09210404601
09210404601
    HARTING(浩亭)
    INSERT MALE 46P+1GND TERM BLOCK
09210404601 数据手册
Han®-Terminal Block Connectors Contents Page Details of the Han®-Terminal block connector . . . . . . . . . . . . . . . . . . . . . . . 08.02 Technical characteristics Han D® AV . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 08.04 Han D® AV . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 08.05 Technical characteristics Han D® AV Distributor . . . . . . . . . . . . . . . . . . . . . 08.06 Han D® AV Distributor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 08.07 Technical characteristics Han E® AV / Han® ES AV . . . . . . . . . . . . . . . . . . 08.08 Han E® AV . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 08.09 Han® ES AV . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 08.10 Han®-Terminal block connectors accessories . . . . . . . . . . . . . . . . . . . . . . . 08.11 Han AV 08 . 01 Han D® AV Possibilities in switch cabinet Left or right hand mounting in the switch cabinet, therefore allows use of the same pre-prepared interface cable Details The terminal block connectors can be supplied for left hand or right hand applications. Hence the ground and connecting terminal for contact no. 1 will always be accessible from above in both types of installation. left hand version Distributor Internal use on standard rails in the switch cabinet in conjunction with Han-Snap® Han AV right hand version Terminal block connector Han D® AV Distributor versions for rail mounting Distributor lockable on standard rails or mountable at terminal block connector Han D® AV Assembly of terminal block connectors Terminal block connectors can be mounted from the inside of the switch cabinet into standard bulkhead housings. Therefore pre-assembly is possible. Standard bulkhead housing ,GHQWLᚏFDWLRQ 08 . 02 7KHLQGLYLGXDOWHUPLQDOVKDYHWKHVDPHLGHQWLᚏFDtion as on the mating face. In addition each circuit PD\EHVHSDUDWHO\ODEHOOHGZLWKLGHQWLᚏFDWLRQVWULSV ᚏWWHGLQWKHDGMDFHQWVORWV Terminal block connector Han D® AV Counterparts For suitable mating inserts of serie Han D® with crimp terminal please refer to the chapter 02. Han E® AV / Han® ES AV Possibilities in switch cabinet Left or right hand mounting in the switch cabinet, therefore allows use of the same pre-prepared interface cable Details The terminal block connectors can be supplied for left hand or right hand applications. Hence the ground and connecting terminal for contact no. 1 will always be accessible from above in both types of installation. left hand version right hand version Terminal block connector Han E® AV, Han® ES AV versions for rail mounting Internal use on standard rails in the switch cabinet in conjunction with Han-Snap® Han AV Assembly of terminal block connectors Male or female insert Housings bulkhead mounting Standard bulkhead housing Terminal block connector Han E® AV 7KHWHUPLQDOEORFNFRQQHFWRULVᚏ[HGLQWKHVWDQdard bulkhead housing in the normal way. Han E® AV and Han® ES AV with 16 and 24 pins can be mounted from the inside of the switch cabinet into standard bulkhead housings. Therefore pre-assembly is possible. ,GHQWLᚏFDWLRQ 7KHLQGLYLGXDOWHUPLQDOVKDYHWKHVDPHLGHQWLᚏFDtion as on the mating face. In addition each circuit PD\EHVHSDUDWHO\ODEHOOHGZLWKLGHQWLᚏFDWLRQVWULSV ᚏWWHGLQWKHDGMDFHQWVORWV Counterparts For suitable mating inserts of series Han E® and Han® ES with screw, cageclamp or crimp terminals please refer to the chapter 03. 