D-Sub – H
Directory chapter 07
D-Sub – Housing range for subminiature D connectors
Page
07.02
Thermoplastic top and side entry hoods
with knurled screws . . . . . . . . . . . . . . . . . . . . . . . . . .
07.04
Thermoplastic side entry hoods
07.05
Thermoplastic top entry hoods
with knurled or locking screws . . . . . . . . . . . . . . . . . . . . . .
07.06
Full metal top and side entry hoods
07.07
Full metal top and side entry hoods with short screws . .
07.08
with different screw options . . . . . . . . . . . . . . . . . .
07.09
General information – hoods for spring or slide locking . . . . . . . . . . . . . . . . . . .
07.10
for spring or slide locking . . . . . . . . . . . . . . . . . . . .
07.11
07.12
D-Sub - H
General information – hoods for screw locking . . . . . . . . . . . . . . . . . . . . . . . . .
07
01
Housings for D-Sub waterproof (IP 67) see chapter 06
D-Sub
DIN 41 652 · CECC 75 301-802 · IEC 60 807
HARTING – Guarantee a secure connection
Modern electronic applications demand a
high degree of mechanical and electrical
security.
To meet these requirements, continuous
screening from the cable to the PCB via
the connector is achieved by using state of
the art components to DIN 41 652.
HARTING offer many solutions. These
utilise various combinations of male and
female connectors with hoods, featuring
either screw locking or latching facilities.
Only 2 examples are shown:
• Continuous security screening and
grounding with screw locking and
metallized hood.
• Continuous grounding and vibration
proof latching system with metallized
hood.
Female connector with
protective metal shell
D-Sub - H
Male connector with dimples
Screw lock
Cable with protective
screen
Strain relief
Grounding contact between protective
metal shell and PCB
Metallized hood
Spring latch
Strain relief
Cable with
protective
screen
Metallized hood
07
02
D-Sub
Connector hoods for screw locking
d
oo
h
try
n
c
e e lastic lasti
d
i
s
p op
o
m
d
n
rm er
p a ck theed th
o
T la alliz
B et
M
ed
url
kn
s
rew
c
s
th
wi
d
o
ic tic
ho ast las
pl op
y
ntr ermotherm
e
th d
p
To lack lize
ed
url
Kn
rew
sc
g
r
ho
s
ith
in
ck
t lo
s
rew
c
s
D-Sub - H
B etal
M
w
od stic astic
o
l
a
h l
ry op op
nt rm erm
p e ck theed th
o
T la alliz
B t
Me
alternative
k
loc hood
w
t
cre hou
s
it
le se w
a
u
M r
fo
w
cre
k
loc
th
wi
t
nu
s
ale
m
Fe
07
03
D-Sub
Top and side entry hoods with knurled screws
Identification
No. of
contacts
Part No.
Top entry hood
Drawing
Dimensions in mm
max. Ø 1
Black thermoplastic
9
15
25
37
50
09 67 009 0424
09 67 015 0424
09 67 025 0424
09 67 037 0424
09 67 050 0424
9
15
25
37
50
B
15
15
15
15
19
C1
34
34
40
40
40
C2 max. Ø 1 max. Ø 2
38
8.0
11.5
38
11.5
11.5
40
11.5
11.5
40
11.5
11.5
14.0
C2: metallized
max. Ø
49
D-Sub - H
max. Ø 2
A2
32.5
41.0
54.5
71.0
C1: non-metallized
UNC 4-40
A1
Top entry hood
A1
31.5
40.0
53.5
71.0
67.5
Metallized
thermoplastic
9
15
25
37
09 67 009 0425
09 67 015 0425
09 67 025 0425
09 67 037 0425
max. Ø
Thread UNC 4-40
A2
Cut appropriate cable entry
to fit actual cable diameter
Top and side
entry hood
Black thermoplastic
9
15
25
37
09 67 009 04341)
09 67 015 04341)
09 67 025 04341)
09 67 037 04341)
9
15
25
37
Top and side
entry hood
Metallized
thermoplastic
9
15
25
37
09 67 009 04351)
09 67 015 04352)
09 67 025 04352)
09 67 037 04351)
Grommet
for top and side entry
black thermoplastic
hood
07
04
1)
2)
A
31.5
40.0
53.5
71.3
max. Ø
max. Ø
09 67 001 9968
37 ways is only side entry
Cable clamp kit for two outputs is available with Part No. 09 67 001 9988 (it includes: screw, metal clamp, plastic insert and grommet)
B
15
15
15
15
C
40.0
40.0
43.0
42.5
D-Sub
Side entry hoods with knurled screws
Hood1)
grey thermoplastic
RAL 7032
grey thermoplastic
with internal
tin-plate screening
No. of
contacts
Part No.
