Directory chapter 01 – DIN Signal (up to 2 A)
Page
Technical characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
01.10
Type B connectors . . . . . . . . . . . . . . . . . . .
01.11
Type 2B connectors . . . . . . . . . . . . . . . . . .
01.16
Type 3B connectors . . . . . . . . . . . . . . . . . .
01.18
Type C connectors . . . . . . . . . . . . . . . . . . .
01.20
Type 2C connectors . . . . . . . . . . . . . . . . . .
01.27
Type 3C connectors . . . . . . . . . . . . . . . . . .
01.32
Special contacts type M . . . . . . . . . . . . . . .
01.36
Type M connectors . . . . . . . . . . . . . . . . . . .
01.41
Type M-flat connectors . . . . . . . . . . . . . . . .
01.43
Type M invers connectors . . . . . . . . . . . . . .
01.44
Type R, RM, R (HE 11) connectors . . . . . .
01.46
Type Q, 2Q and 2R connectors . . . . . . . . .
01.52
Pin shroud, adapter . . . . . . . . . . . . . . . . . . . . . . . .
01.57
Application examples . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
01.60
DIN Signal
up to 2 A
Types B, 2B, 3B, C, 2C, 3C, M, M invers, Q, 2Q, R, 2R
01
01
Number of contacts
16-96
Current carrying capacity
Contact spacing (mm)
2.54
Working current
2 A max.
1 A with insulation displacement
40 A max. type M
³ 1.2 mm
³ 1.2 mm
The current carrying capacity is limited by maximum temperature of
materials for inserts and contacts including terminals. The current
capacity curve is valid for continuous, non interrupted current loaded
contacts of connectors when simultaneous power on all contacts is
given, without exceeding the maximum temperature.
Clearance
Creepage
Working voltage
Control and test procedures according to DIN IEC 60 512
The working voltage also depends according to the safety regulations
on the clearance and creepage
of the equipment
dimensions of the pcb itself,
Explanations see chapter 00
and the associated wiring
Test voltage Ur.m.s.
Contact resistance
Insulation resistance
1 kV
£ 20 mW
³ 1012 W for standard articles
³ 1011 W for special NFF articles
(with part-no. ending 222)
Temperature range
– 55 °C … + 125 °C
– 40 °C … + 105 °C
for press-in connector
The higher temperature limit
includes the local ambient
and heating effects of the
contacts under load
During reflow soldering
Ambient temperature
max. + 240 °C for 15 s
for SMC connectors
Degree of protection for crimp terminal IP 20
according to DIN 40 050
Electrical termination
Male and female connector
Compliant press-in
terminations
PCB thickness
Recommended PCB holes
for press-in technology
Working current
DIN Signal
up to 2 A
see current carrying
capacity chart
Solder pins for pcb connections
Ø 1.0 ± 0.1 mm
according to IEC 60 326-3
wrap posts 0.6 x 0.6 mm
diagonal 0.79-0.86 mm
Crimp terminal 0.09-0.5 mm²
Insulation displacement
connection AWG 28/7
Pin shroud for female connectors
with 0.6 x 0.6 mm pins
A secure interfacing system for signals from the rear of 19” racks
to connectors with wrap posts 0.6 x 0.6 mm is possible with the
use of a pin shroud.
The pin shroud protects the wrap posts on the rear side of the rack
and can be screwed to the printed circuit board.
After assembly the rear ends of the wire wrap posts become the
mating areas of the type C resp. type 2C male connector.
This system can now accept:
³ 1.6 mm
See recommendation page 00.25
in acc. to EN 60 352-5
female connectors type C
female connectors type 2C
female connectors type R
female connectors type 2R
Insertion and withdrawal force 16way £ 15 N
The locking levers provide security for the mated connectors. Fast
and simple disconnection is possible (see application examples,
pages 01.60 ff.
Materials
Fitting and removing crimp contacts
20way £ 20 N
30way £ 30 N
32way £ 30 N
48way £ 45 N
64way £ 60 N
96way £ 90 N
Mouldings
Contacts
Thermoplastic resin,
glass-fibre filled, UL 94-V0
Copper alloy
Contact surface
Contact zone
01
10
Q, 2Q, R, R (HE 11), 2R
1)
Selectively plated according to
performance level1)
Explanation performance levels see chapter 00
Mating conditions see chapter 00
see technical characteristics chapter 02
DIN 41 612 · Type B
Number of contacts
64, 32
Identification
Number
Contact
of contacts arrangement
Male connector
with angled
solder pins
SMC
Male connector
with straight
solder pins
SMC
Part No.
Performance levels according to IEC 60 603-2. Explanation chapter 00
3
2
1
09 02 164 7921
64
09 02 164 6921
09 02 164 6921 222f)
b)09 02 364 6921b)
c)09 02 664 6921c)
09 02 164 2921
32
09 02 132 7921
c)09
32
09 02 132 7931
b)09
09 02 132 6921
02 632 6921c)
09 02 132 2921
09 02 132 6931
02 332 6931b)
09 02 132 2931
09 02 164 2922
09 02 164 2952
62 + 2▲
09 02 164 6951
64
09 02 164 7919d)
09 02 164 6919d)
64
09 02 164 7922
09 02 164 6922
32
09 02 132 7922
09 02 132 6922
32
09 02 132 6932
62 + 2▲
09 02 164 6952
09 02 164 6920d)
64
DIN Signal
up to 2 A
Male connectors
Dimensions
Angled
solder pins
Straight
solder pins
Cross section of solder
terminations
Board drillings
Mounting side
Cross area (A) of contacts row a, b:
A = 0.29 - 0.33 mm²
Dimensions in mm
ale connectors with 2 leading contacts [(0.8 mm) pos. a1 and
M
a32]. Lagging pins row b on request.
Other contact arrangements on request
b) Connectors with snap-in clips see chapter 00
c)
Connectors with coding see chapter 00
d) CTI > 400
f) Railway classification
Flammability class: I2
NFF 16-101, Smoke index: F1,
01
11
DIN 41 612 · Type B
Number of contacts
64
DIN Signal
up to 2 A
Female connectors
Identification
Number
Contact
Female connector
with solder pins
2.9 mm
SMC
Female connector
with solder pins
4.5 mm
SMC
Female connector
with solder pins
13 mm
Female connector
with press-in pins
4.5 mm
1)
a)
b)
c)
3
64
2
09 02 264 6824
02 464 6824b)
c)09 02 764 6824c)
1
09 02 264 2824
b)09
64
09 02 264 6841d)
64
09 02 264 6825
09 02 264 6825 222f)
09 02 464 6825b)
09 02 764 6825c)
64
09 02 264 6829d)
64
09 02 264 6421
09 02 264 2825
Performance level 3
on request
64
09 02 264 6850
09 02 264 6850 222f)
64
09 02 264 6870
Female connector
with press-in pins
13.2 mm
64
09 02 264 6861a)
Female connector
with wrap posts1)
13 mm
64
09 02 264 6821
Female connector
with solder lugs
5.2 mm
64
09 02 264 6823
Female connector
with press-in pins
without flange
5.3 mm
01
12
Part No.
To be used only for wire wrap termination
Wrap posts selectively gold plated (performance level 3)
09 02 264 2850
CTI > 400
ailway classification NFF 16-101, Smoke index: F1,
R
d)
f)
DIN 41 612 · Type B
Number of contacts
64
Identification
Drawing
Dimensions in mm
Dimensions
a
2.9
4.5
13
4.5
5.3
13.2
13
5.2
2,9 - 0,5
8,1 - 0,2
row
DIN Signal
up to 2 A
Female connectors
Solder pins
Press-in pins
Wrap posts
Solder lugs
position
Panel cut out
Board drillings
all holes
Y
position
Solder
Mounting side
Press-in
Y
1 ± 0.1
see recommendation
page 00.25
row
Identification strips for female connectors with wrap posts 09 02 000 9939
Cross section of
solder terminations
Q
P
a
2.9
4.5
13
P
0.75–0.05
0.75–0.05
0.60–0.02
Q
0.30±0.01
0.30±0.01
0.60–0.02
A
0.20 - 0.23 mm²
0.20 - 0.23 mm²
0.33 - 0.38 mm²
01
13
DIN 41 612 · Type B
Number of contacts
64
DIN Signal
up to 2 A
Female connectors
Identification
Number
of contacts
Part No.
