SAN CONNECTOR
2.0mm pitch/Board-in Crimp style connectors
Specifications –––––––––––––––––––
Measuring 2.0mm in pitch, 6.0mm in
mounting height, and 3.25mm in thickness,
this board-in connector meets the needs
for high-density mounting on printed circuit
boards efficiently and economically.
The connector is ideal for VCRs, car stereo
systems, audio products and many other
consumer oriented electronic products.
• Compact
• Housing lances
• Easy mounting onto printed circuit boards
• Two types of contacts
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Standards ––––––––––––––––––––––
Recognized E60389
1 Certified LR20812
1.6 min
9.2
6
2 min
2 ± 0.05
• Current rating: 2A AC, DC (AWG #24)
• Voltage rating: 250V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Insulation resistance: 1,000M Ω min.
• Withstanding voltage: 800V AC/minute
• Applicable wire: AWG #30 to #24
• Applicable PC board thickness:
Type A contact: 1.2mm, 1.6mm
Type B contact: 1.6mm
1.85
Note: 1. The above figure is the figure viewed from soldering side.
2. Tolerances are non-cumulative: ±0.05mm for all centers.
*Type A 0.8 +0.1
-0.05 dia.
*Type B 2 to 7 circuits: 0.75 ±0.05 dia.
8 to 15 circuits: 0.85 ±0.05 dia.
3. Hole dimensions differ according to the kind of PC board and piercing method.
The dimensions above should serve as a guideline. Contact JST for details.
3.25
1
SAN CONNECTOR
Contact
Type A
0.9
2
1.6
Model No.
Type
SAN-002T-0.8A
SAN-002T-0.8K
A
Applicable wire
AWG #
mm2
0.05∼0.22
B
Insulation O.D.(mm) Q’ty / reel
30∼24
0.9∼1.3
14,000
Material and Finish
9
3.1
Brass, tin-plated (reflow treatment)
RoHS compliance
Note: Contact JST if you require shielded wires, thin wires or other special
wires.
Type B
1.8
0.9
Contact
Crimping
machine Crimp applicator
SAN-002T-0.8A
AP-K2N
SAN-002T-0.8K
Applicator
Dies
Crimp applicator with dies
MKS-L
MK/SAN-002-08
APLMK SAN002-08
*MKS-SC
SC/SAN-002-08
APLSC SAN002-08
Note: *Strip-crimp applicator
9
3.1
Housing
Circuits
Model No.
2
2P-SAN
3P-SAN
4P-SAN
5P-SAN
6P-SAN
7P-SAN
8P-SAN
9P-SAN
10P-SAN
11P-SAN
12P-SAN
13P-SAN
14P-SAN
15P-SAN
3
4
5
1
6
13
14
15
8
5.65
JST
7
9
10
11
12
2
3.25
A
B
13
14
15
Dimensions (mm)
A
B
2.0
5.2
1,000
4.0
7.2
1,000
6.0
9.2
1,000
8.0
11.2
1,000
10.0
13.2
1,000
12.0
15.2
1,000
14.0
17.2
1,000
16.0
19.2
1,000
18.0
21.2
1,000
20.0
23.2
1,000
22.0
25.2
1,000
24.0
27.2
1,000
26.0
29.2
1,000
28.0
31.2
1,000
Material
PA 66, UL94V-0, yellow
RoHS compliance
As the color identification,
the following alphabet shall be put in the underlined part.
For availability, delivery and minimum order quantity, contact JST.
ex.
2
Q'ty /
bag
2P-SAN-o(blank)…yellow K…black W…white R…red
很抱歉,暂时无法提供与“9P-SAN”相匹配的价格&库存,您可以联系我们找货
