15404094BA420
15404094BA420
    WURTHELEKTRONIKIBE
    15404094BA420
15404094BA420 数据手册
Dimensions: [mm] Recommended Land Pattern: [mm] Absolute Maximum Ratings (Ambient Temperature 25°C): Properties Polarity Mark 2 Unit PDiss 0.14 W Peak Forward Current IF Peak 500 mA Continuous Forward Current 2 1 IF 70 mA VREV 5 V VESD HBM 2000 V Reverse Voltage ESD Threshold/ Human Body Model 0,5 0,25 ±0,1 0,5 ±0,1 1 Value Power Dissipation 1,0 ±0,1 0,5 ±0,1 0,65 1 0,5 0,65 Optical Properties: Chip Technology AlGaAs Emitting Color Infrared Lens Type 2 Chip LED Waterclear Scale - 20:1 Schematic: Polarity Mark 2 0,25 ±0,1 Operating Temperature 0,5 ±0,1 1 General Information: Storage Conditions (in original packaging) < 40 °C ; < 90 % RH -40 up to +85 °C + - Storage Conditions (for single parts) 1 2 Moisture Sensitivity Level (MSL) 3 0,5 ±0,1 1,0 ±0,1 -40 up to +85 °C  IR LEDs emit high intensity IR light.  Do not look directly into the LED during operation. This can be harmful to your eyes.  Wear protective eyewear.  Please follow safety precautions given in  IEC 60825-1 and IEC 62471.  Keep out of reach of children. Avoid direct eye and skin exposure to LED! CAUTION – IR 1 2 Scale - 12:1 Würth Elektronik eiSos GmbH & Co. KG EMC & Inductive Solutions Max-Eyth-Str. 1 74638 Waldenburg Germany Tel. +49 (0) 79 42 945 - 0 www.we-online.com eiSos@we-online.com CREATED CHECKED GENERAL TOLERANCE DaSc ZAn DIN ISO 2768-1m PROJECTION METHOD DESCRIPTION WL-SICW SMT Infrared Chip LED Waterclear ORDER CODE 15404094BA420 SIZE REVISION STATUS DATE (YYYY-MM-DD) BUSINESS UNIT PAGE 0402 001.000 Valid 2018-10-19 eiPal 1/8 This electronic component has been designed and developed for usage in general electronic equipment only. This product is not authorized for use in equipment where a higher safety standard and reliability standard is especially required or where a failure of the product is reasonably expected to cause severe personal injury or death, unless the parties have executed an agreement specifically governing such use. Moreover Würth Elektronik eiSos GmbH & Co KG products are neither designed nor intended for use in areas such as military, aerospace, aviation, nuclear control, submarine, transportation (automotive control, train control, ship control), transportation signal, disaster prevention, medical, public information network etc.. Würth Elektronik eiSos GmbH & Co KG must be informed about the intent of such usage before the design-in stage. In addition, sufficient reliability evaluation checks for safety must be performed on every electronic component which is used in electrical circuits that require high safety and reliability functions or performance. Electrical & Optical Properties: Properties Peak Wavelength Centroid Wavelength Viewing Angle: Test conditions λPeak 70 mA Value min. typ. 940 λCentroid 70 mA Radiant Intensity Ie 70 mA Forward Voltage VF 70 mA 1.4 Spectral Bandwidth Δλ 70 mA 40 Reverse Current IREV 5V Viewing Angle Phi 0° 2θ50% 70 mA max. 3 Unit nm 940 nm 5 mW/sr 2 V nm 10 µA 140 ° 0° -70 10° 100 20° 30° Relative Luminous Intensity (%) 90 40° 80 45° 70 50° 60 50 60° 40 70° 70° 30 20 80° 10 90° -90 Würth Elektronik eiSos GmbH & Co. KG EMC & Inductive Solutions Max-Eyth-Str. 1 74638 Waldenburg Germany Tel. +49 (0) 79 42 945 - 0 www.we-online.com eiSos@we-online.com -45 0 10 20 CREATED CHECKED GENERAL TOLERANCE DaSc ZAn DIN ISO 2768-1m 30 40 50 60 70 80 90 100 PROJECTION METHOD DESCRIPTION WL-SICW SMT Infrared Chip LED Waterclear ORDER CODE 15404094BA420 SIZE REVISION STATUS DATE (YYYY-MM-DD) BUSINESS UNIT PAGE 0402 001.000 Valid 2018-10-19 eiPal 2/8 This electronic component has been designed and developed for usage in general electronic equipment only. This product is not authorized for use in equipment where a higher safety standard and reliability standard is especially required or where a failure of the product is reasonably expected to cause severe personal injury or death, unless the parties have executed an agreement specifically governing such use. Moreover Würth Elektronik eiSos GmbH & Co KG products are neither designed nor intended for use in areas such as military, aerospace, aviation, nuclear control, submarine, transportation (automotive control, train control, ship control), transportation signal, disaster prevention, medical, public information network