HR08D-12WPK-10S(31)
HR08D-12WPK-10S(31)
    HRS(广濑)
    HIROSE(HRS) - HR08D-12WPK-10S(31) - Circular Connector, HR08D Series, Cable Mount Plug, 10 Contacts,...
HR08D-12WPK-10S(31) 数据手册
Small, Waterproof, Push-On Bayonet Lock Connectors HR08D Series Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Push-On Bayonet Lock Mating is completed simply by pushing the plug onto the receptacle. To unmate this connector, rotate the locking collar to release the lock, then pull them apart. ■Features Fig.q 1. Simplified mating operations •To mate the connector, simply push it onto the receptacle. To unmate, rotate the locking collar and pull the plug back from the receptacle. (Fig. q) •Simplified mating is enabled by the alignment markings •Mating guide keys are provided at 3 points to prevent contact damage. They also provide the ability to blind mate these connectors when needed. Plug connector does not damage the receptacle contacts. Cable exit directions 2. Waterproof structure Supports IP67 and IP68 ratings while in the mated condition. (Ratings explained below*) *IP67: Submerged in 1 m for 30 minutes *IP68: Submerged in 2 m for 14 days Fig.w 3. Adjustable cable direction The right angle plug can be adjusted to mount in any of the 8 different directions (adjustable in 45° increments). (Fig. w) 4. Variations available Items No. of Contacts 2 or 10 positions available Connector Type Straight Plug, Right Angle Plug, Receptacle (10 pos. only) Plug Termination Crimp, solder Receptacle Termination Solder Cord Tube Material Cable Diameter Range (Reference) Plastic, metal (Ø5.7 to 6.5)(Ø6.5 to 7.3)(Ø8.0 to 9.0) In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2018.7② 1 HR08D Series●Small, Waterproof, Push-On Bayonet Lock Connectors ■Product Specifications Rated Current Rated Voltage Ratings Operating Temperature Range Storage Temperature Range -20ç to +85ç -10ç to +60ç Items Specifications Conditions 1. Contact Resistance 2.Insulation Resistance 3. Withstanding Voltage 6. Durability 20mø or below Minimum of 1,000Mø No flashover or breakdown No electrical discontinuity of 10µs or greater No electrical discontinuity of 10µs or greater Contact Resistance : Maximum of 30mø 7. Temperature Cycles Insulation Resistance : Minimum of 500Mø Measured with DC 1A Measured with DC 500V 10 pos. AC 900V for 1 minute 2 pos. AC 1,500V for 1 minute Tested in 3 directions with 10 to 500Hz /cycle, total vibration width of 0.75mm, and 98m/s2, 3 hours each. Tested in 3 directions with the acceleration of 490m/s2, and a duration of 11ms, 3 times each 500 mating cycles Left at -55ç : 30 minutes ⇒ Ordinary temperature : 2 to 3 minutes ⇒ 85ç : 30 minutes ⇒ Ordinary temperature : 2 to 3 minutes, 2 to 3 minutes, Total of 5 cycles Left at temperature 71ç and humidity 95% for 336 hours. Left at the temperature of 71ç and 95% humidity for 336 hours. Left submerged in water at the depth of 1m, for 0.5 hours, in the mated condition. 4. Vibration Resistance 5. Shock Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3A AC200V, DC250V 8. Humidity Resistance 9. Waterproof Structure Insulation resistance Minimum of 50Mø (high humidity) Minimum of 500Mø (dry) Should be no water leakage inside the connector ■Materials / Finish ●Plug Component Outer Shell Insulator Female Contact O Ring, Gasket Materials Zinc Alloy, aluminum alloy and polyamide resin (black) PPS resin (black) Phosphorous bronze NBR, Nitrile hydride rubber Finish Nickel under plating ---------------------Gold plating ---------------------- Remarks ---------------------UL94V-0 ------------------------------------------- Materials Zinc alloy PPS resin (black) Brass NBR Finish Nickel under plating ---------------------Gold plating ---------------------- Remarks ---------------------UL94V-0 ------------------------------------------- ●Receptacle Component Outer Shell Insulator Male Contact 10 position O Ring ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Plug ● Receptacle HR08D 12 WP A - 10 S (**) HR08D 12 WR - 10 P (**) ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❶ Model Name : HR08D series ❷ Shell Size : Diameter (mm) of the mating interface of the plug ❸ Shell Type WP : Straight plug, WLP: Right angle plug ❹ Cord Tube and Cable Range Type A : Material of cord tube : Metal, with cable dia. range of (Ø 5.7 to 6.5) B : Material of cord tube : Metal, with cable dia. range of (Ø 6.5 to 7.3) M : Material of cord tube : Plastic, with cable dia. range of (Ø5.7 to 6.5) N : Material of cord tube : Plastic, with cable dia. range of (Ø6.5 to 7.3) K : Material of cord tube : Metal, with cable dia. range of (Ø8.0 to 9.0) ❺ Number of Contacts : Contacts available (2 or 10) ❻ Contact Shape S : Female contact for solder termination SC : Female contact for crimping termination ❼ Other specifications : A two-digit character is added to indicate other specifications as needed. 2 ❶ ❷ ❸ ❹ ❺ ❻ ❶ Model Name : HR08D series ❷ Shell Size : Diameter (mm) of the mating interface of the plug ❸ Shell Type WR:Receptacle ❹ Number of Contacts : Contacts available (10 only) ❺ Contact Shape P : Male contact for solder termination ❻ Other specifications : A two-digit character is added to indicate other specifications as needed. ●Crimp contact HR34B - SC1 - 2 1 1 ❶ ❷ ❸ ❹ ❺ ❶ Model Name : HR34B series (Shares the same contacts as the HR34B series) ❷ Contact Type SC1 : Female contact ❸ Contact Shape 1 : Single contact 2 : Reel contact ❹ Barrel Shape : 1 : 20 to 25 AWG ❺ Plating Type 1 : Gold plating HR08D Series●Small, Waterproof, Push-On Bayonet Lock Connectors ■Straight plug ●Regular version ( Cord tube material : Plastic) 49.1 4 3 A φ20 1 8 7 10 Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (example) ◆Solder termination version Part No. HRS No. A HR08D-12WPM-10S(31) 108-0274-5 31 Ø7.4 Applicable cable diameter range (Reference) (Ø5.7 to 6.5) HR08D-12WPN-10S(31) 108-0275-8 31 Ø8.5 (Ø6.5 to 7.3) HR08D-12WPM-2S(31) 108-0272-0 31 Ø7.4 (Ø5.7 to 6.5) HR08D-12WPN-2S(31) 108-0266-7 31 Ø8.5 (Ø6.5 to 7.3) Contact solder cup inner diameter Ø1 Ø1.8 ◆ Crimp termination version Part No. HRS No. A Applicable cable diameter range (Reference) HR08D-12WPM-10SC(31) 108-0268-2 31 Ø7.4 (Ø5.7 to 6.5) HR08D-12WPN-10SC(31) 108-0269-5 31 Ø8.5 (Ø6.5 to 7.3) ●Robust version (Cord tube material: Metal) ◆Solder termination version Part No. HRS No. A HR08D-12WPA-10S(31) 108-0219-7 31 Ø7.4 Applicable cable diameter range (Reference) (Ø5.7 to 6.5) HR08D-12WPB-10S(31) 108-0231-2 31 Ø8.5 (Ø6.5 to 7.3) HR08D-12WPK-10S(31) 108-0262-6 31 Ø9.5 (Ø8.0 to 9.0) HR08D-12WPA-2S(31) 108-0279-9 31 Ø7.4 (Ø5.7 to 6.5) HR08D-12WPB-2S(31) 108-0280-8 31 Ø8.5 (Ø6.5 to 7.3) HR08D-12WPK-2S(31) 108-0281-0 31 Ø9.5 (Ø8.0 to 9.0) Contact solder cup inner diameter Ø1 Ø1.8 ◆Crimp termination version Part No. HRS No. A Applicable cable diameter range (Reference) HR08D-12WPA-10SC(31) 108-0220-6 31 Ø7.4 (Ø5.7 to 6.5) HR08D-12WPB-10SC(31) 108-0232-5 31 Ø8.5 (Ø6.5 to 7.3) HR08D-12WPK-10SC(31) 108-0263-9 31 Ø9.5 (Ø8.0 to 9.0) 3 HR08D Series●Small, Waterproof, Push-On Bayonet Lock Connectors ■Right angle plug ●Regular version ( Cord tube material : Plastic) 3 7 10 8 Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 33.5 φ20 1 4 B A (example) ◆Solder termination version HRS No. A HR08D-12WLPM-10S(31) 108-0276-0 31 Ø7.4 Applicable cable diameter range (Reference) (Ø5.7 to 6.5) HR08D-12WLPN-10S(31) 108-0277-3 31 Ø8.5 (Ø6.5 to 7.3) HR08D-12WLPM-2S(31) 108-0273-2 31 Ø7.4 