Crimp
2.5mm
NH CONNECTOR
Disconnectable Crimp style connectors
pitch
Features ––––––––––––––––––––––––
• Superior folded beam construction
(1) This sturdy construction withstands repeated stress, resists
permanent deformation, and offers a very long service life.
(2) High reliability is ensured whether the contact pressure is
high or low.
(3) This contact design has a large tolerance for variations in
mating post thickness and resists deformation when pried.
• Double-sided contact
(1) The receptacle contact has a protected entry which
eliminates contact damage caused by mismating.
(2) It provides high contact pressure, is free from abnormal
stress, and maintains continuity at all times.
(3) It has an extremely long service life due to its folded beam
design.
• Wide, sturdy post
This 2.5mm pitch connector is used to
connect wires to printed circuit boards.
The header is available in three
configurations: top, side, and bottom entry.
This allows the wires to be perpendicular
or parallel to the printed circuit board in
any direction.
The post has a large cross-sectional area to resist prying
during insertion into printed circuit boards and mating with
connector housings.
• Molded-in header
The posts are molded into the insulator to provide stability
when mounted on printed circuit boards. This also prevents
flux from entering the connector during soldering.
Specifications –––––––––––––––––––
1
2
3
JS 4 5
T
• Current rating: 3A AC, DC (AWG #22)
• Voltage rating: 250V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 15m Ω max.
After environmental testing/ 20m Ω max.
• Insulation resistance: 500M Ω min.
• Withstanding voltage: 1,500V AC/minute
• Applicable wire: AWG #30 to #22
• Applicable PC board thickness: 1.6mm
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Standards ––––––––––––––––––––––
2
Recognized E60389
Certified LR20812
J50168090
1
NH
CONNECTOR
Contact –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Applicable wire
Model No.
9
3.8
4
2.2
1.7
mm2
AWG #
Insulation O.D. (mm)
SHF-001T-0.8BS
0.08 to 0.33
28 to 22
1.2 to 1.7
SHF-002T-0.8BS
0.05 to 0.08
30 to 28
0.9 to 1.2
1.2
Q'ty /
reel
5,000
Material and Finish
Phosphor bronze, tin-plated (reflow treatment)
RoHS compliance
Note:
1. Contact JST for gold-plated products.
2. Also contact JST if you require shielded wires, thin wires or other special
wires.
3. Contact JST for brass products.
0.7
1.95
4.6
2
1.8
Housing –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
1.5
A
B
C
3
Dimensions (mm)
C
Q'ty /
bag
5.7
8.7
1,000
8.2
11.2
1,000
7.5
10.7
13.7
1,000
H 5P-SHF-AA
10.0
13.2
16.2
1,000
6
H 6P-SHF-AA
12.5
15.7
18.7
1,000
7
H 7P-SHF-AA
15.0
18.2
21.2
500
8
H 8P-SHF-AA
17.5
20.7
23.7
500
9
H 9P-SHF-AA
20.0
23.2
26.2
500
10
H10P-SHF-AA
22.5
25.7
28.7
500
11
H11P-SHF-AA
25.0
28.2
31.2
500
12
H12P-SHF-AA
27.5
30.7
33.7
500
13
H13P-SHF-AA
30.0
33.2
36.2
500
14
H14P-SHF-AA
32.5
35.7
38.7
500
15
H15P-SHF-AA
35.0
38.2
41.2
200
16
H16P-SHF-AA
37.5
40.7
43.7
200
18
H18P-SHF-AA
42.5
45.7
48.7
200
H20P-SHF-AA
47.5
50.7
53.7
200
21
H21P-SHF-AA
50.0
53.2
56.2
200
22
H22P-SHF-AA
52.5
55.7
58.7
200
24
H24P-SHF-AA
57.5
60.7
63.7
200
25
H25P-SHF-AA
60.0
63.2
66.2
200
Circuits
Model No.
2
3
A
B
H 2P-SHF-AA
2.5
H 3P-SHF-AA
5.0
4
H 4P-SHF-AA
5
11.7
Material
PA 6, UL94V-0, natural (white)
RoHS compliance
As the color identification,
the following alphabet shall be put in the underlined part.
For availability, delivery and minimum order quantity, contact JST.
ex.
2
H2P-SHF-AA-oo(blank)…natural (white)
K…black R…red TR…tomato red E…blue M…green
O…orange N…brown
NH
CONNECTOR
Header ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Top entry type
Model No.
