09140122632
09140122632
    HARTING(浩亭)
    MODULE MALE 12POS PUSH IN LOCK
09140122632 数据手册
98 48 917 0201 HARTING Han-Quick Lock® People | Power | Partnership 2 Contents 1.0 2.0 3.0 4.0 5.0 6.0 Precise technique, so simple as Han-Quick Lock® ........................................... Fast, simple and compact! . ..................................................................................... 2.1 Assembly ........................................................................................................... 2.2 Disassembly ...................................................................................................... Complete build-up .................................................................................................... X-ray cross section ................................................................................................... Advantages of Han-Quick Lock® . ........................................................................ 5.1 Time saving ....................................................................................................... 5.2 Vibration safety ................................................................................................ 5.3 Wire pull out forces ......................................................................................... 5.4 Contact resistance ............................................................................................ Product portfolio ....................................................................................................... 6.1 Han® 3 A Quick Lock ....................................................................................... 6.2 Han® 4 A Quick Lock ....................................................................................... 6.3 Han® Q 5/0 Quick Lock ................................................................................... 6.4 Han® Q 8/0 Quick Lock ................................................................................... 6.5 Han® Q 12/0 ...................................................................................................... 6.6 Han® PushPull Power 4/0 Quick Lock ......................................................... 6.7 Han® 7 D Quick Lock ....................................................................................... 6.8 Han® 8 D Quick Lock ....................................................................................... 6.9 Han DD® Module Quick Lock ......................................................................... 6.10 Han® EE Module Quick Lock .......................................................................... 04 04 05 06 07 08 09 09 10 10 11 12 14 15 16 17 18 19 20 21 22 23 3 Precise technique, so simple as Han-Quick Lock® 1.0 This new connection technique from HARTING combines the reliability and the simple operation of the cage clamp connection with the low space requirements of crimp technology. Han-Quick Lock® is ideally suited to high contact densities and is considerably superior over other connection techniques. No other technology is so simple, space saving and fast. For this vibration safe connection, no special tools are necessary. 