etc.. Würth Elektronik eiSos GmbH & Co KG must be informed about the intent of such usage before the design-in stage. In addition, sufficient reliability evaluation checks for safety must be performed on every electronic component which is used in electrical circuits that require high safety and reliability functions or performance. Spectral: Relative Radiant Intensity vs. Forward Current: 4.0 100 3.5 80 Relative Radiant Intensity Relative Intensity [%] 3.0 60 40 2.5 2.0 1.5 20 1.0 0.5 0 400 500 600 700 800 900 1000 1100 0.0 Wavelength [nm] 0 50 100 150 200 250 Forward Current [mA] Würth Elektronik eiSos GmbH & Co. KG EMC & Inductive Solutions Max-Eyth-Str. 1 74638 Waldenburg Germany Tel. +49 (0) 79 42 945 - 0 www.we-online.com eiSos@we-online.com CREATED CHECKED GENERAL TOLERANCE DaSc ZAn DIN ISO 2768-1m PROJECTION METHOD DESCRIPTION WL-SICW SMT Infrared Chip LED Waterclear ORDER CODE 15404094BA420 SIZE REVISION STATUS DATE (YYYY-MM-DD) BUSINESS UNIT PAGE 0402 001.000 Valid 2018-10-19 eiPal 3/8 This electronic component has been designed and developed for usage in general electronic equipment only. This product is not authorized for use in equipment where a higher safety standard and reliability standard is especially required or where a failure of the product is reasonably expected to cause severe personal injury or death, unless the parties have executed an agreement specifically governing such use. Moreover Würth Elektronik eiSos GmbH & Co KG products are neither designed nor intended for use in areas such as military, aerospace, aviation, nuclear control, submarine, transportation (automotive control, train control, ship control), transportation signal, disaster prevention, medical, public information network etc.. Würth Elektronik eiSos GmbH & Co KG must be informed about the intent of such usage before the design-in stage. In addition, sufficient reliability evaluation checks for safety must be performed on every electronic component which is used in electrical circuits that require high safety and reliability functions or performance. Forward Current vs. Forward Voltage: Derating Curve: 90 250.0 80 70 Forward Currennt (mA) Forward Current [mA] 200.0 150.0 100.0 60 50 40 30 20 50.0 10 0 0.0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 0 10 20 30 40 50 60 70 Ambient Temperature (℃) 80 90 100 Forward Voltage [V] Würth Elektronik eiSos GmbH & Co. KG EMC & Inductive Solutions Max-Eyth-Str. 1 74638 Waldenburg Germany Tel. +49 (0) 79 42 945 - 0 www.we-online.com eiSos@we-online.com CREATED CHECKED GENERAL TOLERANCE DaSc ZAn DIN ISO 2768-1m PROJECTION METHOD DESCRIPTION WL-SICW SMT Infrared Chip LED Waterclear ORDER CODE 15404094BA420 SIZE REVISION STATUS DATE (YYYY-MM-DD) BUSINESS UNIT PAGE 0402 001.000 Valid 2018-10-19 eiPal 4/8 This electronic component has been designed and developed for usage in general electronic equipment only. This product is not authorized for use in equipment where a higher safety standard and reliability standard is especially required or where a failure of the product is reasonably expected to cause severe personal injury or death, unless the parties have executed an agreement specifically governing such use. Moreover Würth Elektronik eiSos GmbH & Co KG products are neither designed nor intended for use in areas such as military, aerospace, aviation, nuclear control, submarine, transportation (automotive control, train control, ship control), transportation signal, disaster prevention, medical, public information network etc.. Würth Elektronik eiSos GmbH & Co KG must be informed about the intent of such usage before the design-in stage. In addition, sufficient reliability evaluation checks for safety must be performed on every electronic component which is used in electrical circuits that require high safety and reliability functions or performance. Packaging Specification - Tape and Reel: [mm] W3 K0 P0 T W1 close to center B A F B0 E2 W C W2 Top Cover Tape A0 A N D0 E1 P2 D A P1 T1 D1 T2 End Feeding direction Start detail B Carrier Tape B Cover Tape Cover Tape Chip Cavity Sprocket Hole Polarity Mark No Component min. 160mm Components Embossment No Component min. 100mm Cover Tape min. 400mm A (mm) ± 2,0 178 Orientation: Cathode on top Packaging is reffered to the international standard IEC 60286-3:2013 tolerance value A0 typ. 0,60 B0 