0.5mm Pitch, 2.8mm high, Single Action Lock at bottom contact point, FPC/FFC/Shield FFC connector
FH63 Series
Single action lock (Dimension diagram : 30pos.)
Mar.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
2.8mm
21.9
4mm
Insert FPC/FFC without opening
the lock lever before insertion!
5.15mm
Fig.1
Two-point contact design for dust prevention
■Features
1. Automatic single action locking design
· Single action locking by simply inserting FPC after mounting
contributes to enhanced workability. (Fig.1)
(Lock release by operating the lock lever when removing.)
· Operation of the lock lever is not required at the time of
mating FPC. Can be inserted with one hand.
Contributes to reduced assembly time.
The lock lever will not be damaged by operation.
Mating failure is reduced by eliminating the need to operate
a lever while mating.
2. Two-points of contact prevents contact failure by dust
Fig.2
Supports FPC/FFC/Shield FFC
· High contact reliability by independent spring two-point
contact design, preventing contact failure by dust. (Fig.2)
3. Supports FPC/FFC/Shield FFC
· FH63 allows you to choose from FPC/FFC/Shield FFC.
· Shielded FFC is acceptable for EMI prevention. (Fig.3)
4. High FPC retention force
· The circuit is automatically locked after FPC/FFC is inserted
by a single action. The notches on both sides of FPC are
held by the lock lever, generating a high FPC retention
force in spite of the small contact. (Fig.4)
FPC
FFC
Shield FFC
5. Visual inspection on the mated status of FPC/FFC is possible.
GND contact
· As the notches on both sides of FPC can be checked from
the top surface after inserting FPC/FFC, insufficient
insertion during assembly is prevented. (Fig.5)
6. Environmental
· Halogen free
*AS defined by IEC 61249-2-21.
Br : 900ppm max, Cl : 900ppm max, Br+Cl : 1,500ppm
max
FPC/FFC can be checked from the top surface after mating.
OK
Mated condition
(correct position)
Shield FFC
GND contact and FFC GND plate
contact at multiple points.
Fig.3
NG
Insufficient insertion condition
(incorrect position)
Fig.5
Robust lock firmly retains FPC/FFC.
2017.8②
Fig.4
1
FH63 Series●0.5mm Pitch, 2.8mm high, Single Action Lock at bottom contact point, FPC/FFC/Shield FFC connector
■Product Specifications
Rated current 0.5A
Rated voltage 50V AC/DC rms
Rating
Adaptive FPC
contact specifications
Storage temperature range : -10ç to +60°C (Note 2)
Storage humidity range : Relative humidity 90% max.
(No condensation)
Thickness : = 0.33 ± 0.03mm Signal layout : Gold plated, GND plate : Tin plated
Item
Operating temperature range : -55ç to +105°C (Note 1)
Operating humidity range : Relative humidity 90% max.
(No condensation)
Specification
Conditions
1. Insulation resistance
500Mø min.
100V DC
2. Withstanding voltage
No flashover or insulation breakdown
150V AC rms / 1 minute
3. Contact
resistance
100mø max.
* Including FPC/FFC conductor resistance
1mA AC
4. Durability
(insertion / withdrawal)
Contact resistance : 100mø max.
No damage, cracks, or parts dislocation
10 cycles
5. Vibration
No electrical discontinuity of 1µs or more
Frequency : 10 to 55Hz, single amplitude of 0.75mm,
10 cycles in each of the 3 directions
6. Shock
Acceleration of 981m/s2, duration of 6 ms, sine half-wave
waveform, 3 cycles in each of the 3 axes
7. Damp heat
(Steady state)
Insulation resistance : 50Mø min.
96 hours at temperature of 60ç and humidity of 90% to
95%
8. Temperature
cycle
Temperature : -55°C / +15ç to +35ç / +105ç / +15ç to +35ç
Time :
30 /
2 to 3
/ 30 / 2 to 3 (Minutes)
5 cycles
9. Resistance to
soldering heat
No deformation of components affecting
performance
Reflow : Recommended Temperature Profile
Manual soldering: 350 ± 10°C for 5 seconds
Note 1 : Includes temperature rise caused by current flow.