2.0 Fast, simple and compact! Characteristics of Han-Quick Lock® Fast, simple and robust termination technique • Field assembly without a special tool • Compatible with many approved Han® insert connectors • Combines high contact density similar to crimp termination with the simple connection like a cage clamp terminal Suitable cable types The termination technology allows to use extra fine wires according to VDE 0295, class 5 The following wires are not suitable: • solid wires • stranded wires • twisted pair wires Technical variables Han-Quick Lock® Material: Isolation body: polycarbonate • Active termination element: polycarbonate • Quick-Lock spring: stainless steel • Contact: copper alloy • Blue slide: Terminal cross-section 0.5 - 2.5 mm2 / AWG 20 - 14 Black slide: Terminal cross-section 0.25 - 1.5 mm2 / AWG 23 - 16 • Stripping length: 10 mm Insulating resistance > 1010 Ohm • Flammability according to UL 94 V 0 • Mechanical working life ≥ 500 mating cycles • Termination tool: screwdriver 0.4 x 2.5 mm or 0.5 x 3.0 mm 4 1. 2. 4. 2.1 3. 5. Assembly 1. Step: Removing cable sheath and wire stripping (10 mm). Do not twist conductors. 2. Step: Insert wire into the Han-Quick Lock® contact chamber. 3. Step: Push in the active termination element with a screwdriver until it comes to a stop. 4. Step: Visual inspection - Check if the wire is deep enough in the contact chamber. 5. Step: Tensile test - Check, whether the wire is in the contact chamber firmly enough. 5 2.2 Disassembly 1 a/b Step: Insert a screwdriver into the side slot of the active termination element at an angle and slide this out. 2 a/b Step: Pull the wire out. 6 1a 1b 2a 2b 1. 3.0 2. 3. Complete build-up The Han-Quick Lock® termination consists of three individual components: 1. Contact with cone 2. Spring 3. Active termination element 7 4.0 Active termination element X-ray of the new Han-Quick Lock® connection showing the method of termination. Photos showing the combination of wire, cone and spring. X-RAY INSPECTION 8 X-RAY INSPECTION X-RAY INSPECTION 5.0 Advantages of Han-Quick Lock® Han-Quick Lock® is a new generation of connection technology. This HARTING patent technique offers a number of advantages which are explained more precisely on the following pages. The special features of this connection technology are: 1. Time saving 2. High vibration safety 3. High wire pull out forces 4. Low contact resistance 5.1 Time saving With use of Han-Quick Lock® a time saving of more than 20% is achieved against a traditional screw connection technique. 9 5.2 Vibration safety The wires terminated with Han-Quick Lock® fulfil the high requirements (shock and vibration test according to DIN EN 61373) from the transportation market. 5.3 Contact pull out forces The required minimum demands according to DIN EN 60352-7 are greatly exceeded. Contact pull out forces with terminal cross-section 0.5 mm2 Force (N) +125% 10 Minimum demand according to DIN EN 60352-7 Contact resistance (after climatic tests) with terminal cross-section 0.5 mm2 Resistance (mΩ) -80% Maximum permitted demand according to DIN EN 60352-7 Contact resistance (industry gas tests) with terminal cross-section 0.5 mm2 Resistance (mΩ) -50% Maximum permitted demand according to DIN EN 60352-7 5.4 Contact resistance Contact resistance Han-Quick Lock® termination achieves considerably lower figures than the permitted values after climate and gas tests according to DIN EN 60352-7. 