09340100301
    HARTING(浩亭)
    CONN BASE BOTTOM ENTRY SZ24B
09340100301 数据手册
Contents Han® Hv ES / Han Hv E® Page Technical characteristics Han® Hv ES . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 04.10 Technical characteristics Han Hv E® . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 04.11 Han® 3 Hv ES . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 04.12 Han® 3 Hv E . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 04.14 Han® 6 Hv ES . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 04.16 Han® 6 Hv E . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 04.18 Han® 10 Hv ES . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 04.20 Han® 10, 16 Hv E . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 04.22 Han® 12 Hv ES / 12 Hv E . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 04.24 Han® 20 Hv ES / 20, 32 Hv E . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 04.26 Difference: Han Hv E® to Standard Hoods/Housings . . . . . . . . . . . . . . . . . . 04.28 Han Hv E 04 . 01 Han® Hv ES Specifications Approvals Inserts Han Hv E Number of contacts Electrical data acc. to DIN EN 61 984 Technical characteristics DIN VDE 0627 DIN VDE 0110 DIN EN 61 984 , , SEV Current carrying capacity The current carrying capacity is limited by maximum temperature of materials for inserts and contacts including terminals. The current capacity-curve is valid for continuous, not interrupted current-loaded contacts of connectors when simultaneous power on all contacts is given, without exceeding the maximum tempe­ rature. Control and test procedures according to DIN IEC 60 5 1 2 - 5 . 3, 6, 10, 12 (2 x 6), 20 (2 x 10) + PE + 2 additional contacts for safe high voltage connections 16 A 830 V 8 kV 3 Working current Working voltage Rated impulse voltage Pollution degree Working voltage acc. to UL/CSA - Relay contacts Insulation resistance Material Limiting temperatures Flammability acc. to UL 94 Mechanical working life - Mating cycles 600 V 250 V ≥ 1010 Ω Polycarbonate - 40 OC / +125 OC V0 ≥ 500 Working current - Pollution degree 2 also 16 A 1000 V 8 kV 2 or    16 A 720/1250 V 8 kV 2 - Relay contact 16 A 500 V 6 kV 3 Wire gauge: 1.5 mm² Ambient temperature Material Surface - hard-silver plated Contact resistance Cage-clamp terminal - mm2 - AWG Hoods/Housings Material Surface Locking element Hoods/Housings seal Limiting temperatures Degree of protection acc. to DIN 40 050 for coupled connector Further selection of hoods/housings copper alloy 3 µm Ag ≤ 3 mΩ 0.14 - 2.5 mm² 26 - 14 die cast aluminium powder-coated RAL 7037 Han-Easy Lock® NBR - 40 OC / +125 OC IP 65 chapter 30 / chapter 31 Working current Contacts Wire gauge: 2.5 mm² Ambient temperature Accessories 04 . 10 Cable clamps Coding of hoods/housings Label acc. to CSA-approval Han-Snap® chapter 40 chapter 40 chapter 40 chapter 11 ➀ Han® 3 Hv ES ➁ Han® 6 Hv ES ➂ Han® 10 Hv ES Han Hv E® Approvals DIN VDE 0627 DIN VDE 0110 DIN EN 61 984 , Inserts Number of contacts 3, 6, 10, 12 (2 x 6), 16, 20 (2 x 10), 32 (2 x 16) + PE + 2 additional contacts for safe high voltage connections Electrical data acc. to DIN EN 61 984 Han Hv E® 3, 6, 10, 12 (2 x 6), 16 A 830 V 8 kV 3 20 (2 x 10) + PE Working current Working voltage Rated impulse voltage Pollution degree - Pollution degree 2 also 16 A 1000 V 8 kV 2 or 16 A 720/1250 V 8 kV 2 - Relay contacts 16 A 500 V 6 kV 3 Han Hv E® 16, 32 (2 x 16) + PE Working current Working voltage conductor – ground Working voltage conductor – conductor Rated impulse voltage Pollution degree or Working voltage acc. to UL/CSA - Relay contacts Insulation resistance Material Limiting temperatures Flammability acc. to UL 94 