Drawing
Dimensions in mm
Female connector
for insulation
displacement
Cable 1
64
Performance level
09 02 264 6828
Performance level 31)
09 02 264 7828
21)
Cable 1
Cable 1 to contact 1 b
Contact arrangement
Strain relief (metal)
View from termination side
09 03 000 9940
Panel cut out
grey
Flat cable
2)
AWG 28/7
30.48 m
grey
100.00 m
grey
30.48 m
colour
coded
30.48 m
twisted
pair2)
64
64
64
64
09 18 064 7001
09 18 064 7004
09 18 064 7005
09 18 064 7006
Important: always
store reels vertically
Wire (tinned)
Cu
Gauge
AWG 28/7
Insulation material as per UL style PVC
Round flat cable3)
64
64
09 18 064 7007
09 18 064 7010
30.48 m
without
screening
100.00 m
64
64
09 18 064 7008
09 18 064 7011
Bench
press
Base
plate
01
14
3)
30.48 m
with
screening
100.00 m
09 99 000 0114
09 99 000 0150
Cable cutter
Spare parts
Blade
Cutting plate
ermination area
T
spacing = 508 mm
Edge mark on
first conductor
AWG 28/7
09 99 000 0116
09 99 000 0179
09 99 000 0180
Further components and accessories for insulation displacement see interface catalogue, chapter 40
1) acc. to IEC 60 603-2
0.089 mm²
ermination area
T
spacing = 100 mm
grey
DIN 41 612 · Type B
Number of contacts
max. 64
Identification
Number
of contacts
Part No.
Drawing
Dimensions in mm
Female connector
for crimp contacts
DIN Signal
up to 2 A
Female connectors
Order contacts
separately
64
09 02 064 3214f)
Contact arrangement
Shell housing 09 02 064 0501 / 09 02 064 0502 see chapter 20
Part No.
Identification
2
1
Female crimp
contacts BC
Bandoliered contacts
(approx. 5,000 pieces)
09 02 000 6484
09 02 000 6474
(approx. 500 pieces)
09 02 000 8434
09 02 000 8444
Individual contacts1)
09 02 000 8484
09 02 000 8474
Wire gauge
mm²
AWG
Insulation ø
mm
0.09 - 0.5
0.7 - 1.5
28 - 20
Bandoliered
contacts
3.5 + 0.5 mm of insulation is stripped from the wires
to be crimped
For the fabrication in line with the specification please Individual contacts
use exclusively crimp tools approved by HARTING
(see DIN EN 60 352-2)
Insertion, removal and crimping tools see chapter 30
1)
f)
Packaging unit 1,000 pieces
ailway classification NFF 16-101, Smoke index: F1, Flammability class: I2
R
01
15
DIN 41 612 · complementary type 2B
Number of contacts
32, 16
DIN Signal
up to 2 A
Male connectors
Part No.
3
Identification
Number
Contact
Male connector
with angled
solder pins
09 22 132 7921
32
SMC
Male connector
with straight
solder pins
SMC
32
2
1
09 22 132 6921
09 22 132 6921 222f)
b)09 22 332 6921b)
09 22 132 2921
b)
09 22 132 6919d)
09 22 332 6919b)d)
16
09 22 116 6921
16
09 22 116 6931
09 22 116 7931
30 + 2▲
09 22 132 6951
32
09 22 132 6922
32
09 22 132 7922
09 22 132 2922
09 22 132 6920d)
Dimensions
row
position
Angled
solder pins
Board drillings
all holes
Mounting side
position
row
01
16
Straight
solder pins
Cross section of
solder terminations
row a, b: A = 0.29 - 0.33 mm²
Dimensions in mm
M
a16]. Lagging pins row b on request.
d) CTI > 400
R
f)
Number of contacts
32
Identification
Number
Contact
Female connector
with solder pins
2.9 mm
Part No.
3
2
b)09
SMC
32
32
SMC
32
32
09 22 232 6825
09 22 232 6825 222f)
b)09 22 432 6825b)
09 22 232 6829d)
4.5 mm
13 mm
Female connector
with wrap posts1)
13 mm
Female connector
with press-in pins
4.5 mm
1
DIN Signal
up to 2 A
Female connectors
09 22 232 6824
22 432 6824b)
09 22 232 6841d)
Performance level 3
on request
32
09 22 232 6421
32
09 22 232 6821
32
09 22 232 6850
Performance level 1
on request
Dimensions
2,9 - 0,5
8,1 - 0,2
row
a
2.9
4.5
13
13
4.5
position
Board drillings
Mounting side
all holes
Y
Solder
position
Press-in
Solder pins
Wrap posts
Press-in pins
Y
1 ± 0.1
see recommendation
page 00.25
row
Cross section
of solder terminations
see page 01.13
d) CTI > 400
1)
b)
Dimensions in mm
R
f)
01
17
DIN 41 612 · complementary type 3B
Number of contacts
DIN Signal
up to 2 A
Male connectors
Identification
Number
Contact
Part No.
3
2
1
Male connector
with angled
solder pins
with fixing flange
with fixing flange, SMC
09 24 120 6919d)
without fixing flange
Performance level 3
on request
without fixing flange, SMC
09 24 120 6579d)
Dimensions
with fixing flange
Performance level 1
on request
09 24 120 6571
row
mounting hole center line
position
Board drillings
Cross section of
solder terminations
all holes
Mounting side
position
row
01
18
Dimensions in mm
d)
CTI > 400
Number of contacts
Identification
Number
Contact
Part No.
3
2
1
Female connector
with solder pins 2.9 mm
with fixing flange
09 24 220 6841d)
09 24 220 6414d)
Female connector
with solder pins 4.5 mm
with fixing flange
Performance level 3
on request
DIN Signal
up to 2 A
Female connectors
Performance level 1
on request
with fixing flange
Female connector with
press-in pins 4.5 mm
Dimensions
with fixing flange
row
a
2.9
solder pins
4.5
4.5 press-in pins
position
Board drillings
Mounting side
all holes
Y
position
Solder
Press-in
Y
1 ± 0.1
see
recommendation
page 00.25
Cross section of
solder terminations
row
row a, b, c: A = 0.20 - 0.23 mm²
Dimensions in mm
d)
CTI > 400
01
19
DIN 41 612 · Type C
Number of contacts
96, 64, 32
DIN Signal
up to 2 A
Male connectors
Part No.
