Ha-VIS eCon 2000 Fast Ethernet Basic PoE / PoE+
5 to 8 Ethernet ports RJ45, FOC, and PoE / PoE+
English
Unmanaged Plug and Play Ethernet switches for DIN rail assembly in control
cabinets
Commercial temp.: 0 °C ... +55 °C / Industrial
temp.: -40 °C ... +70 °C
Energy
Efficient
Ethernet
■ Energy supply of up to 4 terminal devices via PoE+ (137 watts) in
accordance with IEEE 802.3at
■ Fast Ethernet Non-Blocking Switch architecture in accordance with IEEE 802.3
■ Variants with industrial temperature range of -40 °C ... +70 °C
■ Surge protection and reverse polarity protection
■ Minimum energy consumption due to energy-efficient Ethernet
Target markets
Machinery & Robotics
Automation
Industrial network
infrastructures
Wind Energy,
Solar Energy
Transportation
Shipbuilding
General Description
The Ha-VIS eCon 2000 Fast Ethernet PoE family of unmanaged Ethernet
switches is equipped with up to 8 Fast Ethernet ports and allow for
cost-efficient and quick expansion and/or reconstruction of network
infrastructures. The switches work as power sourcing equipment (PSE) and
are capable of simultaneously providing the full PoE output of 34.2 watts
on up to four ports. Due to the extremely flat design, these switches can
be accommodated in installations where space is restricted towards the
cable connection at the front. The selection includes various combinations
of variants with RJ45 and fibre optic ports. Automatic detection of the
transmission rate (auto-negotiation) and of the wiring of the twisted pair data
cable (auto-polarity and auto-MDI(X)) allow for simple plug and play. All variants
are available with the temperature ranges "Industrial" and "Commercial".
Technical characteristics
Switch features
Ethernet ports 10BASE-Te / 100BASE-TX EEE
Enclosure width
120 mm
Number of ports
5, 7, 8
Type of connection
RJ45
Auto-negotiation
Yes
Yes
Switching technology
Store and Forward
Auto-polarity
Supported standards
IEEE 802.3
Frame Size
Auto-MDI(X)
1552 bytes
MAC table size
Transfer conditions
1k entries
Transfer speed
448 kbit
10 / 100 Mbit/s
Transfer length
100 m (twisted pair, Cat 5)
Packet buffer size
Non-blocking
Yes
Quality of Service
Yes
Energy Efficient Ethernet
Yes
PROFINET compatible
Yes
EthernetIP compatible
Yes
Yes
Twisted pair
Ethernet ports 100BASE-FX
Type of fibre
Multi-mode (MM)
Type of connection
Transfer conditions
FOC
Wavelength
Power supply
1310 nm
Transfer speed
Nominal voltage
24 VDC
Permissible voltage range
48 VDC
Yes
Reverse polarity proof
Yes
3.20 A
Overcurrent protection at input
Max. power consumption @ 24 VDC
Conductor cross-section
Type of connection
Pinout
6.40 A
Input sensitivity
7.20 A
Yes (4 A)
1.2 W ... 3.36W
0.08 mm² ... 2.5 mm² (28 AWG ... 12 AWG)
3-pole, pluggable screw type terminal block
Supply circuit (according to 60950)
Transfer length
Output power
9 VDC ... 60 VDC
Surge protection
Starting current
54 VDC
SELV (circuit breaker 10 A)
HARTING Technology Group
P.O.Box 1473, D-32325 Espelkamp
Wilhelm-Harting-Straße 1, D-32325 Espelkamp, Germany
ICPN-Service@harting.com | Service hotline: +49 5772 47-9479
Fax: +49 5772 47-495 | www.HARTING.com/de/ethernet-switches
Single-mode (SM)
SC Duplex
100 Mbit/s
2 km
15 km
-19 dBm ... -14 dBm
-15 dBm ... -8 dBm
≤ -32 dBm
≤ -34 dBm
Environmental conditions
Commercial temperature range
Industrial temperature range
Storage temperature range
0 °C ... +55 °C
-40 °C ... +70 °C
-40 °C ... +85 °C
Relative humidity (operation)
0% ... 95 % (not-condensing)
Relative humidity (storage and
transport)
Air pressure
2000 m (795 hPa)
Note: We reserve the right to make technical changes to the products and to the content of this
document at any time without prior notification. The HARTING Technologiegruppe does not accept any responsibility for possible errors or incompletions in this document. We reserve all the
rights to this document and the topics and illustrations contained within it. Copying, disclosure to
third parties or use of its content - even partially - is forbidden without the prior written consent
of the HARTING Technologiegruppe.