Mechanical working life - Mating cycles Contacts Material Surface - hard-silver plated Contact resistance Crimp terminal - mm2 - AWG Screw terminal - mm2 - AWG - Tightening/test torque Hoods/Housings Material Surface Locking element Hoods/Housings seal Limiting temperatures Degree of protection acc. to DIN EN 60 529 for coupled connector Crimping tools Cable clamps Coding of Hoods/Housings Label acc. to CSA-approval Han-Snap® The current carrying capacity is limited by maximum temperature of materials for inserts and contacts including terminals. The current capacity-curve is valid for continuous, not interrupted current-loaded contacts of connectors when simultaneous power on all contacts is given, without exceeding the maximum tempe­ rature. Control and test procedures according to DIN IEC 60 5 1 2 - 5 . Han Hv E 16 A 400/690 V 6 kV 3 16 A 500 V 6 kV 3 Wire gauge: 1.5 mm² Ambient temperature 600 V 250 V ≥ 1010 Ω Polycarbonate - 40 OC / +125 OC V 0 ≥ 500 copper alloy 3 µm Ag ≤ 1 mΩ 0.5 - 4 mm² 20 - 12 2.5 mm² 14 0.5 Nm IP 65 chapter 99 chapter 40 chapter 40 chapter 40 chapter 11 Wire gauge: 2.5 mm² Ambient temperature die cast aluminium powder-coated RAL 7037 Han-Easy Lock® NBR - 40 OC / +125 OC Further selection of hoods/housings chapter 30 / chapter 31 Accessories Current carrying capacity Working current Working current Specifications Technical characteristics ➀ Han® 3 Hv E ➁ Han® 6 Hv E ➂ Han® 10 Hv E Han® 16 Hv E For a fully equipped crimp connector the following contacts are required: Type Female contacts Operating contacts Relay contacts 5 3 2 Han® 3 Hv E 8 6 2 Han® 6 Hv E 12 10 2 Han® 10 Hv E 16 12 4 Han® 12 Hv E 18 18 – Han® 16 Hv E ® 24 20 4 Han 20 Hv E 36 36 – Han® 32 Hv E 04 . 11 Han® Hv ES Size 10 B 830 V 16 A Number of contacts 3 + 2 additional contacts for safe high voltage connections Inserts Han Hv E Identification Series Cage-clamp terminal Han® Hv ES Part No. Male insert (M) Female insert (F) 09 34 003 2616 Drawing Dimensions in mm 09 34 003 2716 1) Distance for contacts max. 21 mm Contact arrangement View from termination side Han® 3 Hv ES M F Operating contact Relay contact Without contact Panel cut out for inserts for use without hoods/housings 04 . 12 Stock items in bold type Standard Hoods/Housings with 2 levers on the housing Identification Size 10 B Part No. Low construction High construction M 19 30 010 1520 20 19 30 010 1521 25 Drawing Dimensions in mm Hoods side-entry 19 30 010 0527 32 Han Hv E Hoods Hoods top-entry 19 30 010 1420 20 19 30 010 1421 25 Protection covers for hoods thermoplastic/metal 09 30 010 5401 09 30 010 5423 19 30 010 0427 32 Housing bulkhead mounting Panel cut out 60 x 35 mm 09 30 010 0301 – 19 30 010 1230 19 30 010 1231 19 30 010 0231 20 25 2 side-entries 19 30 010 1270 19 30 010 0271 19 30 010 0272 20 25 32 Housings Housings surface mounting 1 side-entry Blind way for one cable entry Low construction High construction a b h 40 52 54 45 57 81 Protection covers for housings bulkhead/surface mounting thermoplastic/metal 09 30 010 5407 09 30 010 5425 Hoods cable to cable 19 30 010 1730 19 30 010 0736 19 30 010 0737 20 25 32 h Low construction 47.5 High construction 74.5 Protection cover for hoods cable to cable metal 04 . 13 09 30 010 5427 Stock items in bold type Han Hv E® Size 10 B 830 V 16 A Number of contacts 3 + 2 additional contacts for safe high voltage connections Inserts Han Hv E Identification Series Screw terminal Han Hv E® Part No. Male insert (M) Female insert (F) 09 34 003 2601 Drawing Dimensions in mm 09 34 003 2701 1) Distance for contact max. 21 mm Contact arrangement View from termination side Han® 3 Hv E Crimp terminal Han Hv E® Order contacts separately 09 34 003 2602 09 34 003 2702 M F Operating contact Relay contact Without contact Panel cut out for inserts for use without hoods/housings Han Hv E® Crimp could also be used with a 10 B standard housing. Wire gauge Identification Han 3 Hv E 3x 5x 04 . 