typ. 1,10 W +0,3/ -0,1 8,00 T ref. 0,23 T1 max. 0,10 T2 typ. 1.089 K0 typ. 0,66 P0 ±0,1 4,00 P1 ±0,05 2,00 P2 ±0,05 2,00 D0 +0,1/ -0,0 1,50 D1 min. 0,30 E1 ±0,1 1,75 E2 min. 6,25 F ±0,05 3,50 Würth Elektronik eiSos GmbH & Co. KG EMC & Inductive Solutions 165° - 180° Max-Eyth-Str. 1 74638 Waldenburg Germany Tel. +49 (0) 79 42 945 - 0 www.we-online.com eiSos@we-online.com Pull-of force Tape width 8 mm 0,1 N - 1,0 N Tape type 2a Polystyrene B (mm) min. 1.5 C (mm) min. 12.8 D (mm) min. 20.2 N (mm) min. 50 W1 (mm) +1,5 8.4 W2 (mm) max. 14.4 W3 (mm) min. 7.9 W3 (mm) max. 10.9 Material Polystyrene/ Polyurethane Packaging Unit pcs. 4000 CREATED CHECKED GENERAL TOLERANCE DaSc ZAn DIN ISO 2768-1m PROJECTION METHOD DESCRIPTION WL-SICW SMT Infrared Chip LED Waterclear ORDER CODE 15404094BA420 SIZE REVISION STATUS DATE (YYYY-MM-DD) BUSINESS UNIT PAGE 0402 001.000 Valid 2018-10-19 eiPal 5/8 This electronic component has been designed and developed for usage in general electronic equipment only. This product is not authorized for use in equipment where a higher safety standard and reliability standard is especially required or where a failure of the product is reasonably expected to cause severe personal injury or death, unless the parties have executed an agreement specifically governing such use. Moreover Würth Elektronik eiSos GmbH & Co KG products are neither designed nor intended for use in areas such as military, aerospace, aviation, nuclear control, submarine, transportation (automotive control, train control, ship control), transportation signal, disaster prevention, medical, public information network etc.. Würth Elektronik eiSos GmbH & Co KG must be informed about the intent of such usage before the design-in stage. In addition, sufficient reliability evaluation checks for safety must be performed on every electronic component which is used in electrical circuits that require high safety and reliability functions or performance. Classification Reflow Profile for SMT components: Classification Reflow Soldering Profile: Profile Feature Tp tp Max. Ramp Up Rate Max. Ramp Down Rate TL Temperature Ts max TC –5°C Ts min 150 °C Preheat Temperature Max Ts max 200 °C Preheat Time ts from Ts min to Ts max ts Ramp-up Rate (TL to TP) Ts min max. 60 - 120 seconds 3 °C/ second max. Liquidous Temperature tL Preheat Area Value Preheat Temperature Min TL 217 °C Time tL maintained above TL tL max. 60 seconds Peak package body temperature Tp see table Time within 5°C of actual peak temperaure tp max. 10 seconds Ramp-down Rate (TL to TP) 6 °C/ second max. Time 25°C to peak temperature max. 220 seconds refer to IPC/ JEDEC J-STD-020E tS Package Classification Reflow Temperature: 25 Time 25°C to Peak Time Properties Volume mm³ 2000 PB-Free Assembly | Package Thickness < 1.6 mm 260 °C 260 °C 260 °C PB-Free Assembly | Package Thickness 1.6 mm - 2.5 mm 260 °C 250 °C 245 °C PB-Free Assembly | Package Thickness ≥ 2.5 mm 250 °C 245 °C 245 °C Applied cycles 2 cycles max. refer to IPC/ JEDEC J-STD-020E Würth Elektronik eiSos GmbH & Co. KG EMC & Inductive Solutions Max-Eyth-Str. 1 74638 Waldenburg Germany Tel. +49 (0) 79 42 945 - 0 www.we-online.com eiSos@we-online.com CREATED CHECKED GENERAL TOLERANCE DaSc ZAn DIN ISO 2768-1m PROJECTION METHOD DESCRIPTION WL-SICW SMT Infrared Chip LED Waterclear ORDER CODE 15404094BA420 SIZE REVISION STATUS DATE (YYYY-MM-DD) BUSINESS UNIT PAGE 0402 001.000 Valid 2018-10-19 eiPal 6/8 This electronic component has been designed and developed for usage in general electronic equipment only. This product is not authorized for use in equipment where a higher safety standard and reliability standard is especially required or where a failure of the product is reasonably expected to cause severe personal injury or death, unless the parties have executed an agreement specifically governing such use. Moreover Würth Elektronik eiSos GmbH & Co KG products are neither designed nor intended for use in areas such as military, aerospace, aviation, nuclear control, submarine, transportation (automotive control, train control, ship control), transportation signal, disaster prevention, medical, public information network etc.. Würth Elektronik eiSos GmbH & Co KG must be informed about the intent of such usage before the design-in stage. In addition, sufficient reliability evaluation checks