BM23FR0.6-34DS-0.35V(51)
    HRS(广濑)
    SMD,P=0.35mm
    板对板连接器 立贴 针脚数:34Pin 间距:0.35mm 排数:2
BM23FR0.6-34DS-0.35V(51) 数据手册
0.35mm Pitch, 0.6 and 0.8mm Height, Board to Board or Board to FPC Connectors BM23FR Series Space-saving Dimension Example : 24 Pos. Receptacle Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Header ■Features Narrow width design allows for use in small spaces. 1. Space-saving design Fig.1 Compact design ideal for mobile devices (See Fig.1) Pitch : 0.35mm, Width : 1.98mm, Stacking height : 0.6/0.8mm ● 2. Robust [Breaking Strength : 90N] Metal guides prevent housing damage due to incorrect mating. (See Fig.2) Robust design Metal guides are designed to reduce connector damage even if mated incorrectly. 3. Highly reliable contact design 2-point contact design for signal contact ensures high reliability. (See Fig.3) Metal guide 4. Good mating operation Wide self alignment range with metal guides offers enhanced mating operation. (0.4mm in pitch direction, 0.35mm in width direction) Furthermore, a clear tactile click generated by the unique locking contact design insures complete mating. Breaking Strength Actually Measured 90 N 5. Supports USB 3.1 Gen.2 (10Gbps) transmission Fig.2 Signal contacts support USB3.1 Gen.2 transmission speed. ■Environmental ● Halogen-free* As defined by IEC 61249-2-21 Br : 900ppm max., Cl : 900ppm max. Br+Cl : 1,500ppm max. Cross-sectional view of mated contact Header contact Receptacle contact Effective mating length • BM23FR0.6 : 0.15mm • BM23FR0.8 : 0.20mm Fig.3 In cases where the application will demand a high level of reliavility, such as automotive, please contact a company representative for further information. 2018.06 ② 1 BM23FR Series●0.35mm Pitch, 0.6 and 0.8mm Height, Board to Board or Board to FPC Connectors ■Product Specifications Ratings Rated current 0.3A Operating temperature range -55°C to 85°C (Note1) Storage temperature range -10°C to 60°C (Note2) Rated voltage 30V AC/DC Operating humidity range 20% to 80% Storage humidity range 40% to 70% (Note2) Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Items Specifications Conditions 1. Contact resistance 100mΩ max. Measured at 20mV AC, 1kHz, and 1mA 2. Insulation resistance 50MΩ min. Measured at 100V DC 3. Withstanding voltage No flashover or insulation breakdown 100V AC for 1 minute 4. Durability Contact resistance: 100mΩ max. 10 mating cycles 5. Vibration No electrical discontinuity for more than 1μs. Frequency: 10 to 55Hz, single amplitude : 0.75mm in 3 axis directions for 5 minutes, 10 cycles 6. Shock resistance No electrical discontinuity of 1µs or more. Acceleration : 490m/s2, duration of pulse : 11ms at 3 times for 3 directions 7. Humidity Contact resistance : 100mΩ max. Insulation resistance : 25mΩ min. 96 hours at temperature of 40±2°C and a humidity range from 90 to 95% 8. Temperature cycle Contact resistance: 100mΩ max. Insulation resistance: 50MΩ min. -55°C for 30 minutes ➝ 85°C for 30 minutes, 5 cycles 9. Soldering heat resistance No dissolution or melting of the resin that will affect the performance. Reflow: with recommended temperature profile; Hand soldering at soldering iron temperature of 350°C for 3 seconds max. Note 1 : Note 2 : Includes temperature rise caused by current flow. Storage refers to long-term-storage of unused items before they are mounted on the PCB. Operating temperature/humidity range applies to the state of temporary storage such as non-powered after mounting on the PCB, and during transportation, etc. ■Materials / Finish Product