Contents
Staf ®
Page
Technical characteristics Staf ® . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
09.10
Staf ® 6 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
09.11
Staf ® 14 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
09.14
Staf ® 20 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
09.16
Staf ® 40 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
09.18
Staf
09
01
Staf ®
Approvals
Inserts
, SEV
Number of contacts
6, 14, 20, 40 (2 x 20)
Electrical data
acc. to DIN EN 61 984
Working current
Working voltage
10 A
~ 25 V / – 60 V
Working voltage
acc. to UL/CSA
50 V
Insulation resistance
Material
Limiting temperatures
Flammability acc. to UL 94
Mechanical working life
- Mating cycles
Contacts
Staf
DIN VDE 0627
DIN VDE 0110
DIN EN 61 984
Material
Surface
- hard-silver plated
Contact resistance
Screw terminal
- mm2
- AWG
- Tightening/test torque
Solder terminal
- mm2
- AWG
≥ 500
copper alloy
3 µm Ag
≤ 2 mΩ
1.5 mm²
16
0.5 Nm
2.5 mm²
14
Hoods/Housings thermoplastic, Size 3 A
Hoods/Housings metal
09
10
Polycarbonate RAL 7032
Polyamide RAL 7032
V0
NBR
- 40 OC / +125 OC
IP 44
Die cast aluminium alloy
Die cast zinc alloy
Han-Easy Lock®
Steel, zinc plated
V0
NBR
- 40 OC / +125 OC
Material
Material size 3 A
Locking element
Locking element size 3 A
Hoods/Housings seal
Degree of protection acc. to DIN
EN 60 529 for coupled connector
IP 44
Further selection
of hoods/housings
chapter 30 / chapter 31
Accessories
Cable clamps
Coding of hoods/housings
Label acc. to CSA-approval
Test connectors
The current carrying capacity is limited by maximum temperature of materials for inserts and contacts including terminals. The
current capacity-curve is valid for continuous, not interrupted
current-loaded contacts of connectors when simultaneous power
on all contacts is given, without exceeding the maximum tempe
rature.
Control and test procedures according to DIN IEC 60 5 1 2 - 5 .
≥ 1010 Ω
Polyamide
- 40 OC / +100 OC
HB
In accordance with the appropriate regulation a wire-end sleeve
has to be used at clamps without wire protection (s. p. 00.12).
Material
Locking element
Hoods/Housings seal
Current carrying capacity
chapter 40
chapter 40
chapter 40
chapter 20
Working current
Specifications
Wire gauge: 1 mm2
Ambient temperature
➀ Staf ® 6
➁ Staf ® 14
➂ Staf ® 20
Staf ® 6
Size 3 A
~ 25 / – 60 V
10 A
Number of contacts
6
Inserts
Identification
Series
Screw terminal
Staf ®
Part No.
Female insert (M)
Male insert (F)
Drawing
Dimensions in mm
Contact arrangement
View from termination side
09 70 006 2813
09 70 006 2616
Staf
Solder terminal
Contact arrangement
Staf ®
09 70 006 2812
09 70 006 2615
Mounting example
09
11
Stock items in bold type
Hoods/Housings
metal
Size 3 A
Identification
Part No.
M
19 20 003 1640
Drawing
Dimensions in mm
Hood
Hoods
side-entry
Hood
top-entry
Protection covers
09 20 003 54221)
09 20 003 54212)
for
hoods
Housings
Panel cut out
22 x 22 mm
bulkhead mounting
09 20 003 0301
Staf
with fixed
cover
without sealing
09 20 003 03051)
with sealing
09 20 003 03062)
09 20 003 0801
Housing
Panel cut out
22 x 22 mm
Housings
surface mounting
side-entry
1
19 20 003 1250
bottom
closed
19 20 003 1252
Housing
screw mounting
Hood
cable to cable
Protection covers
09
12
for
housings
09 20 003 54261)
09 20 003 54252)
for
hoods cable to cable
09 20 003 54281)
09 20 003 54272)
1) for mounted male insert
2) for mounted female insert
Hoods/Housings
thermoplastic
Identification
Part No.
