IPL1-105-01-S-S-RA-K
    SAMTEC(申泰)
    .100 TERMINAL ASSEMBLY
IPL1-105-01-S-S-RA-K 数据手册
REVISION L EXISTING CUSTOMERS ONLY AS OF 5/1/2012, SAMTEC WILL ONLY SUPPORT EXISTING BUSINESS OF THIS PRODUCT DO NOT SCALE FROM THIS PRINT IPL1-1XX-02-XXX-DH-K-XX (No. OF POS. x .100[2.54]) + .075[1.91] LEAD STYLE -02: DOUBLE HORIZONTAL (USE T-1S64-XX-XXX) C C (No. OF POS. - 1) x .100[2.54] .130 3.30 POLARIZATION -K: KEYED POLARIZATION PLATING SPECIFICATION -F: FLASH SELECTIVE (USE T-1S64-XX-F) -L: LIGHT SELECTIVE (USE T-1S64-XX-L) -S: SELECTIVE (USE T-1S64-XX-S) -STL: SELECTIVE TIN/LEAD(USE T-1S64-XX-STL) ROW SPECIFICATION -DH: DOUBLE HORIZONTAL 02 .100 2.54 .250 6.35 REF .040 1.02 REF 2 MAX SWAY (TYP) .025 0.64 SQ. REF 01 PACKAGING BLANK: TUBES (SEE NOTE 13) -TR: TAPE & REEL (SEE NOTES 14 & 15) -FR: FULL REEL QTY TAPE & REEL (SEE NOTES 14 & 15) No OF POSITIONS -02 THRU -25 (PER ROW) .100 2.54 (TYP) .100 2.54 REF .270 6.86 REF C C 2 MAX TOE (TYP) SEE NOTE 4 (No. OF POS. x .100[2.54]) + .160[4.06] REF "A" SEE NOTE 7 SEE NOTE 8 IPL1-XX-DH-X .300 7.62 REF .095 2.41 REF .220 5.59 WT-28-01-T T-1S64-09-XXX C .210±.008 SEE NOTE 10 C .442±.008 "A" C .100 2.54 (TYP) 11.22±0.203 5.34±0.203 .076 1.93 REF (TYP) 2 MAX SWAY (TYP) C C 1. C REPRESENTS A CRITICAL DIMENSION. 2. MINIMUM TERMINAL /WELD TAB RETENTION: 1.0LB.[4.4N} 3. PARTS TO BE MOLDED TO POSITION. 4. POST MUST BE WITHIN .005[0.13] OF EACH OTHER. 5. ALL PIN TO PIN DIMENSIONS TO BE MEASURED FROM TIP TO TIP. 6. DIMENSION TO BE MEASURED AT BEND. 7. TIP TO BE FLUSH TO .010[0.254] BELOW TOP OF SHROUD. 8. THIS NUMBER REPRESENTS THE NUMBER OF POSITIONS PER ROW ONLY AND IS NOT INTENDED TO BE USED IN POSITION NUMBERING. 9. NOTE DELETED. 10. INDENTION FROM WELD TAB CARRIER IS ALLOWABLE. 11. WELD TABS TO BE INSERTED WHILE ON CARRIER. 12. NOTE DELETED. 13. POSITIONS 4-25 TO BE PACKAGED IN TUBES; POSITIONS 1-3 TO BE LAYER PACKAGED. 14. ORDERS WILL BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM. 15. ATTACH LABEL TO EACH REEL. .010[0.25] C .025 0.64 SQ. REF (TYP) SECTION "A"-"A" (No. OF POS. - 1) x .100[2.54] NOTES: .023 0.57 REF (TYP) T-1S64-16-XXX FIG 1 (IPL1-110-02-XXX-DH-K SHOWN) UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [0.3] 2 .XXX: .005 [0.13] .XXXX: .0020 [0.051] MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: LCP UL94-V0, COLOR: BLACK TERMINAL: PHOS BRONZE F:\DWG\MISC\MKTG\IPL1-1XX-02-XXX-DH-K-XX-MKT.SLDDRW SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .100[2.54] DOUBLE ROW TERMINAL ASSEMBLY DWG. NO. IPL1-1XX-02-XXX-DH-K-XX BY: T NEWTON 02/29/2008 SHEET 1 OF 2 REVISION L EXISTING CUSTOMERS ONLY AS OF 5/1/2012, SAMTEC WILL ONLY SUPPORT EXISTING BUSINESS OF THIS PRODUCT PT-1-24-01-44 USE TP-26 PLUGS PACKAGING VIEW (SEE NOTE 13) C C .003 0.08 MAX .001 0.03 MAX .096 2.44 .108 2.73 C C C .025 0.64 REF WT-28-01-T .003 0.08 MAX .006 [.15] MAX COPLANARITY VIEWS IN-PROCESS 1 (SEE NOTE 11) T-1S64-09-XXX .226 5.74 REF .220 5.59 REF C .530 13.46 REF C .235±.005 5.97±0.13 C C .210±.008 5.34±0.203 .806 20.47 REF C C .511±.005 12.98±0.127 45° (TYP) IN-PROCESS 2 T-1S64-16-XXX IN-PROCESS 3 IN-PROCESS 4 * PROPRIETARY NOTE IN-PROCESS 5 DO NOT SCALE DRAWING SHEET SCALE: 2:1 52° (TYP) * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. F:\DWG\MISC\MKTG\IPL1-1XX-02-XXX-DH-K-XX-MKT.SLDDRW .442 11.22 ±.008 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .100[2.54] DOUBLE ROW TERMINAL ASSEMBLY DWG. NO. IPL1-1XX-02-XXX-DH-K-XX BY: T NEWTON 02/29/2008 SHEET 2 OF 2
IPL1-105-01-S-S-RA-K 价格&库存
很抱歉,暂时无法提供与“IPL1-105-01-S-S-RA-K”相匹配的价格&库存,您可以联系我们找货
  • 40+31.1309340+4.01875