2.5
1
Circuits
3.4 3.2
6
0.64
3.5
0.64
A
5.6
Side entry type
1
Side Bottom
entry entry
type type
2
B 2P-SHF-1AA BS 2P-SHF-1AA BE 2P-SHF-1AA
2.5
1,000
1,000
250
3
B 3P-SHF-1AA BS 3P-SHF-1AA BE 3P-SHF-1AA
5.0
1,000
1,000
250
4
B 4P-SHF-1AA BS 4P-SHF-1AA BE 4P-SHF-1AA
7.5
1,000
500
250
5
B 5P-SHF-1AA BS 5P-SHF-1AA BE 5P-SHF-1AA
10.0
1,000
500
250
6
B 6P-SHF-1AA BS 6P-SHF-1AA BE 6P-SHF-1AA
12.5
500
500
150
7
B 7P-SHF-1AA BS 7P-SHF-1AA BE 7P-SHF-1AA
15.0
500
500
150
8
B 8P-SHF-1AA BS 8P-SHF-1AA BE 8P-SHF-1AA
17.5
500
500
150
9
B 9P-SHF-1AA BS 9P-SHF-1AA BE 9P-SHF-1AA
20.0
500
500
150
10
B10P-SHF-1AA BS10P-SHF-1AA BE10P-SHF-1AA
22.5
250
250
100
11
B11P-SHF-1AA BS11P-SHF-1AA BE11P-SHF-1AA
25.0
250
250
100
12
B12P-SHF-1AA BS12P-SHF-1AA BE12P-SHF-1AA
27.5
250
200
100
13
B13P-SHF-1AA BS13P-SHF-1AA BE13P-SHF-1AA
30.0
250
200
100
14
B14P-SHF-1AA BS14P-SHF-1AA BE14P-SHF-1AA
32.5
250
200
50
15
B15P-SHF-1AA BS15P-SHF-1AA BE15P-SHF-1AA
35.0
250
200
50
16
B16P-SHF-1AA BS16P-SHF-1AA
37.5
250
200
17
B17P-SHF-1AA
40.0
200
18
B18P-SHF-1AA BS18P-SHF-1AA
42.5
200
200
19
B19P-SHF-1AA
45.0
250
B20P-SHF-1AA BS20P-SHF-1AA
47.5
250
200
21
B21P-SHF-1AA BS21P-SHF-1AA
50.0
250
200
22
B22P-SHF-1AA BS22P-SHF-1AA
52.5
250
200
23
B23P-SHF-1AA
55.0
250
24
B24P-SHF-1AA BS24P-SHF-1AA
57.5
250
200
25
B25P-SHF-1AA BS25P-SHF-1AA
60.0
250
200
3
3.5
5.6
6
Top entry
type
Q'ty / box
DimenTop
Side entry Bottom entry sions A entry
(mm)
type
type
type
2.5
0.64
0.64
A
5.5
3
Bottom entry type
11.4
1
Material and Finish
Post: Brass, copper-undercoated, tin-plated (reflow treatment)
Wafer: PA 66, UL94V-0, natural (white) for the top and side entry types
PA 6, UL94V-0, natural (white) for the bottom entry type
10
6
7
5.8
3.3
RoHS compliance This product displays (LF)(SN) on a label.
2.5
0.64
A
3.4
3
ex.
B2P-SHF-1AA-oo(blank)…natural (white)
BK…black R…red TR…tomato red E…blue M…green
O…orange N…brown
3
NH
CONNECTOR
PC board layout (viewed from soldering side) and Assembly layout –––––––––––––––––––
Top entry type
Side entry type
6.5
2.5 ±0.05
3.1min.
17.7
6.5
14.9
3 to 12
3.1min.
3.5 min.
2.5 ±0.05
+0.1
φ0.9
1.6
1.6
φ0.9
3
14.7
3.5 3
Bottom entry type
2.5 ±0.05
+0.1
7.5 min.
φ0.9
3.1
14.7
1.6
3 max.
12.2
2.8
9.5
4 min.
Note:
1. Tolerances are non-cumulative: ±0.05mm for all centers.
2. Hole dimensions differ according to the kind of PC board and piercing method. The dimensions above should serve as a guideline.
Crimping machine, Applicator–––––––––––––––––––––––––––––––––––––––––––––––
Contact
SHF-001T-0.8BS
SHF-002T-0.8BS
Note: *Strip-crimp applicator
4
Crimping machine
AP-K2N
AP-K2N
Crimp applicator
Dies
Crimp applicator with dies
MKS-L
MK/SHF-001-08S
APLMK SHF001-08S
*MKS-SC
SC/SHF-001-08S
APLSC SHF001-08S
MKS-L
MK/SHF-002-08S
APLMK SHF002-08S
*MKS-SC
SC/SHF-002-08S
APLSC SHF002-08S
很抱歉,暂时无法提供与“BHF-001T-0.8BS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+0.273031+0.03543
- 500+0.27303500+0.03543
- 1000+0.215121000+0.02791
- 4000+0.182024000+0.02362
- 5000+0.182025000+0.02362
- 10000+0.1737510000+0.02255
- 30000+0.1654830000+0.02147