9
15
25
37
50
09 67 009 0571
09 67 015 0571
09 67 025 0571
09 67 037 0571
09 67 050 0571
9
15
25
37
50
09 67 009 0573
09 67 015 0573
09 67 025 0573
09 67 037 0573
09 67 050 0573
9-37 way
for packaging density
of 3 TE (15.24 mm)
Drawing
Dimensions in mm
D-Sub - H
Identification
15
25
37
50
a
max.
39.62
53.52
69.80
67.41
b
c
33.3
47.0
63.5
61.1
15
15
15
19
d
max.
Ø 9.1
Ø 11.5
Ø 12.8
Ø 14.5
Knurled screw
Thread UNC
Thread M3
9-50
4)09 67 000 99714)
*09 67 001 9965*
Grey head / Nickel plated steel
Thread UNC
Thread M3
9-50
4)09 67 001
9978
*09 67 001 9977
Full metal part
Tooling6)
for assembly
of hoods
Top part
Bottom part
*09 99 000 0215*
*09 99 000 0216*
07
05
* Not normally kept in stock
1) Order knurled screw separately
2) Before assembling the hood, the knurled screws
must be inserted into the lower hood part.
For retained nut when using slide lock or female screw lock
9 way 1 per hood – 15-50 way 2 per hood
5) Screw driver type ISO PH 1 for philips screw No 1 ISO norm 4757
6) Additional tooling (bench press) see chapter 32
3)
4)
D-Sub
Top entry hoods with knurled or locking screws
Identification
No. of
contacts
Part No.
9
15
25
37
50
09 67 009 0442
09 67 015 0442
09 67 025 0442
09 67 037 0442
09 67 050 0442
9
15
25
37
50
09 67 009 0443
09 67 015 0443
09 67 025 0443
09 67 037 0443
09 67 050 0443
9-50
9-50
09 67 000 99252)
09 67 000 99302)
Drawing
Dimensions in mm
Hood
Black thermoplastic
with short locking
screws
D-Sub - H
Hood
Metallized thermoplastic with short
locking screws
Knurled screw
for metallized hood
Thread UNC
Thread M3
07
06
1)
2)
Use of knurled screws is possible. Please order separately
Order 2 for each hood
15
25
37
50
a
b
c
d
40.0
53.2
70.0
67.5
34.7
39.7
39.7
39.7
15.2
15.2
15.2
18.2
33.3
47.0
63.5
61.1
min.
3.3
3.5
3.5
9.3
e
max.
8.5
11.0
11.0
12.0
D-Sub
Full metal top and side entry hoods with knurled screws
No. of
contacts
Identification
Part No.
Drawing
Dimensions in mm
Top entry hood
09 67 009 034
09 67 015 034
09 67 025 034
09 67 037 034
4-40 UNC or M3
A
31.2
39.5
53.4
69.7
B
39.9
41.5
48.6
53.6
D-Sub - H
9
15
25
37
Poles
9
15
25
37
Grommet set halves
Please insert digit for
screw option
Knurled screw,
thread
4-40 UNC
Knurled screw,
thread M3
þ
3
þ
8
Grommet dimensions
Number Diameter
1
4.0
2
5.0
3
7.0
4
10.0
5
10.2
Side entry hood
4-40 UNC or M3
1)
91)
15
25
37
09 67 009 033
09 67 015 033
09 67 025 033
09 67 037 033
Poles
9
15
25
37
A
31.0
40.5
53.7
69.8
B
38.0
41.1
41.8
41.8
Grommet set halves
screw option
Knurled screw,
thread
4-40 UNC
Knurled screw,
thread M3
1)
þ
3
þ
6
9 pole hood provided with only one screw on the opposite side of the cable entry.