08 . 03 Han D® AV Features Technical characteristics ವ For left hand or right hand applications available ವ PE and connecting terminal for contact no.1 are at the top in both types of installation ವ Mountable in standard bulkhead housing and on VWDQGDUGUDLOVE\XVLQJRIᚏ[LQJHOHPHQWV ವ Screw terminal with integrated wire protection 6SHFLᚏFDWLRQV Current carrying capacity The current carrying capacity of the connectors is limited by the thermal load capability of the contact element material including the connections and the insulating parts. The derating curve LVWKHUHIRUHYDOLGIRUFXUUHQWVZKLFKᚐRZFRQVWDQWO\ QRQLQWHUmittent) through each contact element of the connector evenly, ZLWKRXWH[FHHGLQJWKHDOORZHGPD[LPXPWHPSHUDWXUH Measuring and testing techniques according to DIN EN 60 512-5 Han AV Han® 40 D AV Approvals ',1(1 DIN EN 61 984 , Inserts Number of contacts 40, 64 + PE Electrical data acc. to EN 61 984 Rated current Rated voltage Rated impulse voltage Pollution degree 10 A 250 V 4 kV 3 10 A 250 V 4 kV 3 Pollution degree 2 also 10 A 230/400 V 4 kV 2 Rated voltage acc. to UL/CSA 600 V ,QVXODWLRQUHVLVWDQFH Material Limiting temperatures Flammability acc. to UL 94 Mechanical working life PDWLQJF\FOHV ุ10˖ polycarbonate -40 °C ... +125 °C V0 ุ Operating current Contacts Material Surface - mating side - termination side &RQWDFWUHVLVWDQFH copper alloy 3 μm Ag tin plated ืP˖ Screw terminal - Wire gauge1) - AWG - Tightening/test torque PPt 24 ... 14 0.5 Nm Ambient temperature Han® 64 D AV Hoods/Housings see chapter 30 / 31 Operating current ,GHQWLᚏFDWLRQVWULSV Ambient temperature 08 . 04 ᆰZLUHJDXJHPPt ᆱZLUHJDXJHPPt 1) geometric wire gauge the following identifcation strips may be used HARTING  Murrplastik .3; Weidmüller '(. 0XOWL&RQWRXU 0. .'67 3KRHQL[ DS 5 ZB 5 WAGO WSB 5 .:, Murrplastik .:, Single-Contour .:, 6. Wieland $ WAGO Mini-WSB Han D® AV 250 V 10 A Number of contacts 40, 64 + Identification Number of contacts Part number Male insert Female insert Drawing Dimensions in mm Left hand version Multi contour (MK) 40 64 09 21 040 4601 09 21 064 4601 09 21 040 4701 09 21 064 4701 Han AV Left hand version Single contour (SK) 40 64 09 21 040 4602 09 21 064 4602 09 21 040 4702 09 21 064 4702 40 64 09 21 040 4611 09 21 064 4611 09 21 040 4711 09 21 064 4711 40 64 09 21 040 4612 09 21 064 4612 09 21 040 4712 09 21 064 4712 Right hand version Multi contour (MK) Right hand version Single contour (SK) Han® 40 D AV Han® 64 D AV ➀ Contact arrangement for male insert ➁ Contact arrangement for female insert Han02_Kap08_RD .indd 5 a 51 81.5 b 77.5 104 Stock items in bold type 08 . 