20825000002
20825000002
    HARTING(浩亭)
20825000002 数据手册
The key technology for Ethernet cabling. Ha-VIS preLink® Ha-VIS preLink® A superior combination of speed and reliability: the Ha-VIS preLink® Ha-V IS now preLink ® a acros vailable s prod the full uct r ange HARTING's Ha-VIS preLink® is a complete solution for implementing Ethernet cabling. This system solution is a comprehensive product range that offers versatile swappable mating profiles, device interfaces and corresponding junction boxes. The Ha-VIS preLink® termination block is at the heart of the system: it can be wired with total safety in one step using our preLink® crimping tool. This ensures that your cabling remains versatile and sustainable into the future – with 100% process reliability! The same three simple steps are required for each installation: 1 The cable wires are inserted into the Ha-VIS preLink® termination block according to their colour codes. 2 The Ha-VIS preLink® crimping tool ensures that the wires are always assembled precisely and correctly. 3 The wired Ha-VIS preLink® termination block can then easily be snapped onto a variety of different Ha-VIS preLink® mating profiles. The Ha-VIS preLink® RJ45 connector For PROFINET connections The Han® PushPull V14 preLink® RJ45 connector For AIDA interfaces The Ha-VIS preLink® M12 D-coded connector For sensor interfaces The Ha-VIS preLink® M12 X-coded connector For railway applications The Ha-VIS preLink® RJ45 jack HIFF-format For panel feed throughs and service interfaces The Ha-VIS preLink® RJ45 Keystone jack For electrical cabinet patch panels and outlets The Ha-VIS preLink® Extender For cable extensions and cable transitions: solid-stranded Ha-VIS preLink® Ha-VIS preLink® The Ha-VIS preLink® An overview of the advantages: RJ45 connector  Swappable mating profiles: for versatile and sustainable Ethernet cabling  Our Ha-VIS preLink® assembly tool ensures a reliable installation process  Easy, quick installation in cramped spaces  Pre-assembled cable segments can be swapped out quickly during maintenance and upgrades  Robust and compact  For safe installation – even in difficult situations  Optimised external dimensions provide exceptional plugging reliability for industrial switches  Comprehensive system-based product portfolio for automation, railway and energy applications IP20 CAT. 6A har-port service interfaces  Attractive service interfaces for initial commissioning and servicing  Fits into any housing opening with a standardised M22.5 panel cut-out – thanks to our compact HIFF (HARTING industrial form factor) RJ45 jack IP20 CAT. 6A DIN rail outlet  Easy to install on the DIN rail  Integrated shield connection to DIN rails in the electrical cabinet  Small space saving design  Compatible with standardised Keystone-format IP20 CAT. 6A Han® PushPull connector Electrical cabinet interface and device interface  Standardised and easy-to-operate PushPull interface  PROFINET-compliant  Quick and reliable installation – also for IP65 / IP67 degree of protection IP65 IP67 CAT. 6A Industrial junction boxes  Robust, indestructible junction boxes for Han® 3 A und PushPull interfaces  With optimised cable clamp – so that the cable can be conveniently assembled outside the junction box.  Quick and reliable installation – also for IP65 / IP67 degree of protection IP65 IP67 CAT. 6A M12 connector  Proven M12 robustness  PROFINET-compliant  Quick and reliable installation – also for IP65 / IP67 degree of protection  Quick upgrades from Fast Ethernet to Gigabit Ethernet are possible – thanks to the uniform housings for 4-pole D-coded and 8-pole X-coded IP65 IP67 CAT. 5 CAT. 6A Patch panels and RJ45 jacks  Industrial 19"-format termination technique  Compatible to the standardised Keystone-format  Assembled with 24 Keystone jacks: available as ready-to-use system IP20 CAT. 6A Advantages Jacks DIN rail outlet 19" patch panel Junction boxes Device interfaces Service interfaces HIFF-format components 19" patch panel Jacks Components in Keystone-format  Standardised Keystone-format fits for 19" patch panels and outlets  Built-in protective cover Description Part number preLink® RJ45 jack with Cat. 6, Keystone-format incl. cable termination block AWG 24 – AWG 22 20 82 501 0001 preLink® RJ45 jack with Cat. 6, Keystone-format (without cable termination block) Angled version (without cable termination block) 20 82 500 0001 20 82 500 0002 (Package quantity: 24 pieces) 19" patch panel, Keystone-format, empty 20 82 400 0002 19" patch panel, Keystone-format assembled with 24 preLink® jacks for AWG 22 / 23 20 82 405 0001 DIN rail outlet, single Keystone-format, empty 09 45 851 0000 Cover plate set (with 2 covers) 09 45 851 0001 preLink® RJ45 jack with Cat. 6, HIFF-format incl. cable termination block AWG 24 – AWG 22 AWG 27 – AWG 26 20 82 001 0001 20 82 001 0002 preLink® RJ45 jack with Cat. 6, HIFF-format without cable termination block 20 82 000 0002  Fits with HIFF-format jacks  Movable jack carrier – helps to save time