Note 2 : The term “storage” refers to products stored for long period of time prior to mounting and use. Operating Temperature Range
and Humidity Range covers non-conducting condition of installed connectors in storage, shipment or during transportation.
■Materials / Finish
Part
Materials
LCP
LCP
Copper alloy
Copper alloy
SUS
Insulator
Signal contact
Grounding contact
Reinforcing metal tabs
Finish
Grey
Black
Nickel barrier gold plated
Pure tin reflow plated
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
FH 63 − 30S − 0.5 SH (99)
❹
Series name : FH
Series No. : 63
No. of contacts : 30
Contact pitch : 0.5mm
2
❺
❻
Terminal type
SH … SMT horizontal mounting type
Specification
Blank : Standard 3,500pcs/reel
(99) : 500pcs/reel
UL standard
UL94V-0
UL94V-0
■Connector Dimensions
A±0.15
3
B±0.15
(C)
(0.1)
Signal contact No.1
Cavity No.
2
4.5±0.1
4.9±0.1
(3.3)
(Pickup area)
1
Polarity mark
Grounding contact No.1
2±0.1
E±0.1
Grounding contact No.2
E±0.1
(0.1)
5
D±0.15
4
a
2.8±0.2
0.5±0.1
(0.25)
(F)
(0.65)
(5.15)
(4)
(2.85)
(2.4)
(2.2)
0.25±0.2
(0.87)
(0.89)
(0.42)
(5.3)
Ground
contact point
FPC/FFC/Shield FFC t=0.33
G±0.15
(45
HRS mark
0.25±0.2
Reinforcing
metal tabs
Grounding
contact
0.75±0.1
(Grounding contact lead)
4.25±0.2
0.55±0.1
Signal
Signal
(Lead of reinforcing metal tabs)
contact point contact
3.9±0.2
0.35±0.1
(Signal contact lead)
Note
1 : The dimension in parentheses are for reference.
2 : Lead co-planarity including reinforced chucking metals shall be 0.1 max.
3 : To be delivered with tape and reel packages.
See the packaging specifications for details.
4 : Note that preventive hole for sink mark or slit could be added for improvement.
5 : The quality remains good, even with the dark spots, which could occasionally occur on molded plastic.
6 : This product satisfies halogen free requirements defined as 900ppm maximum chlorine,
900ppm maximum bromine, and 1500ppm maximum total of chlorine and bromine.
Unit : mm
Part No.
HRS No.
No. of
Contacts
FH63-10S-0.5SH
Under planning (Note 1)
10
12.7
FH63-20S-0.5SH
9.5
6.55
9
1.5
12.15
14.9
FH63-30S-0.5SH
580-4400-0 **
30
22.7
14.5
5.55
14
2
17.15
19.9
A
B
C
D
E
F
G
4.5
5.55
4
2
7.15
9.9
FH63-40S-0.5SH
580-4403-0 **
40
27.7
19.5
10.55
19
1.5
22.15
24.9
FH63-50S-0.5SH
50
32.7
24.5
15.55
24
2
27.15
29.9
FH63-60S-0.5SH
60
37.7
29.5
20.55
29
1.5
32.15
34.9
Note 1 : Contact positions without HRS No. are currently under planning.
Please contact hirose for detailed information about product variation.
3
BRecommended PCB Mounting Pattern
HX
0.02 Z
0.95±0.02
E
3.95±0.03
3.6±0.03
0.7±0.02
0.9±0.02
(0.25)
2X
0.02 Z
Z
nX
0.02 Z
0.3±0.02
1.1±0.02
(0.15)
B±0.02
0.5
0.3±0.02
E
2
D (±0.02)
G (±0.02)
BRecommended Stencil Pattern
2X
0.02 Y
HX
0.02 Y
0.8±0.01
E
4.1±0.01
0.9±0.01
0.95±0.01
(0.25)
0.65±0.01
Y
nX
0.02 Y
0.28±0.01
0.5
3.8±0.01
(0.05)
B±0.02
0.28±0.01
E
2
D (±0.02)
G(±0.02)
Note 7 : 'n' shows the number of contacts.
