ET60S-D04-3-08-D02-L-V1-S
    SAMTEC(申泰)
    ET60S SOCKET POWER ASSEMBLY
ET60S-D04-3-08-D02-L-V1-S 数据手册
EXTREME HIGH-POWER 60 A SYSTEMS FEATURES & BENEFITS • Up to 60 A per power blade (2 blades powered) • Low 10 mm profile (right-angle) for enhanced system airflow • Power only, or power/signal combinations • 3 or 5 signal rows in the same form factor • AC power, DC power, power/signal combinations and split power options available • Coplanar and perpendicular applications • Modules can be configured to accommodate most any design MAX • Rugged guide posts are standard; top design for board space savings • Press-fit (ET60S only) and hot swap (ET60T only) options available Standard Creepage* 3.02 mm Standard Clearance* 1.87 mm 60 A m p s *Selectively loading contacts achieves customer specific creepage and clearance requrements. Contact asp@samtec.com KEY SPECIFICATIONS (ET60T/ET60S) PITCH Power (5.50 mm) .217" (7.50 mm) .295" Signal (2.00 mm) .097" (5 row) (2.54 mm) .100" (3 row) INSULATOR MATERIAL TERMINAL MATERIAL PLATING OPERATING TEMP RANGE VOLTAGE RATING MATING CYCLES LEAD-FREE SOLDERABLE Black LCP Signal: Phosphor Bronze Power: Copper Alloy Au or Sn over 50 µ" (1.27 µm) Ni -40 °C to +105 °C 280 VAC 500 Yes Notes: Some lengths, styles and options are non-standard, non-returnable. *EXTreme Ten60Power™ is a trademark of Molex Incorporated and is dual sourced by Molex® F-224 samtec.com/extreme-ten60power Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. 60 A SIGNAL/POWER COMBO SYSTEM SERIES - ET60T Terminal ET60S Socket POWER OPTION (R) –AXX = AC Power Positions (02 - 06) –DXX = DC Power Positions (02 - 10) –SXX* = Split Power –000 = No Power - ROWS –0 - SIGNAL POS. PER ROW –00 = No Signal = No Signal –3 = 3 Row only –5 –08 –01, –02, –03, –04, –05, –06, –07, –08 = 5 Row only - POWER OPTION (L) - –AXX = AC Power Positions (02 - 06) –DXX = DC Power Positions (02 - 10) –SXX* = Split Power PLATING - –L = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail (Not available for 5 rows) –S = 30 µ" (0.76 µm) Gold on contact, Matte tin on tail TAIL - GUIDE POST –R1 = Right-angle Through-hole (Use with (1.60 mm) .062" thick card) –VP = Vertical Press-fit (Not available with ET60T) (Required callout) –S = Side Guide Post –T* - OPTION (Leave blank for no hot swap) –H = Hot Swap (ET60T only) = Top Guide Post –V1 = Vertical Through-hole (Use with (1.60 mm) .062" thick card) (–0 and –3 Row only) (Not available with ET60T) –000 = No Power ET60T Board Mates: ET60S (29.25) 1.152 (77.21) 3.04 (10.00) .394 (77.21) 3.04 ET60T-D04-5-03-A04-X-R1-S SHOWN View complete specifications at: samtec.com?ET60T ET60S (18.00) .709 Board Mates: ET60T (77.21) 3.04 VERTICAL ET60S-D04-5-03-A04-X-VP-S SHOWN (77.21) 3.04 (10.00) .394 (25.22) .993 RIGHT-ANGLE ET60S-D04-5-03-A04-X-R1-S SHOWN View complete specifications at: samtec.com?ET60S samtec.com/extreme-ten60power Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
ET60S-D04-3-08-D02-L-V1-S 价格&库存
很抱歉,暂时无法提供与“ET60S-D04-3-08-D02-L-V1-S”相匹配的价格&库存,您可以联系我们找货
