Assembly and soldering instructions
DIN signal male connector
with special contacts
The connectors should be protected when being soldered in a dip, flow or film soldering baths. Otherwise, they might become contaminated as a result
of soldering operations or deformed as a result of overheating.
(1) For prototypes and short runs protect the connectors with an industrial adhesive tape, e.g. Tesaband 4331 (www.tesa.de).
Cover the underside of the connector moulding and the adjacent parts of the pcb as well as the open sides of the connector. This will prevent heat and
gases of the soldering apparatus from damaging the connector. About 140 + 5 mm of the tape should suffice.
General information
Design
IEC 60603-2
No. of contacts
78+2, 60+4, 42+6, 24+8, 6+10
(2) For large series a jig is recommended. Its protective cover with a fast action mechanical locking device shields the connectors from gas and heat
generated by the soldering apparatus. As an additional protection a foil can be used for covering the parts that should not be soldered.
types: M male
Contact spacing
2,54 mm for signal contacts
Test voltage
1000V
Contact resistance
< 20 mOhm
Insulation resistance
> 1012 Ohm
2 A@20°C (see derating diagram) for signal contacts
Working current
-55°C … +125°C
Termination technology signal contacts
solder pins
Insertion and withdrawal force
without special contacts
Cross section of solder terminations
for special contacts refer to corresponding data sheet
Temperature range
Clearance & creepage distance
7,62 mm for special contacts
min. 1,2 mm
6pol. ≤ 6N
78pol. ≤ 74N
24pol. ≤ 23N
60pol. ≤ 57N
42pol. ≤ 40N
Mating cycles
- PL1 acc. to IEC 60 603-2 =>
500 mating cycles
- PL2 acc. to IEC 60 603-2 =>
400 mating cycles
- PL3 acc. to IEC 60 603-2 =>
50 mating cycles
UL file
E102079
RoHS - compliant
Yes
Leadfree
Yes
Hot plugging
No
Insulator material
Material
PBT (thermoplastics, glass fiber reinforcement 30%)
Color
RAL 7032 (grey)
UL classification
UL 94-V0
Material group acc. IEC 60664-1
IIIa (175 < CTI < 400)
NFF classification
I3, F4
Contact material
Copper alloy
Plating termination zone signal contacts
Sn over Ni
Plating contact zone signal contacts
Au over PdNi over Ni
Derating diagram acc. to IEC 60512-5 (Current carrying capacity)
The current carrying capacity is limited by maximum
temperature of materials for inserts and contacts including
terminals.
The current capacity curve is valid for continuous, non
interrupted current loaded contacts of connectors when
simultaneous power on all contacts is given, without exceeding
the maximum temperature.
Control and test procedures according to DIN IEC 60512-5
Electrical load [A]
Released / Freigegeben 2011-09-02-13:07:54:807 UTC
Contact material
Date
Temperature [°C]
EC01482
Mod.
Subject to change without prior notice, all rights reserved
Name
Detail.
27/04/11 mte
Inspec.
27/04/11 TD
Stand.
Date
Name
HARTING Electronics GmbH & Co. KG
Technical data sheet
DS 09 03 120 02 02
Page 1 of 1
很抱歉,暂时无法提供与“09031786901”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+83.77413
- 40+78.77931
- 60+76.19206
- 100+73.42514
- 500+68.34647