14 2x (mm2) Part No. Male contacts Female contacts Crimp contacts Dimensions in mm Operating contact Identification Operating contact silver plated 0.5 0.75 1.0 1.5 2.5 3 4 09 33 000 6121 09 33 000 6114 09 33 000 6105 09 33 000 6104 09 33 000 6102 09 33 000 6106 09 33 000 6107 Relay contact silver plated 0.75-1 1.5 2.5 09 33 000 6109 09 33 000 6110 09 33 000 6111 Number of pieces per insert Drawing 09 33 000 6220 09 33 000 6214 09 33 000 6205 09 33 000 6204 09 33 000 6202 09 33 000 6206 09 33 000 6207 Relay contact Crimp contact identification Identification Wire gauge Stripping length no groove 0.5 mm2 1 groove* 0.75 mm2 1 groove 1. mm2 2 grooves 1.5 mm2 3 grooves 2.5 mm2 wide groove 3.0 mm2 no groove 4. mm2 * on the back crimp collar 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm AWG 20 AWG 18 AWG 18 AWG 16 AWG 14 AWG 12 AWG 12 Stock items in bold type Han Hv E® Hoods/Housings with 2 levers on the housing Size 10 B Identification Part No. M 19 34 003 0520 20 19 34 003 0420 19 34 003 0421 20 25 Drawing Dimensions in mm Hood side-entry Hood Hoods top-entry Han Hv E Protection covers thermoplastic/metal 09 30 010 5401 09 30 010 5423 Housing Panel cut out 60 x 35 mm bulkhead mounting 09 34 003 0301 – 19 34 003 0270 20 Housing surface mounting 2 side-entries Housings Protection covers thermoplastic/metal 09 30 010 5407 09 30 010 5425 Hood cable to cable 19 34 003 0730 19 34 003 0731 20 25 Protection cover metal 09 30 010 5427 04 . 15 Stock items in bold type Han® Hv ES Size 16 B 830 V 16 A Number of contacts 6 + 2 additional contacts for safe high voltage connections Inserts Han Hv E Identification Series Cage-clamp terminal Han® Hv ES Part No. Male insert (M) Female insert (F) 09 34 006 2616 Drawing Dimensions in mm 09 34 006 2716 1) Distance for contact max. 21 mm Contact arrangement View from termination side Han® 6 Hv ES M F Operating contact Relay contact Without contact Panel cut out for inserts for use without hoods/housings 04 . 16 Stock items in bold type Standard Hoods/Housings with 2 levers on the housing Identification Size 16 B Part No. Low construction High construction M 19 30 016 1521 19 30 016 1522 25 32 Drawing Dimensions in mm Hoods side-entry 19 30 016 0527 19 30 016 0528 32 40 Hoods Hoods top-entry 19 30 016 1421 19 30 016 1422 19 30 016 0427 19 30 016 0428 Han Hv E 25 32 32 40 Protection covers for housings thermoplastic/metal 09 30 016 5401 09 30 016 5422 Housing bulkhead mounting Panel cut out 82 x 35 mm 09 30 016 0301 Housings – surface mounting 1 side-entry 19 30 016 1231 19 30 016 0232 25 32 2 side-entries 19 30 016 1271 19 30 016 0271 19 30 016 0272 25 32 19 30 016 0736 19 30 016 0737 25 32 Blind way for one cable entry Low construction High construction h 56 81 Housings Protection covers for housings bulkhead mounting thermoplastic/metal 09 30 016 5405 09 30 016 5425 Hoods cable to cable 19 30 016 1731 h Low construction 47.5 High construction 78.5 Protection cover for hoods cable to cable metal 09 30 016 5426 04 . 17 Stock items in bold type Han Hv E® Size 16 B 830 V 16 A Number of contacts 6 + 2 additional contacts for safe high voltage connections Inserts Han Hv E Identification Series Screw terminal Han Hv E® Part No. Male insert (M) Female insert (F) 09 34 006 2601 Drawing Dimension in mm 09 34 006 2701 1) Distance for contact max. 21 mm Contact arrangement View from termination side Han® 6 Hv E Crimp terminal M Screw terminal F M Crimp terminal F Han Hv E® Order contacts separately 09 34 006 2602 09 34 006 2702 h 32.4 34.6 34.2 37,0 Operating contact Relay contact Without contact M F Panel cut out for inserts for use without hoods/housings Han Hv E® Crimp could also be used with a 16 B standard housing. Wire gauge Identification Han 6 Hv E 6x 8x 04 . 