THE NEW AND EXCITING
Han® “LITE” SAMPLE CASE!!
1
73550000046
Updated 9/2003
Featuring Many New HARTING
Products Including:
• Han® Port – An interface that
provides a convenient and
environmentally protected method
of accessing enclosures
• Identification Module – An
“intelligent” connector that offers
non-volatile decentralized storage
of operating data for machine
components
• Han-Quintax® 3A – Provides a
space-saving, industrially-protected
connector solution for sensitive
signaling and Ethernet
communication
Case Characteristics:
• Constructed with durable black vinyl material, making the case
water and stain resistant
Compact size allows for easy handling (Dimensions: 18” x 12”)
Lightweight (Only 10lbs. Fully assembled!)
Shoulder strap included
Red vinyl table top protector included
PLUS MUCH MORE!!!!!!!!!!!!!!!
Use This Part Number To Order Your Own
Fully-Assembled Han “Lite” Sample Case:
73 55 040 0101
*Distributor Net Price: $330
2
73550000046
Updated 9/2003
SAMPLE CASE CONTENTS
Location
1
1
1
1
1
1
1
Part Number Qty
Description
09 00 000 5017 1 Cable Sealing Metal (IP 65) with Multiple Seal
09 30 024 0301 1 24 B Housing Bulkhead Mounting
09 30 024 0421 1 24 B Top Entry Hood
09 32 046 3001 1 46 EE Male Crimp Insert
09 32 046 3101 1 46 EE Female Crimp Insert
09 33 000 6102 46 2.5mm^2 Male E Pins
09 33 000 6202 46 2.5mm^2 Female E Pins
Catalog Page
40.08
30.19
30.18
03.27
03.27
01.15
01.15
2
2
09 16 042 3001
09 15 000 6106
1 42 DD Male Crimp Insert
42 2.5mm^2 Male D Pins
02.25
02.12
3
09 11 001 2652
1
350 Amp HC Module Male
14.15
4
09 11 001 2752
1
350 Amp HC Module Female
14.15
5
5
5
5
5
5
5
09 00 000 5059
09 12 008 0327
09 12 008 0527
09 12 008 3001
09 12 008 3101
09 33 000 6102
09 33 000 6202
1
1
1
1
1
9
9
Q 8/0 Cable Gland Thermoplastic PG 16
Q 8/0 Housing Bulkhead Mounting Thermoplastic
Q 8/0 Hood Thermoplastic
Q 8/0 Male Crimp Insert
Q 8/0 Female Crimp Insert
2.5mm^2 Male E Pins
13.16
13.17
13.16
13.15
13.15
01.15
01.15
6
6
6
6
6
09 00 000 5350
09 30 024 0408
09 00 000 5353
09 00 000 5358
09 00 000 5362
1
1
1
1
1
Blind Grommet
Han Split Hood 24 B
Cable Entry Gland
Cable Entry Gland
Cable Entry Gland
40.05
40.05
40.05
40.05
40.05
7
7
7
7
7
7
09 12 004 2611
09 12 004 2711
09 20 003 0320
09 20 003 0420
09 15 000 6102
09 15 000 6202
1
1
1
1
5
5
Han-Brid Male
Han-Brid Female
3A Plastic Housing Bulkhead Mounting
3A Plastic Hood Top Entry
1.0mm^2 Male D Pins
1.0mm^2 Female D Pins
8
8
09 30 006 0442
09 33 006 2616
1
1
6 B Top Entry Hood
6 ES Male Cage-Clamp Insert
30.16
03.14
9
09 33 006 4725
1
6 E Female Terminal Block Insert
08.15
10
21 01 130 4061
1
M8 3p Male Straight
50.20
Data Sheet
Data Sheet
30.10
30.10
02.12
02.12
3
73550000046
Updated 9/2003
Location
Part Number
Qty
Description
Catalog Page
11
21 01 140 4091
1
M12 4p HARAX Straight
50.20
12
12
21 03 212 1305
21 03 212 2305
1
1
HARAX M12L 4 pole male
