ELEVATED
SOCKETS
(2.54 mm) .100" PITCH • ESW/ESQ SERIES
ESW/ESQ
Mates:
TSW, MTSW, EW,
MTLW, TSS, ZSS, TSM,
DW, ZW, HW, TSSH, HTSS
SPECIFICATIONS
Insulator Material:
Black Glass Filled Polyester
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating (ESW/TSW):
5.2 A per pin
(2 pins powered)
Current Rating (ESQ/TSW):
5.7 A per pin
(2 pins powered)
Voltage Rating:
515 VAC mated with
TSW or ESQ
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
Insertion Depth:
(3.68 mm) .145" to
(6.35 mm) .250"
Max Cycles:
100 with 10 µ" (0.25 µm) Au
SERIES
ESW
= Solder Tail
NO. PINS
PER ROW
LEAD
STYLE
01 thru 36
Specify
LEAD
STYLE
from
chart
ESQ
= Square Tail
PLATING
OPTION
ROW
OPTION
–L
–S
= 10 µ" (0.25 µm)
Gold contact,
Matte Tin on tail
= Single Row
–D
= Double Row
–G
–T
= 20 µ" (0.51 µm)
Gold contact,
Gold Flash on
Balance
STANDARD
LOW
INSERTION INSERTION
FORCE
FORCE
= Triple Row
(ESQ only)
OTHER
OPTION
–LL
= Locking Lead
(Two leads per
strip crimped.
Not available
with single row
1 or 2 positions)
“XXX”
= Polarized
–T
LEAD STYLE
PROCESSING
Lead-Free Solderable:
No, Lead Wave only
-1
A
B
– 12
– 37
(2.29) .090
– 13
– 38
(7.36) .290
= Matte Tin
(Not available
with LIF contact)
(11.05) .435
– 23
– 48
(4.83) .190 (13.59) .535
– 33
– 58
(2.29) .090 (16.13) .635
(12.19) .480 (11.05) .435
– 14
– 39
– 24
– 49
(9.65) .380 (13.59) .535
– 34
– 59
(7.11) .280 (16.13) .635
– 44
– 69
(4.57) .180 (18.67) .735
(2.54) .100 X No. of Positions + (0.51) .020
—S
(2.41)
.095
—D
(4.95)
.195
—T
(ESQ only)
(7.49)
.295
APPLICATIONS
(ESQ SERIES)
PC/104 J1/P1 “Stackthrough” Connectors
Standard Insertion Force
ESQ-132-14-G-D
Low Insertion Force
ESQ-132-39-G-D
PC/104™ J1 “Non-Stackthrough” Connectors
ESQ-132-12-G-D
Low Insertion Force
ESQ-132-37-G-D
PC/104™ J2/P2 “Stackthrough” Connectors
ESQ-120-14-G-D
Low Insertion Force
ESQ-120-39-G-D
B
ALSO AVAILABLE
MOQ Required
PC/104 is a trademark of the PC/104 Consortium.
Other Platings
A
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
(2.54)
.100
TYP
ESW
(0.41) x (0.79)
.016 .031
ESQ
(0.64)
.025
SQ
samtec.com?ESW or samtec.com?ESQ
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-224
很抱歉,暂时无法提供与“ESQ-109-69-G-T-LL”相匹配的价格&库存,您可以联系我们找货