BRecommended Dimensions of PCB Mounting Pattern and Stencil Pattern
Part No.
HRS No.
FH63-10S-0.5SH
10
4.5
4
FH63-20S-0.5SH
9
FH63-30S-0.5SH
580-4400-0 **
30
14.5
14
2
19.9
8
FH63-40S-0.5SH
580-4403-0 **
40
19.5
19
1.5
24.9
11
FH63-50S-0.5SH
50
24.5
24
2
29.9
13
FH63-60S-0.5SH
60
29.5
29
1.5
34.9
16
4
Units:mm
No. of
Contacts
B
D
E
G
H
2
9.9
3
1.5
14.9
6
BRecommended FPC/FFC Dimensions
0.4±0.03
nX
0.02 X
2.9±0.1
R0.2
R0.2
R0.1±0.1
R0.2
R0.2
1.3±0.07
1.3±0.07
J±0.05
L±0.1
BRecommended Shield FFC Dimensions
0.8±0.05
1.3±0.08
0.32±0.03
0.5
0.33±0.03
W
nX
0.05 W
R0.1±0.1
R0.1±0.1
R0.2
R0.2
1.3±0.08
1.3±0.08
(M)
1.1±0.3
1.1±0.3
0.5±0.3
R0.2
R0.2
R0.2
1.3±0.08
J±0.05
(K)
B±0.05
6 MIN (Reinforcing film)
0.8±0.05
1.25±0.1
2.9±0.1
4.15±0.1
4.75±0.1
1 MIN (overlapping amount)
R0.1±0.1
1.3±0.07
1.3±0.07
0.5
4.15±0.1
X
1.25±0.1
R0.2
0.33±0.03
0.8±0.05
4.75±0.3
J±0.05
(K)
B±0.02
0.8±0.05
Grounding plate
Shield
J±0.05
L±0.1
Note 7 : The value 'n' indicates the number of pos.
8 Overlap the shield on the grounding plate.
BRecommended Dimensions of FPC/FFC/Shield FFC
Part No.
HRS No.
No. of
Contacts
FH63-10S-0.5SH
10
4.5
7.1
FH63-20S-0.5SH
12.1
FH63-30S-0.5SH
580-4400-0 **
30
14.5
17.1
FH63-40S-0.5SH
580-4403-0 **
40
19.5
22.1
FH63-50S-0.5SH
50
24.5
FH63-60S-0.5SH
60
29.5
B
J
Units:mm
K
L
M
5.5
9.1
4.9
10.5
14.1
9.9
15.5
19.1
14.9
20.5
24.1
19.9
27.1
25.5
29.1
24.9
32.1
30.5
34.1
29.9
5
BMaterial composition of FPC/FFC/Shield FFC (Recommended specifications)
② Cover lay film
① Shield
④ Surface treatment
③ Cover lay adhesive
⑥ Base adhesive
⑤ Pattern copper foil
⑦ Base material
⑧ Reinforcing film adhesive
⑨ Reinforcing film
⑩ Grounding plate adhesive
⑬ Shield
⑪ Grounding plate
⑫ Surface treatment
FPC
Material name
FFC
Shield FFC
FFC
Thickness (μm)
Materials
Thickness
(μm)
Materials
Polyimide 1mil
Thermosetting adhesive
25
28
Polyester
Adhesive
25
25
25
25
Nickel foundation 1 to 6μm
+Gold plated 0.2μm
(3.7)
Nickel foundation 0.5 to 5μm
+Gold plated 0.05 to 1μm
(3.275)
(3.275)
Rolled copper 1oz
⑤
Pattern copper foil
⑥
Base adhesive
⑦
Polyimide 1mil
Base material
⑧ Reinforcing film adhesive Thermosetting adhesive
⑨
Polyimide 8mil
Reinforcing film
⑪
Grounding plate
⑫
Surface treatment
⑬
Shield tape
35
8
25
55
200
Annealed copper foil
Adhesive
Polyester
Adhesive
Polyester
Adhesive
35
25
25
30
150
30
35
25
50
30
188
Conductive tape
Tin plated 1 to 5μm
37
①
②
③
Shield tape
Cover lay film
Cover lay adhesive
④
Surface treatment
3. Caution
1. This specification is recommendation for the construction of the FH63 series FPC/FFC/Shield FFC
(t=0.33±0.03mm)