HARAX M12L 4 pole female
50.20
50.20
13
09 33 000 9989
1
Han Snap - Din Rail Mount
11.15
14
09 62 000 5008
1
PG 21 EMC Cable Clamp (IP 68)
40.09
15
09 00 000 5093
1
PG 21 Universal Cable Protection (IP 68)
40.08
16
16
16
16
16
16
09 12 003 3001
09 12 003 2794
09 20 003 0301
09 20 003 1443
09 15 000 6102
09 15 000 6202
1
1
1
1
2
2
Han 3A Cable Side (Male) RJ-45 without PCB
Panel Feed Through w/2x RJ-45 Jack
Han 3A Housing Bulkhead Mounting
Han 3A Top Entry Hood Metal
1.0mm^2 Male D Pins
17
73 55 040 0915
1
Han Port RJ-45 120VAC 3A
Flyer
18
18
09 38 006 2601
09 38 006 2701
1
1
4/2 K Male Insert Screw Terminal
4/2 K Female Insert Screw Terminal
05.15
05.15
19
09 20 003 0440
1
Han 3A with HARAX (Male Version)
01.12
09 20 004 2711
09 40 003 0301
09 40 003 0402
1
1
1
1
4A Male Insert
4A Female Insert
3A HPR Housing Bulkhead Mounting with Sealing Screw
3A HPR Hood with Sealing Screw
01.12
01.12
30.30
30.30
21
21
21
21
21
21
21
21
09 15 003 3001
09 15 003 3101
09 15 004 3013
09 15 004 3113
09 15 000 6102
09 15 000 6202
09 20 003 1443
09 20 003 0301
1
1
1
1
6
6
1
1
Han Quintax 3A Male Insert
Han Quintax 3A Female Insert
Quintax Z Contact Male
Quintax Z Contact Female
Male Crimp Contacts
Female Crimp Contacts
Han 3A Bulkhead Mounted Housing Metal
22
22
22
09 14 000 6274
09 14 002 2751
09 14 025 3001
2
1
1
6mm Female Pneumatic Contact
100 A Module Female Axial Screw Termination
Male D-Sub Module
Data Sheet
Data Sheet
30.11
30.11
02.12
02.12
Data Sheet
Data Sheet
06.33
06.33
02.12
02.12
30.11
30.11
06.31
06.11
06.25
4
73550000046
Updated 9/2003
Location
22
22
22
22
22
22
22
22
22
22
22
23
Part Number Qty
Description
09 14 025 3101 1 Female D-Sub Module
09 14 002 4501 2 Pneumatic Module
09 14 008 3101 1 Han 8 EE Module Female
09 14 024 0303 1 24 B Hinged Frame (A…F)
09 33 000 6104 8 1.5mm^2 Male E pin
09 14 024 0313 1 24 B Hinged Frame (a…f)
09 14 008 3001 1 Han 8 EE Module Male
09 14 002 2651 1 100 A Module Male Axial Screw Termination
09 14 000 6174 2 6mm Male Pneumatic Contact
09 33 000 6204 8 1.5mm^2 Female E pin
09 14 000 9950 2 Blank Module (Dummy)
73 55 042 0044
1
ID Module (Dummy)
73 55 000 0046
98 42 020 0201
73 55 000 0045
73 55 000 0048
1
1
1
1
73 55 000 0049
98 42 914 0401
1
1
Han "Lite" Cover Sheet
Short Form Han Catalog
Han Port Flyer
ID Module Data Sheet
Han-Brid Industrial Network Interfaces Data Sheet
(Includes Han-Brid RJ-45 and Han Quintax 3A)
HMI 2003 Catalog
Catalog Page
06.25
06.31
06.19
06.09
01.15
06.09
06.19
06.11
06.31
01.15
06.34
Data Sheet
ENCLOSED LITERATURE
20 4
5
73550000046
Updated 9/2003
Han “Lite” Reference Diagram
HARTING, Inc. of North America
1370 Bowes Road
Elgin, IL 60123
Phone: 1-866-278-0306
Fax: (847) 741-8257
6
73550000046
Updated 9/2003
很抱歉,暂时无法提供与“09120032794”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+512.399501+66.01460
- 3+458.458093+59.06510
- 5+404.516695+52.11560