11 6.0 Product portfolio Overview of the existing product portfolio Han-Quick Lock® Han® 3 A Han® 4 A Han® Q 5/0 Han® Q 8/0 Han® Q 12/0 Han® PushPull Power 4/0 12 Han® 7 D Han® 8 D Han DD® Module Han® EE Module 13 6.1 Han® 3 A Quick Lock Characteristics Technical details • • • • • • Blue slide Han-Quick Lock® quick termination technology Field assembly without special tool Compatible with standard Han® 3 A i nserts Reduced assembly times Fully compatible with the metal and plastic housings of the Han® 3 A series • • • • • • • • Degree of protection IP 65 / IP 67 Number of contacts 3 + PE Electrical data according to DIN EN 61 984 10 A  230/400 V  4 kV  3 Working current 10 A Working voltage conductor-ground 230 V Working voltage conductor-conductor 400 V Rated impulse voltage 4 kV Pollution degree 3 Termination Han-Quick Lock® • • • • • Terminal cross-section Insulation resistance Material Flammability according to UL 94 Mechanical working life 0.5 - 2.5 mm2 (AWG 20 - 14) ≥ 1010 Ohm Polycarbonate V0 ≥ 500 mating cycles Male insert Part number: 09 20 003 2633 Female insert Part number: 09 20 003 2733 14 6.2 Han® 4 A Quick Lock Characteristics Technical details • • • • • • Blue slide Han-Quick Lock® quick termination technology Field assembly without special tool Compatible with standard Han® 4 A i nserts Reduced assembly times Fully compatible with the metal and plastic housings of the Han® 3 A series • • • • • • • • • Degree of protection IP 65 / IP 67 Number of contacts 4 + PE Electrical data according to DIN EN 61 984 10 A  230/400 V  4 kV  3 Working current 10 A Working voltage conductor-ground 230 V Working voltage conductor-conductor 400 V Rated impulse voltage 4 kV Pollution degree 3 Pollution degree 2 also 10 A  320/500 V  4 kV  2 Termination Han-Quick Lock® • • • • • Terminal cross-section Insulation resistance Material Flammability according to UL 94 Mechanical working life 0.5 - 2.5 mm2 (AWG 20 - 14) ≥ 1010 Ohm Polycarbonate V0 ≥ 500 mating cycles Male insert Part number: 09 20 004 2633 Female insert Part number: 09 20 004 2733 15 6.3 Han® Q 5/0 Quick Lock Characteristics Technical details • • • • • • Blue slide Han-Quick Lock® quick termination technology Field assembly without special tool Reduced assembly times Fully compatible with the metal and plastic housings of the Han® 3 A series Compatible with Han® Q 5/0 crimp inserts • • • • • • • • • Degree of protection IP 65 / IP 67 Number of contacts 5 + PE Electrical data according to DIN EN 61 984 16 A  230/400 V  4 kV  3 Working current 16 A Working voltage conductor-ground 230 V Working voltage conductor-conductor 400 V Rated impulse voltage 4 kV Pollution degree 3 Pollution degree 2 also 16 A  320/500 V  4 kV  2 Termination Han-Quick Lock® • • • • Terminal cross-section Insulation resistance Material Flammability according to UL 94 Mechanical working life 0.5 - 2.5 mm2 (AWG 20 - 14) ≥ 1010 Ohm Polycarbonate V0 ≥ 500 mating cycles Male Part number: 09 12 005 2633 Female Part number: 09 12 005 2733 16 6.4 Han® Q 8/0 Quick Lock Characteristics • Blue slide • Han-Quick Lock® quick termination technology • Field assembly without special tools • Compatible with Han® Q 8/0 standard inserts with crimp terminal • Reduced wiring times • Insert suitable for plastic hoods and housings of the sizes Han-Compact® • Space-saving and compact design • Leading protective ground contact Technical details • Specifications • Number of contacts • Electrical data according to DIN EN 61 984 • Working current • Working voltage • Rated impulse voltage • Pollution degree • Pollution degree 2 also DIN EN 60 664-1 DIN EN 61 984 