2. For details about the construction, please contact FPC/FFC/Shield FFC manufactures.
6
BPackaging Specifications
●Embossed Carrier Tape Dimensions
R±0.1
1.75±0.1
R±0.1
7
P±0.3
9
6
9
Unreeling
direction
Unreeling
direction
●Reel Dimensions
●Leader, Trailer Dimensions
S±1 (Reel outer width)
Unreeling direction
Unreeling
direction
400mm MIN(Leader)
Ø380±2
Ø80±1
8
(Ø
13
6
4±0.1
(2)
1
0.
+ 0
7
8±0.1
(3)
(0.3)
.5
Ø1
1
0.
+ 0
4±0.1
(2)
Q±0.1
P±0.3
8±0.1
.5
Ø1
(3)
(0.3)
tape width 32mm or less
1.75±0.1
tape width 24mm or less
160mm MIN
(Trailer, empty components)
Embossed carrier tape
Top cover tape
100mm MIN
(empty components)
U±1 (Reel inner width)
Note 9 : 3500 pieces shall be packaged in one reel. (For standard products)
Note 10 : The package complies with JIS C 0806 and IEC 60286-3 (Packaging of automotive mounting parts).
Unit : mm
Part No.
HRS No.
No. of
Contacts
P
Q
R
S
U
FH63-10S-0.5SH
10
24
11.5
29.4
25.4
FH63-20S-0.5SH
28.4
14.2
37.4
33.4
FH63-30S-0.5SH
580-4400-0 **
30
44
40.4
20.2
49.4
45.4
FH63-40S-0.5SH
580-4403-0 **
40
44
40.4
20.2
49.4
45.4
FH63-50S-0.5SH
50
56
52.4
26.2
61.4
57.4
FH63-60S-0.5SH
60
56
52.4
26.2
61.4
57.4
7
BTemperature Profile
Applicable Conditions
Temperature(℃)
MAX 250℃
245
Reflow method
220℃
Solder
200
: IR/Hot air
Reflow environment : Room air
: Paste type Sn/3.0Ag/0.5Cu
(M705-GRN360-K2-V made by Senju
180℃
Metal Industry Co.)
150
Test PCB
150℃
: PCB material and size
Glass epoxy 45×25×1mm
Land size, per recommended on page 4.
100
Metal mask
: Thickness and opening size
Per recommended on page 4.
50
25℃
120±5 sec.
Preheating time
20 to 40 sec.
Peak temperature
60 to 90 sec.
Soldering time
start
It may vastly depending on solder paste type, manufacturer,
PCB size and mounting materials. Please use only after
checking the mounting conditions.
Time(sec.)
8
This temperature profile is based on the above conditions.
BConnector operation and points to note
[Operation method]
Care needs to be taken when handling this connector. In order to prevent the damage and
contact failure etc. (incorrect mating, disconnection of FPC pattern) of connectors and FPC,
please use after confirming the following contents.
This connector supports FPC/FFC/Shield FFC, however, for convenience, the description is
made only for FPC.
Signal contact
Grounding
contact
Lock lever
Insulation case
Connector's top surface
(absorbing surface)
Connector's bottom surface
(mounting surface)
(FPC insertion port)
Reinforcing
metal tabs
(Diagram of the connector's top surface)
(Diagram of the connector's front surface)
1. Delivered state
This product is delivered with the lock lever closed. The lock lever does not need to be operated before
inserting FPC.
[Caution]
· Do not open the lock lever when FPC is not inserted.
Additionally, the lock lever does not need to be opened except to remove the FPC. (Example 1)
· Do not operate the connector until it is mounted on the board. (Example 1)
(Example 1)
NG
– Delivered state –
Lock lever (open)
Lock lever (closed)
FPC not inserted
Unmounted
9
[Operation method]
2. How to insert FPC
Insert FPC to the end correctly (Ex.2) horizontal to the board surface.
