LTMM-113-02-S-D-SM-P
    SAMTEC(申泰)
    CONN HEADER SMD 26POS 2MM
LTMM-113-02-S-D-SM-P 数据手册
SHROUDED HEADER & STACKER (2.00 mm) .0787" PITCH • LTMM/ZLTMM SERIES LTMM/ZLTMM Mates: SQT, SQW, ESQT, SMM -1 LTMM 04, 05, 06, 07, 08, 10, 12, 13, 15, 17, 20, 22, 25 SPECIFICATIONS Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +105 °C with Tin; -55 °C to +125 °C with Gold PROCESSING - 02 - NO. PINS PER ROW D - –F TAIL OPTION - –“XX” = Polarized Position –RA = Right-angle –L –SM = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail = Surface Mount –T –LC = Locking Clip (-SM only) (Manual placement required) –K = Matte Tin  [ 1RRISRVLWLRQV   OTHER OPTION Leave blank for Through-hole = Gold flash on post, Matte Tin on tail (Standard sizes) Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max - PLATING OPTION = (7.50 mm) .295" DIA Film Pick & Place Pad (-SM only)   –TR = Tape & Reel (–SM only) –FR —TH ALSO AVAILABLE MOQ Required Other sizes Other plating ZLTMM -1 NO. PINS PER ROW   —TH —RA —SM - 04, 05, 06, 07, 08, 10, 12, 13, 15, 17, 20, 22, 25 LEAD STYLE Specify LEAD STYLE from chart (Standard sizes) - PLATING OPTION –L –T (4.80) .190 BODY HEIGHT (6.35) B (OAL) .250 MIN (2.29) .090 MIN Note: This Series is non-standard, non-returnable. F-224 - D - –F = Gold flash on post, Matte Tin on tail = Matte Tin (6.00) .237 —RA —SM = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail (2.00) .0787 x No. of positions + (2.39) .094 = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (–SM only)     BODY HEIGHT –“XXX” = Body Height LEAD STYLE B (OAL) - OTHER OPTION –“XX” = Polarized Position MAX BODY HEIGHT –75 (9.58) 0.377 (7.42) 0.292 –62 (10.08) 0.397 (7.92) 0.312 –65 (10.49) 0.413 (8.33) 0.328 –73 (12.09) 0.476 (9.93) 0.391 –63 (14.10) 0.555 (11.94) 0.470 –66 (15.09) 0.594 (12.93) 0.509 –69 (15.60) 0.614 (13.44) 0.529 –74 (17.09) 0.673 (14.94) 0.588 –70 (17.60) 0.693 (15.44) 0.608 –71 (21.08) 0.830 (18.92) 0.745 –72 (21.62) 0.851 (19.46) 0.766 Note: For added mechanical stability, Samtec recommends mechanical board spacers be used in applications with gold or selective gold plated connectors. Contact ipg@samtec.com for more information. samtec.com?LTMM or samtec.com?ZLTMM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
LTMM-113-02-S-D-SM-P 价格&库存
很抱歉,暂时无法提供与“LTMM-113-02-S-D-SM-P”相匹配的价格&库存,您可以联系我们找货
