870-504
870-504
    WAGO(万可电子)
    Double-Deck Terminal Block, Through/through Terminal Block
870-504 数据手册
Data sheet | Item number: 870-504 Double-deck terminal block; Through/through terminal block; N/N; suitable for Ex i applications; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; CAGE CLAMP®; 2,50 mm²; blue www.wago.com/870-504 Color: Item description Safety information 1: Max. insulation diameter: 4.4 mm Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 18.05.2021    Page 1/15 Data sheet | Item number: 870-504 www.wago.com/870-504 Data Electrical data Ratings per IEC/EN Ratings per IEC/EN 60947-7-1 Nominal voltage (III/3) 500 V Rated surge voltage (III/3) 6 kV Rated current 24 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Connection data Connection technology CAGE CLAMP® Actuation type Operating tool Connectable conductor materials Copper Solid conductor 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded conductor 0.08 … 4 mm² / 28 … 12 AWG Fine-stranded conductor; with insulated ferrule 0.08 … 1.5 mm² / 28 … 14 AWG Strip length 6 … 7 mm / 0.24 … 0.28 inch Total number of connection points 4 Total number of potentials 2 Number of levels 2 Wiring type Front-entry wiring Physical data Width 5 mm / 0.197 inch Height 70 mm / 2.756 inch Depth from upper edge of DIN-rail 40 mm / 1.575 inch Mechanical data Potential marking N/N Design horizontal type Mounting type DIN-35 rail Marking level Side marking Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 18.05.2021    Page 2/15 Data sheet | Item number: 870-504 www.wago.com/870-504 Material data Color blue Fire load 0.166 MJ Weight 9.9 g Commercial data Packaging type BOX Country of origin DE GTIN 4044918630917 Customs tariff number 85369010000 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947 NTR NL 7468 CCA DEKRA Certification B.V. EN 60947 2189801.01 Approval Additional Approval Text ABS American Bureau of Shipping - 20HG1941090PDA BV Bureau Veritas S.A. EN 60947 07436/F0 BV DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00001V2 Ship Approvals Logo LR EN 60947 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Certificate name 91/20112 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 18.05.2021    Page 3/15 Data sheet | Item number: 870-504 www.wago.com/870-504 LR Lloyds Register EN 60947 91/20112 (E9) UL-Approvals Logo Approval Additional Approval Text cURus UL International Germany GmbH UL 1059 Certificate name 20160928E45172 Required accessories End plate Item no.: 870-518 End and intermediate plate; 2 mm thick; gray www.wago.com/870-518 Item no.: 870-519 End and intermediate plate; 2 mm thick; orange www.wago.com/870-519 Compatible products Insulation stop Item no.: 280-470 Insulation stop; 0.08 - 0.2 mm² "s" (0.14 mm² "f-st"); 5 pieces/strip; white www.wago.com/280-470 Item no.: 280-471 Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray www.wago.com/280-471 Item no.: 280-472 Insulation stop; 0.75 - 1 mm²; 5 pieces/strip www.wago.com/280-472 Protective Warning Marker Item no.: 280-405 Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow www.wago.com/280-405 Item no.: 870-425 Tap-off module; with anti-rotation protection; modular; suitable for 870 Series terminal blocks with jumper slots in the current bar; gray www.wago.com/870-425 Item no.: 870-426 Tap-off module; modular; suitable for 870 Series terminal blocks with jumper slots in the current bar; gray www.wago.com/870-426 Item no.: 870-427 Spacer module; modular; bridging commoned terminal blocks; gray www.wago.com/870-427 check ferrule to changes. Please also observe the further product documentation! Subject WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 18.05.2021    Page 4/15 Data sheet | Item number: 870-504 www.wago.com/870-504 ferrule Item no.: 216-121 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored www.wago.com/216-121 Item no.: 216-122 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored www.wago.com/216-122 Item no.: 216-123 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; silver-colored www.wago.com/216-123 Item no.: 216-124 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated www.wago.com/216-124 Item no.: 216-131 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored www.wago.com/216-131 Item no.: 216-132 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-132 Item no.: 216-221 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-221 Item no.: 216-222 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-222 Item no.: 216-223 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-223 Item no.: 216-224 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black www.wago.com/216-224 Item no.: 216-321 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-321 Item no.: 216-322 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-322 Item no.: 209-192 Separator for Ex e/Ex i applications; 3 mm thick; 125.5 mm wide; orange www.wago.com/209-192 Item no.: 209-106 Mounting carrier; for isolated mounting on DIN 35 rails; gray www.wago.com/209-106 Item no.: 249-116 Screwless end stop; 6 mm wide; for DIN-rail 35 x 15 and 35 x 7.5; gray www.wago.com/249-116 Item no.: 249-117 Screwless end stop; 10 mm wide; for DIN-rail 35 x 15 and 35 x 7.5; gray www.wago.com/249-117 End plate assembling Marking accessories Item no.: 2009-115 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2009-115 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 18.05.2021    Page 5/15 Data sheet | Item number: 870-504 www.wago.com/870-504 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white www.wago.com/2009-115 Item no.: 2009-115/000-002 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-115 /000-002 Item no.: 2009-115/000-006 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue www.wago.com/2009-115 /000-006 Item no.: 2009-115/000-007 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray www.wago.com/2009-115 /000-007 Item no.: 2009-115/000-012 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-115 /000-012 Item no.: 2009-115/000-017 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; light green www.wago.com/2009-115 /000-017 Item no.: 2009-115/000-023 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-115 /000-023 Item no.: 2009-115/000-024 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-115 /000-024 Item no.: 2009-145 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white Item no.: 2009-145/000-002 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-145 /000-002 Item no.: 2009-145/000-005 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; red www.wago.com/2009-145 /000-005 Item no.: 2009-145/000-006 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue /000-006 Item no.: 2009-145/000-007 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray /000-007 Item no.: 2009-145/000-012 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange Item no.: 2009-145/000-023 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2009-145 /000-012 www.wago.com/2009-145 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 18.05.2021    Page 6/15 Data sheet | Item number: 870-504 www.wago.com/870-504 Item no.: 2009-145/000-023 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-145 /000-023 Item no.: 2009-145/000-024 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-145 /000-024 Item no.: 248-501 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/248-501 Item no.: 248-501/000-002 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/248-501 /000-002 Item no.: 248-501/000-005 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/248-501 /000-005 Item no.: 248-501/000-006 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/248-501 /000-006 Item no.: 248-501/000-007 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/248-501 /000-007 Item no.: 248-501/000-012 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/248-501 /000-012 Item no.: 248-501/000-017 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/248-501 /000-017 Item no.: 248-501/000-023 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/248-501 /000-023 Item no.: 248-501/000-024 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/248-501 /000-024 Item no.: 709-177 Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; translucent www.wago.com/709-177 Item no.: 709-178 Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; white www.wago.com/709-178 Item no.: 709-196 Marking strips; for laser printer; translucent www.wago.com/709-196 Item no.: 793-501 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 18.05.2021    Page 7/15 Data sheet | Item number: 870-504 www.wago.com/870-504 Item no.: 793-501/000-002 WMB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/793-501 /000-002 Item no.: 793-501/000-005 WMB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/793-501 /000-005 Item no.: 793-501/000-006 WMB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/793-501 /000-006 Item no.: 793-501/000-007 WMB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/793-501 /000-007 Item no.: 793-501/000-012 WMB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/793-501 /000-012 Item no.: 793-501/000-017 WMB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/793-501 /000-017 Item no.: 793-501/000-023 WMB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/793-501 /000-023 Item no.: 793-501/000-024 WMB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/793-501 /000-024 Item no.: 793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501 type; white Item no.: 793-5501/000-002 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-002 type; yellow Item no.: 793-5501/000-005 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-005 type; red Item no.: 793-5501/000-006 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-006 type; blue Item no.: 793-5501/000-007 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-007 type; gray Item no.: 793-5501/000-012 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 18.05.2021    Page 8/15 Data sheet | Item number: 870-504 www.wago.com/870-504 Item no.: 793-5501/000-012 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501 /000-012 type; orange Item no.: 793-5501/000-017 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-017 type; green Item no.: 793-5501/000-023 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-023 type; light green Item no.: 793-5501/000-024 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-024 type; violet Item no.: 870-182 Adaptor; gray www.wago.com/870-182 Item no.: 870-183 Adaptor; gray www.wago.com/870-183 Item no.: 870-184 Adaptor; gray www.wago.com/870-184 Item no.: 210-657 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short; multicoloured www.wago.com/210-657 Item no.: 210-658 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short; multicoloured www.wago.com/210-658 Item no.: 210-720 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured www.wago.com/210-720 tools Carrier rail Item no.: 210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm; www.wago.com/210-112 silver-colored Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-113 Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored www.wago.com/210-114 Item no.: 210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm; www.wago.com/210-115 silver-colored Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored Item no.: 210-196 www.wago.com/210-118 www.wago.com/210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 18.05.2021    Page 9/15 Data sheet | Item number: 870-504 www.wago.com/870-504 