RUGGED TIGER EYE™ SYSTEMS
(2.00 mm) .0787" PITCH
MAX
3.8
A
m
p
s
8
G b p s
FEATURES & BENEFITS
• Rugged Tiger Eye™ contact system for high reliability
• Wide range of stack heights (SMM/TMM Series)
• Right-angle mating headers available
• Optional metal latching, screw downs, weld tabs and locking clips
• Surface mount or through-hole
• Discrete wire assemblies available in 24-30 AWG
PVC or *Teflon™ Fluoropolymer (See page 240).
Contact asp@samtec.com for custom solutions
• Severe Environment Testing qualified (S2M/T2M); aligns with
MIL-DTL-55302. Visit samtec.com/set
Optional strain relief
and variety of
wiring options
*Teflon™ is a trademark of The Chemours Company FC, LLC
used under license by Samtec.
Components
(ISD2/CC81) &
tooling available:
samtec.com/tooling
KEY SPECIFICATIONS (S2M/T2M)
STACK
INSULATOR
HEIGHTS MATERIAL
6 & 7 mm
F-224
Black LCP
CONTACT
MATERIAL
PLATING
OPERATING
TEMP RANGE
BeCu (S2M)
Au or Sn over
-55 °C to +125 °C
Phosphor Bronze (T2M) 50 µ" (1.27 µm) Ni
CURRENT
RATING
MAX.
CYCLES
3.8 A (T2M)
100 with 10 µ"
2.6 A (S2M)
(0.25 µm) Au
(2 pins powered)
VOLTAGE LEAD-FREE
RATING SOLDERABLE
350 VAC
Yes
samtec.com/2mm-TigerEye
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
(2.00 mm) .0787" PITCH • HIGH-RELIABILITY CABLE INTERCONNECTS
SERIES
NO. OF
POSITIONS
1
S2M
05, 07, 10,
15, 20, 25, 30
Socket
(Per Row)
LEAD
STYLE
PLATING
OPTION
–01
D
–F
= Through-hole
–02
Leave blank for
tube packaging
= (5.50 mm)
.217" DIA Polyimide film
Pick & Place Pad
(–02 only)
–L
–TR
= Tape & Reel
(–02 only)
–LC
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
–FR
= Locking Clip
(Manual placement required)
(–02 only)
= Full Reel Tape & Reel
(must order max. quantity
per reel; contact Samtec
for quantity breaks)
(–02 only)
–DS
= Screw Down
(N/A with –LC)
(mates with –T2M–DS)
S2M
Board Mates:
T2M
Cable Mates:
T2SD
PACKAGING
–K
= Gold flash on
contact, Matte
Tin on tail
= Surface Mount
OPTIONS
No. of positions x (2.00) .0787 + (0.35) .014
(4.25)
.167
(4.52)
.178
(4.65)
.183
(6.30)
.248
–TH
–LC
–SM
View complete specifications at: samtec.com?S2M
SERIES
T2M
Header
NO. OF
POSITIONS
1
05, 07, 10,
15, 20, 25, 30
(Per Row)
- 01 -
PLATING
OPTION
-D-
No. of positions x (2.00) .0787 + (14.38) .566
(6.00)
.236
TAIL
OPTION
–L
–TH
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
= Surface
Mount
MATED HEIGHT
–TR
= Tape & Reel
(–SM only)
–DS
= Screw Down
(N/A with –RA)
(mates with –S2M–DS,
S2SD/S2SDT –SS/–DS option)
–K
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
(–SM only)
(3.98)
.157
(7.44)
.293
60
70
Leave blank for
tube packaging
.335
= (7.50 mm) .295" DIA
Polyimide film Pick
& Place Pad
(–SM only)
No. of positions x (2.00) .0787 + (5.67) .223
PACKAGING
= Weld Tab
(S2SD & S2SDT,
–SR/–DR required
mate)
(8.50)
–RA
–SM
Board Mates:
S2M
Cable Mates:
S2SD, S2SDT
–WT
= Throughhole
= Right-angle
T2M
OTHER
OPTIONS
–DS
60 PP
7+ PP
(8.76)
.345
Notes:
Severe Environment Testing qualified;
aligns with MIL-DTL-55302.
Some lengths, styles and options are
non-standard, non-returnable.
(8.63) .340
–TH–WT
–SM–WT
–RA–WT
View complete specifications at: samtec.com?T2M
F-224
S2M-115-02-L-D-K-TR 价格&库存
很抱歉,暂时无法提供与“S2M-115-02-L-D-K-TR”相匹配的价格&库存,您可以联系我们找货