05 08 .12 .2008 12:07:49 Han D® AV Distributor Features Technical characteristics ವ Easy mounting direct adjacent to terminal block connector Han D® AV ವ %\XVLQJRIᚏ[LQJHOHPHQWVPRXQWDEOHRQVWDQGDUG rails ವ Screw terminal with integrated wire protection 6SHFLᚏFDWLRQV Approvals ',1(1 DIN EN 61 984 , Distributor 1XPEHURIFRQWDFWV 0RXQWLQJH[DPSOH Distributor on standard rail Distributor with teminal block connector Han D® AV Han AV [[ Electrical data acc. to EN 61 984 16 A 400/690 V 6 kV 3 Rated current 16 A Rated voltage conductor - ground 400 V Rated voltage conductor - conductor 690 V Rated impulse voltage 6 kV Pollution degree 3 Pollution degree 2 also 16 A 480/830 V 6 kV 2 Rated voltage acc. to UL/CSA 600 V ,QVXODWLRQUHVLVWDQFH Material Limiting temperatures Flammability acc. to UL 94 Mechanical working life PDWLQJF\FOHV ุ10˖ polycarbonate -40 °C ... +125 °C V0 ุ Contacts ContactsMaterial Surface - termination side copper alloy tin plated Screw terminal - Wire gauge1) - AWG - Tightening/test torque PPt 24 ... 14 0.5 Nm ,GHQWLᚏFDWLRQ 7KHLQGLYLGXDOWHUPLQDOVKDYHWKHVDPHLGHQWLᚏFDWLRQDVRQWKH mating face. In addition each circuit may be separately labelled ZLWKLGHQWLᚏFDWLRQVWULSVᚏWWHGLQWKHDGMDFHQWVORWV ,GHQWLᚏFDWLRQVWULSV WKHIROORZLQJLGHQWLᚏFDWLRQVWULSVPD\EHXVHG HARTING  Murrplastik .3; .'67 3KRHQL[ ZB 5 DS 5 08 . 06 1) geometric wire gauge Han D® AV Distributor 400/690 V 16 A Number of contacts [[ ,GHQWLᚏFDWLRQ Terminals Part number Drawing Dimensions in mm Distributor with screw terminals Han AV 20 09 42 020 0111 [ 09 42 020 0121 [ 09 42 020 0131 Optionally mountable on terminal block connectors Han D® AV Stock items in bold type 08 . 07 Han E® AV / Han® ES AV Features Technical characteristics ವ For left hand or right hand applications available ವ PE and connecting terminal for contact no.1 are at the top in both types of installation ವ Mountable in standard bulkhead housing and on VWDQGDUGUDLOVE\XVLQJRIᚏ[LQJHOHPHQWV ವ Screw terminal with integrated wire protection at Han E® AV ವ Cage-clamp terminal at Han® ES AV 6SHFLᚏFDWLRQV Current carrying capacity The current carrying capacity of the connectors is limited by the thermal load capability of the contact element material including the connections and the insulating parts. The derating curve LVWKHUHIRUHYDOLGIRUFXUUHQWVZKLFKᚐRZFRQVWDQWO\ QRQLQWHUmittent) through each contact element of the connector evenly, ZLWKRXWH[FHHGLQJWKHDOORZHGPD[LPXPWHPSHUDWXUH Measuring and testing techniques according to DIN EN 60 512-5  [   [ 3( Electrical data acc. to EN 61 984 Rated current Rated voltage Rated impulse voltage Pollution degree 16 A 500 V 6 kV 3 16 A 500 V 6 kV 3 Pollution degree 2 also 16 A 400/690 V 6 kV 2 Rated voltage acc. to UL/CSA 5DWHGFXUUHQWDFFWR8/&6$ 600 V $ RQO\IRU+DQ® ES) ุ10˖ polycarbonate -40 °C ... +125 °C V0 ุ Operating current Material Surface - mating side - termination side &RQWDFWUHVLVWDQFH copper alloy 3 μm Ag tin plated ืP˖ Screw terminal - Wire gauge1) - AWG - Tightening/test torque PPt 24 ... 14 0.5 Nm Cage clamp terminal - Wire gauge1) - AWG PPt 26 ... 14 ,GHQWLᚏFDWLRQVWULSV+DQ(® AV Ambient temperature ᆰ+DQ® 6 E AV / Han® 6 ES AV ᆱ+DQ® 10 E AV / Han® 10 ES AV ᆲ+DQ® 16 E AV / Han® 16 ES AV ᆳ+DQ® 24 E AV / Han® 24 ES AV 1) 1XPEHURIFRQWDFWV Contacts Ambient temperature 08 . 08 Inserts ,QVXODWLRQUHVLVWDQFH Material Limiting temperatures Flammability acc. to UL 94 Mechanical working life PDWLQJF\FOHV Operating current Han AV Approvals ',1(1 DIN EN 61 984 , geometric wire gauge WKHIROORZLQJLGHQWLᚏFDWLRQVWULSVPD\EHXVHG +$57,1* [  Murrplastik .3; 0XOWLFRQWRXU 0. Weidmüller '(. 