for safety must be performed on every electronic component which is used in electrical circuits that require high safety and reliability functions or performance. Cautions and Warnings: Storage Conditions: The following conditions apply to all goods within the product series of Optoelectronic Components of Würth Elektronik eiSos GmbH & Co. KG: General: • This electronic component was designed and manufactured for use in general electronic equipment. • Würth Elektronik must be asked for written approval (following the PPAP procedure) before incorporating the components into any equipment in fields such as military, aerospace, aviation, nuclear control, submarine, transportation (automotive control, train control, ship control), transportation signal, disaster prevention, medical, public information network, etc. where higher safety and reliability are especially required and/or if there is the possibility of direct damage or human injury. • Electronic components that will be used in safety-critical or high-reliability applications, should be pre-evaluated by the customer. • The component was designed and manufactured to be used within the datasheet specified values. If the usage and operation conditions specified in the datasheet are not met, the component may be damaged or dissolved. • Do not drop or impact the components, as the LED body may flake apart. • Würth Elektronik products are qualified according to international standards, which are listed in each product reliability report. Würth Elektronik does not guarantee any customer qualified product characteristics beyond Würth Elektroniks’ specifications, for its validity and sustainability over time. • The customer is responsible for the functionality of their own products. All technical specifications for standard products also apply to customer specific products. • A storage of Würth Elektronik products for longer than 12 months is not recommended. Within other effects, the terminals may suffer degradation, resulting in bad solderability. Therefore, all products shall be used within the period of 12 months based on the day of shipment. • Do not expose the components to direct sunlight. • The storage conditions in the original packaging are defined according to DIN EN 61760-2. • If there is a moisture sensitive component, the storage condition in the original packaging is defined according to IPC/JEDEC-JSTD-033. It is also recommended to return the component to the original moisture proof bag and reseal the moisture proof bag again. Handling: • Violation of the technical product specifications such as exceeding the nominal rated current, will void the warranty. • Product design might influence the automatic optical inspection. • Certain LED surfaces consist of soft material. Pressure on the top surface has to be handled carefully to prevent negative influence to the function and reliability of the LEDs. • ESD prevention methods need to be applied for manual handling and processing by machinery. • Resistors for protection are obligatory. • Luminaires in operation could harm human vision or skin on a photo-biological level, therefore direct light impact shall be avoided. All products are additionally certified as risk groups 0 to 2 according to DIN EN 62471:2008. • In addition to LEDs testing, products which incorporate these devices have to follow the safety precautions given in IEC 60825-1 and IEC 62471. Product specific: Technical specification: Soldering: • The solder profile must comply with the Würth Elektronik technical soldering specification. All other profiles will void the warranty. • All other soldering methods are at the customer’s own risk. Cleaning and Washing: • Washing agents used during the production to clean the customer application might damage or change the characteristics of the LED body, marking or plating. Washing agents may have a negative effect on the long-term functionality of the product. • Using a brush during the cleaning process could break the LED body. Therefore, we do not recommend using a brush during the PCB cleaning process. • The typical and/or calculated values of technical parameters can only reflect statistical figures. The actual parameters of each single product, may differ from the typical and/or calculated values or the typical characteristic line. • On each reel, only