BM12B-ZPDSS-TF (LF)(SN)
    JST
BM12B-ZPDSS-TF (LF)(SN) 数据手册
Emboss Tape ZPD CONNECTOR 1.5mm pitch/Disconnectable Crimp style connectors • Secure locking structure • Low insertion force • Suction area for picking up • Improvement of engagement with prying Specifications ––––––––––––––––––– In order to correspond to the high-density PC board designing, this ZPD connector is designed as 1.5mm pitch double row type connector with secure locking device. Low insertion force is realized and good mating feeling is also prepared, and these provide the certain mating operation. Top entry type • Current rating: 2A AC, DC (AWG #24) • Voltage rating: 100V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 30m Ω max. After environmental testing/ 60m Ω max. • Insulation resistance: 500M Ω min. • Withstanding voltage: 500V AC/minute • Applicable wire: Conductor size/ AWG #28 to #24 Insulation O.D./ 0.8 to 1.2mm * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Side entry type ±0.05 (9.2) 8.3 ±0.1 ±0.05 0.7 1.5 1.7 1.7 Circuit No.1 (10.5) ±0.05 Circuit No.N ±0.05 3.5 Circuit No.N-1 Circuit No.N-1 1.7 1.7 Circuit No.2 Circuit No.1 Circuit No.2 8.95 2.8 Connector outline (9.5) ±0.1 1.5 Circuit No.N ±0.05 (8.6) ±0.05 ±0.05 0.7 ±0.1 Connector outline ±0.05 ±0.05 A ±0.05 ±0.05 ±0.1 ±0.1 1 A ±0.1 C 1 Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ±0.05mm for all centers. 3. The dimensions above should serve as a guideline. Contact JST for details. Contact Applicable wire mm2 AWG# Model No. SZPD-002T-P0.3 0.08∼0.21 Insulation O.D. (mm) Q´ty / reel 0.8∼1.2 16,000 28∼24 6.6 2.9 3.15 Material and Finish 1 1.07 Copper alloy, tin-plated (reflow treatment) RoHS compliance Contact Crimping machine Crimp applicator SZPD-002T-P0.3 AP-K2N 1 MKS-L Applicator Dies Crimp applicator with dies MK/SZE-002-03 APLMK SZE002-03 ZPD CONNECTOR Housing 8.6 B (10 circuits) Circuit No.1 mark Circuits Model No. 10 ZPDR-10V-S ZPDR-12V-S ZPDR-14V-S ZPDR-16V-S ZPDR-18V-S ZPDR-20V-S ZPDR-22V-S ZPDR-24V-S ZPDR-26V-S ZPDR-28V-S ZPDR-30V-S 7.6 12 14 16 1.5 18 A (12 to 24 circuits) 20 22 8.6 B Circuit No.1 mark 24 26 7.6 28 30 Q'ty / bag 6.0 11.2 1,000 7.5 12.7 1,000 9.0 14.2 1,000 10.5 15.7 1,000 12.0 17.2 1,000 13.5 18.7 1,000 15.0 20.2 1,000 16.5 21.7 1,000 18.0 23.2 1,000 19.5 24.7 500 21.0 26.2 500 Material 1.5 A (26 to 30 circuits) Dimensions (mm) A B PBT, UL94V-0, natural 8.6 B RoHS compliance 7.6 Circuit No.1 mark As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. 1.5 A ZPDR-10V-SS...natural Z...ivory MG...moss green TR...tomato red DPK...dark pink E...blue Shrouded header Circuit No.1 mark 1.5 A (12 to 30 circuits) (12 to 30 circuits) B 1 7.4 7.85 (5.7) 5.55 1.5 Side entry type Circuits Model No. 10 BM10B-ZPDSS-TF BM12B-ZPDSS-TF BM14B-ZPDSS-TF BM16B-ZPDSS-TF BM18B-ZPDSS-TF BM20B-ZPDSS-TF BM22B-ZPDSS-TF BM24B-ZPDSS-TF BM26B-ZPDSS-TF BM28B-ZPDSS-TF BM30B-ZPDSS-TF 22 24 26 28 30 0.6 A Top entry type 20 6.7 1.5 A 18 0.3 B Circuit No.1 mark Circuit No.1 mark 16 (8) (5.7) 7.85 (10 circuits) 1.5 14 0.6 Circuit No.1 mark A 12 6.7 0.3 B Side entry type 1 7.4 5.55 (10 circuits) B (8) Top entry type Dimensions (mm) A B C Q'ty / reel Circuits Model No. 6.0 11.2 9.2 1,000 10 7.5 12.7 10.7 1,000 12 9.0 14.2 12.2 1,000 14 10.5 15.7 13.7 1,000 16 12.0 17.2 15.2 1,000 18 13.5 18.7 16.7 1,000 20 15.0 20.2 18.2 1,000 22 16.5 21.7 19.7 1,000 24 18.0 23.2 21.2 1,000 26 19.5 24.7 22.7 1,000 28 21.0 26.2 24.2 1,000 30 SM10B-ZPDSS-TF SM12B-ZPDSS-TF SM14B-ZPDSS-TF SM16B-ZPDSS-TF SM18B-ZPDSS-TF SM20B-ZPDSS-TF SM22B-ZPDSS-TF SM24B-ZPDSS-TF SM26B-ZPDSS-TF SM28B-ZPDSS-TF SM30B-ZPDSS-TF Dimensions (mm) A B 6.0 11.2 700 7.5 12.7 700 9.0 14.2 700 10.5 15.7 700 12.0 17.2 700 13.5 18.7 700 15.0 20.2 700 16.5 21.7 700 18.0 23.2 700 19.5 24.7 700 21.0 26.2 700 Material and Finish Material and Finish Contact: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Polyamide, UL94V-0, natural Reinforcing tab: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Contact: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Polyamide, UL94V-0, natural RoHS compliance This product displays (LF)(SN) on a label. This products listed above are supplied on embossed-tape. Q'ty / reel RoHS compliance This product displays (LF)(SN) on a label. This products listed above are supplied on embossed-tape. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. BM10B-ZPDSS-TF- SM10B-ZPDSS-TFS...natural Z...ivory MG...moss green TR...tomato red DPK...dark pink E...blue 2
BM12B-ZPDSS-TF (LF)(SN) 价格&库存
很抱歉,暂时无法提供与“BM12B-ZPDSS-TF (LF)(SN)”相匹配的价格&库存,您可以联系我们找货