[Caution]
· Please confirm that the lock lever is closed when you insert FPC.
Do not insert FPC while the lock lever is open. (Example 3)
· Do not FPC while at the same time pressing the lock lever. (Example 4)
· Insert FPC straight after positioning its tip end in a horizontal plane in reference to the guides on both ends
of the connector mating port.
· Insert in a manner that it won't be diagonal to the insertion direction. (Example 5)
· When inserting, do not move the FPC in a vertical, lateral or diagonal direction. (Example 6)
(Example 2)
(Example 3)
OK
OK
NG
Lock lever (closed)
Lock lever (open)
Lock lever (closed)
FPC (horizontal)
FPC (horizontal)
Insert FPC straight after positioning both its ends in a horizontal plane
in reference to the guides on both ends of the connector mating port.
(Example 4)
(Example 5)
NG
Lock lever (closed)
(Example 6)
NG
Lock lever (closed)
FPC (horizontal)
FPC (diagonal)
FPC (diagonal)
10
[Operation method]
3. Confirming the mated state of FPC
When FPC is completely inserted, visually inspect the inserted status of FPC. (Example 7)
(This connector uses the lock protrusion of the lock lever for positioning FPC.)
[Caution]
· FPC is not inserted deep enough or in a diagonal direction. (Example 8)(Example 9)
· Because of the single action lock, The lever does not need to be operated after inserting FPC.
(Example 7)
OK
The FPC tab inserted to
the back of the mating port
can be visually confirmed.
Case butting position
(Example 8)
NG
enough down to the back
of the mating port.
(Example 9)
NG
FPC is inserted diagonally,
and is not inserted to the
back of the mating port.
FPC
Outer shape of FPC is
parallel to the outer
shape of the housing.
– Cross section of the lock section –
FPC (shallow)
FPC is not inserted deep enough,
leaving a large gap between FPC
and the housing.
The protrusion of the lock lever
runs over the FPC tab.
FPC (diagonal)
FPC is inserted diagonally, and
leaves a large gap between FPC
and the housing.
11
[Operation method]
4. How to unlock the lock lever
Push up the lock lever slowly, and release the lock. (Example 10)
[Caution]
· When releasing the lock, operate the lock lever around the center. (Example 11)
· When releasing the lock, do not operate only one side of the lock lever. (Example 12)
· As the lock lever cannot be opened to over 45°, do not open it over this angle. (Example 13)
· Do not pick and raise the lock lever off, or pull it. (Example 14)
· Be sure to operate the lock lever by hand, and do not operate it with sharp-edged tools such as tweezers
etc. (Example 15)
· Don't apply an excessive force to the housing during operation. (Example 16)
· The FPC insertion direction for this connector is different from the direction of the lock lever operation
section. Do not try to open FPC from its insertion side. (Example 17)
(Example 10)
OK
Lock lever
Lock lever
(Example 11)
(Example 12)
OK
Operate the lock lever around the center.
12
NG
Lock lever
Operate the lock lever on one side.
[Operation method]
(Example 13)
NG
45°
Lock lever
A load is applied to the lock lever
in the opposite direction.
(Example 14)
(Example 15)
NG
NG
Sharp-edged tools
Lock lever
Lock lever
Rotation axis
Load is concentrated on the rotation axis,
and leads to breakage.
(Example 16)
(Example 17)
NG
Apply an excessive force to
the lock lever.
NG
Lock lever
Lock lever
13
[Operation method]
5. How to remove FPC
After releasing the lock lever, remove the FPC in the horizontal direction. (Example 18)
When removing the FPC, do not press the lock lever. (Example 19)
As the released lock lever automatically closes when removing the FPC, the lever does not need to be
operated after removal. (Example 20)
[Caution]
· Do not pull out FPC while the lever is locked. (Example 21)
· This connector is equipped with the FPC retention mechanism by means of the lock lever. When pulling
out FPC, do not apply load in the upward or lateral direction. (Example 22)
(Example 18)
OK
(Example 19)
OK
NG
Lock lever (open)
Lock lever (open)
(Example 20)
(Example 21)
– Condition after FPC is pulled out –
Lock lever (closed)
NG
Lock lever (closed)
(Example 22)
(Example 23)
NG
NG
Lock lever (closed)
FPC (diagonal)
FPC (diagonal)
14
[Operation method]
[Cautions for PCB layout]
Depending on the routing of FPC to mate, a load may be applied to the connector, which could lead to failure.