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored www.wago.com/210-197 Item no.: 210-504 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715; silvercolored www.wago.com/210-504 Item no.: 210-505 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715; silver-colored www.wago.com/210-505 Item no.: 210-506 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715; silvercolored www.wago.com/210-506 Item no.: 210-508 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715; silvercolored www.wago.com/210-508 Item no.: 870-402 Jumper; 2-way; insulated; light gray www.wago.com/870-402 Item no.: 870-403 Jumper; 3-way; insulated; light gray www.wago.com/870-403 Item no.: 870-404 Push-in type jumper bar; insulated; 4-way; Nominal current 18 A; light gray www.wago.com/870-404 Item no.: 870-405 Jumper; 5-way; insulated; light gray www.wago.com/870-405 Item no.: 870-405/011-000 Ready-made push-in type jumper bar; insulated; 3-way (1-3-5); Nominal current 18 A; light gray www.wago.com/870-405 /011-000 Item no.: 870-406 Jumper; 6-way; insulated; light gray www.wago.com/870-406 Item no.: 870-406/020-000 Delta jumper; insulated; light gray www.wago.com/870-406 /020-000 Item no.: 870-407 Jumper; 7-way; insulated; light gray www.wago.com/870-407 Item no.: 870-407/011-000 Ready-made push-in type jumper bar; insulated; 1-3-5-7; Nominal current 18 A; light gray www.wago.com/870-407 /011-000 Item no.: 870-408 Jumper; 8-way; insulated; light gray www.wago.com/870-408 Jumper Item no.: 870-409 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/870-409 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 18.05.2021    Page 10/15 Data sheet | Item number: 870-504 www.wago.com/870-504 Item no.: 870-409 Jumper; 9-way; insulated; light gray www.wago.com/870-409 Item no.: 870-409/011-000 Ready-made push-in type jumper bar; insulated; 1-3-5-7-9; Nominal current 18 A; light gray www.wago.com/870-409 /011-000 Item no.: 870-410 Push-in type jumper bar; insulated; 10-way; Nominal current 18 A; light gray www.wago.com/870-410 Item no.: 870-433 Jumper; from 1 to 3; insulated; light gray www.wago.com/870-433 Item no.: 870-434 Jumper; from 1 to 4; insulated; light gray www.wago.com/870-434 Item no.: 870-435 Jumper; from 1 to 5; insulated; light gray www.wago.com/870-435 Item no.: 870-436 Jumper; from 1 to 6; insulated; light gray www.wago.com/870-436 Item no.: 870-437 Jumper; from 1 to 7; insulated; light gray www.wago.com/870-437 Item no.: 870-438 Jumper; from 1 to 8; insulated; light gray www.wago.com/870-438 Item no.: 870-439 Jumper; from 1 to 9; insulated; light gray www.wago.com/870-439 Item no.: 870-440 Push-in type jumper bar; insulated; from 1 to 10; Nominal current 18 A; light gray www.wago.com/870-440 Downloads Documentation Bid Text 870-504 2017 May 31 doc 25.1 kB Download 2019 Feb 19 xml 3.4 kB Download 2019 Apr 3 pdf 2.2 MB Download doc - Datei 870-504 X81 - Datei Additional Information Technical explanations CAD/CAE-Data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 18.05.2021    Page 11/15 Data sheet | Item number: 870-504 www.wago.com/870-504 CAD/CAE-Data CAD data 2D/3D Models 870-504 URL Download EPLAN Data Portal 870-504 URL Download ZUKEN Portal 870-504 URL Download WSCAD Universe 870-504 URL Download URL Download CAE data Environmental Product Compliance Compliance Search Environmental Product Compliance 870-504 Double-deck terminal block; Through/through terminal block; N/N; suitable for Ex i applications; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; CAGE CLAMP®; 2,50 mm²; blue Installation Notes Removing a terminal block from the assembly. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 18.05.2021    Page 12/15 Data sheet | Item number: 870-504 www.wago.com/870-504 CAGE CLAMP® connection Inserting a conductor via operating tool (0.08 … 4 mm² “f-st”). With ferruled conductors, it is necessary to use a terminal block one size smaller than the conductor's nominal cross-section. Commoning Push jumper bars down firmly until fully inserted. When using multipole bars, push alternately on the right and then left side until installed. Commoning with push-in type jumper bars: Two parallel jumper slots are accommodated in one terminal block. Push-in type jumper bars 1 – 3 – 5 – 7 or 1 – – 4 – – 7 upon request Testing Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 18.05.2021    Page 13/15 Data sheet | Item number: 870-504 www.wago.com/870-504 Testing with phase testing device, also possible with single-pole voltage tester. Testing is also possible using a pre-wired tap-off module assembly in the very same way as test plugs. Cover Protective warning markers (280‑405), with a black high-voltage symbol Use 50% less rail space with double-deck terminal blocks. Marking Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 18.05.2021    Page 14/15 Data sheet | Item number: 870-504 www.wago.com/870-504 WMB markers in Mini-WSB marker slots Translucent marking strip (709-196) – jumpers below may be visible. Translucent marking strip Mini-WSB markers In addition to the plastic marker strips, group marker carriers are now available for the WMB and WSB marking systems. They can be mounted in parallel to a push-in type jumper bar via the open jumper contact slot. It is also very useful if the marker slots on the side of the terminal block are hidden. The carriers are available in the following widths: 5 mm (0.197 inch), 10 mm (0.394 inch) and 15 mm (0.591 inch). Notice: Group marker carriers are not suitable for ground conductor terminal blocks and double potential terminal blocks as they have no jumper contact slots. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 18.05.2021    Page 15/15
870-504 价格&库存
很抱歉,暂时无法提供与“870-504”相匹配的价格&库存,您可以联系我们找货
  • 1+75.963651+9.83995