and money during the assembly process  Additional strain relief mechanism 19" patch panel, HIFF-format, empty 20 82 400 0001  Suitable for surface mount or installation in electrical cabinet Junction box assembled with 2 preLink® RJ45 HIFF-format jacks, for AWG 22 / 23 20 82 101 0220 Accessories for mounting on DIN rail 20 80 000 0003  Fits with all Keystone-format jacks  Inexpensive because of simple set up  Additional strain relief mechanism  Fits with all Keystone-format jacks  Built-in cover protects against dust  Labelling field  HIFF-format: for use in Han® 3 A, HARTING PushPull (V4), Han® PushPull (V14) and har-port  Robust aluminium die cast housing  Easy to assemble  E xternal attachment and earth connections  Degree of protection: IP65 / IP67  Fits with HIFF-format jacks  Standardised interfaces can be easily implemented in devices as well as electrical cabinets  Degree of protection: IP65 / IP67  Easy to assemble  Compact design  Available as standard in lengths from 0.20 m to 10.00 m Han® 3 A metal outlet, with 2 Han® 3 A RJ45 ports, assembled with 2 preLink® HIFF-format jacks, for AWG 22  /  23 Han® 20 82 102 0101 Han® PushPull (V14) metal outlet, with 2 PushPull RJ45 ports, assembled with 2 preLink® HIFF-format jacks, for AWG 22  /  23 20 82 104 0101 Han® 3 A bulkhead mounted housing Black plastic Grey plastic 09 20 003 0327 09 20 003 0301 Han® 3 A HIFF adapter for assembling the HIFF modules 09 45 515 0024 Han® PushPull (V14) bulkhead mounted housing for HIFF modules Black plastic Rectangular metal Round metal 09 35 012 0331 09 35 012 0311 09 35 012 0312 har-port RJ45 service interface, incl. HIFF coupling 09 45 452 1560 har-port panel feed through, suitable for holding HIFF modules 09 45 452 0000 har-port RJ45 service interface with cable (RJ45 jack to RJ45 plug) 09 45 452 1501 – 09 45 452 1518 Ha-VIS preLink® Advantages Description Part number preLink® RJ45 connector 20 82 101 0010  Compliant with PROFINET and AIDA  Proven PushPull locking mechanism Han® PushPull (V14) preLink® RJ45 connector Plastic 20 82 204 0001 Han® PushPull (V14) preLink® RJ45 connector Straight metal 45° angled metal 20 82 104 0001 20 82 104 0045  Standardised PROFINET connector Han® 3 A RJ45 preLink® insert 20 82 002 0001  E xtremely robust For industrial and railway usage preLink® M12 D-coded connector, 4 poles Han® 3 A Connector Han® PushPull RJ45  Industry-proven Available starting in Q 1 / 2015 Tool Accessories Termination blocks Coupling M12 preLink® M12 X-coded connector, 8 poles preLink® male insert, M12 D-coded, 4 poles 20 82 005 0001 20 82 005 0002 20 82 005 1214 preLink® male insert, M12 X-coded, 8 poles 20 82 006 1218 preLink® M12 housing, empty 20 82 000 1210  The simplest cable transition preLink® Extender Cat. 6A 20 82 101 0001  The cable termination is easy to assemble and ensures process reliability  Can be combined flexibly with all jacks and plugs preLink® cable termination block (AWG 24 – 22) for installation cable 20 82 000 0001 (Package quantity: 10 pieces) preLink® cable termination block (AWG 27 – 26) for flexible cable 20 82 000 0003 (Package quantity: 10 pieces)  Protects pre-assembled preLink® cables during feeding and routing preLink® protective cover 20 82 000 9915 (Package quantity: 10 pieces)  Simultaneously crimps all IDC contacts safely while cutting off all individual wires properly  The assembly is completed in one step  C ycling ratchet mechanism preLink® assembly tool 20 82 000 9901  For opening all RJ45 jacks quickly and easily preLink® release tool 20 82 000 9916 (Package quantity: 10 pieces) The Ha-VIS preLink® in action: Check out our Youtube clip. Find out more about the Ha-VIS preLink® now at  www.HARTING.com/preLink www.HARTING.ae www.HARTING.at www.HARTING.com.au www.HARTING.be www.HARTING.com.br www.HARTING.ca www.HARTING.ch www.HARTING.com.cn www.HARTING.cz www.HARTING.de www.HARTING.dk www.HARTING.es www.HARTING-easterneurope.com www.HARTING.fi HARTING.com – the gateway to your country website. www.HARTING.fr www.HARTING.co.uk www.HARTING.com.hk www.HARTING.hu www.HARTING.co.in www.HARTING.it www.HARTING.co.jp www.HARTING.co.kr www.HARTINGbv.nl www.HARTING.no www.HARTING.pl www.HARTING.pt www.HARTING.ro www.HARTING.ru www.HARTING.se www.HARTING.sg www.HARTING.sk www.HARTING.com.tr www.HARTING.com.tw www.HARTING-USA.com HARTING Technology Group info@HARTING.com www.HARTING.com MO / 2014-11-07 / 6.0 98 42 130 0201 Version 1 www.HARTING.co.za
20825000002 价格&库存
很抱歉,暂时无法提供与“20825000002”相匹配的价格&库存,您可以联系我们找货
  • 1+126.17405
  • 6+123.39356
  • 12+120.74844
库存:55
20825000002
  • 24+105.53816
  • 48+94.75796
  • 72+89.72720
  • 100+86.66083
  • 120+85.27138
    • 24+113.8927224+14.70130
    • 48+102.2495848+13.19840
    • 72+96.8219572+12.49780
    • 100+93.49533100+12.06840
    • 120+92.00711120+11.87630
    • 24+97.83696
    • 48+95.39075
    • 96+93.92448
    库存:45
    20825000002
      • 1+87.36120
      • 192+34.86240
      • 504+33.69600
      • 1008+33.12360
      • 1+168.209351+21.71251