Part Material Finish UL Regulation Insulator LCP Black UL94V-0 Contact Copper alloy Gold plating ____ Metal Fitting Copper alloy Gold plating ____ Receptacle Header ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders ●Receptacle / Header BM 23 FR 1 2 ** 3 4 * DS - 0.35 V (***) 5 6 7 9 Series Name: BM Connector Type DS: Receptacle DP: Header Series No. : 23 Contact Pitch : 0.35mm Shape Symbols FR: With locking metal fitting Terminal type V : Straight SMT Stacking Height : 0.6mm, 0.8mm Number of Contacts 2 - 8 Gold plated specification and packaging status (51) : Gold plate thickness 0.05µm Embossed tape packaging (10,000pcs/reel) (895) : Gold plate thickness 0.05µm Embossed tape packaging (1,000pcs/reel) BM23FR Series●0.35mm Pitch, 0.6 and 0.8mm Height, Board to Board or Board to FPC Connectors Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■H=0.6mm Receptacle ■H=0.8mm Receptacle Recommended PCB layout [H=0.6 mm] Recommended PCB layout [H=0.8 mm] 3 BM23FR Series●0.35mm Pitch, 0.6 and 0.8mm Height, Board to Board or Board to FPC Connectors Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Recommended metal mask dimensions (mask thickness : 100µm) [0.6mm and 0.8mm common] Unit : mm Part No. HRS No. No. of contacts A B C D BM23FR0.6-6DS-0.35V(***) 480-0287-0 ** 6 3.55 0.70 2.11 1.08 BM23FR0.6-8DS-0.35V(***) 480-0360-0 ** 8 3.90 1.05 2.46 1.43 BM23FR0.6-10DS-0.35V(***) 480-0258-0 ** 10 4.25 1.40 2.81 1.78 BM23FR0.6-12DS-0.35V(***) 480-0371-0 ** 12 4.60 1.75 3.16 2.13 BM23FR0.6-16DS-0.35V(***) 480-0295-0 ** 16 5.30 2.45 3.86 2.83 BM23FR0.6-20DS-0.35V(***) 480-0272-0 ** 20 6.00 3.15 4.56 3.53 BM23FR0.6-24DS-0.35V(***) 480-0260-0 ** 24 6.70 3.85 5.26 4.23 BM23FR0.6-30DS-0.35V(***) 480-0327-0 ** 30 7.75 4.90 6.31 5.28 BM23FR0.6-34DS-0.35V(***) 480-0274-0 ** 34 8.45 5.60 7.01 5.98 BM23FR0.6-40DS-0.35V(***) 480-0390-0 ** 40 9.50 6.65 8.06 7.03 BM23FR0.6-50DS-0.35V(***) 480-0382-0 ** 50 11.25 8.40 9.81 8.78 Part No. HRS No. No. of contacts A B C BM23FR0.8-10DS-0.35V(***) 480-0298-0 ** 10 4.25 1.40 2.81 BM23FR0.8-18DS-0.35V(***) 480-0469-0 ** 18 5.65 2.80 4.21 BM23FR0.8-60DS-0.35V(***) 480-0300-0 ** 60 13.00 10.15 11.56 Note 1 : Please place orders in full reel quantities. Note 2 : This connector has no polarity. Note 3 : The specification number(895) in the Part No. changes to(95) in the HRS No. 4 BM23FR Series●0.35mm Pitch, 0.6 and 0.8mm Height, Board to Board or Board to FPC Connectors Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■H=0.6mm Header ■H=0.8mm Header Recommended PCB layout [H=0.6mm] Recommended PCB layout [H=0.8mm] 5 BM23FR Series●0.35mm Pitch, 0.6 and 0.8mm Height, Board to Board or Board to FPC Connectors Recommended metal mask dimensions (mask thickness : 100µm) [0.6mm and 0.8mm common] Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unit : mm Part No. HRS No. No. of contacts A B C D E BM23FR0.6-6DP-0.35V(***) 480-0286-0 ** 6 2.75 0.70 2.00 1.41 3.55 BM23FR0.6-8DP-0.35V(***) 480-0361-0 ** 8 3.10 1.05 2.35 1.76 3.90 BM23FR0.6-10DP-0.35V(***) 480-0257-0 ** 10 3.45 1.40 2.70 2.11 4.25 BM23FR0.6-12DP-0.35V(***) 480-0364-0 ** 12 3.80 1.75 3.05 2.46 4.60 BM23FR0.6-16DP-0.35V(***) 480-0290-0 ** 16 4.50 2.45 3.75 3.16 5.30 BM23FR0.6-20DP-0.35V(***) 480-0273-0 ** 20 5.20 3.15 4.45 3.86 6.00 BM23FR0.6-24DP-0.35V(***) 480-0259-0 ** 24 5.90 3.85 5.15 4.56 6.70 BM23FR0.6-30DP-0.35V(***) 480-0328-0 ** 30 6.95 4.90 6.20 5.61 7.75 BM23FR0.6-34DP-0.35V(***) 480-0275-0 ** 34 7.65 5.60 6.90 6.31 8.45 BM23FR0.6-40DP-0.35V(***) 480-0391-0 ** 40 8.70 6.65 7.95 7.36 9.50 