Grommet dimensions
Number Diameter
1
4.0
2
5.0
3
7.0
4
10.0
5
10.2
07
07
D-Sub
with short screws
No. of
contacts
Identification
Part No.
Drawing
Dimensions in mm
Top entry hood
9
15
25
37
50
09 67 009 034
09 67 015 034
09 67 025 034
09 67 037 034
09 67 050 034
D-Sub - H
Please insert digit for screw option
Locking screw,
thread 4-40 UNC
Locking screw, thread M3
þ
þ
4-40 UNC
or M3
4
9
Side entry hood
9
15
25
37
50
09 67 009 033
09 67 015 033
09 67 025 033
09 67 037 033
09 67 050 033
Poles
A
B
C
D
9
15
25
37
50
31.8
40.3
54.0
70.2
67.8
42.4
43.5
47.7
50.4
50.5
20.8
23.3
31.7
48.2
45.8
15.4
15.4
15.4
15.4
18.2
Ø F1
Min. Max.
3.0
9.5
3.0
8.5
3.0
8.5
3.0 12.0
3.0 12.0
Ø F2 Ø F3
6.5
6.5
8.0
9.0
9.7
12.5
12.5
15.0
15.0
* Cable diameter without rubber bushing = Ø F1
Cable diameter with rubber bushing
= Ø F2
and without cable reduction plate
= Ø F3
Locking screw,
thread 4-40 UNC
þ
þ
4
5
4-40 UNC
or M3
Locking hook
Front mount
09 67 002 9031
Locking
hook
Latch lock bolt
Front mount
thread 4-40 UNC
thread M3
09 67 002 9041
09 67 002 9042
thread 4-40 UNC
thread M3
09 67 002 9032
09 67 002 9040
thread 4-40 UNC
thread M3
09 67 002 9044
09 67 002 9045
Rear mount
Cable to cable
07
08
Latch lock
bolt
Rear mount
Cable to cable
D-Sub InduCom
Identification
No. of
contacts
Part No.
9
15
25
61 03 001 . 013
61 03 001 . 014
61 03 001 . 015
Drawing
Dimensions in mm
D-Sub - H
40° side entry hood
No. of
contacts
9
15
25
A
B
C
D
31.0
39.3
53.0
25.0
33.3
47.0
35.0
35.0
35.0
15.0
15.0
15.0
No. of
contacts
9
15
25
37
50
No. of
cable entries
1 (top)
1 (top)
3
3
3
A
B
C
D
31.0
39.5
53.0
69.5
67.2
25.0
33.3
47.0
63.5
61.6
38.0
35.0
43.0
43.0
43.0
15.0
15.0
15.0
15.0
17.8
Top/side entry hood
9
15
25
37
50
61 03 001
61 03 001
61 03 001
61 03 001
61 03 001
010
016
017 1)
018 1)
019 1)
Knurled screw,
thread 4-40 UNC
Hexagonal screw, thread M3
with captive washer
Hexagonal screw, thread 4-40 UNC
with captive washer
Knurled screw, thread M3
1)
þ
þ
þ
2
þ
3
Part No. contains two blanking pieces
Accessories see page 07.14
07
09
D-Sub
Connector hoods for spring or slide locking
tic
c
sti plas
a
l
op mo
d thermd ther
o
Ho rey allize
G et
M
tic
c
sti plas
a
l
op mo
d thermd ther
o
Ho rey allize
G et
M
g
e
lid
s
or
D-Sub - H
ng ic tic
pri plast oplas
s
o m
or
d f erm her
o
th d t
Ho lackallize
B et
M
h
atc
r
Sp
l
ing
e
ic
ev
gd
kin
oc
l
e
d
Sli
alternative
h
atc
l
ed
x
i
F
olt
b
ing
ck
Lo
07
10
kin
loc
D-Sub
Thermoplastic top
Identification
No. of
contacts
Part No.
