PRECISION BOARD
STACKING STANDOFF
SO SERIES
SO
Use With:
QXH, QXE, QXS,
QXSS, QRX8, ERX5,
ERX6, ERX8, LSHM,
LSS, LSEM, SX4, SX5, XLH
SO
BOARD
STACKER
Specify
BOARD STACKER
from chart
SPECIFICATIONS
–01
THREAD
STYLE
–01
= Female Thread/Press-In
(–0515 thru –0865 only)
–02
01
L
–L
= #4-40
Thread
= –02 & –03
Lead Style
thread locking
compound
(Leave blank for
–01 Lead Style)
–02
= Male/Male Thread
(–0515 and
–1115 thru –2515 only)
Material:
Aluminum
Locking Compound:
Nylon
= M3 x 0.5
Thread
–03
= Male/Female Thread
(-0815 thru –2515 only)
INDUSTRY STANDARD SOLUTIONS
STACK
HEIGHT
LEAD
STYLE
(0.44)
.017
–05
Requires Standoff
SO-1524-03-01-01-L or
JSOM-1524-02 for 15.24 mm
or SO-2200-03-01-01-L
for 22 mm board spacing.
Connectors designed to not
fully seat when mated.
For more information on the JSOM,
visit samtec.com?JSOM
INTERCONNECTS
INDUSTRY
STANDARD
TERMINAL
SOCKET
BANKS
STACK
HEIGHT
SUMIT™
PCI/104-Express™
PCI/104-Express™
PCI/104-Express™
PCI/104-Express™
PCI/104-Express™
ASP-129637-01
ASP-129637-03
ASP-129637-13
ASP-142781-01
ASP-142781-02
ASP-142781-03
ASP-129646-01
ASP-129646-03
ASP-129646-22
ASP-129646-01
ASP-129646-02
ASP-129646-03
1
3
1
1
2
3
15.24 mm
15.24 mm
15.24 mm
22 mm
22 mm
22 mm
= Female/Female Thread
(–1524 thru –2515 only)
BOARD
STACKER
A
BOARD STACK
HEIGHT
–0515
(5.15) .203
5 mm
–0715
(7.15) .282
7 mm
–0815
(8.15) .321
8 mm
–0865
(8.65) .341
8.5 mm
–1115
(11.15) .439
11 mm
–1215
(12.15) .478
12 mm
15.09 mm
–1524
(15.24) .600
–1615
(16.15) .636
16 mm
–1890
(18.90) .744
18.75 mm
–1915
(19.15) .754
19 mm
–2515
(25.15) .990
25 mm
(4.76)
.188
HEX
(4.76)
.188
HEX
ALSO AVAILABLE
MOQ Required
Other heights
Stainless Steel
Locking compound removed
Other materials and threading
No Hardware
(6.35)
.250
DIA
A
A
A
A
Note:
Some sizes, styles and
options are non-standard,
non-returnable.
F-224
–01 LEAD STYLE
–02 LEAD STYLE
–03 LEAD STYLE
–05 LEAD STYLE
Components are to be packaged in separate bags unassembled.
samtec.com?SO
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
QTS-016-01-L-D-DP-A 价格&库存
很抱歉,暂时无法提供与“QTS-016-01-L-D-DP-A”相匹配的价格&库存,您可以联系我们找货