3
Identification
Number
Contact
Male connector
with angled
solder pins
09 03 196 7921
b)09 03 396 7921b)
96
96
09 03 164 7921
64
b)09 03 364 7921b)
SMC
64
32
94 + 2
SMC
94
09 03 132 7921
03 332 7921b)
b)09
09 03 196 7951
+ 2▲
62 + 2▲
SMC
Male connector
with straight
solder pins
SMC
01
09 03 196 2921 222f)
b)09 03 396 2921b)
c)09 03 696 2921c)
09 03 164 6921
09 03 164 6921 222f)
b)09 03 364 6921b)
c)09 03 664 6921c)
09 03 132 6921
03 332 6921b)
09 03 164 2921
09 03 164 2921 222f)
b)09 03 364 2921b)
c)09 03 664 2921c)
b)09
09 03 196 6951
03 396 6951b)
09 03 196 2919d)
09 03 396 2919b)d)
09 03 164 2919d)
09 03 364 2919b)d)
09 03 132 2921
03 332 2921b)
b)09
09 03 196 2951
b)09
09 03 396 6918b)d)
09 03 164 7951
09 03 164 6951
62 + 2▲
96
09 03 196 7922
96
09 03 196 6920d)
64
09 03 164 6922
09 03 164 7922
M
c) Connectors with coding see chapter 00
09 03 196 6921
09 03 196 6921 222f)
b)09 03 396 6921b)
c)09 03 696 6921c)
09 03 696 6921 222c)f)
09 03 164 6919d)
09 03 364 6919b)d)
1
09 03 196 6919d)
09 03 396 6919b)d)
09 03 696 6919c)d)
SMC
2
d)
f)
09 03 196 6922
09 03 164 2951
09 03 164 2918d)
09 03 196 2922
09 03 164 2922
CTI > 400
R
DIN 41 612 · Type C
Number of contacts
96, 64, 32
DIN Signal
up to 2 A
Male connectors
Dimensions
Straight
solder pins
Angled
solder pins
Board drillings
all holes
position
Mounting side
row
Cross section
of solder
terminations
Cross area (A) of contacts row a, b, c: A = 0.29 - 0.33 mm²
1)
Recommendation for variants with clip: Drillings can be enlarged up to 3.1 mm ø to reduce standard mounting force
Dimensions in mm
01
21
DIN 41 612 · Type C
Number of contacts
96, 64, 32
DIN Signal
up to 2 A
Female connectors
3
Number
Contact
Female connector
with solder pins
2.9 mm
09 03 296 7824
96
09 03 296 6824
09 03 296 6824 222f)
09 03 496 6824b)
09 03 796 6824c)
09 03 296 6841d)
SMC
SMC
Female connector
with kinked
solder pins1)
2.9 mm
Female connector
with solder pins
4.5 mm
SMC
SMC
Female connector
with kinked
solder pins1)
4.5 mm
Female connector
with solder pins
13 mm
01
22
Part No.
Identification
96
b)
1
09 03 296 2824
09 03 496 2824b)
09 03 264 7824
64
09 03 264 6824
09 03 264 6824 222f)
09 03 464 6824b)
09 03 764 6824c)
64
09 03 264 6841d)
32
09 03 232 7824
09 03 232 6824
09 03 232 2824
96
09 03 296 7855
09 03 296 6855
09 03 296 2855
64
09 03 264 7855
09 03 264 6855
09 03 264 2855
32
09 03 232 7855
09 03 232 6855
09 03 232 2855
09 03 296 7825
09 03 296 2825
09 03 296 2825 222f)
09 03 296 6825
09 03 296 6825 222f)
09 03 496 6825b)
09 03 796 6825c)
09 03 796 6825 222c)f)
09 03 296 6829d)
b)09 03 496 7825b)
96
96
09 03 264 2824
09 03 464 2824b)
09 03 796 2825c)
09 03 264 7825
b)09 03 464 7825b)
64
09 03 264 6825
09 03 464 6825b)
09 03 764 6825c)
64
09 03 264 6829d)
32
09 03 232 7825
09 03 232 6825
09 03 232 2825
96
09 03 296 7845
09 03 296 6845
09 03 296 2845
64
09 03 264 7845
09 03 264 6845
09 03 264 2845
32
09 03 232 7845
09 03 232 6845
09 03 232 2845
96
09 03 296 6421
09 03 796 6421c)
64
09 03 264 6421
09 03 764 6421c)
32
09 03 232 6421
09 03 732 6421c)
Kinked pins for fixing the connector onto the pcb see chapter 00
1)
2
d) CTI > 400
09 03 264 2825
DIN 41 612 · Type C
Number of contacts
96, 64, 32
Identification
Drawing
Dimensions in mm
Dimensions
DIN Signal
up to 2 A
Female connectors
2,9 - 0,5
10,6 - 0,2
row
position
a
b
2.9 2.75
4.5 4.35 Solder pins
13 –
b=
^ Length of kinked pins
Board drillings
all holes
position
Mounting side
row
Cross section of
solder terminations
Q
P
a
2.9
4.5
13
P
0.75–0.05
0.75–0.05
0.60–0.02
Q
0.30±0.01
0.30±0.01
0.60–0.02
A
0.20 - 0.23 mm²
0.20 - 0.23 mm²
0.33 - 0.38 mm²
Dimensions in mm
01
23
DIN 41 612 · Type C
Number of contacts
96, 64, 32
DIN Signal
up to 2 A
Female connectors
Identification
Number
Contact
Female connector
Type C
with press-in terminations
4.5 mm
13.2 mm
17 mm
Part No.
3
2
1
09 03 296 7850
96
09 03 296 6850
09 03 296 6850 222f)
09 03 796 6850c)
09 03 796 6850 222c)f)
09 03 296 2850
09 03 296 2850 222f)
64
09 03 264 7850
09 03 264 6850
09 03 264 2850
32
09 03 232 7850
09 03 232 6850
09 03 232 2850
96
09 03 296 6851
09 03 296 6861l
64
09 03 264 6851
09 03 264 6861l
96
09 03 296 6852
09 03 296 6862l
Dimensions
2,9 - 0,5
10,6 - 0,2
row
position
Board drillings
Mounting side
all holes
1)
a
4.5
13.2 Press-in pins
17
position
row
01
24
Dimensions in mm
rap posts for interfacing selectively gold plated
W
1) refer to recommended configuration of pcb holes, see page 00.25
l
c)
f)
R
DIN 41 612 · Type C
Number of contacts
96, 64
Part No.
3
Identification
Number
Contact
Female connector
with wrap posts2)
13 mm
96
09 03 296 6821
03 796 6821c)
2)09 03 296 68781)
64
Performance level 3
on request
09 03 264 6821
09 03 764 6821c)
2)09 03 264 68781)
Female connector
with solder lugs
a + c 5.2 mm
b
7.7 mm
Dimensions
2
1
c)09
96
09 03 296 6823
09 03 796 6823c)
64
09 03 264 6823
09 03 764 6823c)
wrap posts
DIN Signal
up to 2 A
Female connectors
Performance level 1
on request
solder lugs
wrap posts
row
solder lugs
position
Panel cut out
09 03 000 9939
Dimensions in mm
Wrap posts for interfacing, selectively gold-plated (performance level 3)
To be used only for wire wrap termination. Solder versions see page 01.22
1)
2)
01
25
DIN 41 612 · Type C
Number of contacts
64
DIN Signal
up to 2 A
Female connectors
Identification
Number
of contacts
Part No.
Drawing
Dimensions in mm
Female connector
for insulation
displacement
64
Performance level 21)
09 03 264 6828
c)09 03 764 6828c)
Cable 1
09 03 264 7828
Cable 1
Cable 1 to contact 1 c
09 03 000 9940
Contact arrangement
Panel cut out
Mateable with 3 row male connector type C,
no female contacts in the middle row
grey
Flat cable
2)
AWG 28/7
grey
30.48 m
grey
100.00 m
colour
coded
30.48 m
)twisted
pair2)
30.48 m
64
64
64
64
09 18 064 7001
09 18 064 7004
09 18 064 7005
09 18 064 7006
Edge mark
on first conductor
01
26
3)
64
64
09 18 064 7007
09 18 064 7010
without
30.48 m
screening
100.00 m
64
64
09 18 064 7008
09 18 064 7011
Bench
press
Base
plate
Important: always
Wire (tinned)
Cu
Gauge
AWG 28/7
Round flat cable3)
with
30.48 m
screening
100.00 m
09 99 000 0114
09 99 000 0150
Cable cutter
Spare parts
Blade
Cutting
plate
ermination area
T
spacing = 508 mm
Edge mark on
first conductor
AWG 28/7
09 99 000 0116
09 99 000 0179
09 99 000 0180
0.089 mm²
ermination area
T
spacing = 100 mm
grey
DIN 41 612 · Type C, 2C
Number of contacts
max. 96, 48
Identification
Number
of contacts
Part No.