HR08D-12WLPN-2S(31) 108-0267-0 31 Ø8.5 Part No. B 30.85 (Ø5.7 to 6.5) (Ø6.5 to 7.3) Contact solder cup inner diameter Ø1 Ø1.8 ◆Crimp termination version Part No. HRS No. A HR08D-12WLPM-10SC(31) 108-0270-4 31 Ø7.4 HR08D-12WLPN-10SC(31) 108-0271-7 31 Ø8.5 B 30.85 Applicable cable diameter range (Reference) (Ø5.7 to 6.5) (Ø6.5 to 7.3) ●Robust version (Cord tube material: Metal) ◆Solder termination version Part No. HRS No. A HR08D-12WLPA-10S(31) 108-0221-9 31 Ø7.4 HR08D-12WLPB-10S(31) 108-0233-8 31 Ø8.5 B 30.5 HR08D-12WLPK-10S(31) 108-0264-1 31 Ø9.5 HR08D-12WLPA-2S(31) 108-0282-3 31 Ø7.4 31.5 HR08D-12WLPB-2S(31) 108-0283-6 31 Ø8.5 HR08D-12WLPK-2S(31) 108-0284-9 31 Ø9.5 31.5 HRS No. A B HR08D-12WLPA-10SC(31) 108-0222-1 31 Ø7.4 HR08D-12WLPB-10SC(31) 108-0234-0 31 Ø8.5 HR08D-12WLPK-10SC(31) 108-0265-4 31 Ø9.5 30.5 Applicable cable diameter range (Reference) Contact solder cup inner diameter (Ø5.7 to 6.5) (Ø6.5 to 7.3) Ø1 (Ø8.0 to 9.0) (Ø5.7 to 6.5) (Ø6.5 to 7.3) Ø1.8 (Ø8.0 to 9.0) ◆Crimp termination version Part No. 30.5 31.5 Applicable cable diameter range (Reference) (Ø5.7 to 6.5) (Ø6.5 to 7.3) (Ø8.0 to 9.0) 4 HR08D Series●Small, Waterproof, Push-On Bayonet Lock Connectors ■Receptacle ◆Solder termination version 4× (R 2 3. φ 4× 8) A B 2. B Part No. HRS No. A B HR08D-12WR-10P(31) 108-0218-4 31 17.26 23.4 Contact solder cup inner diameter Ø1.1 Note : The number 10 contact is connected to the outer shell, which provides the ground connection. BPanel Mount Hole Dimensions Dimension HR08D-12WR-10P(31) A 17.26±0.05 B M3×0.5 A B 4− C 1 0/ ー 0.1 D 12.2 +0.1/0 E 16.2 +0.1/0 C A φD φE ■Crimp contact ●Female contact 15 1.2 Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. A Type Part No. HRS No. Loose piece contact HR34B-SC1-111 134-0051-7 Reel contact HR34B-SC1-211 134-0050-4 Applicable electric wires 20 to 25 AWG Note : The loose piece contacts are sold in packs of 100. Reel contacts are sold in full reel quantities of 10,000 pieces per reel. 5 HR08D Series●Small, Waterproof, Push-On Bayonet Lock Connectors BPlug Contact Diagram 2 position version 10 position version 1 3 2 1 7 6 5 4 10 9 8 2 Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Note : The numbering of the contact is from the plug termination side. Powered by TCPDF (www.tcpdf.org) BApplicable Tools Tools Manual Crimping Tool Automatic Crimping Press Automatic Crimping Applicator Part No. HT304/HR34B-1 CM-105C HRS No. 150-0107-9 901-0001-0 AP105-HR34B-1 901-2051-2 RP6-SC-TP 150-0039-0 Contact Extraction Tool BManual Crimping Tool Applicable contacts Applicable wire size HR34B-SC1-111 20 AWG、23 AWG、25 AWG HR34B-SC1-211 20 to 25 AWG HR34B-SC1-111 HR34B-SC1-211 ---------------------- BAutomatic Crimping Press CM-105C Model (applicator sold separately) BContact Extraction Tool BOperating Precautions 1.Prior to inserting or extracting this connector, make sure that the connector is not energized and the power is in the OFF position. 2.There may be some resistance when inserting the cables into this connector, even if the cables are within the applicable cable range. This is to be expected due to the connector’s waterproof ability. The waterproof performance and clamp force is dependant on the cable specification. Please check the cable specifications before using as they can cause a difference in performance in the waterproof protection and cable clamp force. 3.Please contact your local Hirose Sales Representative for any inquiries regarding the assembly procedures of this connector. ® 6 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 07/2018. Contents are subject to change without notice for the purpose of improvements.
HR08D-12WPK-10S(31) 价格&库存
很抱歉,暂时无法提供与“HR08D-12WPK-10S(31)”相匹配的价格&库存,您可以联系我们找货