M
side-entry
grey
19 20 003 0620
schwarz
19 20 003 0627
top-entry
grey
19 20 003 0420
schwarz
19 20 003 0427
Hoods
Hoods
Size 3 A
Hoods
Drawing
Dimensions in mm
Protection covers
for hoods
09 20 003 54421)
09 20 003 54412)
Housings
Panel cut out 22 x 22 mm
bulkhead mounting
Staf
grey
09 20 003 0320
grey
09 20 003 0820
Housings
Housings
Panel cut out
22 x 22 mm
surface mounting
1 side-entry
grey
19 20 003 0220
cable to cable
grey
19 20 003 0720
schwarz
19 20 003 0727
Hoods
Protection covers
for housings
A
09 20 003 54071)3)1)
09 20 003 54082)3)4)
B
09 20 003 54452)1)1)
09 20 003 54461)1)1)
09 20 003 54472)3)4)
hoods cable to cable C
for
54481)1)1)
09 20 003
3) for metal housings and cable to cable hoods also
4) for mounted Han-Brid® male and female insert
A
B
C
09
13
Staf ® 14
Size 10 A
~ 25 / – 60 V
10 A
Number of contacts
14
Inserts
Identification
Series
Screw terminal
Staf ®
Part No.
Female insert (M)
09 70 014 2811
Male insert (F)
Drawing
Dimensions in mm
09 70 014 2614
1) Distance for contact max. 24 mm
Staf
Contact arrangement View from termination side
Solder terminal
Staf ®
09 70 014 2810
09 70 014 2613
Panel cut out for inserts
for use without hoods/housings
09
14
Standard Hoods/Housings with 1 lever on the housing
Identification
Size 10 A
Part No.
Low construction High construction
M
19 20 010 1540
Drawing
Dimensions in mm
Hoods
side-entry
Hoods
19 20 010 0546
25
Hoods
top-entry
19 20 010 1440
19 20 010 0446
Staf
Protection covers
for hoods
09 20 010 5423
Housings
bulkhead mounting
Housings
09 20 010 0301
with thermoplastic cover
09 20 010 0321
Housings
surface mounting
1 side-entry
19 20 010 0251
1 x 25
2 side-
entries
19 20 010 0290
2 x 20
19 20 010 0295
2 x 20
Protection covers
for housings
09 20 010 5425
09
15
Staf ® 20
Size 16 A
~ 25 / – 60 V
10 A
Number of contacts
Inserts
Identification
Series
Screw terminal
Staf ®
Part No.
Female insert (M)
09 70 020 2817
Male insert (F)
Drawing
Dimensions in mm
09 70 020 2622
Staf
Solder terminal
Staf ®
09 70 020 2816
09 70 020 2621
09
16
Identification
Size 16 A
Part No.
M
19 20 016 1540
Drawing
Dimensions in mm
Hoods
side-entry
Hoods
19 20 016 0546
25
Hoods
top-entry
19 20 016 1440
19 20 016 0446
Staf
Protection covers
for hoods
09 20 016 5423
Housings
bulkhead mounting
09 20 016 0321
1 side-entry
19 20 016 0251
1 x 25
2 side-
entries
19 20 016 0290
2 x 20
Housings
09 20 016 0301
Housings
surface mounting
19 20 016 0295
2 x 20
Protection covers
for housings
09 20 016 5425
09
17
Staf ® 40
Size 32 A
~ 50 / – 60 V
10 A
Number of contacts
40
Inserts
Identification
Series
Screw terminal
Staf ®
1–20
1–20
Part No.
Female insert (M)
Male insert (F)
Drawing
Dimensions in mm
Dimensions for inserts see page 09.16
09 70 020 2817
09 70 020 2817
09 70 020 2622
09 70 020 2622
Staf
Solder terminal
Staf ®
1–20
1–20
09 70 020 2816
09 70 020 2816
09 70 020 2621
09 70 020 2621
09
18
Standard Hoods/Housings for 2 inserts
Identification
Size 32 A
Part No.
M
19 20 032 1521
25
Drawing
Dimensions in mm
Hoods
side-entry
Hoods
19 20 032 0527
32
19 20 032 0427
32
Hoods
top-entry
Staf
Protection cover
09 20 032 5401
Housing
bulkhead mounting
09 20 032 0301
Panel cut out
Housings
Housings
surface mounting
19 20 032 0231
1 x 25
19 20 032 0232
1 x 32
2 side-
entries
19 20 032 0272
2 x 32
09 20 032 5405
1 side-entry
Blind way
for one cable entry
Protection cover
09
19
Notes
Staf
09
很抱歉,暂时无法提供与“09200030427”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+41.87404
- 3+40.97845
- 5+40.09328
- 国内价格 香港价格
- 1+60.078521+7.79710
- 10+51.0683410+6.62774
- 30+47.2588030+6.13333
- 50+45.5833250+5.91589
- 100+43.40713100+5.63346
- 250+40.68987250+5.28081
- 500+39.24329500+5.09307