Drawing type C
Dimensions in mm
Female connector
for crimp contacts
DIN Signal
up to 2 A
Female connectors
Order contacts
separately
Type C
96
Type C
c)
96
09 03 096 3214f)
09 03 596 3214c)f)
f)09
03 096 3217f)
Position marking turned
for mating type R male
row
position
Type 2C
48
09 23 048 3214f)
Type 2C
48
09 23 048 3217f)
Contact arrangement
for mating type 2R male
Shell housing see chapter 20
Part No.
Identification
2
1
Female crimp
contacts BC
(approx. 5 ,000 pieces)
09 02 000 6484
09 02 000 6474
09 02 000 8434
09 02 000 8444
09 02 000 8484
09 02 000 8474
Wire gauge
mm²
AWG
Insulation ø
mm
0.09 - 0.5
0.7 - 1.5
28 - 20
Bandoliered
contacts
to be crimped
f) Railway classification NFF 16-101, Smoke index: F1, Flammability class: I2
c)
1)
01
27
DIN 41 612 · complementary type 2C
Number of contacts
48, 32, 16
DIN Signal
up to 2 A
Male connectors
Identification
Number
Contact
Male connector
with angled
solder pins
SMC
SMC
SMC
SMC
3
2
1
09 23 148 7921
48
b)09 23 348 7921b)
09 23 148 6921
09 23 148 6921 222f)
09 23 348 6921b)
09 23 148 2921
09 23 148 7919
48
09 23 148 6919d)
09 23 348 6919b)d)
09 23 148 2919d)
09 23 348 2919b)d)
32
09 23 132 6921
09 23 332 6921b)
09 23 132 2921
09 23 132 6919d)
09 23 332 6919b)d)
09 23 132 2919d)
09 23 332 2919b)d)
09 23 132 7921
23 332 7921b)
b)09
32
Male connector
with straight
solder pins
Part No.
16
09 23 116 2921
09 23 116 7931
16
09 23 116 6931
09 23 316 6931b)
09 23 116 2931
09 23 148 7951
46 + 2▲
09 23 148 6951
09 23 348 6951b)
09 23 148 2951
48
09 23 148 6922
09 23 148 2922
48
09 23 148 6920d)
32
09 23 132 6922
32
09 23 148 7922
09 23 132 7922
09 23 132 2922
09 23 132 6920d)
01
28
M
d) CTI > 400
Number of contacts
48, 32, 16
Identification
Drawing
Dimensions in mm
Dimensions
DIN Signal
up to 2 A
Male connectors
row
position
Angled
solder pins
Board drillings
Straight
solder pins
all holes
Mounting side
position
row
Cross section
of solder
terminations
1)
01
29
Number of contacts
48, 32
DIN Signal
up to 2 A
Female connectors
Identification
Number
Contact
Female connector
with solder pins
2.9 mm
SMC
SMC
Female connector
with solder pins
4.5 mm
3
2
1
48
09 23 248 6824
09 23 248 6824 222f)
09 23 448 6824b)
09 23 248 2824
48
09 23 248 6841d)
32
09 23 232 6824
09 23 432 6824b)
09 23 232 6841d)
32
48
09 23 248 6825
09 23 248 6825 222f)
09 23 448 6825b)
48
09 23 248 6829d)
32
32
09 23 232 6829d)
Female connector
with solder pins
13 mm
48
09 23 248 6421
Female connector
with press-in pins
3.7 mm
48
09 23 248 6866
SMC
SMC
Female connector
with press-in pins
4.5 mm
01
30
Part No.
09 23 232 7825
09 23 232 6825
48
09 23 248 6850
09 23 248 6850 222f)
32
09 23 232 6850
Female connector
with wrap posts1)
13 mm
48
09 23 248 6821
Female connector
with solder lugs
5.2 mm
32
09 23 232 6823
1) To be used only for wire wrap termination
09 23 248 2825
d) CTI > 400
09 23 248 2850
Number of contacts
48, 32
Identification
Number
Contact
Part No.
3
2
1
Dimensions
2,9 - 0,5
10,6 - 0,2
DIN Signal
up to 2 A
Female connectors
row
a
2.9
4.5
13
3.7
4.5
13
5.2
position
Solder pins
Press-in pins
Wrap posts
Solder lugs
Board drillings
Mounting side
all holes
Solder
Y
Press-in
position
Y
1 ± 0.1
see recommendation
page 00.25
row
Cross section of
solder terminations
Q
P
a
2.9
4.5
13
P
0.75–0.05
0.75–0.05
0.60–0.02
Q
0.30±0.01
0.30±0.01
0.60–0.02
A
0.20 - 0.23 mm²
0.20 - 0.23 mm²
0.33 - 0.38 mm²
Dimensions in mm
01
31
DIN 41 612 · complementary type 3C
Number of contacts
30, 20
DIN Signal
up to 2 A
Male connectors
Identification
Number
Contact
Part No.
3
2
1
Male connector
with angled
solder pins
with fixing flange
30
09 25 130 6921
30
09 25 130 6919d)
30
09 25 130 6571
30
09 25 130 6579d)
Performance level 3
on request
Performance level 1
on request
Male connector
with straight
solder pins
30
09 25 130 6922
30
09 25 130 6572
30
09 25 130 6590d)
with fixing flange
01
32
d)
CTI > 400
Number of contacts
30, 20
Identification
Dimensions
Drawing
with
fixing flange
Dimensions in mm
without
fixing flange
angled solder pins
straight solder pins
DIN Signal
up to 2 A
Male connectors
row
position
Board drillings
all holes
Mounting side
position
row
Cross section of
solder terminations
01
33
Number of contacts
30, 20
DIN Signal
up to 2 A
Female connectors
Identification
Number
Contact
Part No.
3
2
1
Female connector
with solder pins
2.9 mm
30
09 25 230 6824
30
09 25 230 6841d)
30
09 25 230 6414d)
with fixing flange
Female connector
with solder pins
4.5 mm
with fixing flange
Performance level 3
on request
Performance level 1
on request
30
09 25 230 6825
with fixing flange
30
09 25 230 6850
30
09 25 230 6870
press-in pins
4.5 mm
01
34
d)
CTI > 400
Number of contacts
30, 20
Identification
Dimensions in mm
with fixing flange
a
Dimensions
Drawing
DIN Signal
up to 2 A
Female connectors
row
a
2.9
solder pins
4.5
4.5 press-in pins
position
Board drillings
Mounting side
all holes
Solder
Y
Press-in
Y
1 ± 0.1
see recommendation
page 00.25
position
row
Cross section of
solder terminations
Cross area (A) of contacts row a, b, c: A = 0.20 - 0.23 mm²
01
35
DIN 41 612 · Special contacts type M
Application matrix Coax Contacts
l
High Voltage Contacts
FOC- Contacts
l
l
Board to Backplane
1.
M male
& M female
DIN Signal
up to 2 A
Connector
M male
& M flat
female
3.
4.
MH 21+ 5
male
M invers
& MH 21+ 5
male
female
& M female
5.
M invers
male
& M flat
female
Part number
Male connector type M angled
09 03 1XX X901
Female connector type M straight
09 03 2XX 6804
09 03 2XX 6805
09 03 2XX 6850
Female connector type M flat
09 03 2XX 6864
09 03 2XX 6865
09 03 2XX 6830
Male connector type MH 21+5
09 06 X21 6883
Female connector type MH 21+5
09 06 121 6981
Male connector type M invers
09 73 1XX 6902
09 73 1XX 6903
09 73 1XX 6904
09 73 1XX 6907
09 73 1XX 6974
09 73 1XX 6985
Impedance
Termination
Part number
50 Ω
cable
solder/crimp
09 03 000 6160
50 Ω
cable
solder/crimp
09 03 000 6161
50 Ω
pcb
solder
09 03 000 6165
50 Ω
cable
solder
09 03 000 6167
75 Ω
cable
solder/crimp
09 03 000 6181
50 Ω
pcb
solder
09 03 000 6182
50 Ω
cable
solder/crimp
09 03 000 6260
50 Ω
cable
solder/crimp
09 03 000 6261
50 Ω
pcb
solder
09 03 000 6262
50 Ω
pcb
solder
09 03 000 6263
75 Ω
pcb
solder
09 03 000 6269
50 Ω
cable
solder/crimp
09 03 000 6274
75 Ω
cable
solder/crimp
09 03 000 6281
High voltage 1.5 KV
FOC ceramic ferrule*
FOC for SI-fibre (HCS)*
01
36
2.
