* 09 18 526 09 18 530 09 18 534 09 18 540 09 18 550 09 18 560 09 18 564 814* 814* 814* 814* 814* 814* 814* No. of contacts A B No. of contacts A B No. of contacts A B 7 * 6 5 * 6 10 14 20 12.20 17.30 22.40 24.90 30.00 5.08 10.16 15.24 17.78 22.86 24 26 30 34 40 35.18 37.60 42.70 47.80 55.40 27.94 30.48 35.56 40.64 48.26 50 60 64 68.10 80.80 85.90 60.96 73.66 78.74 Pitch tolerance: ± 0.1 * Not normally kept in stock 1) 16
09 18 516 6813 价格&库存
很抱歉,暂时无法提供与“09 18 516 6813”相匹配的价格&库存,您可以联系我们找货
    • 1+14.75280
    • 10+12.51720
    • 30+11.12400
    库存:13
    09185166813
    • 100+13.92702100+1.79670
    • 200+13.31388200+1.71760
    • 500+12.61315500+1.62720
    • 1000+12.175201000+1.57070
    • 1500+11.824831500+1.52550
    • 2000+11.649652000+1.50290
    • 2500+11.562062500+1.49160
    • 5000+11.124105000+1.43510