18 2x (mm2) Part No. Male contacts Female contacts Crimp contacts Dimensions in mm Operating contact Identification Operating contact silver plated 0.5 0.75 1.0 1.5 2.5 3 4 09 33 000 6121 09 33 000 6114 09 33 000 6105 09 33 000 6104 09 33 000 6102 09 33 000 6106 09 33 000 6107 Relay contact silver plated 0.75-1 1.5 2.5 09 33 000 6109 09 33 000 6110 09 33 000 6111 Number of pieces per insert Drawing 09 33 000 6220 09 33 000 6214 09 33 000 6205 09 33 000 6204 09 33 000 6202 09 33 000 6206 09 33 000 6207 Relay contact Crimp contact identification Identification Wire gauge Stripping length no groove 0.5 mm2 1 groove* 0.75 mm2 1 groove 1. mm2 2 grooves 1.5 mm2 3 grooves 2.5 mm2 wide groove 3.0 mm2 no groove 4. mm2 * on the back crimp collar 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm AWG 20 AWG 18 AWG 18 AWG 16 AWG 14 AWG 12 AWG 12 Stock items in bold type Han Hv E® Hoods/Housings with 2 levers on the housing Size 16 B Identification Part No. M 19 34 006 0521 25 Drawing Dimensions in mm Hood side-entry Hood Hoods top-entry 19 34 006 0421 Han Hv E 25 Protection covers thermoplastic/metal 09 30 016 5401 09 30 016 5422 Housing Panel cut out 82 x 35 mm bulkhead mounting 09 34 006 0301 – 19 34 006 0271 25 Housing surface mounting 2 side-entries Housings Protection covers thermoplastic/metal 09 30 016 5405 09 30 016 5425 Hood cable to cable 19 34 006 0731 19 34 006 0732 25 32 Protection cover metal 09 30 016 5426 04 . 19 Stock items in bold type Han® Hv ES Size 24 B 830 V 16 A Number of contacts 10 + 2 additional contacts for safe high voltage connections Inserts Han Hv E Identification Series Cage-clamp terminal Han® Hv ES Part No. Male insert (M) Female insert (F) 09 34 010 2616 Drawing Dimensions in mm 09 34 010 2716 1) Distance for contact max. 21 mm Contact arrangement View from termination side Han® 10 Hv ES M F Operating contact Relay contact Without contact Panel cut out for inserts for use without hoods/housings 04 . 20 Stock items in bold type Standard Hoods/Housings with 2 levers on the housing Identification Size 24 B Part No. Low construction High construction M 19 30 024 1521 19 30 024 1522 25 32 Drawing Dimensions in mm Hoods side-entry 19 30 024 0527 19 30 024 0528 32 40 Hoods Hoods top-entry 19 30 024 1422 Protection covers for hoods thermoplastic/metal 09 30 024 5401 09 30 024 5422 19 30 024 0427 32 19 30 024 0428 40 Housing bulkhead mounting Panel cut out 108 x 35 mm 09 30 024 0301 Housings Housings Han Hv E – surface 1 side-entry 19 30 024 1231 mounting 19 30 024 0232 25 32 2 side-entries 19 30 024 1271 19 30 024 0272 25 32 Blind way for one cable entry Low construction High construction h 56 81 Protection covers for housings bulkhead/surface mounting thermoplastic/metal 09 30 024 5405 09 30 024 5425 Hoods cable to cable 19 30 024 1732 19 30 024 0737 19 30 024 0738 32 40 h Low construction 57.5 High construction 78.5 Protection cover for hoods metal 04 . 21 09 30 024 5426 Stock items in bold type Han Hv E® Size 24 B 690 / 830 V 16 A Number of contacts 10, 16 + 2 additional contacts for safe high voltage connections Inserts Han Hv E Identification Series Screw terminal Han Hv E® Part No. Male insert (M) Female insert (F) 09 34 010 2601 Drawing Dimensions in mm 09 34 010 2701 1) Distance for contact max. 21 mm Crimp terminal Han Hv E® Contact arrangement View from termination side Han® 10 Hv E Order contacts separately 09 34 010 2602 Han® 16 Hv E 09 34 010 2702 Han Hv E® Crimp could also be used with a 24 B standard housing. Screw terminal Han Hv E® 09 34 016 2601 09 34 016 2701 M F M F Operating contact Relay contact Without contact Panel cut out for inserts for use without hoods/housings Wire gauge Identification Han 10 Han 16 Hv E Hv E 10 x 18 x 12 x 18 x 04 . 