Mezzanine
FOC for 1 mm (POF)*
09 03 000 6140
09 03 000 6240
20 10 125 4212
20 10 125 4222
20 10 230 4211
20 10 230 4221
20 10 001 4211
20 10 001 4221
l = can be used in male connector
= male connector for l contacts
* details see catalogue Industrial Connectors Han®
u
u
u
u
u
l
l
l
l
l
l
l
l
u
l
u
l
u
l
u
u
l
l
l
l
l
u
u
u
u
l
l
l
l
l
l
l
l
u
l
u
l
u
l
u
u = can be used in female connector
= female connector for u contacts
u
u
u
u
l
l
u
l
l
l
l
l
l
u
l
u
l
u
l
u
Application matrix High Power Contacts
l
Board to Backplane
1.
M male
& M female
4.
5.
M invers
male
& M flat
female
Part number
09 03 1XX X901
09 03 2XX 6804
09 03 2XX 6805
09 03 2XX 6850
09 03 2XX 6864
09 03 2XX 6865
09 03 2XX 6830
09 06 X21 6883
09 06 121 6981
09 73 1XX 6902
09 73 1XX 6903
09 73 1XX 6904
09 73 1XX 6907
09 73 1XX 6974
09 73 1XX 6985
Currency
M male
& M flat
female
3.
MH 21+ 5
male
M invers
& MH 21+ 5
male
female
& M female
Termination
Preleading
Part number
10 A
cable
solder
09 03 000 6101
20 A
cable
solder
09 03 000 6102
40 A
cable
solder
09 03 000 6103
40 A
pcb
solder
09 03 000 6104
40 A
pcb
solder
09 03 000 6110
10 A
cable
solder
0.8
09 03 000 6111
10 A
cable
crimp
09 03 000 6113
20 A
cable
crimp
09 03 000 6114
40 A
cable
crimp
09 03 000 6115
20 A
cable
solder
0.8
09 03 000 6122
40 A
pcb
solder
09 03 000 6127*
40 A
pcb
solder
1.8
09 03 000 6128*
40 A
cable
solder
0.8
09 03 000 6133
40 A
pcb
solder
0.6
09 03 000 6134
10 A
cable
solder
09 03 000 6201
20 A
cable
solder
09 03 000 6202
40 A
cable
solder
09 03 000 6203
10 A
cable
crimp
09 03 000 6213
20 A
cable
crimp
09 03 000 6214
40 A
cable
crimp
09 03 000 6215
20 A
cable
crimp
09 03 000 6220*
40 A
pcb
solder
09 03 000 6225
40 A
busbar
screw
09 03 000 6245
40 A
pcb
press-in
09 03 000 6250
* see also chapter 04
DIN Signal
up to 2 A
Steckverbinder
2.
Mezzanine
l l
l l
l l
l l
l l
l l
l l
l l
l l
l l
l l
l
l l
l l
u
u
u
u
u
u
u
u
l
l
l
l
l
l
l
l
l
l
l
l
l
u
u
l
l
l
l
l
l
l
l
l
l
l
l
l
l
u
u
u
u
u
u
u
u
l
l
l
l
l
l
l
l
l
l
l
l
l
l
l
l
l
u
u
u
u
u
u
u
u
l
u
u
01
37
I
II + V
DIN Signal
up to 2 A
Coaxial contacts
Identification
Part No.
Performance level 1
Male coaxial contacts
I
for straight solder
and/or crimp termination
II
for angled solder
III
III
VI
IV
Drawing
Dimensions in mm
acc. to DIN 41 626
09 03 000 6160
03 000 61811)
1)09
09 03 000 6161
I
for straight pcb termination
for type M-flat
09 03 000 6182
III
for type M
09 03 000 6165
II
x
x
6165 16.05
6182 14.2
Female coaxial contacts
for male connectors
IV
for straight solder
09 03 000 6260
03 000 62811)
2)09 03 000 62742)
V
for angled solder
09 03 000 6261
VI
angled for pcb termination
1)09
09 03 000 6262
03 000 62691)
1)09 03 000 62632)
1)09
Assembly instruction
for contacts
I
IV
and
V
VI
for contacts
IV
II
solder
and
V
solder
crimp
solder
crimp
solder
01
38
Coaxial contact 75 Ω
With knurled area for permanent fixing, not removable
Fibre optic contacts on request
1)
2)
Insert insulator,
solder closing-washer
I
II
III
IV
Identification
Part No.
Performance level 1
Dimensions in mm
acc. to DIN 41 626
High voltage male contact
for male connectors2)
I
Drawing
for straight solder
2.8 kV
termination
DIN Signal
up to 2 A
High voltage contacts
09 03 000 6140
High voltage female contact
for female connectors2)
II
for straight solder
2.8 kV
termination
09 03 000 6240
Crimping tool
for
coaxial contacts
09 99 000 0194
Crimping tool
for high current contacts
09 99 000 0196
Removal tool
III
incl. removal jacket
for contact replacement
in
male and female connectors
09 99 000 0174
Replacement removal jacket
09 99 000 0243
Removal tool
IV
in
male connectors
Electrical characteristics
of coaxial contacts
and wires
09 99 000 0328
Impedance
Max. working frequency
Return loss
RF-leakage
Test voltage
Working voltage
Contacts resistance – Center contact
– Outer contact
Contact current max.
Admissible power (depends on: frequency, application, return loss, environmental characteristics)
Cable group 2
flexible wires
RG 174 A/U
RG 188 A/U
RG 316 U
RG 179 B/U
1)
2)
Contact resistance max. 1.5 mΩ
Contact resistance internal wire max. 3 mΩ
Impedance
50 Ω
50 Ω
50 Ω
75 Ω
Shell
ø
2.5
2.6
2.5
2.54
50 Ω
75 Ω
0 up to 10 GHz
0 up to 1.5 GHz
³ 20 dB up to 6 GHz
³ 20 dB
³ 80 dB up to 0.5 GHz
³ 68 dB up to 1.5 GHz
750 Vrms
250 Vmax.
³ 1 GΩ
³ 200 MΩ
≤ 10 mΩ
≤ 3 mΩ
1.5 A
Screening
ø
2.0
2.0
2.0
2.0
Data on request
Dielectric Internal wire Hexagonal crimp
ø
Spanner width
ø
1.5
0.48
3.25
1.5
0.54
3.25
1.5
0.54
3.25
1.6
0.3
3.25
01
39
V
I
III
VII
VI
II
VIII
IV
DIN Signal
up to 2 A
High current contacts
Identification
Part No.