8 + PE Termination Han-Quick Lock® • • • • • • Terminal cross-section Insulation resistance Material Category temperature Flammability according to UL 94 Mechanical working life 0.5 - 2.5 mm2 (AWG 20 - 14) ≥ 1010 Ohm Polycarbonate -40 °C ... +125 °C V0 ≥ 500 mating cycles 16 A  500 V  6 kV  3 16 A 500 V 6 kV 3 16 A  400/690 V  6 kV  2 Male Part number: 09 12 008 2633 Female Part number: 09 12 008 2733 17 6.5 Han® Q 12/0 Characteristics • Blue slide • PE-contact with Han-Quick Lock® quick termination technology • 16x coding possibilities without loss of a contact place • Fully compatible with the metal and plastic housings of the Han® 3 A series • 12 contact chambers for the contacts of the series Han D® with crimp termination Technical details • Specifications • Number of contacts • Electrical data according to DIN EN 61 984 • Working current • Working voltage • Rated impulse voltage • Pollution degree • Pollution degree 2 also • Termination Han D® contacts DIN VDE 0627 / 0110 DIN EN 61 984 12 + PE 10 A  400 V  6 kV  3 10 A 400 V 6 kV 3 10 A  400/690 V  6 kV  2 Crimp; 0.14 - 2.5 mm2 (AWG 26 - 14) Termination PE-contact Han-Quick Lock® • • • • • • Terminal cross-section PE-contact Insulation resistance Material Category temperature Flammability according to UL 94 Mechanical working life 0.5 - 2.5 mm2 (AWG 20 - 14) ≥ 1010 Ohm Polycarbonate -40 °C ... +125 °C V0 ≥ 500 mating cycles Male Part number: 09 12 012 3001 Female Part number: 09 12 012 3101 18 6.6 Han® PushPull Power 4/0 Quick Lock Characteristics • HARTING PushPull Technologie • Compact, space-saving design • Finger protection Metal Technical details • Locking device • Degree of protection • Number of contacts • Electrical data according to DIN EN 61 984 • Cable diameter PushPull-Technology IP 65 / IP 67 4 + PE Han-Quick Lock® Termination • Terminal cross-section • Housing material 16 A  690 V  4 kV  3 4 - 11 mm metal version 9 -13 mm plastic version 0.5 - 2.5 mm2 (AWG 20 - 14) Zinc die-cast (nickel plated), Plastic Cable side female Part number: 09 35 232 0401 Bulkhead mounting male Part number: 09 35 232 0313 Plastic Cable side female Part number: 09 35 232 0421 Bulkhead mounting male Part number: 09 35 232 0333 19 6.7 Han® 7 D Quick Lock Characteristics • Black slide • Han-Quick Lock® quick termination technology • Field assembly without special tools • Compatible with Han® 7 D standard inserts with crimp terminals • Reduced wiring times • Insert suitable for plastic hoods and housings using the Han® 3 A size • Space-saving and compact design • Leading protective ground contact Technical details • Specifications • Number of contacts • Electrical data according to DIN EN 61 984 • Working current • Working voltage • Rated impulse voltage • Pollution degree • Pollution degree 2 also DIN EN 60 664-1 DIN EN 61 984 7 + PE Termination Han-Quick Lock® • • • • • • Terminal cross-section Insulation resistance Material Category temperature Flammability according to UL 94 Mechanical working life 0.25 - 1.5 mm2 (AWG 24 - 16) ≥ 1010 Ohm Polycarbonate -40 °C ... +125 °C V0 ≥ 500 mating cycles 10 A  250 V  4 kV  3 10 A 250 V 4 kV 3 10 A  230/400 V  4 kV  2 Male Part number: 09 21 007 2632 Female Part number: 09 21 007 2732 20 6.8 Han® 8 D Quick Lock Characteristics • Black slide • Han-Quick Lock® quick termination technology • Field assembly without special tools • Compatible with Han® 8 D standard inserts with crimp terminals • Reduced wiring times • Insert suitable for metal hoods and housings using the Han® 3 A size • Space-saving and compact design • Leading protective ground contact Technical details • Specifications • Number of contacts • Electrical data according to DIN EN 61 984 • Working current • Working voltage • Rated impulse voltage • Pollution degree DIN EN 60 664-1 DIN EN 61 984 8 Termination Han-Quick Lock® • • • • • • Terminal cross-section Insulation resistance Material Category temperature Flammability according to UL 94 Mechanical working life 0.25 - 1.5 mm2 (AWG 24 - 16) ≥ 1010 Ohm Polycarbonate -40 °C ... +125 °C V0 ≥ 500 mating cycles 10 A  ~50 V/–120 V  4 kV  3 10 A ~50 V / –120 V 4 kV 3 Male Part number: 09 12 012 3001 Female Part number: 09 12 012 3101 21 6.9 Han DD® Module Quick Lock Characteristics • Black slide • Han-Quick Lock® quick termination technology • Field assembly without special tools • Mating compatible with standard Han DD® Module with crimp terminal • Reduced wiring times Technical details • Specifications • Number of contacts • Electrical data according to DIN EN 61 984 • Working current • Working voltage • Rated impulse voltage • Pollution degree DIN EN 60 664-1 DIN EN 61 984 12 Termination Han-Quick Lock® • • • • • • Terminal cross-section Insulation resistance Material Category temperature Flammability according to UL 94 Mechanical working life 0.25 - 1.5 mm2 (AWG 24 - 16) ≥ 1010 Ohm Polycarbonate -40 °C ... +125 °C V0 ≥ 500 mating cycles 10 A  250 V  4 kV  3 10 A 250 V 4 kV 3 Male Part number: 09 14 012 2632 Female Part number: 09 14 012 2732 22 6.10 Han® EE Module Quick Lock Characteristics • Blue slide • Han-Quick Lock® quick termination technology • Field assembly without special tools • Mating compatible with standard Han® EE module with crimp terminal • Reduced wiring times Technical details • Specifications • Number of contacts • Electrical data according to DIN EN 61 984 • Working current • Working voltage • Rated impulse voltage • Pollution degree • Pollution degree 2 also DIN EN 60 664-1 DIN EN 61 984 8 Termination Han-Quick Lock® • • • • • • Terminal cross-section Insulation resistance Material Category temperature Flammability according to UL 94 Mechanical working life 0.5 - 2.5 mm2 (AWG 20 - 14) ≥ 1010 Ohm Polycarbonate -40 °C ... +125 °C V0 ≥ 500 mating cycles 16 A  400 V  6 kV  3 16 A 400 V 6 kV 3 16 A  400/690 V  6 kV  2 Male Part number: 09 14 008 2633 Female Part number: 09 14 008 2733 23 24 Sales Network – worldwide Albania see Eastern Europe Argentina see Brazil Armenia see Eastern Europe Australia HARTING Pty Ltd Suite 11 / 2 Enterprise Drive Bundoora 3083, AUS-Victoria Phone +61 9466 7088 Fax +61 9466 7088 au@HARTING.com www.HARTING.com Austria HARTING Ges.m.b.H. Deutschstraße 19, A-1230 Wien Phone +431 6162121 Fax +431 6162121-21 at@HARTING.com www.HARTING.at Belgium HARTING N.V./S.A. Z.3 Doornveld 23, B-1731 Zellik Phone +32 2 466 0190 Fax +32 2 466 7855 be@HARTING.com www.HARTING.be Bosnia and Herzegovina see Eastern Europe Brazil HARTING Ltda. Av. Dr. Lino de Moraes Pq. Jabaquara, 255 CEP 04360-001 – São Paulo – SP – Brazil Phone +55 11 5035 0073 Fax +55 11 5034 4743 br@HARTING.com www.HARTING.com.br Brunei see Singapore Azerbaijan see Eastern Europe Bulgaria see Eastern Europe Belarus see Eastern Europe Canada see USA China Zhuhai HARTING Limited Shanghai branch Room 5403, HK New World Tower 300 Huai Hai Road (M.) Shanghai 200021, China Phone +86 21 6386 2200 Fax +86 21 6386 8636 cn@HARTING.com www.HARTING.com.cn Croatia see Eastern Europe Czech Republic HARTING s.r.o. Ml´ynská 2, CZ-160 00 Praha 6 Phone +420 220 380 460 Fax +420 220 380 461 cz@HARTING.com www.HARTING.cz Denmark HARTING ApS Phone +45 75 67 43 42 Fax +45 75 67 43 43 dk@HARTING.com www.HARTING.com Denmark Wexøe A/S Lejrvej 31, DK-3500 Vaerloese Phone +4545465800 Fax +4545465801 wexoe@wexoe.dk www.wexoe.dk Sales Network – worldwide Eastern Europe HARTING Eastern Europe GmbH Bamberger Straße 7 D-01187 Dresden Phone +49 351 4361 760 Fax +49 351 436 1770 Eastern.Europe@HARTING.com www.HARTING.com Estonia see Eastern Europe Finland HARTING Oy Teknobulevardi 3-5, PL 35 FI-01530 Vantaa Phone +358 9 350 87 300 Fax +358 9 350 87 320 fi@HARTING.com www.HARTING.fi France HARTING France 181 avenue des Nations, Paris Nord 2 BP 66058 Tremblay en France F-95972 Roissy Charles de Gaulle Cédex Phone +33 1 4938 3400 Fax +33 1 4863 2306 fr@HARTING.com www.HARTING.fr Germany HARTING Deutschland GmbH & Co. KG P.O. Box 2451, D-32381 Minden Simeonscarré 1, D-32427 Minden Phone +49 571 8896 0 Fax +49 571 8896 282 de@HARTING.com www.HARTING-Deutschland.de Germany (Office) HARTING Deutschland GmbH & Co. KG Blankenauer Straße 99 D-09113 Chemnitz Phone +49 0371 429211 Fax +49 0371 429222 de.sales@HARTING.com www.HARTING-Deutschland.de Hong Kong HARTING (HK) Limited Regional Office Asia Pacific 3512 Metroplaza Tower 1 223 Hing Fong Road Kwai Fong, N. T., Hong Kong Phone +852 2423 7338 Fax +852 2480 4378 ap@HARTING.com www.HARTING.com.hk Hungary HARTING Magyarország Kft. Fehérvári út 89-95, H-1119 Budapest Phone +36 1 205 34 64 Fax +36 1 205 34 65 hu@HARTING.com www.HARTING.hu India HARTING India Private Limited No. D, 4th Floor, ‚Doshi Towers‘ No. 156 Poonamallee High Road Kilpauk, Chennai 600 010 Tamil Nadu, India Phone +91 44 435604 15 / 016 Fax +91 44 435604 17 in@HARTING.com www.HARTING.com Indonesia see Malaysia Island Smith & Norland, Nóatún 4 IS – 105 Reykjavík Phone +354 520 3000, Fax +354 520 3011 olaf@sminor.is, www.sminor.is Israel COMTEL Israel Electronics Solutions Ltd. Bet Hapamon, 20 Hataas st. P.O.Box 66 Kefar-Saba 44425 Phone +972-9-7677240 Fax +972-9-7677243 sales@comtel.co.il www.comtel.co.il Georgia see Eastern Europe Italy HARTING SpA Via Dell' Industria 7 I-20090 Vimodrone (Milano) Phone +39 02 250801 Fax +39 02 2650 597 it@HARTING.com www.HARTING.it Great Britain HARTING Ltd., Caswell Road Brackmills Industrial Estate GB-Northampton, NN4 7PW Phone +44 1604 827 500 Fax +44 1604 706 777 gb@HARTING.com www.HARTING.co.uk Japan HARTING K. K. Yusen Shin-Yokohama 1 Chome Bldg., 2F 1-7-9, Shin-Yokohama, Kohoku-ku Yokohama 222-0033 Japan Phone +81 45 476 3456 Fax +81 45 476 3466 jp@HARTING.com www.HARTING.co.jp Kazakhstan see Eastern Europe Kirghizia see Eastern Europe Korea (South) HARTING Korea Limited #308 Yatap Leaders Building, 342-1 Yatap-dong, ­Bundang-gu Sungnam-City, Kyunggi-do 463-828, Republic of Korea Phone +82 31 781 4615 Fax +82 31 781 4616 kr@HARTING.com www.HARTING.com.cn/kr Kosovo see Eastern Europe Latvia see Eastern Europe Lithuania see Eastern Europe Macedonia see Eastern Europe Malaysia (Office) HARTING Singapore Pte Ltd Malaysia Branch 11-02 Menara Amcorp Jln. Persiaran Barat 46200 PJ, Sel. D. E., Malaysia Phone +60 3 / 7955 6173 Fax +60 3 / 7955 5126 sg@HARTING.com Montenegro see Eastern Europe Netherlands