21033814422
21033814422
    HARTING(浩亭)
    Transformer 1CT:1CT 1500V 33.9 X 24mm 24 X Gull Wing Surface Mount
21033814422 数据手册
Product data sheet 21 03 381 4422 M12 MAGNET D-CODED ANG POE FAST ETHERNET M12 MAGNET D-CODED ANG POE FAST ETHERNET Part number 21 03 381 4422 Specification M12 MAGNET D-CODED ANG POE FAST ETHERNET HARTING eCatalogue https://b2b.harting.com/21033814422 Identification Category Connector Series Circular connectors M12 Identification M12 Magnetics Element PCB adapter Specification with integrated transformer Angled PoE enabled for front mounting Version Termination method Reflow soldering termination (SMT) Gender Female Shielding Shielded Number of contacts 4 Coding D-coding Pack contents incl. housing Technical characteristics Rated current 3 A Rated voltage 57 V Rated impulse voltage 1.5 kV Pollution degree 3 Insulation resistance > 108 Ω Contact resistance ≤10 mΩ Ambient temperature -40 ... +85 °C Page 1 / 2 | Creation date 2019-04-17 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com Product data sheet 21 03 381 4422 M12 MAGNET D-CODED ANG POE FAST ETHERNET Technical characteristics +245 °C for reflow soldering Mating cycles ≥100 Degree of protection acc. to IEC 60529 IP65 / IP67 when mated Transmission characteristics Cat. 5 Class D up to 100 MHz Data rate 100 Mbit/s Material properties Material (insert) LCP Material (contacts) Brass Surface (contacts) Gold plated RoHS compliant with exemption RoHS exemptions 6c: Copper alloy containing up to 4 % lead by weight 7c-I: Electrical and electronic components containing lead in a glass or ceramic other than dielectric ceramic in capacitors, e.g. piezoelectronic devices, or in a glass or ceramic matrix compound ELV status compliant with exemption China RoHS 50 REACH Annex XVII substances No REACH ANNEX XIV substances No REACH SVHC substances Yes REACH SVHC substances Lead Specifications and approvals Specifications IEC 61076-2-101 Commercial data Packaging size 1 Net weight 23 g Country of origin China European customs tariff number 8536901900 eCl@ss 27440402 PCB connector Page 2 / 2 | Creation date 2019-04-17 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com
21033814422 价格&库存
很抱歉,暂时无法提供与“21033814422”相匹配的价格&库存,您可以联系我们找货