Performance level 1
High current male contacts
for male connectors1)
straight crimp
for
termination
10 A
20 A
40 A
09 03 000 6113
09 03 000 6114
09 03 000 6115
II
straight solder
for
termination
Leading
contact
10 A
20 A
40 A
10 A
20 A
40 A
09 03 000 6101
09 03 000 6102
09 03 000 6103
09 03 000 6111
09 03 000 6122
09 03 000 6133
III
for angled pcb
termination
max. 40 A*
09 03 000 6110
max. 40 A*
09 03 000 6104
Leading
contact
max. 40 A*
09 03 000 6134
* depending on the pcb design
High current female contacts
for female connectors1)
01
40
1)
2)
Dimensions in mm
acc. to DIN 41 626
I
IV
Drawing
V
straight crimp
for
termination
10 A
20 A
40 A
09 03 000 6213
09 03 000 6214
09 03 000 6215
VI
straight solder
for
termination
10 A
20 A
40 A
09 03 000 6201
09 03 000 6202
09 03 000 6203
VII
for screw fixing
on busbar
40 A
09 03 000 6245
VIII
for type M-flat
for
solder termination
for
40 A
40 A
09 03 000 6250
09 03 000 6225
ø A ø B wire gauge AWG
[mm²]
10 A 1.85 2.55 1.5
16
20 A 2.85 3.70
4
12
40 A 4.40 5.60 10
8
ø
10 A 1.7
20 A 2.8
40 A 4.8
… 6104
… 6134
x
17.7
18.4
y
6.4
7.0
[mm²]
10 A 1.85 2.55 1.5
16
20 A 2.80 3.70
4
12
40 A 4.40 5.60 10
8
ø
10 A 1.7
20 A 2.8
40 A 4.8
DIN 41 612 · Type M
Number of contacts
78+2, 60+4,
42+6, 24+8
Identification
Male connector
with angled
solder pins
(without special contacts)*
Number
Contact
Part No.
3
2
1
09 03 178 7901
78 + 2
09 03 178 6901
09 03 178 6901 222f)
09 03 378 6901b)
09 03 178 2901
60 + 4
09 03 160 7901
09 03 160 6901
09 03 160 2901
42 + 6
09 03 142 7901
09 03 142 6901
09 03 142 2901
09 03 124 6901
09 03 124 6901 222f)
09 03 124 2901
09 03 124 7901
24 + 8
b)09
DIN Signal
up to 2 A
Male connectors
03 378 2901b)
Dimensions
Angled
solder pins
Order high current,
high voltage, coaxial
and fibre optic contacts
separately, see pages
01.38 ff
Board drillings
Mounting side
all holes
oard drillings depend on type
B
and special contact loading
* Pre-loaded with special contacts on request
Dimensions in mm
01
41
DIN 41 612 · Type M
Number of contacts
78+2, 60+4,
42+6, 24+8
DIN Signal
up to 2 A
Female connectors
Part No.
3
Identification
Number
Contact
Female connector
with solder pins
2.9 mm
78 + 2
09 03 278 6804
60 + 4
09 03 260 6804
42 + 6
09 03 242 6804
24 + 8
09 03 224 6804
Female connector
with solder pins
4.5 mm
2
09 03 278 6805
09 03 278 6805 222f)
78 + 2
Performance level 3
on request
60 + 4
42 + 6
Female connector
with press-in pins
4.5 mm
1
Performance level 1
on request
09 03 260 6805
09 03 242 6805
24 + 8
09 03 224 6805
09 03 224 6805 222f)
78 + 2
09 03 278 6850
60 + 4
09 03 260 6850
42 + 6
09 03 242 6850
24 + 8
09 03 224 6850
Dimensions
row
position
a
2.9
4.5
4.5
Order high current,
01.38 ff
Board drillings
Mounting side
all holes
Y
Solder
position
row
01
42
Board drillings depend on
type and special contact
loading
Press-in
Solder pins
Press-in pins
Y
1 ± 0.1
see recommendation
page 00.25
Type
78 + 2
60 + 4
42 + 6
24 + 8
c
25 x 2.54 = 63.50
19 x 2.54 = 48.26
13 x 2.54 = 33.02
7 x 2.54 = 17.78
Dimensions in mm
DIN 41 612 · complementary type M-flat
Number of contacts
78+2, 60+4,
42+6, 24+8
Part No.
Identification
Number
Contact
Female connector
with solder pins
2.9 mm
78 + 2
09 03 278 6864
60 + 4
09 03 260 6864
42 + 6
09 03 242 6864
24 + 8
09 03 224 6864
09 03 224 6864 222f)
Female connector
with solder pins
4.5 mm
Female connector
with press-in pins
4.5 mm
3
2
78 + 2
60 + 4
42 + 6
1
DIN Signal
up to 2 A
Female connectors
09 03 278 6865
Performance level 3
on request
09 03 260 6865
09 03 242 6865
24 + 8
09 03 224 6865
78 + 2
09 03 278 6830
60 + 4
09 03 260 6830
42 + 6
09 03 242 6830
24 + 8
09 03 224 6830
Performance level 1
on request
Dimensions
a
2.9
4.5
4.5
row
Order high current,
01.38 ff
Press-in pins
position
Board drillings
Mounting side
Solder pins
all holes
Solder
Y
position
Press-in
Y
1 ± 0.1
see recommendation
page 00.25
row
loading
Type
78 + 2
60 + 4
42 + 6
24 + 8
c
25 x 2.54 = 63.50
19 x 2.54 = 48.26
13 x 2.54 = 33.02
7 x 2.54 = 17.78
Dimensions
in mm
01
43
DIN 41 612 · complementary type M invers
Number of contacts
78+2, 60+4,
42+6, 24+8
DIN Signal
up to 2 A
Male connectors
Identification
Male connector
with solder pins
2.5 mm
Male connector
with solder pins
4.0 mm
Male connector
with wrap posts
13 mm
Part No.
Number
Contact
Male connector
with press-in pins
13 mm
01
44
2
78 + 2
09 73 178 6902
60 + 4
09 73 160 6902
42 + 6
09 73 142 6902
24 + 8
09 73 124 6902
78 + 2
09 73 178 6903
60 + 4
09 73 160 6903
42 + 6
09 73 142 6903
24 + 8
09 73 124 6903
78 + 2
09 73 178 6907
1
09 73 160 6907
60 + 4
42 + 6
Male connector
with press-in pins
5.5 mm
3
Performance level 3
on request
09 73 142 6907
24 + 8
09 73 124 6907
78 + 2
09 73 178 6904
60 + 4
09 73 160 6904
42 + 6
09 73 142 6904
24 + 8
09 73 124 6904
78 + 2
09 73 178 6985
09 73 178 6974●
60 + 4
09 73 160 6985
09 73 160 6974●
42 + 6
09 73 142 6985
09 73 142 6974●
24 + 8
09 73 124 6985
Male connectors with 17 mm wrap posts on request
● Wrap posts for interfacing selectively gold plated (performance level 3)
Performance level 1
on request
Number of contacts
78+2, 60+4,
42+6, 24+8
Identification
Drawing
Dimensions in mm
Dimensions
a
a
b
2.5
ø 0.7 Solder pins
4.0
13 l 0.6 Wrap posts
5.5
Press-in pins
13
DIN Signal
up to 2 A
Male connectors
Order high current,
01.38 ff
Board drillings
b
Y
Solder
Mounting side
Press-in
Y
1 ± 0.1
see recommendation
page 00.25
Board drillings depend on type and special contact loading
01
45
DIN 41 612 · Type R
Number of contacts
96, 64
DIN Signal
up to 2 A
Male connectors
Identification
Number
Contact
Male connector
with solder pins
2.5 mm
SMC
Male connector
with solder pins
4.0 mm
SMC
Male connector
with solder pins
13 mm
Male connector
with wrap posts1)
13 mm
Male connector
with press-in pins
5.0 mm
SMC
Part No.