PoE
Enclosures
Number of PoE ports
4
Standard
IEEE 802.3af / IEEE 802.3at
PoE type
PSE
Supported mode
Alternative A
Power supply PSE
48 VDC
Maximum Power consumption
Maximum output power PSE
54 VDC
375 mA
638 mA
15.4 W per port
61.6 W total
34.2 W per port
136.8 W total
Supported cabling
See 802.3at, section 33.1.4
PoE pinout
Alternative A, MDI-X (1/2 = V-, 3/6 = V+)
Status and diagnostic displays
Power ("Pwr")
illuminated green
Supply voltage is applied
Link/Activity ("L/A") off
No link
Link/Activity ("L/A") illuminated green
Link/Activity ("L/A") flashes green
Link is active
Link is active and data is transferred
Link speed ("Spd") off
10 Mbit/s
Link speed ("Spd") illuminated yellow
100 Mbit/s
PoE status off
PoE is inactive / low voltage
PoE status illuminated green
Voltage in PoE range
PoE status illuminated blue
Voltage in PoE+ range
PoE status illuminated red
Fault
Enclosure width
Dimensions H x W x D (without
block and holding bracket)
Weight
120 mm
113.5 mm x 120 mm x 27.3 mm
364 g ... 420 g
Type of installation
35 mm DIN rail acc. to EN 60 715
Material enclosures
Anodised aluminium
Protection class (with pluggable
screw type terminal block)
IP30
Protection class
III
Approvals
CE, FCC CFR 47 Part 15, cUL US 508 listed, DNV, GL, ABS, NK, ABB IIT
EMC and environmental conditions
EMC interference immunity (EN 61000-6-1, 61 000-6-2 55024)
Electrostatic discharge (ESD) EN 61 000-4-2
Electromagnetic field EN 61 000-4-3
Rapid transients (burst) EN 61 000-4-4
Surge voltages EN 61 000-4-5
Conducted interference voltages EN 61 000-4-6
EMC interference emission (EN 61000-6-4, EN 55 022, FCC CFR 47 Part 15)
Mechanical stability (EN 60721-3)
IEC 60068-2-6 Vibration
IEC 60068-2-6 Resonance search
IEC 60068-2-27 Shock test
Included in delivery
■ Pluggable screw type terminal block for power supply
■ Installation instructions
Drawings
Technical characteristics / order information
Ports / order information
Industrial temp.: -40 °C ... +70 °C
SC
Enclosure
width
Power consumption @ 24 VDC
without PoE
MTBF
in million h
120 mm
0.05 A
0.84
Ha-VIS eCon 2050B-A-P
24 02 005 0030 Ha-VIS eCon 2050BT-A-P
1x MM (2 km)
120 mm
0.10 A
0.78
Ha-VIS eCon 2061B-AD-P
24 02 006 1130 Ha-VIS eCon 2061BT-AD-P
24 02 006 1120
6
1x SM (15 km)
120 mm
0.09 A
0.79
Ha-VIS eCon 2061B-AF-P
24 02 006 1230 Ha-VIS eCon 2061BT-AF-P
24 02 006 1220
6
2x MM (2 km)
120 mm
0.14 A
0.76
Ha-VIS eCon 2062B-AD-P
24 02 006 2130 Ha-VIS eCon 2062BT-AD-P
24 02 006 2120
6
2x SM (15 km)
120 mm
0.12 A
0.78
Ha-VIS eCon 2062B-AF-P
24 02 006 2230 Ha-VIS eCon 2062BT-AF-P
24 02 006 2220
8
120 mm
0.07 A
0.73
Ha-VIS eCon 2080B-A-P
24 02 008 0030 Ha-VIS eCon 2080BT-A-P
24 02 008 0020
RJ45
SFP
5
6
Copyright© 2014
All rights reserved
Date of issue 02.2015
ICPN Datasheet 0836/01
Switch
Part no.
Switch
Part no.
24 02 005 0020
很抱歉,暂时无法提供与“24020050030”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5845.41129
- 5+5620.57151
- 国内价格 香港价格
- 1+5947.409661+740.09263