BM23FR0.6-50DP-0.35V(***) 480-0383-0 ** 50 10.45 8.40 9.70 9.11 11.25 Part No. HRS No. No. of contacts A B C D E F BM23FR0.8-10DP-0.35V(***) 480-0297-0 ** 10 3.45 1.40 2.70 2.11 3.41 4.25 BM23FR0.8-18DP-0.35V(***) 480-0468-0 ** 18 4.85 2.80 4.10 3.51 4.81 5.65 BM23FR0.8-60DP-0.35V(***) 480-0299-0 ** 60 12.20 10.15 11.45 10.86 12.16 13.00 Note 1 : Please place orders in full reel quantities. Note 2 : This connector has no polarity. Note 3 : The specification number(895) in the Part No. changes to(95) in the HRS No.   6 BM23FR Series●0.35mm Pitch, 0.6 and 0.8mm Height, Board to Board or Board to FPC Connectors Embossed Tape Dimensions (IEC 602286-3, with JIC C 0806) Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Receptacle Un-reeling direction ●Reel dimensions 10,000pcs/reel 1,000pcs/reel ▶ ▶ Unit : mm Part No. HRS No. No. of contacts A B C D E F G H I BM23FR0.6-6DS-0.35V(***) 480-0287-0 ** 6 12 5.5 3.66 0.25 0.8 2.07 13.5 17.5 330 BM23FR0.6-8DS-0.35V(***) 480-0360-0 ** 8 12 5.5 4.01 0.25 0.8 2.07 13.5 17.5 330 BM23FR0.6-10DS-0.35V(***) 480-0371-0 ** 10 16 7.5 4.36 0.25 0.8 2.07 17.5 21.5 380 BM23FR0.6-12DS-0.35V(***) 480-0295-0 ** 12 16 7.5 4.71 0.25 0.8 2.07 17.5 21.5 330 BM23FR0.6-16DS-0.35V(***) 480-0272-0 ** 16 16 7.5 5.41 0.25 0.8 2.07 17.5 21.5 330 BM23FR0.6-20DS-0.35V(***) 480-0260-0 ** 20 16 7.5 6.11 0.25 0.8 2.07 17.5 21.5 380 BM23FR0.6-24DS-0.35V(***) 480-0327-0 ** 24 16 7.5 6.81 0.25 0.8 2.07 17.5 21.5 380 BM23FR0.6-30DS-0.35V(***) 480-0274-0 ** 30 24 11.5 7.86 0.25 0.8 2.07 25.5 29.5 330 BM23FR0.6-34DS-0.35V(***) 480-0390-0 ** 34 24 11.5 8.56 0.25 0.8 2.07 25.5 29.5 380 BM23FR0.6-40DS-0.35V(***) 480-0382-0 ** 40 24 11.5 9.61 0.25 0.8 2.07 25.5 29.5 330 BM23FR0.6-50DS-0.35V(***) 480-0371-0 ** 50 24 11.5 11.36 0.25 0.8 2.07 25.5 29.5 330 Part No. HRS No. No. of contacts A B C D E F G H I BM23FR0.8-10DS-0.35V(***) 480-0298-0 ** 10 16 7.5 4.36 0.3 1.0 2.07 17.5 21.5 330 BM23FR0.8-18DS-0.35V(***) 480-0469-0 ** 18 16 7.5 5.76 0.3 1.0 2.07 17.5 21.5 330 BM23FR0.8-60DS-0.35V(***) 480-0300-0 ** 60 24 11.5 13.11 0.3 1.0 2.07 25.5 29.5 330 Note 1 : The specification number(895) in the Part No. changes to(95) in the HRS No.  7 BM23FR Series●0.35mm Pitch, 0.6 and 0.8mm Height, Board to Board or Board to FPC Connectors Embossed Tape Dimensions (IEC 602286-3, with JIC C 0806) Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Header Un-reeling direction ●Reel Dimensions 10,000pcs/reel 1,000pcs/reel ▶ ▶ Unit : mm Part No. HRS No. No. of contacts A B C D E F G H I BM23FR0.6-6DP-0.35V(***) 480-0286-0 ** 6 12 5.5 2.85 0.25 0.65 1.58 13.5 17.5 330 BM23FR0.6-8DP-0.35V(***) 480-0361-0 ** 8 12 5.5 3.20 0.25 0.65 1.58 13.5 17.5 330 BM23FR0.6-10DP-0.35V(***) 480-0257-0 ** 10 12 5.5 3.55 0.25 0.65 1.64 13.5 17.5 380 BM23FR0.6-12DP-0.35V(***) 480-0364-0 ** 12 12 5.5 3.90 0.25 0.65 1.64 13.5 17.5 330 BM23FR0.6-16DP-0.35V(***) 480-0290-0 ** 16 16 7.5 4.60 0.25 0.65 1.64 17.5 21.5 330 BM23FR0.6-20DP-0.35V(***) 480-0273-0 ** 20 16 7.5 5.30 0.25 0.65 1.64 17.5 21.5 380 BM23FR0.6-24DP-0.35V(***) 480-0259-0 ** 24 16 7.5 6.00 0.25 0.65 1.64 17.5 21.5 380 BM23FR0.6-30DP-0.35V(***) 480-0328-0 ** 30 16 7.5 7.05 0.25 0.65 1.64 17.5 21.5 330 BM23FR0.6-34DP-0.35V(***) 480-0275-0 ** 34 16 7.5 7.75 0.25 0.65 1.64 17.5 21.5 380 BM23FR0.6-40DP-0.35V(***) 480-0391-0 ** 40 24 11.5 8.80 0.25 0.65 1.64 25.5 29.5 330 BM23FR0.6-50DP-0.35V(***) 480-0383-0 ** 50 24 11.5 10.55 0.25 0.65 1.64 25.5 29.5 330 Part No. HRS No. No. of contacts A B C D E F G H I BM23FR0.8-10DP-0.35V(***) 480-0297-0 ** 10 12 5.5 3.55 0.3 0.78 1.64 