3
2
09 73 196 7902
96
09 73 196 6902
09 73 396 6902b)
09 73 696 6902c)
09 73 196 6519d)
96
09 73 164 7902
64
09 73 164 6902
09 73 364 6902b)
09 73 196 7903
96
94 + 2▲
09 73 196 6903
09 73 196 6903 222f)
09 73 396 6903b)
09 73 196 6953
09 73 196 6520d)
96
1
09 73 196 2902
09 73 164 2902
73 364 2902b)
b)09
09 73 196 2903
09 73 164 7903
64
09 73 164 6903
09 73 364 6903b)
09 73 164 2903
09 73 196 6577
09 73 196 2577
96
6521d)
96
09 73 196
64
09 73 164 6577
09 73 196 7907
96
09 73 196 6907
09 73 696 6947●c)
09 73 196 2907
09 73 164 7907
64
09 73 164 6907
09 73 164 6947●
09 73 664 6947●c)
09 73 164 2907
09 73 196 7904
96
94 + 2▲
09 73 196 6904
09 73 696 6904c)
09 73 196 6954
09 73 164 6904
64
09 73 164 7904
performance level 1
or special
Male connector
with press-in pins
13 mm
01
46
96
●09 73 196 7974●
94 + 2▲
09 73 196 6985
09 73 196 6974●
09 73 196 6995
64
09 73 164 6985
09 73 164 6974●
▲ Male connectors with 2 leading contacts [(0.8 mm) pos. a1 and a32]
Other contact arrangements as well with lagging pins on request
1)
b)
c)
d)
gold plating
on request
CTI > 400
DIN 41 612 · Type R
Number of contacts
96, 64
Identification
Drawing
Dimensions in mm
Dimensions
a
b
2.5
ø 0.7
4
13 l 0.6
13 l 0.6
5
13
DIN Signal
up to 2 A
Male connectors
Solder pins
Wrap posts
Press-in pins
Panel cut out
Board drillings
1 Y
1
1
1
Mounting side
Solder
Press-in
Y
1 ± 0.1
see recommendation
page 00.25
Contact arrangement
Cross section of
solder terminations
Cross area (A) of contacts row a, b, c: A = 0.35 - 0.39 mm²
01
47
DIN 41 612 · complementary type RM
Number of contacts
96, 64
DIN Signal
up to 2 A
Male connectors
Identification
Number
Contact
Part No.
3
2
1
Male connector
5.0 mm
13 mm
96
09 79 196 2950
performance level 3
performance level 2
64
or special
or special
09 79 164 2950
gold plating
gold plating
on request
on request
96
09 79 196 2961*
A-B
Dimensions
a
5
13
row
position
Board drillings
Mounting side
position
all holes
row
01
48
Dimensions in mm
* Wrap posts for interfacing selectively gold plated (performance level 2)
Other contact arrangements also
DIN 41 612 · Type R
Number of contacts
96, 64, 32
Identification
Number
Contact
Female connector
with angled
solder pins
SMC
3
2
1
09 73 296 7801
96
09 73 496 7801b)
09 73 296 6801
09 73 296 6801 222f)
09 73 496 6801b)
09 73 796 6801c)
09 73 296 2801
09 73 296 6804d)
09 73 496 6804b)d)
09 73 296 2804d)
09 73 496 2804b)d)
09 73 264 6801
09 73 464 6801b)
09 73 264 2801
64
09 73 264 6804d)
09 73 464 6804b)d)
09 73 264 2804d)
09 73 464 2804b)d)
32
09 73 232 7801
09 73 232 6801
09 73 232 2801
32
09 73 232 7811
09 73 232 6811
09 73 232 2811
96
64
SMC
Part No.
09 73 264 7801
09 73 464 7801b)
DIN Signal
up to 2 A
Female connectors
Dimensions
row
position
Cross section of
solder terminations
Board drillings
Mounting side
position
all holes
row
Cross area (A) of
0.20 - 0.23 mm²
Dimensions in mm
b)
d) CTI > 400
01
49
DIN 41 612 · complementary to type R (HE 11)
Number of contacts
96, 64
DIN Signal
up to 2 A
Male connectors
Identification
Number
Contact
Part No.
3
2
1
Male connector
with solder pins
2.5 mm
Male connector
with solder pins
4.0 mm
96
09 79 196 6902
96
Performance level 3
on request
64
Male connector
with wrap posts1)
13 mm
09 79 196 6903
79 396 6903b)
b)09
09 79 164 6903
79 364 6903b)
Performance level 1
on request
b)09
96
09 79 196 6907
64
09 79 164 6907
Dimensions
a
b
2.5
ø 0.7
4.0
a
13
Panel cut out
b
l 0.6
Solder pins
Wrap posts
Contact arrangement
Board drillings
Mounting side
01
50
Dimensions in mm
= deviating dimensions from standard male connectors
(see page 01.46f)
b)
1)
Number of contacts
96, 64
Identification
Number
Contact
Part No.
3
2
1
Female connector
with angled
solder pins
09 79 296 7801
96
b)09
09 79 296 6801
79 496 6801b)
09 79 264 7801
64
b)09
09 79 264 6801
79 464 6801b)
DIN Signal
up to 2 A
Female connectors
Performance level 1
on request
Dimensions
row
position
Z
Board drillings
Mounting side
position
all holes
row
Dimensions in mm
= deviating dimensions from standard female connectors
(see page 01.49)
b)
01
51
DIN 41 612 · Type Q
Number of contacts
64
DIN Signal
up to 2 A
Male connectors
Part No.
3
Identification
Number
Contact
Male connector
with solder pins 2.5 mm
09 72 164 7902
64
09 72 164 6902
09 72 364 6902b)
4.0 mm
64
09 72 164 6903
13 mm
64
09 72 164 6577
Male connector
with wrap posts1) 13 mm
64
09 72 164 6907
17 mm
64
2
09 72 164 7903
09 72 164 7907
1
Performance level 1
on request
09 72 164 6909
Male connector
with press-in pins 5.0 mm
64
62 + 2▲
09 72 164 6904
09 72 164 6904 222f)
09 72 164 6954
13 mm
64
62 + 2
09 72 164 6985
09 72 164 6974●
09 72 164 6995
Dimensions
a
b
2.5
ø 0.7
4
Solder pins
13 l 0.6
13
l 0.6 Wrap posts
17
5
Press-in pins
13
Panel cut out
Board drillings
1
Y
1
1
Solder
Mounting side
Press-in
01
52
Y
1 ± 0.1
see recommendation
page 00.25
Dimensions in mm
Other contact arrangements as well with lagging/leading pins on request
▲ Male connectors with 2 leading contacts (0.8 mm) pos. a1 and a32/a16
1)
b)
DIN 41 612 · complementary type 2Q
Number of contacts
32
Identification
Number
Contact
Male connector
with solder pins
2.5 mm
32
Part No.
3
09 27 132 7902
09 27 332 7902
2
1
DIN Signal
up to 2 A
Male connectors
09 27 132 6902
4.0 mm
09 27 132 7903
32
09 27 132 6903
09 27 132 6903 222f)
13 mm
32
09 27 132 6577
32
09 27 132 6907
Performance level 1
on request
Male connector
with wrap posts1)
13 mm
Male connector
with press-in pins
5.0 mm
09 27 132 7907
32
30 + 2▲
Dimensions
09 27 132 6904
09 27 132 6954
a
b
2.5
ø 0.7
4
13 l 0.6
13 l 0.6
5
Solder pins
Wrap posts
Press-in pins
Panel cut out
Board drillings
Y
Mounting side
Solder
Press-in
Y
1 ± 0.1
see recommendation
page 00.25
Dimensions in mm
01
53
DIN 41 612 · complementary type 2R
Number of contacts
48, 32
DIN Signal
up to 2 A
Male connectors
Identification
Number
Contact
Male connector
with solder pins
2.5 mm
48
SMC
SMC
Male connector
with solder pins
4.0 mm
SMC
SMC
Male connector
with solder pins
13 mm
SMC
Male connector
with wrap posts1)
13 mm
Male connector
with press-in pins
5.0 mm
Male connector
with press-in pins
13 mm
01
54
Part No.
