02P-MWPV-SSR
02P-MWPV-SSR
    JST
    P=7mm
    线对板针座
02P-MWPV-SSR 数据手册
MWP CONNECTOR 7.0mm pitch/Disconnectable Crimp style Wire-to-wire connectors Specifications ––––––––––––––––––– • Current rating: 7A AC, DC max. • Voltage rating: 300V AC, DC max. • Temperature range: -40˚C to +105˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/7m Ω max. After environmental testing/10m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 1,500V AC/minute • Applicable wire: AWG #26 to #18 0.13 to 0.75mm2 Insulation O.D./2.1 to 2.5mm • Waterproof grade: Grade 4 ingress protection of JIS C 0920(IEC 60529 IPX4) * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Note: The current rating varies depending on the number of circuits and the wire size used in each connector. The table below lists the current rating as a function of the number of circuits and wire size. Current unit: A Waterproof wire-to-wire connector for electric power supply. • Low insertion force contact • Housing lance • Inner-housing lock • Slider locking mechanism • Interchangeability Wire size (AWG) Circuits #18 #20 #22 #24 #26 1 7 5 4 3 2 2 7 5 4 3 2 Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 Assembly layout 14.2 43.9 1 MWP CONNECTOR Contact Applicable wire Model No. 1.4 Pin contact mm2 AWG # Pin contact Socket contact SSM-01T-P1.4 SSF-01T-P1.4 0.13∼0.5 26∼20 SSM-21T-P1.4 SSF-21T-P1.4 0.3 ∼0.75 22∼18 Insulation O.D. Q'ty / reel (mm) 2.1∼2.5 6,000 Material and Finish 17.6 Phosphor bronze, tin-plated (reflow treatment) 4.3 0.5 RoHS compliance Note: Contact JST for special products. Crimping machine Crimp applicator Contact MKS-L SSM-01T-P1.4 Socket contact SSF-01T-P1.4 SSM-21T-P1.4 − AP-K2N MKS-L SSF-21T-P1.4 − Applicator Dies Crimp applicator with dies MK/SSF/M-01-14 APLMK SSF/M01-14 − − MK/SSF/M-21-14 APLMK SSF/M21-14 − − 12.6 4.3 Housing Material: PBT, UL94V-0, white Receptacle housing(for socket contact) 02R-MWPV-SSRR 7A 6.0 7.7 300V 11.9 12.85 2 7.0 Q'ty / box 13.9 252 Q'ty / box 17.9 01P-MWPV-SSR 11.7 7A 6.0 7.7 300V 11.9 12.85 1 Q'ty / box 02P-MWPV-SSR 144 228 Q'ty / box 18.7 11.7 13.9 01R-MWPV-SSRR Plug housing(for pin contact) 6.0 7.7 Current rating 6.0 7.7 Circuits Voltage rating 144 7.0 RoHS compliance Note: 1. Model ( )P-MWPV-SSR comes with the wire end seal and slider. 2. Model ( )R-MWPV-SSRR comes with the rubber ring, wire end seal and slider. 2
02P-MWPV-SSR 价格&库存
很抱歉,暂时无法提供与“02P-MWPV-SSR”相匹配的价格&库存,您可以联系我们找货
02P-MWPV-SSR
    • 144+2.53000
    库存:13536
    02P-MWPV-SSR
      库存:320
      02P-MWPV-SSR
        • 144+2.68460
        库存:18144
        02P-MWPV-SSR
          库存:432
          02P-MWPV-SSR
            • 1+6.601591+0.85451
            • 50+5.0755950+0.65699
            • 100+4.56140100+0.59043
            • 300+4.22137300+0.54642
            • 500+4.14673500+0.53675
            • 1000+4.096971000+0.53031
            • 4000+4.063794000+0.52602
            库存:24
            02P-MWPV-SSR
              • 1+6.949041+0.89948
              • 50+5.3427350+0.69156
              • 100+4.80147100+0.62150
              • 300+4.44354300+0.57517
              • 500+4.36497500+0.56500
              • 1000+4.312601000+0.55822
              库存:168
              02P-MWPV-SSR
                库存:144
                02P-MWPV-SSR
                  • 144+3.74000
                  库存:9504