13.5 17.5 330 BM23FR0.8-18DP-0.35V(***) 480-0468-0 ** 18 16 7.5 4.95 0.3 0.78 1.64 17.5 21.5 330 BM23FR0.8-60DP-0.35V(***) 480-0299-0 ** 60 24 11.5 12.30 0.3 0.78 1.64 25.5 29.5 330 Note 1 : The specification number (895) in the Part No. changes to (95) in the HRS No. 8 BM23FR Series●0.35mm Pitch, 0.6 and 0.8mm Height, Board to Board or Board to FPC Connectors BM29 Series Ultra-small, power/signal contact design for Board-to-Board/FPC-to-Board providing 3A max current Precautions Precautions 1.Recommended 1.temperature Recommended solder profi le MAX 250℃ temperature profile 250 220℃ Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Jul.1.2017 Copyright 2017 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Temperature ( ℃) 220 200 180 180℃ 150℃ 150 100 50 25 25℃ (60 sec onds) 0 90 to 120 seconds Preheating time Max. 60 seconds Soldering time Start Time (seconds) [Conditions] [Conditions] 1. Peak temperature 1. Peak temperature 2. Heating unit 2. Heat section unit 3. Preheating 3. Preheat section 4. Number of times : 250ç : Maximum of 250℃ : No less than 220ç for no more than 60 seconds : 220℃ min., : 150 to 180çwithin for 9060 to seconds 120 seconds : 150 to 180℃, 90 to 120 seconds : No more than 2 times 4. Number of reflow cycles : Maximum of 2 cycles Note 1 :The temperature is the surface temperature of the PCB in the vicinity of the connector Note 1 lead : Thepart. temperature is the surface temperature of the PCB in the vicinity of the connector Note 2 :When you use nitrogen refl ow, please mount the product with the oxygen concentration lead part. Note 2 at : When using nitrogen reflow process, please mount the product with the oxygen a minimum of 1,000 [ppm]. concentration a minimum of 1,000[ppm]. Please contactatus if the concentration is below 1,000 [ppm]. Please contact Hirose if the concentration is below 1,000 [ppm]. 2. Recommended hand 2. Recommended manual soldering conditions Soldering iron temperature : 340 ± 10°C, Soldering iron: temperature: 340±10℃ Soldering time within 3 seconds 3. Recommended screen thickness/aperture ratio 3. Recommended screen (pattern area ratio)area thickness and open Thickness : 0.1mm Aperture ratio: 0.1mm : 100% on the DS side ; 80% on the DP side Thickness soldering conditions to PCBofpattern area 4. ratio Warpage the PCB 5. Cleaning 4. Warpage of the PCB 6. Notes 5. Cleaning 6. Notes Soldering time : within 3 seconds Aperture ratio : 100% on the DS side, 100% on the DP side A maximum of 0.02mm at the center part of the connector based on both ends of the connector. Not recommended. If you clean this product, please evaluate the performance before using it. A maximum of 0.02mm at the center in partthe of the connector based onproperty both endsand of theits connector. (Cleaning may cause a change mating/unmating resistance to environment) Not recommended. If this product is cleaned, please evaluate the performance before using Care should be taken that mating/unmating operation when the product is not mounted on the it. Cleaning may cause a change in the mating/unmating properties as well as environmental PCB could cause damage or deformation, etc. of the contact. resistance. Avoid supporting the PCB only by connectors, and support it by other means than connectors. ■Care sholud taken when mating/unmating the connectorcould and when is not Care should be be taken that excessive prying mating/unmating causeit damage. mounted the PCB.do Damage or deformation of cause the contacts may occur. During hand on soldering, not apply fl ux