22 2x – (mm2) Part No. Male contacts Female contacts Crimp contacts Dimensions in mm Operating contact Identification Operating contact silver plated 0.5 0.75 1.0 1.5 2.5 3 4 09 33 000 6121 09 33 000 6114 09 33 000 6105 09 33 000 6104 09 33 000 6102 09 33 000 6106 09 33 000 6107 Relay contact silver plated 0.75-1 1.5 2.5 09 33 000 6109 09 33 000 6110 09 33 000 6111 Number of pieces per insert Drawing 09 33 000 6220 09 33 000 6214 09 33 000 6205 09 33 000 6204 09 33 000 6202 09 33 000 6206 09 33 000 6207 Relay contact Crimp contact identification Identification Wire gauge Stripping length no groove 0.5 mm2 1 groove* 0.75 mm2 1 groove 1. mm2 2 grooves 1.5 mm2 3 grooves 2.5 mm2 wide groove 3.0 mm2 no groove 4. mm2 * on the back crimp collar 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm AWG 20 AWG 18 AWG 18 AWG 16 AWG 14 AWG 12 AWG 12 Stock items in bold type Han Hv E® Hoods/Housings with 2 levers on the housing Size 24 B Identification Part No. M 19 34 010 0521 25 Drawing Dimensions in mm Hood side-entry Hood Hoods top-entry 19 34 010 0422 Han Hv E 32 Protection covers thermoplastic/metal 09 30 024 5401 09 30 024 5422 Housing Panel cut out 108 x 35 bulkhead mounting 09 34 010 0301 – 19 34 010 0271 25 Housing surface mounting 2 side-entries Housings Protection covers thermoplastic/metal 09 30 024 5405 09 30 024 5425 Hood cable to cable 19 34 010 0732 32 Protection cover metal 09 30 024 5426 04 . 23 Stock items in bold type Han® Hv ES / Han Hv E® Size 32 B 830 V 16 A Number of contacts 12 + 4 additional contacts for safe high voltage connections Inserts Han Hv E Part No. Identification Series Cage-clamp terminal Han® Hv ES 1– 6 09 34 006 2616 09 34 006 2716 1– 6 09 34 006 2616 09 34 006 2716 Crimp terminal Order contacts separately Male insert (M) Female insert (F) Contact arrangement View from termination side Han Hv E® 09 34 006 2602 09 34 006 2702 1– 6 09 34 006 2602 09 34 006 2702 Han Hv E® 1– 6 1– 6 Wire gauge 04 . 24 4x Relay contact silver plated Number of pieces per assembly M F M F Operating contact Relay contact Without contact Han Hv E® Crimp could also be used with a 32 B standard housing. Han 12 Crimp contacts Hv E/ Hv ES Operating contact silver plated 12 x 16 x Han® 12 Hv ES Han® 12 Hv E 1– 6 Identification Dimensions in mm Dimensions for inserts page 04.16/04.18 Screw terminal Drawing (mm2) 09 34 006 2601 09 34 006 2601 09 34 006 2701 09 34 006 2701 Panel cut out for insert for use without hoods/housings Part No. Male contacts Female contacts Drawing Dimensions in mm Operating contact Identification 0.5 0.75 1.0 1.5 2.5 3 4 09 33 000 6121 09 33 000 6114 09 33 000 6105 09 33 000 6104 09 33 000 6102 09 33 000 6106 09 33 000 6107 0.75-1 1.5 2.5 09 33 000 6109 09 33 000 6110 09 33 000 6111 09 33 000 6220 09 33 000 6214 09 33 000 6205 09 33 000 6204 09 33 000 6202 09 33 000 6206 09 33 000 6207 Relay contact Crimp contact identification Identification Wire gauge Stripping length no groove 0.5 mm2 1 groove* 0.75 mm2 1 groove 1. mm2 2 grooves 1.5 mm2 3 grooves 2.5 mm2 wide groove 3.0 mm2 no groove 4. mm2 * on the back crimp collar 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm AWG 20 AWG 18 AWG 18 AWG 16 AWG 14 AWG 12 AWG 12 Stock items in bold type Standard Hoods/Housings with 2 levers on the housing Identification Part No. M 19 30 032 0527 19 30 032 0528 19 30 032 0529 32 40 50 Size 32 B Drawing Dimensions in mm Hoods side-entry Hoods Hoods top-entry 19 30 032 0427 19 30 032 0428 19 30 032 0429 32 40 50 09 30 032 5420 – 09 30 032 0301 – Han Hv E Protection cover for hoods Housing bulkhead mounting Panel cut out Housings Housings surface mounting 19 30 032 0232 1 x 32 19 30 032 0272 2 x 32 19 30 032 0273 2 x 40 Blind way for one cable entry Hoods cable to cable 19 30 032 0738 2 x 40 09 30 032 5425 – Protection covers for housings 04 . 