one bin is sorted and taped. The bin is defined on intensity, chromaticity coordinate or wavelength and forward voltage. • In order to ensure highest availability, the reel binning of standard deliveries can vary. A single bin cannot be ordered. Please contact us in advance, if you need a particular bin sorting before placing your order to clarify the lead time, MOQ and pricing. These cautions and warnings comply with the state of the scientific and technical knowledge and are believed to be accurate and reliable. However, no responsibility is assumed for inaccuracies or incompleteness. Potting: • If the product is potted in the costumer application, the potting material might shrink or expand during and after hardening. Shrinking could lead to an incomplete seal, allowing contaminants into the LED body, pins or termination. Expansion could damage the LED body, pins or termination. We recommend a manual inspection after potting to avoid these effects. Würth Elektronik eiSos GmbH & Co. KG EMC & Inductive Solutions Max-Eyth-Str. 1 74638 Waldenburg Germany Tel. +49 (0) 79 42 945 - 0 www.we-online.com eiSos@we-online.com CREATED CHECKED GENERAL TOLERANCE DaSc ZAn DIN ISO 2768-1m PROJECTION METHOD DESCRIPTION WL-SICW SMT Infrared Chip LED Waterclear ORDER CODE 15404094BA420 SIZE REVISION STATUS DATE (YYYY-MM-DD) BUSINESS UNIT PAGE 0402 001.000 Valid 2018-10-19 eiPal 7/8 This electronic component has been designed and developed for usage in general electronic equipment only. This product is not authorized for use in equipment where a higher safety standard and reliability standard is especially required or where a failure of the product is reasonably expected to cause severe personal injury or death, unless the parties have executed an agreement specifically governing such use. Moreover Würth Elektronik eiSos GmbH & Co KG products are neither designed nor intended for use in areas such as military, aerospace, aviation, nuclear control, submarine, transportation (automotive control, train control, ship control), transportation signal, disaster prevention, medical, public information network etc.. Würth Elektronik eiSos GmbH & Co KG must be informed about the intent of such usage before the design-in stage. In addition, sufficient reliability evaluation checks for safety must be performed on every electronic component which is used in electrical circuits that require high safety and reliability functions or performance. Important Notes 6. Product Life Cycle The following conditions apply to all goods within the product range of Würth Elektronik eiSos GmbH & Co. KG: Due to technical progress and economical evaluation we also reserve the right to discontinue production and delivery of products. As a standard reporting procedure of the Product Termination Notification (PTN) according to the JEDEC-Standard we will inform at an early stage about inevitable product discontinuance. According to this we cannot guarantee that all products within our product range will always be available. Therefore it needs to be verified with the field sales engineer or the internal sales person in charge about the current product availability expectancy before or when the product for application design-in disposal is considered. The approach named above does not apply in the case of individual agreements deviating from the foregoing for customer-specific products. 1. General Customer Responsibility Some goods within the product range of Würth Elektronik eiSos GmbH & Co. KG contain statements regarding general suitability for certain application areas. These statements about suitability are based on our knowledge and experience of typical requirements concerning the areas, serve as general guidance and cannot be estimated as binding statements about the suitability for a customer application. The responsibility for the applicability and use in a particular customer design is always solely within the authority of the customer. Due to this fact it is up to the customer to evaluate, where appropriate to investigate and decide whether the device with the specific product characteristics described in the product specification is valid and suitable for the respective customer application or not. 2. Customer Responsibility related to Specific, in particular Safety-Relevant Applications It has to be clearly