which will fl ux oozing on connector. ■Avoid supporting the PCB connectors. lot Support it by other means suchhave as any This product may differ in only hue with due the to production variability, but it doesn’t bolts, screws, posts, etc. infl uence on the performance. ■Care should be taken to avoid excessive prying mating/unmating that could cause Please refer to the next page for the precautions for mating/unmating. damage. Considering the possibility of sengagement di due to the counterfor ce caused by the drop, impact ■During manual soldering, do not apply flux which will cause flux oozing on connector. and routing of FPC, xfi the mated state by the use of housings and cushion materials, etc. ■This product may have slight color differences due to production lot variability, but this Caution! Do have not use connector in non-recommended conditions (i.e., rated current, rated does not anythe effect on the performance. voltage, PCB design and operating environment, etc.). mating/unmating. Such usage could lead to material ■Please refer to the next page for precautions regarding outgassing, ignition, or short-circuit, etc. ■Because the product can disengage if dropped (or other impact), and by FPC Refer to theit specifi cations and the for board dimensions, board routing, is advised to secure theguidelines mated connectors to pattern the board with housings andcautions, andcushioning connectormaterials. treatment. ■Caution! Do not use the connector in non-recommended conditions Pleasae contact Hirose if using the connector under conditions other(i.e., thanrated those described in rated voltage, design is and operating environment, etc.). Such usage the current, specifi cations and thePCB guidelines being considered. could lead to material outgassing, ignition, or short-circuit, etc. Refer to the specifications and the guidelines for board pattern dimensions, board cautions, and connector treatment. Please contact Hirose if using the connector under conditions other than those described in the specifications and the guidelines is being considered. 9 5 BM23FR Series●0.35mm Pitch, 0.6 and 0.8mm Height, Board to Board or Board to FPC Connectors ●Handle with care when mating a connector BM23FR**-*DP-0.35V BM23FR**-*DS-0.35V Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Alignment method OK When aligning, look for the guide port without applying excessive force. Caution! If excessive force is applied, the connector could crack or be shaved which could lead to a defect in contact resistance. NG Guiding condition Mated condition 10 When guided, the connectors are aligned parallel to each other with longitudinal and lateral movements restricted. Mate them parallel to each other. BM23FR Series●0.35mm Pitch, 0.6 and 0.8mm Height, Board to Board or Board to FPC Connectors Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Handle with care when un-mating connectors OK Un-mate connectors parallel to each other. OK If the connector cannot be un-mated parallel, it can be removed diagonally from the pitch direction, as shown in the left figure. However, the connector can be broken if the FPC is not rigid. Please confirm rigidity of the FPC at the time of trial production. Pitch direction Do not pull from the corner. If it is pulled from the corner as shown in the left figure, the contact and connector could be damaged. NG Corner direction NG Please provide a reinforcing plate for the FPC. If the rigidity of the FPC is not sufficient, the connector may break as shown in the left figure. Please