25 Stock items in bold type Han® Hv ES / Han Hv E® Size 48 B 830 V 16 A Number of contacts 20, 32 + 4 additional contacts for safe high voltage connections Inserts Han Hv E Part No. Identification Series Cage-clamp terminal Han® Hv ES 1– 10 09 34 010 2616 09 34 010 2716 1– 10 09 34 010 2616 09 34 010 2716 Crimp terminal Han Hv E® Order contacts separately Male insert (M) Female insert (F) Drawing Dimensions in mm Dimensions for inserts page 04.20 / 04.22 Contact arrangement View from termination side Han® 20 Hv ES M F M F M F Han® 20 Hv E 1– 10 09 34 010 2602 09 34 010 2702 1– 10 09 34 010 2602 09 34 010 2702 Han® 32 Hv E Han Hv E® Crimp could also be used with a 48 B standard housing. Screw terminal Han Hv E® 1– 10 1– 10 09 34 010 2601 09 34 010 2601 09 34 010 2701 09 34 010 2701 1– 16 1– 16 09 34 016 2601 09 34 016 2601 09 34 016 2701 09 34 016 2701 Wire gauge Identification (mm2) 04 . 26 4x Relay contact silver plated – Number of pieces per assembly Panel cut out for inserts for use without hoods/housings see chapter 03 size 48 E. Part No. Male contacts Female contacts Crimp contacts Han 20 Han 32 Hv E Hv E Operating contact silver plated 20 x 36 x 24 x 36 x Operating contact Relay contact Without contact Drawing Dimensions in mm Operating contact Identification 0.5 0.75 1.0 1.5 2.5 3 4 09 33 000 6121 09 33 000 6114 09 33 000 6105 09 33 000 6104 09 33 000 6102 09 33 000 6106 09 33 000 6107 0.75-1 1.5 2.5 09 33 000 6109 09 33 000 6110 09 33 000 6111 09 33 000 6220 09 33 000 6214 09 33 000 6205 09 33 000 6204 09 33 000 6202 09 33 000 6206 09 33 000 6207 Relay contact Crimp contact identification Identification Wire gauge Stripping length no groove 0.5 mm2 1 groove* 0.75 mm2 1 groove 1. mm2 2 grooves 1.5 mm2 3 grooves 2.5 mm2 wide groove 3.0 mm2 no groove 4. mm2 * on the back crimp collar 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm AWG 20 AWG 18 AWG 18 AWG 16 AWG 14 AWG 12 AWG 12 Stock items in bold type Hoods/Housings with 1 lever on the housing for 2 inserts Identification Part No. M 19 30 048 0548 19 30 048 0549 40 50 Drawing Size 48 B Dimensions in mm Hoods side-entry Hoods Han Hv E Hoods top-entry 19 30 048 0448 19 30 048 0449 40 50 Housings bulkhead mounting 09 30 048 0301 – Panel cut out with metal cover 09 30 048 0317 – 19 30 048 0292 19 30 048 0293 2 x 32 2 x 40 with thermoplastic cover Housings with thermoplastic cover Housings surface mounting 2 side-entries 19 30 048 0298 2 x 40 04 . 27 1) Blind grommet Stock items in bold type Difference: Han Hv E® to Standard Hoods/Housings Standard Hood/Housing Han® B Suitable for all Standard inserts (also Han® Hv ES) Han Hv E Coding bar Special Hood/Housing Han Hv E® Han Hv E® inserts may be used together with the corresponding Han Hv E® hoods/housings only Milled Coding bar Insulation tape Coding pin 04 . 28
09340100301 价格&库存
很抱歉,暂时无法提供与“09340100301”相匹配的价格&库存,您可以联系我们找货
  • 1+463.601881+57.71408
  • 10+394.0327810+49.05339
  • 25+369.3681825+45.98287
  • 50+351.7523850+43.78987
  • 100+334.98085100+41.70197
  • 250+315.95283250+39.33316
库存:14
09340100301
  • 1+235.06113
  • 100+223.30391
  • 500+214.36884
库存:14