pointed out that the possibility of a malfunction of electronic components or failure before the end of the usual lifetime cannot be completely eliminated in the current state of the art, even if the products are operated within the range of the specifications. In certain customer applications requiring a very high level of safety and especially in customer applications in which the malfunction or failure of an electronic component could endanger human life or health it must be ensured by most advanced technological aid of suitable design of the customer application that no injury or damage is caused to third parties in the event of malfunction or failure of an electronic component. Therefore, customer is cautioned to verify that data sheets are current before placing orders. The current data sheets can be downloaded at www.we-online.com. 7. Property Rights All the rights for contractual products produced by Würth Elektronik eiSos GmbH & Co. KG on the basis of ideas, development contracts as well as models or templates that are subject to copyright, patent or commercial protection supplied to the customer will remain with Würth Elektronik eiSos GmbH & Co. KG. Würth Elektronik eiSos GmbH & Co. KG does not warrant or represent that any license, either expressed or implied, is granted under any patent right, copyright, mask work right, or other intellectual property right relating to any combination, application, or process in which Würth Elektronik eiSos GmbH & Co. KG components or services are used. 8. General Terms and Conditions Unless otherwise agreed in individual contracts, all orders are subject to the current version of the “General Terms and Conditions of Würth Elektronik eiSos Group”, last version available at www.we-online.com. 3. Best Care and Attention Any product-specific notes, cautions and warnings must be strictly observed. Any disregard will result in the loss of warranty. 4. Customer Support for Product Specifications Some products within the product range may contain substances which are subject to restrictions in certain jurisdictions in order to serve specific technical requirements. Necessary information is available on request. In this case the field sales engineer or the internal sales person in charge should be contacted who will be happy to support in this matter. 5. Product R&D Due to constant product improvement product specifications may change from time to time. As a standard reporting procedure of the Product Change Notification (PCN) according to the JEDEC-Standard inform about minor and major changes. In case of further queries regarding the PCN, the field sales engineer or the internal sales person in charge should be contacted. The basic responsibility of the customer as per Section 1 and 2 remains unaffected. Würth Elektronik eiSos GmbH & Co. KG EMC & Inductive Solutions Max-Eyth-Str. 1 74638 Waldenburg Germany Tel. +49 (0) 79 42 945 - 0 www.we-online.com eiSos@we-online.com CREATED CHECKED GENERAL TOLERANCE DaSc ZAn DIN ISO 2768-1m PROJECTION METHOD DESCRIPTION WL-SICW SMT Infrared Chip LED Waterclear ORDER CODE 15404094BA420 SIZE REVISION STATUS DATE (YYYY-MM-DD) BUSINESS UNIT PAGE 0402 001.000 Valid 2018-10-19 eiPal 8/8 This electronic component has been designed and developed for usage in general electronic equipment only. This product is not authorized for use in equipment where a higher safety standard and reliability standard is especially required or where a failure of the product is reasonably expected to cause severe personal injury or death, unless the parties have executed an agreement specifically governing such use. Moreover Würth Elektronik eiSos GmbH & Co KG products are neither designed nor intended for use in areas such as military, aerospace, aviation, nuclear control, submarine, transportation (automotive control, train control, ship control), transportation signal, disaster prevention, medical, public information network etc.. Würth Elektronik eiSos GmbH & Co KG must be informed about the intent of such usage before the design-in stage. In addition, sufficient reliability evaluation checks for safety must be performed on every electronic component which is used in electrical circuits that require high safety and reliability functions or performance.
15404094BA420 价格&库存
很抱歉,暂时无法提供与“15404094BA420”相匹配的价格&库存,您可以联系我们找货
