Data sheet from 12.08.2010
Item no.:
224-104
Product description:
LIGHTING CONNECTOR VERSION FOR INCREASED
CONTINUOUS SERVICE TEMPERATURE OF 120°C
Produkt kann von Bild abweichen / product may differ
Packing unit 100 pieces
Product group
7 (Push Wire Conn.)
Cross section [mm²]
1 - 2.5 mm²
Cross section [AWG]
14 - 12 AWG
Wiring method
e
Connection method
CAGE CLAMP® CONNECTION
Cross section [mm²]
0.5 - 2.5 mm²
Cross section [AWG]
20 - 16 AWG
Wiring method
e+f
Measured voltage EN
400 V
Measured shock voltage
4 kV
Pollution degree
2
Current intensity EN
24 A
Weight
2.34 g
Color
black
Wiring type
Side-entry
No. of connection Points
2
No. of potentials
1
Height
15.5 mm
Height
0.61 in
Width
8.5 mm
1 von 4
Width
0.335 in
Depth
20.5 mm
2 von 4
Depth
0.807 in
Strip length from
9 mm
Strip length to
11 mm
Strip length
0.39 in
3 von 4
Item no.
Admission office
Approval no.
Voltage [V]
Current [A]
Cross section [ mm² ]
224-104
ABS
04-HG476172/1-PDA
400
24
1-2,5/0,5-2,5
224-104
BV
11914/BO
300
24
2,5
224-104
CCA
DK2527
400
24
2,5
224-104
CSA
154112-1059435
300
224-104
DEMKO
143835-01
400
24
2,5
224-104
DNV
E-9215
400
24
2,5
224-104
FIMKO
163400-01
224-104
GL
17294-00HH
300
24
2,5
224-104
KEMA
96.1739.01
400
24
2,5
224-104
LR
04/20013(E3)
400
24
2,5
224-104
NEMKO
P96191377
224-104
ÖVE
1193-032-02
400
24
1-2,5/0,5-2,5
224-104
PSE
JET0695-43040-1001
300
224-104
RMR
11130002
400
24
1-2,5/0,5-2,5
224-104
SEMKO
9617079
224-104
UL
E69654
300
Sorting criteria: admission office - approval number
© WAGO Kontakttechnik GmbH & Co. KG
Specifications are subject to changes and errors may be expected
4 von 4
14-12
2,5
2,5
2,5
14-12
