PMSD-10-24C-K-12.00-D-LUS 数据手册
(4.19 mm) .165" PITCH • DISCRETE WIRE CABLE & COMPONENTS
SERIES
PMSD
= Double Row PVC Cable
PMSDT
= Double Row Blue *Teflon™
Fluoropolymer Cable
(24 AWG only)
PMSS
= Single Row PVC Cable
PINS PER
ROW
—02,
—03, —04,
—05, —08,
—10, —15*
(Standard sizes)
*Only available
for double row
WIRE
GAUGE
–16
K
–K
= Keyed
Polarization
–18
–206
ASSEMBLED
LENGTH
END
OPTION
–"XX.XX"
–S
= Wire length in
inches (88.90 mm)
03.50" min.
–LUS
= Single
Ended
= Plastic Latch up, straight
–D
= Plastic Latch down, straight
–LDS
= Double
Ended
(Latch
Required)
(20 AWG/
600 volts)
–22
–LUX*
= Plastic Latch up, crossed
–LDX*
–24
PMSST
= Single Row Blue *Teflon™
Fluoropolymer Cable
(24 AWG)
PMSD, PMSDT,
PMSS, PMSST
= Plastic Latch down, crossed
*(PMSD/PMSDT only)
PMSD/IPBT
CURRENT
RATING
(PER PIN)
WIRE
GAUGE
No. of Positions
x (4.19) .165
+ (1.02) .040
Board Mates:
IPBT
(7.95)
.313
Assembled
Length
± (3.18) .125
PMSS/PMSST
SPECIFICATIONS
Insulator Material:
Valox 457
Contact Material:
Phosphor Bronze
Plating:
Sn over 50 µ" (1.27 µm) Ni
Operating Temp Range:
-10 °C to +105 °C (PVC)
-40 °C to +105 °C
(Teflon™ Fluoropolymer)
LATCH OPTION
No. of Positions
x (4.19) .165
+ (1.02) .040
16 AWG
*10.3 A
18 AWG
*8.8 A
22 AWG
*5.7 A
24 AWG
*5.2 A
VOLTAGE
RATING
424 VAC/600 VDC (PVC)
300 VAC/424 VDC (PVC)
300 VAC/424 VDC (PMSXT)
*2 PINS POWERED
*Teflon™ is a trademark of The Chemours Company FC,
LLC used under license by Samtec.
Notes:
Teflon™ Fluoropolymer cable is intended for crimp only.
Contact Samtec for solderable cable applications.
(12.14)
.478
PMSD/PMSDT
For wiring option information refer to drawing on web.
View complete specifications at: samtec.com?PMSD, samtec.com?PMSDT, samtec.com?PMSS & samtec.com?PMSST
IPBD
POSITIONS PER ROW
—02, —03, —04, —05,
—08, —10, —15
(Standard sizes)
ROW
OPTION
–S
= Single Row
–D
K
–K
= Keyed
Polarization
= Double Row
SERIES
CC69L
= Contact, Loose
CC69R
= Contact, Full Reel
(4,000 Parts per
Reel)
(19.56)
.770
(12.14)
.478
–D
WIRE
GAUGE
–2024
= 20 to 24 AWG
- 01
T
SP
–T
= Tin
–1620
= 16 to 20 AWG
(19.23)
.757
(7.95)
.313
(7.95)
.313
–S
TOOLING
Hand Tool: CAT-HT-169-1620-13 (16-20 AWG)
Hand Tool: CAT-HT-169-2024-13 (20-24 AWG)
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
Mini Applicator: CAT-MC-169-1620-XX-02 (16-20 AWG)
Mini Applicator: CAT-MC-169-2024 XX-01 (20-24 AWG)
Extraction Tool: CAT-EX-169-01
View complete specifications at: samtec.com?IPBD, samtec.com?CC69L & samtec.com?CC69R
samtec.com/PowerMate
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-224
PMSD-10-24C-K-12.00-D-LUS 价格&库存
很抱歉,暂时无法提供与“PMSD-10-24C-K-12.00-D-LUS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+213.098861+27.50928