check the action of the FPC to be used repeatedly. A reinforcing plate of 0.3mm or thicker made of glass epoxy material, or 0.2mm or thicker stainless steel is recommended 11 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BM23FR Series●0.35mm Pitch, 0.6 and 0.8mm Height, Board to Board or Board to FPC Connectors DF22 Series●7.92mm Contact Pitch High-Current Connectors for Internal Power Supplies (UL, C-UL and TÜV Listed) USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE 2300 Warrenville Road, Suite 150, Downers Grove, IL 60515 Phone : +1-630-282-6700 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 2841 Junction Ave, Suite 200 San Jose, CA. 95134 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 17197 N. Laurel Park Drive, Suite 253, Livonia, MI 48152 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE 300 Brickstone Square Suite 201, Andover, MA 01810 Phone : +1-978-662-5255 THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Schoenbergstr. 20, 73760 ostfildern Phone : +49-711-456002-1 Fax : +49-711-456002-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE Neumeyerstrasse 22-26, 90411 Nurnberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE Bayernstr. 3, Haus C 30855 Langenhagen, Germany Phone : +49-511 97 82 61 30 Fax : +49-511 97 82 61 35 http://www.hirose.com/eu/ FRANCE: HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE 130 Avenue Joseph Kessel, Bat E, 78960 Voisins le Bretonneux, France Phone : +33-1-85764886 Fax : +33-1-85764823 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. (SHANGHAI, HEADQUARTERS) 18, Enterprise Center Tower 2, 209# Gong He Road, Jing’an District, Shanghai, CHINA 200070 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. SHENZHEN BRANCH Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7355 http://www.hirose.com/tw/ KOREA: HIROSE KOREA CO.,LTD. 143, Gongdan 1-daero, Siheung-si, Gyeonggi-do, 15084, Korea Phone : +82-31-496-7000 Fax : +82-31-496-7100 http://www.hirose.co.kr/ INDIA: SINGAPORE: HIROSE ELECTRIC SINGAPORE PTE. LTD. HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE 03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C, Singapore 079909 Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India Phone : +65-6324-6113 Phone : +91-12-660-8018 Fax : +65-6324-6123 Fax : +91-120-4804949 http://www.hirose.com/sg/ http://www.hirose.com/sg/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma Gandhi (MG) Road, Bangalore 560 001, Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ THAILAND: MALAYSIA: BANGKOK OFFICE (REPRESENTATIVE OFFICE) PENANG REPRESENTATIVE OFFICE 73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn Lepas Penang, 11950, Malaysia Road, Yannawa, Sathorn, Bangkok 10120 Thailand Phone : +604-648-5536 Phone : +66-2-686-1255 http://www.hirose.com/sg/ Fax : +66-2-686-3433 http://www.hirose.com/sg/ ® 12 16 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com Thecharacteristics characteristicsand andthe thespecifications specificationscontained containedherein hereinare arefor forreference reference purpose. purpose. Please Please refer refer to to the the latest latest customer customer drawings prior to use. The The contents this catalog are current date 02/2018. Contents are subject change without notice thepurpose purposeofofimprovements. improvements. The contents of of this catalog are current asas of of date of of 06/2018. Contents are subject toto change without notice forforthe
BM23FR0.6-34DS-0.35V(51) 价格&库存
很抱歉,暂时无法提供与“BM23FR0.6-34DS-0.35V(51)”相匹配的价格&库存,您可以联系我们找货