HARTING B.V. Larenweg 44 NL-5234 KA 's-Hertogenbosch Postbus 3526 NL-5203 DM 's-Hertogenbosch Phone +31 736 410 404 Fax +31 736 440 699 nl@HARTING.com www.HARTINGbv.nl Norway HARTING A/S Østensjøveien 36, N-0667 Oslo Phone +47 22 700 555 Fax +47 22 700 570 no@HARTING.com www.HARTING.no Philippines see Malaysia Sales Network – worldwide Poland HARTING Polska Sp. z o. o ul. Kamieńskiego 201-219 PL-51-126 Wrocław Phone +48 71 352 81 71 Fax +48 71 320 74 44 pl@HARTING.com www.HARTING.pl Portugal HARTING Iberia, S. A. Avda. Josep Tarradellas 20-30, 4o 6a E-08029 Barcelona Phone +351 219 673 177 Fax +351 219 678 457 es@HARTING.com www.HARTING.es/pt Republic of Moldova see Eastern Europe Romania HARTING Romania SCS Europa Unita str. 21 550018-Sibiu, Romania Phone +40 369-102 671 Fax +40 369-102 622 ro@HARTING.com www.HARTING.com Russia HARTING ZAO Maliy Sampsoniyevsky prospect 2A 194044 Saint Petersburg, Russia Phone +7 812 327 6477 Fax +7 812 327 6478 ru@HARTING.com www.HARTING.ru Serbia see Eastern Europe Singapore HARTING Singapore Pte Ltd. 25 International Business Park #02-06 German Centre Singapore 609916 Phone +65 6225 5285 Fax +65 6225 9947 sg@HARTING.com www.HARTING.com Slovakia HARTING s.r.o. Sales office Slovakia Povázska 2, SK - 940 67 Nové Zámky Phone +421 356-493 993 Fax +421 356-402 114 sk@HARTING.com www.HARTING.sk Slovenia see Eastern Europe MO/15.09.09 98 48 917 0201 South Africa HellermannTyton Pty Ltd. Private Bag X158 Rivonia 2128 34 Milky Way Avenue Linbro Business Park 2065, Johannesburg Phone +27(0)11879-6600 Fax +27(0)11879-6606 sales.jhb@hellermann.co.za Spain HARTING Iberia S.A. Avda. Josep Tarradellas 20-30 4o 6a E-08029 Barcelona Phone +34 93 363 84 75 Fax +34 93 419 95 85 es@HARTING.com www.HARTING.es Sweden HARTING AB Gustavslundsvägen 141 B 4tr S-167 51 Bromma Phone +46 8 445 7171 Fax +46 8 445 7170 se@HARTING.com www.HARTING.se USA HARTING Inc. of North America 1370 Bowes Road USA-Elgin, Illinois 60123 Phone +1 (877) 741-1500 (toll free) Fax +1 (866) 278-0307 (Inside Sales) Fax +1 (847) 717-9430 (Sales and Marketing) us@HARTING.com www.HARTING-USA.com Uzbekistan see Eastern Europe Vietnam (Office) HARTING Singapore Pte Ltd Hanoi Representative Office Suite 616, 6th Floor Press Club Building 59A Ly Thai To Street Hoan Kiem District Hanoi, Vietnam Phone +84 4 / 3936 7851 Fax +84 4 / 3936 8069 sg@HARTING.com Switzerland HARTING AG Industriestrasse 26 CH-8604 Volketswil Phone +41 44 908 20 60 Fax +41 44 908 20 69 ch@HARTING.com www.HARTING.ch Taiwan HARTING R.O.C. Limited Room 1, 5/F 495 GuangFu South Road RC-110 Taipei, Taiwan Phone +886 227 586 177 Fax +886 227 587 177 tw@HARTING.com www.HARTING.com.tw Tajikistan see Eastern Europe Distributors – worldwide Farnell: www.farnell.com RS Components: www.rs-components.com Thailand see Malaysia Turkey Gökhan Elektrik San. Tic. Ltd. Sti. Perpa Elektrikçiler Is Merkezi A Blok Kat:7-8-9 No.694 80270 Okmeydani/Istanbul Phone +90(212) 2213236 (pbx) Fax +90(212) 2213240 gokhan@gokhanelektrik.com.tr www.gokhanelektrik.com Turkmenistan see Eastern Europe Ukraine see Eastern Europe Other countries and general contact HARTING Electric GmbH & Co. KG P.O. Box 1473, D-32328 Espelkamp Phone +49 5772 47-97100 Fax + 49 5772 47-495 electric@HARTING.com www.HARTING.com
09140122632 价格&库存
很抱歉,暂时无法提供与“09140122632”相匹配的价格&库存,您可以联系我们找货
  • 1+257.462331+33.23330
  • 10+240.3915510+31.02980
  • 50+159.4147950+20.57730
库存:75
