IP5-06-01-S-S-RA1-L-TR 数据手册
RF-18
IP5–04–01–L–S–RA1–TR
IP5–08–05.0–L–S–1–TR
IP5–04–05.0–L–S–1–TR
(4.00 mm) .1575"
IP5, IP5-RA SERIES
50 W HIGH ISOLATION RF PLUGS
SPECIFICATIONS
IP5
For complete specifications and
recommended PCB layouts see
www.samtec.com?IP5
Shell Material:
Copper Alloy
Insulator Material:
Black LCP
Contact Material:
Copper Alloy
Dielectric Material:
Black LCP
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating (Vertical):
Signals: 2.36 A per pin
(2 adjacent pins powered)
Grounds: 4.4 A per pin
Operating Temp Range:
-55 °C to +125 °C
Dielectric Withstanding
Voltage:
IP5 = 600 VAC
IP5-RA = 190 VAC
Working Voltage:
IP5 = 200 VAC
IP5-RA = 190 VAC
RoHS Compliant:
Yes
Mates with:
IJ5, IJ5C
IP5/IJ5
10 mm Stack Height
PLUGS
PER ROW
05.0
–01,
–02, –04,
–06, –08
PLATING
ROW
OPTION
–L
= Single Row
TAIL
–1
–S
= 10 µ" (0.25 µm)
Gold on contact area,
Matte Tin on tail
= (1.60 mm)
.062"
board
thickness
–D
= Double Row
(Not available
with –01)
OPTION
TR
–L
–TR
A
Frequency
Insertion Loss = 3 dB 10.5 GHz / 21.0 Gbps
Return Loss = 15 dB 5.5 GHz / 11.0 Gbps
Isolation = 60 dB
8.8 GHz / 17.6 Gbps
Isolation = 70 dB
7.6 GHz / 15.2 Gbps
Isolation = 80 dB
1.3 GHz / 2.6 Gbps
Complete test data available
at www.samtec.com?IP5
or contact sig@samtec.com
NO. OF
PLUGS
A
–01
(8.33)
.328
(12.32)
.485
(20.32)
.800
(28.32)
1.115
(36.32)
1.430
–02
(8.53)
.336
= Tape
& Reel
= Cable
Latch
(Single
Row only)
(12.52)
.493
–04
–06
(4.00) .1575
–08
(1.52) .060
(9.09)
.358
(1.52) .060
PROCESSING
–S
(4.00).1575
–D
Lead–Free Solderable:
Yes
RECOGNITIONS
IP5
For complete scope
of recognitions see
www.samtec.com/quality
Mates with:
IJ5, IJ5C
FILE NO. E111594
ALSO AVAILABLE
(MOQ Required)
PLUGS
PER ROW
01
–02, –04,
–06, –08
• Other PCB thicknesses
= (1.60 mm)
.062"
board
thickness
= 10 µ" (0.25 µm)
Matte Tin on grounds,
tails & weld tabs
NO. OF PLUGS
–02
–04
–06
–08
Contact Samtec.
–RA1
–L
A
• Other stack heights
TAIL
OPTION
S
PLATING
A
B
C
(15.64) .616 (13.27) .523 (12.32) .485
OPTION
(Leave blank
for no Cable
Latch)
–L
B
–RA1 SHOWN
= Tape
& Reel
APPLICATION
(23.64) .931 (21.27) .838 (20.32) .800
(31.64) 1.246 (29.27) 1.153 (28.32) 1.115
(39.64) 1.561 (37.27) 1.468 (36.32) 1.430
IJ5
10 mm
(8.92)
.351
(1.52)
.060
–TR
= Cable Latch
(14.72) .580
(12.52) .493
C
(4.00) .1575
TR
(8.34)
.328
(9.72) .383
(0.64) .025
(4.76) .188
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
IP5
IP5-06-01-S-S-RA1-L-TR 价格&库存
很抱歉,暂时无法提供与“IP5-06-01-S-S-RA1-L-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+330.95520
- 200+132.05160
- 500+127.64520
- 1000+125.46360
