GT5
Interface Connector
GT13
GT16
PO5G
GT7 Series
GT21
GT26
GT36
GT11
GT17
GT3
These automotive crimp terminals are equivalent to 040 and 070 tab width items.
The contact point of the F connector side has been given a double structure to make these connectors
compatible with low insertion force and high contact pressure at the time of coupling.
GT32
GT10
GT18W
GT25
GT8E
GT9
GT15
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
179
Interface Connector
GT7
Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
GT19
Features
F Connectors
2.3
A
Terminals
GT21
GT26
GT36
HRS No.
Material
Plating
GT7-2022SCF(70)
GT7A-2022SCF(70)
GT3-2024SCF(70)
757-0001-1 70
757-0003-7 70
753-0006-0 70
Copper
palloy
Tin plating
Conductor
Size (AWG)
Outer
A
B
Diameter Dimension Dimension
φ1.4 to 2.4
φ2.6 to 3.1
20 to 24 AWG φ1.4 to 2.4
20 to 22 AWG
2.8
19
2.3
18.2
Housing
16 Pos.
5,000 pcs/reel
3,000 pcs/reel
5,000 pcs/reel
YES
21
5.2
GT32
15.7
15
25
22
GT3
GT7
RoHS
3
Part No.
GT7-16DS-HU
HRS No.
757-0008-0
Color
Light Gray
Material
PBT
25.5
Packaging RoHS
1
YES
Retainer (Only for GT7-16DS-HU)
16.8
25.5
13.2
14.4
GT18W
GT10
Packaging
Note 1: Sold in reel.
Note 2: This component is used only with applicable HRS housings.
GT17
GT11
Part No.
GT9
GT8E
GT25
14.7
GT15
Interface Connector
GT19
PO5G
B
GT16
GT13
GT5
GT7 Series ● Interface Connector
180
Part No.
GT7-16R
HRS No.
757-0010-2
Color
Dark Gray
Material
PBT
Packaging RoHS
1
YES
3.1
22 Pos.
21
3.1
GT5
3.5
3
GT13
5.2
5.2
Housing
35.8
16.8
PO5G
15.7
GT16
35.2
Color
Light Gray
Material
PBT
Packaging RoHS
1
YES
13.2
35.95
GT26
15.4
Retainer (Only for GT7-22DS-HU)
GT21
14.7
GT36
Color
Dark Gray
Material
PBT
Packaging RoHS
1
YES
7 3.1
3
3.5
21
3.1
3.5
16.8
42.8
14.7
GT25
14.4
13.2
GT18W
42.95
Retainer (Only for GT7-26DS-HU)
22
15
Packaging RoHS
1
YES
GT8E
GT9
Part No.
GT7-26R
HRS No.
757-0011-5
Color
Dark Gray
Material
PBT
Packaging RoHS
1
YES
GT15
181
Interface Connector
Material
PBT
GT10
Color
Light Gray
GT7
HRS No.
757-0009-3
GT3
15.7
42.2
Part No.
GT7-26DS-HU
GT32
5.2
26 Pos.
GT17
Housing
HRS No.
757-0016-9
5.2
Part No.
GT7-22R
GT11
HRS No.
757-0015-6
GT19
Part No.
GT7-22DS-HU
GT5
BRecommended PCB pattern
Board Type 26 Pos.
18.5
5.7
21.9
PO5G
4
GT19
A
5.7
4.5
8.4
15.3
GT21
GT26
GT36
0.65
HRS No.
Material / Plating or Color
Packaging RoHS
A Dimension
757-0014-3 70 Housing:PBT/Light Gray
3
1
YES
757-0006-5 70 Terminal:Brass/Tin plating Shaded portion without stand-off
Board Type / Hybrid Type
42 Pos. (26pos.+16pos.)
18.5
GT17
GT11
Part No.
GT7A-26DP-DS(70)
GT7-26DP-DS(70)
72.1
21.9
GT32
(Tolerance of unmarked values is +- 0.05.)
4
Mates with a 26-pos. + 16-pos. F connector.
A
□0.64
4.5
3.1
3.5
8.4
15.3
GT7
5.7
3.5
21
3.1
3
3.5
26.95
21
3
5.7
4.5
GT3
1
1.
-φ
39
□0.64
GT7 has shaded portion without stand-off
GT10
GT18W
GT25
GT8E
GT9
3.5
26
Part No.
GT7A-42DP-DS(70)
GT7-42DP-DS(70)
HRS No.
Packaging RoHS
A Dimension
757-0013-0 70 Housing:PBT/Light Gray
3
1
YES
757-0007-8 70 Terminal:Brass/Tin plating Shaded portion without stand-off
1.1
-φ
3.5
3-φ
42
0.4
24.25
65.7
182
3.1
4.5
45.4
GT15
3.1
21
3
Mates with a 26-pos. F connector.
Interface Connector
3.5 3.5
GT16
GT13
M Connectors
GT5
64 Pos.
18.5
GT13
GT16
4
□0.64
3.2
4.5
GT19
111.4
117.8
A
5.7
PO5G
21.9
109
8.4
15.3
6.4
GT21
3
3.1
36.65
21
3 3.1
3.5
5.05
3.5
111.4
GT17
BCrimping tools
GT11
4-φ
38.85
65.55
GT36
3
Part No.
HRS No.
Packaging RoHS
A Dimension
GT7A-64DP-DS(70) 757-0012-8 70
3
1
YES
757-0005-2 70 Shaded portion without stand-off
GT7-64DP-DS(70)
63.6
21
4.5
3.1
3.1 3.5
21
5.7
1.1
-φ
3.5 3.5
GT26
64
User manuals are available. Please ask your Hirose Electric account representative.
GT32
Automatic Crimping Machine
GT3
Picture reference only
Specifications
Specification
Remarks
1.5ton
30mm
200spm(50 Hz)
Weight
75 kg
0.2kw
2,000 to 4,000 pcs/hour
AC100V
GT18W
Motor
Crimping speed
240spm(60 Hz)
GT10
Stroke Length
Number of strokes
Part No. CM-105C
GT25
Harness tool
Terminal HRS No.
757-0001-1 70
757-0003-7 70
Tool Part No.
AP 105-GT7-2022
AP 105-GT7A-2022
Tool HRS No.
901-5004-9
901-5039-3
GT9
*Crimp height setting tables are available for each cable type.
Please contact your nearest Hirose Electric account representative.
Different cables will require different crimp height settings.
GT8E
Terminal Part No.
GT7-2022SCF(70)
GT7A-2022SCF(70)
GT15
183
Interface Connector
Item
Press capacity
GT7
+ 22-pos. F connector.
很抱歉,暂时无法提供与“GT7A-26DP-DS(70)”相匹配的价格&库存,您可以联系我们找货