3
09 28 148 7902
28 348 7902b)
b)09
48
09 28 148 6519d)
32
09 28 132 6902
32
09 28 132 7902
09 28 148 2902
09 28 132 2902
09 28 132 6519d)
09 28 148 7903
48
09 28 148 6903
09 28 148 6903 222f)
09 28 348 6903b)
48
09 28 148 6520d)
32
09 28 132 6903
32
09 28 132 6520d)
48
09 28 148 6577
48
09 28 148 6521d)
48
09 28 148 7907
09 28 148 6907
09 28 148 2907
32
09 28 132 7907
09 28 132 6907
09 28 132 2907
09 28 132 7903
09 28 148 6904
09 28 148 6904 222f)
09 28 132 6904
32
48
09 28 148 7985
32
09 28 148 2903
09 28 132 2903
09 28 148 7904
48
b)
1
09 28 148 6902
09 28 348 6902b)
2
09 28 148 6985
09 28 148 6974●
09 28 132 6985
d) CTI > 400
Number of contacts
48, 32
Identification
Drawing
Dimensions in mm
Dimensions
Panel cut out
a
b
2.5
ø 0.7
4
13 l 0.6
13 l 0.6
5
13
DIN Signal
up to 2 A
Male connectors
Solder pins
Wrap posts
Press-in pins
Contact arrangement
Board drillings
Mounting side
Y
Solder
Press-in
Y
1 ± 0.1
see recommendation
page 00.25
Cross section of
solder terminations
01
55
DIN 41 612 · Type Q – complementary types 2Q, 2R
Number of contacts
64, 48, 32
DIN Signal
up to 2 A
Female connectors
Identification
Number
Contact
Part No.
Performance level 2 according to IEC 60 603-2. Explanation chapter 00
Female connector
with angled
solder pins
Type Q
64
09 72 264 6801
09 72 464 6801b)
Type 2Q
32
09 27 232 6801
09 27 432 6801b)
Type 2R
48
09 28 248 6801
09 28 448 6801b)
Dimensions
Types Q / 2Q
Type 2R
row
row
position
position
Type
a
b
c
d
e
f
88.90±0.1
94.0-0.2
31
78.74
32
48.26±0.1
53.9-0.2
15
38.10
16
Q
85.0-0.2
2Q
44.4-0.2
Board drillings
Mounting side
all holes
all holes
position
row
01
56
position
row
Dimensions in mm
DIN 41 612 · Type C, R, 2C, 2R
Number of contacts
96, 48
Identification
Number
Contact
Part No.
3
2
1
Male connector
type R
with pin shroud for
pcb distance
41 mm
96
DIN Signal
up to 2 A
Mezzanine Adapter
09 73 196 5531
Performance level 3
on request
Male connector
type 2R
with pin shroud for
pcb distance
41 mm
37.5 mm
48
09 28 148 6532
Dimensions
09 28 148 5531
position
row
09 73 148 5531
09 28 148 5531
09 28 148 6532
a
94.9 ± 0.1
54.9 ± 0.1
54.9 ± 0.1
b
31
15
15
c
78.74
38.1
38.1
d
29.6 ± 0.3
29.6 ± 0.3
26.15 ± 0.3
Dimensions in mm
01
57
Pin shroud
III
Number of contacts
96, 48
I
DIN Signal
up to 2 A
Pin shrouds
for types C, 2C, R, 2R
Identification
Pin shrouds
type C, R
I
Pin shrouds
type 2C, 2R
II
II
Termination pcb-thick- Dimension a
length ± 0.3 ness ± 0.4
± 0.1
Part No. – Pin shrouds with
screw fixing
press-in fixing1)
1.6
6.7
2.4
5.9
3.2
5.1
4.0
4.3
09 03 000 9956
09 03 000 9957
09 03 000 9958
09 03 000 9959
09 03 000 9966
09 03 000 9967
09 03 000 9968
09 03 000 9969
17.0
1.6
9.9
2.4
9.1
3.2
8.3
4.0
7.5
4.8
6.7
5.6
5.9
6.4
5.1
09 03 000 9952
09 03 000 9953
09 03 000 9954
09 03 000 9955
09 03 000 9956
09 03 000 9957
09 03 000 9958
09 03 000 9962
09 03 000 9963
09 03 000 9964
09 03 000 9965
09 03 000 9966
09 03 000 9967
09 03 000 9968
20.0
3.2 11.75
4.0
10.7
4.8
9.9
5.6
9.1
6.4
8.3
7.2
7.5
09 03 000 9950
09 03 000 9951
09 03 000 9952
09 03 000 9953
09 03 000 9954
09 03 000 9955
09 03 000 9960
09 03 000 9961
09 03 000 9962
09 03 000 9963
09 03 000 9964
09 03 000 9965
/13.0/
13.2
1.6
6.7
2.4
5.9
3.2
5.1
4.0
4.3
09 23 000 9956
09 23 000 9957
09 23 000 9958
09 23 000 9959
09 23 000 9966
09 23 000 9967
09 23 000 9968
09 23 000 9969
17.0
1.6
9.9
2.4
9.1
3.2
8.3
4.0
7.5
4.8
6.7
5.6
5.9
6.4
5.1
09 23 000 9952
09 23 000 9953
09 23 000 9954
09 23 000 9955
09 23 000 9956
09 23 000 9957
09 23 000 9958
09 23 000 9962
09 23 000 9963
09 23 000 9964
09 23 000 9965
09 23 000 9966
09 23 000 9967
09 23 000 9968
20.0
3.2 11.75
4.0
10.7
4.8
9.9
5.6
9.1
6.4
8.3
7.2
7.5
09 23 000 9950
09 23 000 9951
09 23 000 9952
09 23 000 9953
09 23 000 9954
09 23 000 9955
09 23 000 9960
09 23 000 9961
09 23 000 9962
09 23 000 9963
09 23 000 9964
09 23 000 9965
Part No.
Locking lever for female connectors
type C, 2C*
III
09 03 000 9914
type R, 2R*
IV
09 03 000 9913
Fixing bracket for shell housing C*
V
09 03 000 9921
* order 2 pieces per connector
1) Tooling see chapter 30
IV
/13.0/
13.2
Identification
01
58
V
Pin shroud
Number of contacts
96, 48
Identification
Drawing
Pin shrouds
type C, R
Dimensions in mm
screw
fixing
press-in
fixing1)
DIN Signal
up to 2 A
Pin shrouds
a
area for press-fit to interface pins
row
position
nut M2.5
a
Pin shrouds
type 2C, 2R
row
position
01
59
1)
Female connector
09 03 296 6861
Backplane
Pin shroud
09 03 000 9957
Locking lever
09 03 000 9914
Female connector
09 03 264 6828
Female connector
09 03 096 3214
Application 2
Female connector
09 03 296 6862
Backplane
Pin shroud
09 03 000 9953
Locking lever
09 03 000 9913
Female connector
09 73 296 6801
Daughtercard
Application 3
Female connector
09 03 296 6861
Backplane
Pin shroud
09 03 000 9957
Fixing brackets
09 03 000 9921
Female connector
09 03 096 3214
Locking levers
left 09 02 000 9902
right
09 02 000 9903
DIN Signal
up to 2 A
Application 1
01
60
Shell housing C
09 03 096 0501
Backplane
Male connector
Type R
09 73 196 6903
Fixing elements
09 02 000 9953 (R 1)
09 02 000 9954 (R32)
Female connector
Locking levers
09 03 096 3217 left
09 02 000 9902
right 09 02 000 9903
DIN Signal
up to 2 A
Application 4
Shell
housing C
09 03 096 0501
Application 5*
Daughtercard
Male connector
09 03 196 6921
Female connector
09 73 296 6801
Daughtercard
Application 6*
Backplane
Male connector
09 73 196 6904
Female connector
09 03 296 6845
Backplane
01
61
* Position marking turned: a1 contacts a32, a2 contacts a31, …
Backplane
Female connector
09 03 296 6845
Adapter
09 73 196 5531
Female connector
09 03 296 6850
Backplane
Backplane
Female connector
09 23 248 6866
Adapter
09 28 148 6532
Female connector
09 23 248 6824
Backplane
Backplane
Male connector
09 03 196 6922
Female connector
09 03 296 6845
Backplane
40.5 – 41.5
DIN Signal
up to 2 A
Application 7
37.05 – 37.80
Application 8
18.5 – 19.9
Application 9
01
62
