09150000102
09150000102
    HARTING(浩亭)
09150000102 数据手册
Contents R 15 Page Technical characteristics R 15 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.10 R 15 Inserts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.11 R 15 Hoods/Housings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.12 R 15 10 . 01 R 15 Specifications Approvals Inserts Number of contacts Electrical data acc. to DIN EN 61 984 , Current carrying capacity The current carrying capacity is limited by maximum temperature of materials for inserts and contacts including terminals. The current capacity-curve is valid for continuous, not interrupted current-loaded contacts of connectors when simultaneous power on all contacts is given, without exceeding the maximum tempe­ rature. Control and test procedures according to DIN IEC 60 5 1 2 - 5 . 7 + PE 10 A 250 V 4 kV 3 Working current Working voltage Rated impulse voltage Pollution degree Working voltage acc. to UL/CSA R 15 DIN VDE 0627 DIN VDE 0110 DIN EN 61 984 Insulation resistance Material Limiting temperatures Flammability acc. to UL 94 Mechanical working life - Mating cycles 600 V ≥ 1010 Ω Polyamide - 40 OC / +125 OC HB ≥ 500 Working current Technical characteristics Ambient temperature Contacts Material Surface - hard-silver plated - hard-gold plated Contact resistance Crimp terminal - mm2 - AWG Hoods/Housings Material Hoods/Housings seal Limiting temperatures Degree of protection acc. to DIN 40 050 for coupled connector 10 . 10 Accessories Crimping tools Cable clamps Label acc. to CSA-approval copper alloy 3 µm Ag 2 µm Au over 3 µm Ni ≤ 3 mΩ 0.14 - 2.5 mm² 26 - 14 metal hoods/housings thermoplastic resin NBR - 40 OC / +125 OC IP 65 chapter 99 chapter 40 chapter 40 R 15 250 V 10 A Number of contacts 7 Inserts Identification Series Part No. Male insert (M) Female insert (F) Crimp terminal R 15 Inserts for thermoplastic hoods/housings Order crimp contacts separately Drawing Dimensions in mm Contact arrangement View from termination side 09 15 007 3001 09 15 007 3101 Male insert (M) 09 15 007 3021 09 15 007 3121 Female insert (F) Crimp terminal R 15 Inserts for metal hoods/housings Order crimp contacts separately R 15 Mounting example Male contact Male insert (M) Female insert (F) Housing screw mounting Female contact Hood Cable seal Wire gauge Part No. Identification (mm2) Male contacts Female contacts Crimp contacts 0.14-0.37 0.5 0.75 1.0 1.5 2.5 09 15 000 6104 09 15 000 6103 09 15 000 6105 09 15 000 6102 09 15 000 6101 09 15 000 6106 09 15 000 6204  09 15 000 6203  09 15 000 6205  09 15 000 6202  09 15 000 6201  09 15 000 6206 0.14-0.37 0.5 0.75 1.0 1.5 2.5 09 15 000 6124 09 15 000 6123 09 15 000 6125 09 15 000 6122 09 15 000 6121 09 15 000 6126 09 15 000 6224  09 15 000 6223  09 15 000 6225  09 15 000 6222  09 15 000 6221  09 15 000 6226 20 10 001 3211 20 10 001 3221 silver plated gold plated Drawing Dimensions in mm Wire gauge ø 2 0.14-0.37 mm AWG 26-22 0.90 mm 1.10 mm 0.5 mm2 AWG 20 1.30 mm 0.75 mm2 AWG 18 1.45 mm 1. mm2 AWG 18 1.75 mm 1.5 mm2 AWG 16 2.25 mm 2.5 mm2 AWG 14 Stripping length 8 mm 8 mm 8 mm 8 mm 8 mm 6 mm FOC contacts for 1 mm plastic fibre 10 . 11 Stock items in bold type Hoods/Housings R 15 Identification Part No. thermoplastic metal Drawing Dimensions in mm Hoods 09 15 000 0401 Pg 11 19 15 000 0401 M 16 Hoods 09 15 000 0421 Pg 11 a M 16 Pg 11 Housings bulkhead mounting 09 15 000 0301 – 09 15 000 0101 – Housings screw mounting R 15 09 15 000 0121 – Housings angled 09 15 000 0102 Housings 09 15 000 0122 – – Cover screw mounting 09 15 000 5401 – Mounting example 10 . 12 R15 insert fixing screw (for replacement) Plastic 09 15 000 9905 Metal 09 15 000 9921 Stock items in bold type
09150000102 价格&库存
很抱歉,暂时无法提供与“09150000102”相匹配的价格&库存,您可以联系我们找货