Drawing
Dimensions in mm
9
15
25
37
50
Thermoplastic
grey
Thermoplastic
metallized
09 67 009 0411
09 67 015 0411
09 67 025 0411
09 67 037 0411
09 67 050 0411
09 67 009 0413
09 67 015 0413
09 67 025 0413
09 67 037 0413
09 67 050 0413
9-37 way
of 3 TE (15.24 mm)
9
15
25
37
50
Side entry hood
9
15
25
37
50
Thermoplastic
grey
Thermoplastic
metallized
09 67 009 0511
09 67 015 0511
09 67 025 0511
09 67 037 0511
09 67 050 0511
09 67 009 0513
09 67 015 0513
09 67 025 0513
09 67 037 0513
09 67 050 0513
Thermoplastic
black
Thermoplastic
metallized
09 67 009 0452
09 67 015 0452
09 67 025 0452
09 67 037 0452
09 67 050 0452
09 67 009 0453
09 67 015 0453
09 67 025 0453
09 67 037 0453
09 67 050 0453
a
b1
b2
c
d
31.0
39.4
53.3
69.7
67.1
23
28
34
43
41
28
28
34
43
41
12.8
12.8
12.8
12.8
15.8
10
10
14
a
c
d
31.0
39.4
53.2
69.5
67.0
15.4
15.4
15.4
15.4
17.9
7
7
9
9
9
e
min. max.
5.75
9.0
5.75
9.0
5.75
9.0
5.75
9.0
5.75 11.6
D-Sub - H
Top entry hood
9-37 way
of 3 TE (15.24 mm)
Top and side entry
hood 1)
9
15
25
37
50
9
15
25
37
50
1) 9 poles is only side entry
Accessories see page 07.13
e
min. max.
1.7
7.5
1.7
8.0
1.5
8.0
1.5
8.0
1.5
8.0
07
11
D-Sub InduCom
Identification
No. of
contacts
Part No.
9
15
25
37
50
61 03 001 00221)
61 03 001 00112)
61 03 001 00122)
61 03 001 00212)
61 03 001 00202)
Drawing
Dimensions in mm
D-Sub - H
Top/side entry hood with
spring/slide locking
No. of
contacts
9
15
25
37
50
No. of
cable entries
2
3
3
3
3
A
B
C
D
31.0
39.0
53.0
69.5
67.0
22.6
30.6
42.6
59.2
55.0
40.0
40.0
40.0
40.0
40.0
14.8
14.8
14.8
14.8
17.6
07
12
1)
2)
Part No. contains one blanking piece
D-Sub
Accessories for spring or slide locking hoods
Identification
No. of
contacts
Part No.