3KRHQL[ .'67 WAGO WSB Murrplastik .:, 6LQJOHFRQWRXU 6. Wieland $ WAGO Mini-WSB ,GHQWLᚏFDWLRQVWULSV+DQ® ES AV WKHIROORZLQJLGHQWLᚏFDWLRQVWULSVPD\EHXVHG +$57,1* [  Murrplastik .:, 6LQJOHFRQWRXU 6. Wieland $ WAGO Mini-WSB Han E® AV 500 V 16 A Number of contacts 6, 10, 16, 24 + ,GHQWLᚏFDWLRQ Number of contacts Part number Male insert Female insert Drawing Dimensions in mm Left hand version 0XOWLFRQWRXU 0. 6 10 16 24 09 33 006 4625 09 33 010 4625 09 33 016 4625 09 33 024 4625 09 33 006 4725 09 33 010 4725 09 33 016 4725 09 33 024 4725 Han AV Left hand version 6LQJOHFRQWRXU 6. 6 10 16 24 09 33 006 4626 09 33 010 4626 09 33 016 4626 09 33 024 4626 09 33 006 4726 09 33 010 4726 09 33 016 4726 09 33 024 4726 6 10 16 24 09 33 006 4635 09 33 010 4635 09 33 016 4635 09 33 024 4635 09 33 006 4735 09 33 010 4735 09 33 016 4735 09 33 024 4735 6 10 16 24 09 33 006 4636 09 33 010 4636 09 33 016 4636 09 33 024 4636 09 33 006 4736 09 33 010 4736 09 33 016 4736 09 33 024 4736 Right hand version 0XOWLFRQWRXU 0. Right hand version 6LQJOHFRQWRXU 6. Han® 6 E AV Han® 10 E AV Han® 16 E AV Han® 24 E AV ᆰ&RQWDFWDUUDQJHPHQWIRUPDOHLQVHUW ᆱ&RQWDFWDUUDQJHPHQWIRUIHPDOHLQVHUW a 20 34 54 81 b 44   104 Stock items in bold type 08 . 09 Han® ES AV 500 V 16 A Number of contacts 6, 10, 16, 24 + ,GHQWLᚏFDWLRQ Number of contacts Part number Male insert Female insert Drawing Dimensions in mm Left hand version 6LQJOHFRQWRXU 6. 6 10 16 24 09 33 006 4629 09 33 010 4629 09 33 016 4629 09 33 024 4629 09 33 006 4729 09 33 010 4729 09 33 016 4729 09 33 024 4729 6 10 16 24 09 33 006 4639 09 33 010 4639 09 33 016 4639 09 33 024 4639 09 33 006 4739 09 33 010 4739 09 33 016 4739 09 33 024 4739 Han AV Right hand version 6LQJOHFRQWRXU 6. Han® 6 ES AV Han® 10 ES AV Han® 16 ES AV Han® 24 ES AV 08 . 10 ᆰ&RQWDFWDUUDQJHPHQWIRUPDOHLQVHUW ᆱ&RQWDFWDUUDQJHPHQWIRUIHPDOHLQVHUW a 20 34 54 81 b 44   104 Stock items in bold type Accessories ,GHQWLᚏFDWLRQ Part number Drawing Dimensions in mm )L[LQJHOHPHQW for Terminal block connector Han D® AV, Han E® AV, Distributor 09 33 000 9928 Terminal block connector Han D® AV Han AV )L[LQJHOHPHQW C-rail ',1(1& G-rail ',1(1* Rail ',1(1[ RU[ )L[LQJHOHPHQW for Terminal block connector Han® ES AV Terminal block connector Han® ES AV 09 33 000 9929 )L[LQJHOHPHQW C-rail ',1(1& G-rail ',1(1* Rail ',1(1[ RU[ There are moulded slots at the rear of the terminal block connectors and distriEXWRUVWRDFFHSWWKHᚏ[LQJHOHPHQWV:KHQXVHGWKHVHHOHPHQWVIRUH[DPSOH can be used to secure the connectors inside the switch cabinets on standard rails. For mounting Han® 6 E AV, Han®(6$9 ᚏ[LQJHOHPHQW Han® 10/16/24 E AV, Han®(6$9 ᚏ[LQJHOHPHQWV Han®'$9 ᚏ[LQJHOHPHQWV 'LVWULEXWRU ᚏ[LQJHOHPHQW Stock items in bold type 08 . 11 Accessories ,GHQWLᚏFDWLRQ Part number Drawing Dimensions in mm ,GHQWLᚏFDWLRQVWULSV 88 pieces in one block 0.FRQWRXU 5 mm width 09 21 000 9971 for Terminal block connector Han D® AV and Distributor 10 mm long 09 33 000 9971 for Terminal block connector Han E® AV 15 mm long 09 33 000 9973 for Terminal block connector Han® ES AV 10 mm long Han AV ,GHQWLᚏFDWLRQVWULSV 64 pieces in one block 0.FRQWRXU 6 mm width Adapter for Han E® AV WRᚏWLGHQWLᚏFDWLRQ VWULSV 6.FRQWRXU Han® 6 E AV 09 33 000 9964 Han® 10 E AV 09 33 000 9965 Han® 16 E AV 09 33 000 9966 Han® 24 E AV 09 33 000 9967 Han® 6 E AV Han® 10 E AV Han® 16 E AV Han® 24 E AV 08 . 12 a 26.8 40.2 60.3  Stock items in bold type
09210404601 价格&库存
很抱歉,暂时无法提供与“09210404601”相匹配的价格&库存,您可以联系我们找货