In order to prevent failure, please consider the following concerning the mechanism design.
[Caution]
· When routing the FPC, please be careful that FPC is not pulled and routing is carried out with a margin.
· Please check that the reinforcing film is placed horizontal to the board surface. (Example 23)
· Please insure there is no load applied to the connector in the pulling, inserting or lateral direction.
A bent FPC, it could cause contact failure or damage/disconnection of FPC. Therefore, please take some
measure to fix FPC etc. (Example 24)(Example 25)
· Don't place any parts under the FPC that will interfere with FPC. (Example 26)
· As for the flexibility of FPC, please make adjustments with the FPC manufacturer.
· Please ensure the FPC has adequate insertion space when designing the layout so that it is not inserted
diagonally.
Additionally, ensure the insertion space is not too short for FPC. Please adopt adequate parts layout and
length for FPC.
· When you design the board/layout, please secure a space required for operations.
(Example 23)
(Example 24)
OK
Reinforcing film
NG
Lock lever
Reinforcing film
Lock lever
The state where a load
is applied to FPC
(Example 25)
(Example 26)
NG
NG
Lock lever
Lock lever
Reinforcing film
is applied to FPC
Mounting parts
interfering with FPC
15
[Notes for mounting on the board/after mounting on the board]
[Notes for mounting on the board]
Please be careful of the following at the time of board mounting.
[Caution]
· Please confirm recommendations for mount board land shape, metal mask opening shape, and FPC
shape.
· If the land is narrower than recommend, or if the metal mask opening is wider than recommend, solder
(flux) wicking is more likely to occur.
If there is difference from the recommendation, please use check the mounted state.
· The level difference between the bottom surfaces of contact lead and the mold is designed to be small.
When there is silk print etc. on the bottom surface of the connector, it could push up the connector bottom
surface, and cause non-sticking solder or defective fillet formation.
When there is silk print etc. on the bottom surface of the connector, please use it after checking the
mounted state.
· Use the reflow conditions within the specifications of our company.
The mounted status may vary due to external conditions such as the type of cream solder, manufacturer,
and board size. Please use it after checking the mounted state.
· Please control the board warpage as much as possible. While the coplanarity of this connector is 0.1mm or
less, defective soldering could occur if the board warpage is considerable.
· When mounted on FPC, be sure to provide a reinforcing plate to ease handling. We recommend a
reinforcing plate of 0.3mm or thicker made of glass epoxy material.
· When pulling out the emboss from the reel, or when the connector is absorbed from the emboss and so on,
do not apply any excessive external force (of 1N or more) to the connector before mounting.
Powered by TCPDF (www.tcpdf.org)
[Cautions when handling the board after mounting]
Please be careful of the following when handling the board after mounting operation.
[Caution]
· Do not apply any load to the board in the assembly process, such as "dividing a multi-piece board" or
"securing the board to the frame".
Such action could apply a load to the connector and damage it.
· Use the board with the deflection being 1mm or less when the board width is 100mm. (Example 27)
If the board has some deflection, it could apply a load to the connector and damage it.
(Example 27)
1 MAX
100
Connector
Connector
PCB
1 MAX
100
[Cautions for hand-soldering]
Please be careful of the following when hand-soldering for repair work etc.
[Caution]
· Do not hand-solder while FPC is inserted.
· Please be careful not to apply excessive heat, or allow the solder iron to touch any place other than the
connector contact lead.
Such action could cause the connector to be deformed or melted.
· Do not supply an excessive amount of solder (flux).
If too much solder (flux) is supplied to the contact, the solder or flux could adhere on the contact point and
cause contact failure.
Additionally, if you supply too much solder to the reinforcing metal tabs the rotational action of the lock
lever could be defective and the connector could be damaged.
16
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 08/2017. Contents are subject to change without notice for the purpose of improvements.