Drawing
Dimensions in mm
Spring latch
corrosion resistant steel
9-50
09 67 000 99071)
Fixed latch
09 67 001 99711)
09 67 001 99721)
D-Sub - H
9-37
50
Slide locking device
9
15
25
37
50
09 67 000 9914
09 67 000 9915
09 67 000 9916
09 67 000 9917
09 67 000 9918
9
15
25
37
50
a
35.6
44.0
57.8
74.3
72.0
b
25.0
33.3
47.0
63.5
61.1
c
12.0
12.0
12.0
12.0
14.8
d
10.0
10.0
10.0
10.0
13.5
Locking bolt
tinned
9-50
09 67 001 99731)
07
13
1)
Order 2 for each connector
D-Sub InduCom
Accessories for full metal hoods
Drawing
Hoods for
9-37 pole
D-Sub
Hoods for
50 pole
D-Sub
61 03 000 0062
61 03 000 0063
61 03 000 0064
61 03 000 0065
61 03 000 0066
61 03 000 0166
61 03 000 0067
61 03 000 0068
61 03 000 0069
61 03 000 0070
61 03 000 0071
61 03 000 0165
61 03 000 0072
61 03 000 5062
61 03 000 5063
61 03 000 5064
61 03 000 5065
61 03 000 5066
61 03 000 5166
61 03 000 5067
61 03 000 5068
61 03 000 5069
61 03 000 5070
61 03 000 5071
61 03 000 5165
61 03 000 5072
Crimp ferrule
D-Sub - H
61 03 000 0045
61 03 000 0046
61 03 000 0047
61 03 000 0048
61 03 000 0049
61 03 000 0050
61 03 000 0051
61 03 000 0052
61 03 000 0053
61 03 000 0054
61 03 000 0055
61 03 000 0056
61 03 000 0057
61 03 000 0058
61 03 000 0142
61 03 000 0059
61 03 000 0127
61 03 000 0060
61 03 000 0061
Cable clamp
cable-Ø appr. 5- 7 mm
61 03 000 0141
cable-Ø appr. 7-10 mm
61 03 000 0044
cable-Ø appr. 10-12 mm
61 03 000 0143
61 03 000 0145
cable-Ø appr. 11-14 mm
Blanking piece
for hoods
61 03 000 0042
61 03 000 0041
Hexagonal screw
07
14
thread 4-40 UNC x 17.58.8 with captive washer
09 67 002 9020
thread M3 x 17.5-8.8
with captive washer
09 67 002 9019
Knurled screw
thread 4-40 UNC
09 67 002 9018
thread M3
09 67 002 9017
Tooling see chapter 31
Dimensions in mm
D1
3.0
3.5
4.0
4.5
5.0
5.5
6.0
6.5
7.0
7.5
8.0
8.5
9.0
D2
4.0
4.5
5.0
5.5
6.0
6.5
7.0
7.5
8.0
8.5
9.0
9.5
10.0
D3
5.0
5.5
6.0
6.5
7.0
7.5
8.0
8.5
9.0
9.5
10.0
10.5
11.0
11.5
12.0
12.5
13.0
13.7
14.0
D4
6.0
6.5
7.0
7.5
8.0
8.5
9.0
9.5
10.0
10.5
11.0
11.5
12.0
12.5
13.0
13.5
14.0
15.0
15.0
D3
Crimp flange
Part No.
D1
D2
Identification
D4
D-Sub InduCom
Mounting details
Crimp flange termination instruction
1. Strip the cable sheath to the correct length
(approx. 35 to 40 mm, depending on interface
type).
3. Place the crimp flange over the wires covered
by the remaining foil shield. Push and twist
the crimp flange under the outer screen and
cable sheath until the end of the cable sheath touches the crimp flange. HARTING has
developed a special tool for optimised installation
of the shielding over the crimp flange, part number 61 03 600 0017.
D-Sub - H
2. Place the crimp ferrule over the cable sheath.
Bend the outer screen backwards over the cable
sheath. Cut screen approx. 2 mm from the end
of the cable sheath.
4. Move the crimp ferrule back onto the crimp
flange and crimp the two parts together with
the special service crimp tool part number
61 03 600 0020. For an optimised crimp process the tool should to be positioned as close
as possible to the crimp flange sholder.
5. Cut off the internal screen foil and push the
crimp flange inside the metal hood.
HARTING offers to test and define the best
crimp flange and ferrule combination for
customer specific cables.
07
15
很抱歉,暂时无法提供与“09 67 015 0442”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+28.25280
- 10+27.62640
- 30+27.21600
- 国内价格 香港价格
- 1+57.304751+7.44789
- 10+48.6920510+6.32850
- 25+45.6365025+5.93137
- 50+43.4556150+5.64792
- 100+41.38102100+5.37829
- 250+38.79031250+5.04157
- 500+36.93997500+4.80109
- 1000+35.178021000+4.57209
- 2500+32.978392500+4.28620
- 国内价格 香港价格
- 1+46.262071+6.01268
- 5+38.646715+5.02291
- 10+33.5009710+4.35412
- 30+30.0649830+3.90754
- 50+29.3794350+3.81844
- 60+29.2059860+3.79590
- 100+28.86733100+3.75189
