Plug-In Current Transformers
with CAGE CLAMP® connector
Secondary rated current: 1 A
Secondary rated current: 5 A
Short description:
The 855 Series Plug-In Current Transformers are inductive,
single-conductor current transformers. Based on the
principle of measurement, current transformers of this type
are used exclusively in AC networks.
Features:
• Screwless CAGE CLAMP® connection technology
• Several mounting options available
• Vibration- and shock-resistant
• High mechanical retention forces
• High current-carrying capacity
• Continuous overload of 120 % the nominal primary
current
• Low-voltage current transformer for max. operating
voltages up to 1.2 kV
• Can be used in 690 V power networks
• UL Recognized Components
Description
IpN
IsN
SN
G
Item No.
Pack.
Unit
IpN
IsN
SN
G
Item No.
Pack.
Unit
Plug-in current transformer
50 A
60 A
75 A
100 A
150 A
200 A
250 A
400 A
600 A
400 A
1000 A
1A
1A
1A
1A
1A
1A
1A
1A
1A
1A
1A
1.25
1.25
2.5VA
2.5VA
5VA
5VA
5VA
10VA
10VA
5VA
10VA
3
1
1
1
1
1
1
1
1
1
1
855-301/050-103
855-301/060-101
855-301/075-201
855-301/100-201
855-301/150-501
855-301/200-501
855-301/250-501
855-301/400-1001
855-301/600-1001
855-401/400-501
855-501/1000-1001
1
1
1
1
1
1
1
1
1
1
1
50 A
60 A
75 A
100 A
150 A
200 A
250 A
400 A
600 A
400 A
1000 A
5A
5A
5A
5A
5A
5A
5A
5A
5A
5A
5A
1.25
1.25
2.5VA
2.5VA
5VA
5VA
5VA
10VA
10VA
5VA
10VA
3
1
1
1
1
1
1
1
1
1
1
855-305/050-103
855-305/060-101
855-305/075-201
855-305/100-201
855-305/150-501
855-305/200-501
855-305/250-501
855-305/400-1001
855-305/600-1001
855-405/400-501
855-505/1000-1001
1
1
1
1
1
1
1
1
1
1
1
IpN = Primary rated current
IsN = Secondary rated current
SN = Rated power
G = Accuracy class
Technical Data
Input:
Rated continuous thermal current Icth
Rated short-time thermal current Ith
Max. operating voltage Vm
Rated frequency
Overcurrent limiting factor
Environmental requirements:
Ambient operating temperature
Storage temperature
Max. operating altitude
Safety and protection:
Test voltage
Insulation class
Connection and type of mounting:
Connection technology (1)
Cross sections
Strip lengths
Standards and approvals:
Conformity marking
Standards/Specifications
Y (Recognized Components)
1.2 x IN
60 x IN (max.100 kA), 1 s
1.2 kV
50 Hz ... 60 Hz
FS5 or FS10 (type-dependent, see type plate inscription)
1.2 x IN
1.2 kV
50 Hz ... 60 Hz
-5 °C ... +50 °C
-25 °C ... +70 °C
1000 m
-5 °C ... +50 °C
-25 °C ... +70 °C
1000 m
6 kVrms AC / 50 Hz / 1 min
E
E
CAGE CLAMP®
0.08 mm² ... 4 mm² / AWG 28 ... 12
9 ... 10 mm / 0.37 in
CAGE CLAMP®
1
EN 61869-1; EN 61869-2
E356480
1
E356480
Accessories
Carrier rail adapter for plug-in current transformers
(for 855-3xx/xxxx-xxxx and 855-4xx/xxxx-xxxx)
Quick-mount kit
Operating tool, with partially insulated shaft,
type 2, blade (3.5 x 0.5) mm
Connector assembly for current transformer
WAGO Kontakttechnik GmbH & Co. KG
Subject to design changes
17.03.2015
Item No.
Pack.
Unit
855-9900
855-9910
1
1
210-720
2007-8873
1
1
Postfach 2880 - D-32385 Minden
Hansastr. 27 - D-32423 Minden
Tel.: +49(0)571/887-0
E-Mail: info@wago.com
Fax: +49(0)571/887-169
www.wago.com
855 Series
Connection / Connection Assignment
Implementation of the primary winding is designated with “K-P1” and “L-P2.” Connections for the secondary
winding are designated with the corresponding lower case letters “ k-S1” and “I-S2.”
Dimensions:
Item No.
855-3xx/xxxx-xxxx
Item No.
855-4xx/xxxx-xxxx
Item No.
855-5xx/xxxx-xxxx
Current bar 1: 30 x 10 mm
Current bar 2: 25 x 12 mm
Current bar 3: 20 x 20 mm
Round cable: 26 mm
Current bar 1: 40 x 10 mm
Current bar 2: 30 x 15 mm
Current bar 1: 50 x 12 mm
Current bar 2: 40 x 30 mm
Round cable: 32 mm
Round cable: 44 mm
Width: 60 mm
Overall height: 80.5 mm
Overall depth: 52 mm
Width: 70 mm
Overall height: 91 mm
Width: 85 mm
Overall height: 105.25 mm
Application examples:
750 Series (3-Phase Power Measurement Module)
857 Series (JUMPFLEX® Current Transducer)
Current
transformer
250 A/1 A
2007-7783
Connector assembly
for current
transformer
PLC/
LED indication
L1
DO/
LED indication
24 V/500 mA
e.g. 787-1002
16.8 ... 31.2 V
230 VAC
Mounting Options
Mounting on round cable
Mounting on copper current Mounting on carrier rail with Mounting on mounting plate Quick-mount installabar
carrier rail adapter
tion for conductors
Note:
* The carrier rail adapter is only suitable for 855-3xx/xxxx-xxxx and 855-4xx/xxxx-xxxx transformers.
很抱歉,暂时无法提供与“855-301/050-103”相匹配的价格&库存,您可以联系我们找货
